I Can Haz Track Car???
Old Jan 16, 2018 | 04:39 PM
  #166
Ayoustin's Avatar
This past weekend I decided that while my dash was out it'd be a good time to flock it. I let it finish curing today. The process is pretty straightforward and it definitely didn't turn out perfect but for $40 I'm pretty happy with it and knowing that I won't have reflection issues while driving, plus it's fuzzy!
Old Jan 17, 2018 | 11:37 AM
  #167
V.8MR's Avatar
I like that! Care to share where you purchased the supplies?
Old Jan 17, 2018 | 12:58 PM
  #168
evoguy4242's Avatar
Awesome!
Old Jan 17, 2018 | 05:50 PM
  #169
Ayoustin's Avatar
Thanks! I ordered black: http://www.flockit.com/index.php/pro...ck-fibers.html
Some tips for anyone who decides to do this:
- Do it in a warmish room if you can (60-75F), I did it in my garage that was about 20F and the adhesive took a while to settle even though it is self leveling. If I were to do it again in a room this cold I would've thinned the adhesive first.
- Buy a wider paint brush, they send a tiny 1/2" brush with it. I bought a 1 1/2" brush at walmart that was a perfect size for the can
- Paint fast and have the fiber applicator/duster thing already filled before you start, you'll need as much time as possible to get the whole dash covered
- Lay down a tarp or garbage bags to reclaim what doesn't get on the dash. You will need to reclaim fibers to finish the whole dash unless you buy a second bag (1 is enough though). I didn't do this and had to scrape it off my floor which wasted time
- Do the front edge (the one that faces you) first. The applicator doesn't push the fibers out as well when used upside down and when there's only a small amount left it barely pushes any out.
- Pop your vents out with a screw driver and put a stripe of tape along the lower section so you don't get adhesive lower down
- Use all of the fibers. You can't put too much on, whatever doesn't get held by the adhesive can easily be blown off. I gave it a day and a half to fully cure and then vacuumed the whole dash clean.
Old Jan 18, 2018 | 06:48 AM
  #170
Xska555's Avatar
Ive always wanted to do this, thanks for the tips!
Old Jan 18, 2018 | 08:21 AM
  #171
Ayoustin's Avatar
Found a bit of free time and decided to make a model of the cage. Hopefully getting more wiring out of the way tonight and tomorrow.
Old Jan 18, 2018 | 08:36 AM
  #172
LetsGetThisDone's Avatar
That roof tube is a dead tube. It needs to go to the corners.
Old Jan 18, 2018 | 10:21 AM
  #173
Ayoustin's Avatar
It's modeled off a couple pictures and my memory, didn't bother to get dimensions since I'm just using this for representation purposes. I couldn't remember how the roof bar is run but I think one of the ends is in a corner.
Old Jan 18, 2018 | 10:50 AM
  #174
V.8MR's Avatar
Originally Posted by ayoustin
Ordered! Thanx for the tips too. This is a sweet mod that is inexpensive. Would be cool even on a street car
Old Jan 18, 2018 | 12:59 PM
  #175
kyoo's Avatar
what spec are those wheels? were they powder coated? just sent off my wheels to get pc'd too, pretty excited
Old Jan 18, 2018 | 01:20 PM
  #176
Ayoustin's Avatar
18x10.5 +30. Yup, powdercoated. What color did you get?
Old Jan 18, 2018 | 01:56 PM
  #177
kyoo's Avatar
charcoal mist, it's like a light grey metallic. pretty standard stuff, i'm not a colorful guy lol
Old Jan 19, 2018 | 07:33 AM
  #178
Dan_evo_8's Avatar
Great build
Old Jan 19, 2018 | 11:29 AM
  #179
V.8MR's Avatar
You know, as I think about flocking my dash also, I realize I dont have the cutouts I'll need for a cage (eventually). Wondering if I could see your dash and make some similar cutouts. Can you take some pictures of how/where its been cut?
Old Jan 19, 2018 | 11:37 AM
  #180
kyoo's Avatar
re: the powdercoating - did you get the back of the wheels pc'd? as in the surface that mates to the wheel hub?
