Focus RS
Old May 12, 2016 | 01:28 PM
  #3481
moparfan's Avatar
deleted
Old May 15, 2016 | 07:11 PM
  #3482
Robevo RS's Avatar
https://www.facebook.com/pumaspeedperformance
https://www.facebook.com/pumaspeedperformance/videos/1020762481311111/
Old May 17, 2016 | 07:27 AM
  #3483
nemsin's Avatar
Ford has filed a patent for an artificial engine-noise system that makes it sound like there are more cylinders at work – not for “go fast” purposes, however, but to save fuel. According to the manufacturer, the new technology would improve fuel efficiency by encouraging the driver to shift gears lower in the rev range.
http://www.caradvice.com.au/442662/f...e-fuel/?plista
Old May 17, 2016 | 07:39 AM
  #3484
stvn87903's Avatar
Same article, one paragraph later..
"On the flip side, Ford’s performance models such as the Mustang pony car and Focus RS hot hatch fitted with the larger 2.3-litre Ecoboost engine already feature a version of artificial sound producing tech, but this is used more to enhance the driving experience rather than encourage drivers to save fuel."
Old May 17, 2016 | 07:43 AM
  #3485
mrfred's Avatar
Doesn't seem bad to me. Kinda interesting actually. Since you're posting here, I guess its implemented in the RS?
Old May 17, 2016 | 07:53 AM
  #3486
nemsin's Avatar
Same technology rebranded as either "fuel saving" or to "increase driver experience." Imo fake engine sounds are silly.
Old May 17, 2016 | 03:55 PM
  #3487
whtrice's Avatar
Veteran: Air Force
RS currently has something similar but this might be implemented as a future "feature".
So are fake engine fart sounds....but they work.
Old May 17, 2016 | 07:23 PM
  #3488
moparfan's Avatar
Old May 17, 2016 | 08:01 PM
  #3489
Robevo RS's Avatar
I am not sure if that is right, I see they do measure the engine hp, so is this stock , or they "gained" 28 hp with what ( based on the 350 engine hp number)? or what is the base number? Any info on these?
Old May 17, 2016 | 08:11 PM
  #3490
kaj's Avatar
kaj
that engine needs to rev at LEAST 1k higher :P
Old May 18, 2016 | 05:39 AM
  #3491
whtrice's Avatar
Veteran: Air Force
Looks like they are playing around with the tune a couple times. Probably the lowest
curve is stock. Torque definitely comes on early and holds well ( 1st and lowest curve). Playing around they got close to 400 ft/lb peak.
Rudimentary stuff but looks promising. Motor sounds gutsy and responsive.
Old May 18, 2016 | 05:57 AM
  #3492
IzzyRS's Avatar
Looks like stock redline is at 6500RPM, I would like a bit more (although I'm not one to rev to the moon lol).
That engine and exhaust note is different. Not convinced if I love it yet, but it sounds unique.
Old May 18, 2016 | 07:58 AM
  #3493
RazorLab's Avatar
Base and after is right there on the chart they show and I'm assuming base is stock. Either way there are gains. Looks like approx 50hp gained at 5300rpm and approx 70tq (converted from newton meters) gained at 2800rpm and 4000rpm.
Superflow dyno measures wheel hp (it's right there in the video) and 'calculates' engine hp from there. I put that in quotes because without an engine on an engine dyno, it's not really 'engine power' shown.
Old May 18, 2016 | 08:37 AM
  #3494
nemsin's Avatar
My Ford goes bwaaahhhh
Old May 18, 2016 | 12:57 PM
  #3495
Robevo RS's Avatar
thank you for the info.
