razorlab's simple build(s)
Old Aug 29, 2016 | 12:34 PM
  #436
RazorLab's Avatar
Originally Posted by yawseph
Is the stock turbo going back on?
No, most likely a GTX3076R.
Old Aug 30, 2016 | 07:50 AM
  #437
mrfred's Avatar
Any consideration given to an EFR?
Old Aug 30, 2016 | 07:52 AM
  #438
RazorLab's Avatar
Yes I considered it but moved away from it for two reasons:
1. Tubular manifold
2. Not stealth enough for me in CA
My current problem is trying to figure out how to find/make a full 3" intake from compressor to filter not look obviously aftermarket...
Old Aug 30, 2016 | 08:09 AM
  #439
LetsGetThisDone's Avatar
Register the car in NV...lol
Old Aug 30, 2016 | 08:30 AM
  #440
RazorLab's Avatar
Heh, that would help one of the items. Tubular manifold still being a problem...
Old Aug 30, 2016 | 08:41 AM
  #441
I still wouldn't run a tube mani on a X without proper mounts for the turbo. But it'll make the intake super easy. As well as a test pipe and many other things.
Old Aug 30, 2016 | 09:13 AM
  #442
RazorLab's Avatar
yes, and they all crack.
test pipe I've run for 20+ years in CA. All in the strategy
Old Aug 30, 2016 | 09:45 AM
  #443
kyoo's Avatar
just caught up with the build - brutal to hear. the car fuel starved even with a surge tank in it? if the pump has to fill the surge tank too how do you prep for that? bigger pump?
Old Aug 30, 2016 | 09:47 AM
  #444
Yeah, he had the stock fuel pump in the tank. In my friends X, we did a hardwired walbro 255 in the stock tank. Just to make sure she keeps up
Even with proper mounting? Just too much heat being against the firewall? And what if it's built out of schedule 10 stainless?
Old Aug 30, 2016 | 09:52 AM
  #445
kyoo's Avatar
ahhh. X won't fuel starve with an upgraded pump then, regardless of fuel level (to an extent)?
Old Aug 30, 2016 | 09:55 AM
  #446
No, it needs a surge tank. Basically, the stock pump wasn't flowing enough to keep the surge tank full. Then when the stock pump was starved during a corner, it wasn't filling the surge tank and the surge tank pump would start to starve.
  #447
mikemike396's Avatar
Do you have to get inspected every so often in CA? I use to have e-check in OH but they would just check for exhaust content, and any CEL, never a physical check of parts and such.
Old Aug 30, 2016 | 11:52 AM
  #448
RazorLab's Avatar
Unfortunately that is only one of the theories of what went wrong. Since I wasn't logging the correct things we really don't know. The only thing I do know is the car leaned out and I have a non working Evo that has been sitting in my garage for the last four months.
I'm getting a solution together to be able to log 'all the things' for this next round...
Old Aug 30, 2016 | 11:53 AM
  #449
RazorLab's Avatar
After six years for new cars. So I don't have to smog my Evo 10 until 2020, and now they only do OBD2 testing and visual, no tail pipe sniffer.
Unless I get my hand caught in the cookie jar.
Old Aug 30, 2016 | 12:35 PM
  #450
momostallion's Avatar
an intake would cause you to fail smog's visual check even if all codes were clear?
cobb offered a 3" silicone inlet pipe. it mates up to stock position airbox/other. that would be the most discrete 3" inlet i can think of.
