Focus RS
Old Mar 16, 2016 | 06:59 PM
  #2866
whtrice's Avatar
Veteran: Air Force
Originally Posted by WestSideBilly
How on earth does it take 60 days to go from Germany to Halifax?
Old Mar 17, 2016 | 05:01 PM
  #2867
Robevo RS's Avatar
https://www.facebook.com/events/243575899309724/
Old Mar 18, 2016 | 08:43 AM
  #2868
nemsin's Avatar
I wonder if Mountune will offer an upgraded FMIC for the Focus RS. Maybe they will just remove the van plate to unleash the power
Old Mar 18, 2016 | 09:02 AM
  #2869
ambystom01's Avatar
Still salty, eh bro? For somebody with no interest in the car, you sure are insecure about it.
Old Mar 18, 2016 | 09:08 AM
  #2870
nemsin's Avatar
No, I am seriously curious if Mountune will offer a FMIC, and if it will suffer from being "too efficient."
Old Mar 18, 2016 | 09:12 AM
  #2871
ambystom01's Avatar
Sure you are. It's totally believable that you have a genuine interest in this car after spending 180 pages *****ing about every aspect of it, and throwing out ridiculous "arguments" about how it's a ****ty car.
Old Mar 18, 2016 | 11:05 AM
  #2872
WarmMilk's Avatar
ok you're starting this BS arguing for no reason again. stop it with the personal attacks
for the record I'm also curious about the same thing and its a legitimate question. if ford claims the intercooler is too efficient, there shouldn't be a reason to upgrade... I'm curious how this will play out in the real world
Old Mar 18, 2016 | 12:12 PM
  #2873
kaj's Avatar
kaj
"too efficient" to what point? for the stock turbo and boost levels, maybe? I'd imagine an upgrade would be needed for any mods we'd make LOL.
Old Mar 18, 2016 | 12:30 PM
  #2874
moparfan's Avatar
I'm sure that the aftermarket will be able to add more horsepower but the question everyone is waiting for is how much?. From what they've said before, the problem for HP increases might in the AWD system's lack of a permanent center diff. The clutches in the rear diff are constantly slipping to did its job to apportion the power front and back.
Old Mar 18, 2016 | 12:36 PM
  #2875
nemsin's Avatar
The GKN engineer that worked on the Focus RS said that any added power will only go to the front wheels. At stock power up to 70% of the power can go to the rear. So if you say, double the hp, then only 35% would be going to the rear. i.e., they have built in a safety measure to preserve the rear.
So the real question, is how well will the awd system still performs when added hp is only going to the front.
Old Mar 18, 2016 | 02:44 PM
  #2876
kaj's Avatar
kaj
I honestly have no idea, I was only replying to the comment about the FMIC.
Old Mar 18, 2016 | 06:11 PM
  #2877
Robevo RS's Avatar
As I heard we don't have to worry about the engine and the transmission.
The rear end sounds more of the problem for tuners and racers. But I am sure Mountune and Cosworth will take care of that. Maybe just a simple cooler will fix the problem of the over heating.
RS was always a race car and tuner car. I don't think that will change. Even though Ford stated the car rear end designed for that stock power level. Which might be an easy fix with a swap of the rear diff to a mechanical one.
The suspension upgrade is a different subject, since as soon as you swap it out for example to Ohlins, how the ECU set ups will work? It will recognize these are not the magnetic suspensions, and just will throw the fault code or do nothing. etc?
The Evo X was almost a same like the RS now, predicted problems etc, and turned out much less problems as was predicted, and very easy to mod. SO I am not worry about the RS.
I think it will be a good tuner and race car. How much and how easy it will be to build the car etc? We don't know yet, so I wouldn't comment on it.
Old Mar 18, 2016 | 06:58 PM
  #2878
ambystom01's Avatar
That's kinda what I figured; a cooler in the rear would fix any problems most tuners would see.
Old Mar 18, 2016 | 07:36 PM
  #2879
Robevo RS's Avatar
http://www.ford.com/cars/focus/specifications/
if you get these EPA numbers for the RS , the you picked the wrong car for yourself
Old Mar 18, 2016 | 08:50 PM
  #2880
Robevo RS's Avatar
I still think the out going version body looks better , mainly because the louvers and the wide body. The new one desperately needs those. Really not a big deal to put louvers on the hood/car and fender extensions, can you hear me Ford?
