COBB AccessTUNER Pro for 2008 EVO X (merge)
Old Jan 9, 2009 | 03:09 PM
  #226
John83's Avatar
wow.... and you are talking about flashing to new map, correct? so then do you disconnect fans every time you flash?
Old Jan 9, 2009 | 03:13 PM
  #227
Japistani's Avatar
I haven't disconnected the fan, and it's worked for me every time... I do make sure that I'm not playing the stereo and lights, heated seats, AC, etc... is all off though...
Old Jan 9, 2009 | 03:37 PM
  #228
funks's Avatar
I plugin my battery charger . The first time it saved the rom though - it took 20+ minutes..
Old Jan 9, 2009 | 03:40 PM
  #229
LVSBB6's Avatar
Hi Rob, any word on the stage 2 map from Cobb?
Thanks!
Originally Posted by Rob@cobbtuning
We're finishing up the boost fix and adding other useful monitors for both AccessTuner Pro and Race along with the AP logging. Lots of other cool stuff is coming out at well. AP install will take ~3mins with saving the stock ROM Change map in 20-40 sec.
We're working to have that all tested and out by the end of next week. At worst case, the following week.
Rob
Old Jan 11, 2009 | 09:25 PM
  #230
goevox's Avatar
can 1 ap unit flash multiple evos? i want to go half with my friend.
Old Jan 11, 2009 | 10:26 PM
  #231
Japistani's Avatar
No... it's married to the first car it's installed on... until you uninstall it!
Old Jan 12, 2009 | 05:43 AM
  #232
melnor's Avatar
So will COBB make posts to this thread and/or forum when they add/update their maps or will they have some news on their own website? I've often wondered where do I go to see the latest news on any AP developments.
Old Jan 12, 2009 | 05:46 AM
  #233
Stellar24's Avatar
Rob,
I sent you a PM with my questions but figured I should just post on here in case someone else has the same question. What is the sample rate of the build in data logger? Is it depndant on the number of channels you log at once? If so, how many channels can you record max? Also, how much (time wise) data can you record at once? Is that dependant on the number of channels as well? I guess I am just trying to get a better description of the data logging capabilites of the AccessPort.
Old Jan 12, 2009 | 10:43 AM
  #234
dek0026's Avatar
Until I can test with the HKS filter I have to lean on the safe side and say no, we do not currently suggest you run the HKS drop-in filter with the AP.
As soon as I have tested the filter, I will post the data collected.
Thanks,
Rob
i just picked an AP up. so you suggest i put the stock filter back in prior to using the AP? i have the K&N drop in currently.
Old Jan 12, 2009 | 11:05 AM
  #235
Rob@cobbtuning's Avatar
For now yes. We will be developing tunes specific to the major players in the intake market including a drop-in or two.
Thanks,
Rob
Old Jan 12, 2009 | 11:07 AM
  #236
Originally Posted by Stellar24
Rob,
Hello,
I just finished up the PM before I found your post. You are more than welcome to post up what I sent, although the number maybe changing slightly as we add new parameters for logging.
Thanks,
Old Jan 12, 2009 | 11:08 AM
  #237
dek0026's Avatar
Thanks,
Rob
thanks for the quick answer.
Old Jan 12, 2009 | 11:31 AM
  #238
Stellar24's Avatar
Hello,
Thanks,
Incase anyone is interested, here is Rob's respons:
Sample rate for the logger is 5-20Hz depending on how my parameters are requested. You should be able to request all the parameters we allow at once, although there should be no need. The power of the logging is more than adequate for tuning or data analysis.
We can loosely record up to 10 hours of data, but we limit the number of files stored on the device to 10.
This coming week we will be adding several new custom monitors aiding in tuning. We will be releasing AccessTuner Race at the same time which also has the capability to log.
Old Jan 12, 2009 | 12:07 PM
  #239
Keep an eye out here( http://cobbtuning.com/info/?id=3059 ) for updates and new maps. We'll do our best to post up when new features/maps are out.
Thanks,
Old Jan 12, 2009 | 09:10 PM
  #240
evojanoy's Avatar
Hey Rob do you know when the stage 2 will be released for the X. BTW your product is great I am very happy with it's performance.
