Philadelphia's Classiest Drunkards
Old Aug 2, 2011 | 09:22 AM
  #25816
AlwaysinBoost's Avatar
Originally Posted by dek0026
Computer scientists get an hourly rate?
More than you can afford pal!
Old Aug 2, 2011 | 09:26 AM
  #25817
B.J.@ToxicFab's Avatar
Hey guys, trying to get a meet together Saturday, August 27th at Buffalo Wild Wings in Somerville, NJ...Here is the thread is anyone is interested...
https://www.evolutionm.net/forums/no...ewater-nj.html
Old Aug 2, 2011 | 09:29 AM
  #25818
steinvb12's Avatar
Originally Posted by evremonde
i was referring to my hourly rate.
Huh? I thought he was an instructor at the Rock Gym.
This thread is confusing
Old Aug 2, 2011 | 09:39 AM
  #25819
igo4bmx's Avatar
he's a consultant at NAMBLA
Old Aug 2, 2011 | 09:44 AM
  #25820
psushoe's Avatar
What's up with the Holbert reg? It's only showing day one registrants and very few ppl. Guess no one is going, and those that are only run Sat???
Old Aug 2, 2011 | 09:46 AM
  #25821
honda-guy's Avatar
im interested. Only problem is that i might be taking a road trip this weekend.
when does he need to know by?
he can only do limited number of cars, so sign up early if you want to make sure you get a spot. or just show up sunday and he if he has time to do yours. Chu said he might be interested and i might get the front done. Robi will be there to support if i want to adjust anything after the sessions.
Old Aug 2, 2011 | 10:03 AM
  #25822
evremonde's Avatar
it is a very confusing thread.
Once again, I'm worried that you knew this existed.
I'm not sure whats would have been worse, using my work computer to search that or my spyphone.
Old Aug 2, 2011 | 10:14 AM
  #25823
06RS's Avatar
I'm not only the president, but I'm also a client
Old Aug 2, 2011 | 10:17 AM
  #25824
RT has my car on the lift. should have a diagnosis shortly...
Old Aug 2, 2011 | 10:25 AM
  #25825
^ this.
Old Aug 2, 2011 | 10:27 AM
  #25826
if anyone cares, here is some video of Dan's last session at the Glen. he started out running high 2:40's and got it down to the low 2:20's (i think he said 2:24). not bad losing 20 seconds in a weekend.
http://www.youtube.com/watch?v=WUuZTl2kRrc
Videos just do not do this track justice at all. It is unreal. If everything is OK with my car I'm going to try like hell to get back up there before the season is over... even if it has to be in the E30.
Old Aug 2, 2011 | 10:28 AM
  #25827
igo4bmx's Avatar
http://www.youtube.com/watch?v=6dTMIXoeNpg
Old Aug 2, 2011 | 11:07 AM
  #25828
grillpt's Avatar
Better stop talking like that, something bad is gonna happen again.
Old Aug 2, 2011 | 12:14 PM
  #25829
small update
Initial info from RT/Tuning:
balance shaft belt indeed broke. Timing belt looks to be in good shape though and did not move. Broken BS belt might have taken out the crankshaft position sensor, which caused the car to shut down (hopefully that is the case). They are going to do a compression test and a leak-down test to confirm all is OK with the motor. I should have those results in a couple hours. If everything checks out they'll install a BS eliminator kit, new crank pos. sensor and the car should be back in action by tomorrow.
Old Aug 2, 2011 | 12:17 PM
  #25830
turbotekray's Avatar
What belt did you have on there? and how old?
