razorlab's simple build(s)
Old Oct 10, 2017 | 08:46 AM
  #841
RazorLab's Avatar
Originally Posted by mrfred
Is it hooked up to the intake pipe to pull the vacuum?
This is the current setup:
Old Oct 10, 2017 | 10:13 AM
  #842
whtrice's Avatar
Veteran: Air Force
Oil pressure readings look fine to me. The loose fitting not leaking is good but like you said should be fixed. The biggest bummer is the oil burning at idle from the turbo. Bad seal (not familiar with this turbo....others having this issue)? Possibly from when you pressurized the system and vented oil everywhere? Maybe reseal and should be good?
Old Oct 15, 2017 | 02:06 AM
  #843
Strider327's Avatar
5 Year Member
Looking good Bryan.
Old Oct 15, 2017 | 04:42 PM
  #844
RazorLab's Avatar
YES!!!!!!
Fixed my oil burning issue. Went down to a .035 oil restrictor like FP does on their ball bearing turbos and I no longer spy hunter once the car is fully warm at stop lights. YAY.
My fuel trim issue didn’t go away. I ended up turning off fuel trims to see what the car is really doing....
At idle it’s lean, 15.8-16.8. At cruise it’s a perfect 14.5-14.8.
So, leaning towards exhaust leak since cruise is perfect. What do you all think?
Old Oct 15, 2017 | 06:07 PM
  #845
whtrice's Avatar
Veteran: Air Force
Originally Posted by razorlab
YES!!!!!!
That's great news! Does it still puff a little when you first fire it up?
It is a bit cooler now. Does the idle circuit need to tweaked a bit? If you had a Holley I could help ya...
Old Oct 15, 2017 | 07:23 PM
  #846
RazorLab's Avatar
It never burned oil when cold, only when fully warm and after driving it.
On another note, took some updated photos of the engine bay. I tried my best to hide the catch can, breather hoses, sensors, etc... I have to say, it came out pretty stealthy...
Old Oct 16, 2017 | 06:51 AM
  #847
mrfred's Avatar
YES!!!!!!
I don't have experience with what magnitude of exhaust leak is required to cause that much of a false reading. Does it idle steady with trims disabled, or does the engine start acting poorly as the AFR goes towards 16.8:1?
Old Oct 16, 2017 | 07:29 AM
  #848
RazorLab's Avatar
The more I drove it yesterday the more I realized it was actually running lean at idle. The idle is strong but it feels lean. I also noticed it is leaner (around 16.8-17.1) directly after starting the car (when warm) and gets less lean down to about 15.8 the more you drive it.
I'll have to go through the engine bay. Symptoms seem like a gasket maybe.
Old Oct 16, 2017 | 07:31 AM
  #849
LetsGetThisDone's Avatar
The precision CHRA is internally restricted, I would consult precision on further restricting the supply.
Were the fuel trims good before? The Vband stuff is pretty easy to get sealed right. Possible injectors clogged, or just need to adjust the tune since the engine has broken in and VE has improved with ring seal, which usually most greatly effects idle..
Old Oct 16, 2017 | 07:35 AM
  #850
RazorLab's Avatar
I did a bunch of searching and it seems like most BB Precision owners with cars with higher oil pressure than others (Evo, etc) have had to use restrictors.
Trims have been nuts since I picked the car up, on both ID1000 and ID1300.
I tried to do a boost leak test the other weekend but the engine wasn't at TDC so everything just went out the exhaust. I was pressed for time so I didn't get around to setting the engine to TDC to test again. I'll have to set aside some time to do it right.
Nothing really points to a boost leak though as cruise and WOT seems right and WGDC levels are normal for the boost amount.
Old Oct 16, 2017 | 07:51 AM
  #851
whtrice's Avatar
Veteran: Air Force
How much manifold Vac are you measuring at idle? Is there any choppiness with these cams or is the idle pretty smooth.
Old Oct 16, 2017 | 08:21 AM
  #852
RazorLab's Avatar
You can't even tell the car has cams.
After warm start:
https://datazap.me/u/razorlab/rcpidl...-5-13-15-24-25
After driving:
https://datazap.me/u/razorlab/rcpidl...3-4-5-13-27-29
Cruise:
https://datazap.me/u/razorlab/rcpidl...13-20-23-33-34
Basically -8.4 or so idle and -9 to -10 cruise
Old Oct 16, 2017 | 09:41 AM
  #853
Are the trims more calm now? I really think it's just the engine breaking in. I've had them where it goes as far as needing to adjust the BISS screw (in 4g63 cars). So, a fueling change wouldn't surprise me.
Old Oct 16, 2017 | 09:49 AM
  #854
RazorLab's Avatar
No, see above. Only way I can get the car to not drive like crap off idle is turning trims off. If i richen the car up it just gets super rich on throttle tip in.
i’ve tried about ten different variations of injector scaling, latency, maf scaling, cal fueling, etc
Old Oct 16, 2017 | 10:53 AM
  #855
mrfred's Avatar
Are you running E85 or pump gas?
