Rebuilding my VIII
Old Feb 23, 2014 | 03:33 PM
  #496
aggieEVO's Avatar
Had a busy day. Correctly wired the UEGO. Then I got to work.
I gave the AEM no-weld bung a shot. They make it for several different sizes of piping. The OEM pipe is super bendy and crushed. Luckly the clamp fit almost perfectly where I wanted it. This install REALLY makes me want a new downpipe...
This was where I initially had it clocked. Didn't work. Ran right into the driveshaft. Oops. Ended up putting it almost straight up. The downside is that I drilled a second hold. Hope I don't have a leak. It's sputtering a tad but I'll crank it down a hair now that it's heat cycled.
Without the factory heatshields I wrapped the pipe. I've had a roll of exhaust wrap on my shelf for 3 years. I just ordered some metal tie wraps. Not happy with how well they clamp.
Installed:
If you try this, definitely use a stepped bit. Ate right through the pipe. Install almost straight up, but just a hair to the driver's side to clear a heatshield.
Nice to know I'm "ok", now. My A/F at WOT is almost a 10 flat. Guess I have some room to play, now. Excited to make some progress tuning!
Old Feb 24, 2014 | 08:15 AM
  #497
charlie.tunah's Avatar
Looking good! I did the same thing with my 1st attempt at a WB bung. Marked it, brought it to a muffler shop to get welded, installed it and it hit the driveshaft.
I now have 2 bungs right next to each other.
Old Feb 24, 2014 | 09:18 AM
  #498
aggieEVO's Avatar
If you can't tell, I'm used to things like this by now! I have a very small leak. Going to try to tighten the clamp a little and see if that fixes it.
But seriously, stock down pipe is horrible.
It's looking like logging the wideband through the ECU isn't super reliable, I guess I'll build a serial cable. I'll try to make it to Radio Shack today.
So Charlie, you have an 8.5 turbo. With my setup (Walbro, 8.5 turbo, drop-in), what should I target for boost? I was thinkigng 22 trailing to 20 by redline. 93 octane.
Old Feb 24, 2014 | 09:48 AM
  #499
Sounds like a good starting point, but Id eventually go a little higher. Im peaking at 24 and dropping to 22 by redline on 91 oct.
Old Feb 24, 2014 | 09:53 AM
  #500
aggieEVO's Avatar
Even with a stock exhaust? I assumed I'd turn it up a hair when I at least installed a catback.
Old Feb 24, 2014 | 10:19 AM
  #501
Maybe a little lower with stock exhaust. Not really sure to be honest, Ive never tuned on a stock exhaust. Just keep an eye out for knock and you should be good to go.
Old Feb 24, 2014 | 10:47 AM
  #502
Terror Rising's Avatar
I ran my 9.8 cm turbo at 24 psi through my factory catback when my downpipe cutout wasn't open. It didn't seem to care and shouldn't be much different than full factory exhaust.
Old Feb 25, 2014 | 04:55 AM
  #503
aggieEVO's Avatar
Good to know. I guess I'll start out at 22 and work my way up a little to see if it actually makes power.
Thanks guys!
Old Feb 26, 2014 | 11:43 AM
  #504
aggieEVO's Avatar
Very happy to have a well running motor... ugly bay or not!
Attachment 331913
Old Feb 26, 2014 | 12:56 PM
  #505
badev0's Avatar
You have been on quite the adventure with this car my friend. Good work!!
Old Feb 26, 2014 | 01:18 PM
  #506
aggieEVO's Avatar
And I'm sure it's not over! I'd like to get a reliable 300whp and some fun suspension bits and lightweight wheels over the next year or so.
A radio would be nice, too.
Old Feb 26, 2014 | 03:12 PM
  #507
I agree man. Im sure its a good feeling to reap the benefits of all the hard work and lessons learned. I love these kind of builds because it helps those of us that know we can do it just get the proper tools and do it.
Old Feb 27, 2014 | 01:23 PM
  #508
aggieEVO's Avatar
Wired my UEGO into #75 on the ECU. Readings are within .2 of my gauge. I'll check it out tonight and make some changes to my timing and watch VD and my logs closely. Pretty excited to make some power!
Old Feb 28, 2014 | 06:36 AM
  #509
ILuvJDM's Avatar
Lol you and me both. I had it marked correctly, and took the downpipe to them but the muffler shop took it upon themselves to weld it on where they saw fit based on how the pipe sat on the welding table...
Old Feb 28, 2014 | 07:04 AM
  #510
Mine reads off a little bit too. Id have to check what formula Im using, but I do remember tweaking the last number (9, in your case) to make the log match the wideband.
