Let's see your fully tuned timing maps
Old Oct 30, 2010 | 07:30 AM
  #676
Jack_of_Trades's Avatar
I was referring to the Tephra NLTS mod.
Old Oct 30, 2010 | 08:00 AM
  #677
Raptord's Avatar
So a very fast v7-NLTS shift is less abuse on the drivetrain than a moderately fast granny-shift? Am I understanding you correctly?
Old Oct 30, 2010 | 09:47 AM
  #678
Yessum.
Old Oct 31, 2010 | 04:42 AM
  #679
leecavturbo's Avatar
i really have to look at the graph from all angles to get a real feel for the map
[youtube]Amr_mJwLIOc[/youtube]
Old Oct 31, 2010 | 07:21 AM
  #680
Raptord's Avatar
Wow, that's a nice lookin' map!
Old Oct 31, 2010 | 09:26 AM
  #681
Very smooth map, I can definitely tell its on 91 from the low timing at peak torque
It looks like you could increase the cruise timing out to 3500 RPM a bit more though before you start to slope down towards peak load. You'll really gain some peppyness in the cruise area. You can use the stock maps as a reference since the the USDM maps were made for 91 octane from the factory.
Old Oct 31, 2010 | 09:54 AM
  #682
yes prob got carried away smoothing near the cruise
Old Oct 31, 2010 | 08:29 PM
  #683
F0RSAKEN's Avatar
For better or worse, here's mine lol (self tuned, still working on it and learning).
As a side note, I use an unmodified JDM RS Mivec map.
Old Nov 1, 2010 | 05:17 AM
  #684
Raptord's Avatar
Your timing seems to twitch between going up and going down. For example, in the 3500 rpm column, starting at 200 load: 6 5 4 5 5 4 4. There are other places where this happens. Timing should gradually decrease as load increases, and gradually increase as rpm increases.
Old Nov 1, 2010 | 10:27 AM
  #685
Andy_8's Avatar
This is where i'm currently at, might not finish it before i go for a bigger turbo.
It on UK Shell 99 so like US Shell 93. 29psi over peak torque and down to 24psi at peak hp.
Old Nov 1, 2010 | 11:01 AM
  #686
kelfords and the green doing well there andy. looks like your boost tapers up top
sd or maf? 9653 v7?
Old Nov 1, 2010 | 11:21 AM
  #687
Andy_8's Avatar
sd or maf? 9653 v7?
MAF and 9653 v7 yeah.
It really nice and peppy low down and on transient throttle. The actuator is only around 12psi so not really helping with taper up top, though it goes well enough on UK Roads.
Couple of things to try like ported TB, Ported IM, uprated actuator and getting rid of the standard (modded) air intake box.
Only Driven it once in 6 months due to working overseas
Old Nov 1, 2010 | 06:00 PM
  #688
F0RSAKEN's Avatar
Oops
Old Nov 1, 2010 | 06:11 PM
  #689
Raptord's Avatar
Much better
Old Nov 1, 2010 | 06:14 PM
  #690
evo8426's Avatar
FORSAKEN, what mods?
