Let's see your fully tuned timing maps
Old Nov 2, 2010 | 01:43 AM
  #691
F0RSAKEN's Avatar
Originally Posted by evo8426
FORSAKEN, what mods?
Car is just a bolt on affair thus far:
Stock turbo @ 25.5-26lbs
Stock cams
Ported exhaust mani, MAP o2 dump/dp combo
Test pipe w/ Greddy cbe
ETS 3.5" FMIC kit with all piping
PTE880s and Walbro 255
Omni 4 bar and SD tune
Iridium 1 step colder plugs
Bunch of other **** that doesn't add power.
EDIT: Regarding the ignition map, my car's peak load at any given time is 280-285, so any timing beyond that point really has no bearing on my current setup.
Old Nov 2, 2010 | 01:54 AM
  #692
leecavturbo's Avatar
MR cams aren't that bad. you should try gsr cams dam.
Old Nov 2, 2010 | 03:37 AM
  #693
Egolution's Avatar
what do you think about this..
evo 8 gsr stock but with evo 4 turbo. 12 PSI of boost at 90 oct jajajajaj
i was drinking a pair of coorslights and a bottle of wine. and 1 friend of mine come to my home to play with his car whit thats moods, it his daily drive car and is not interesting in a lot of moods.
this is what a tune....daa just AFR adjust and maybe 1 or 2 degress of timing and maybe my magic. lol
comments please....
Old Nov 2, 2010 | 04:31 AM
  #694
tscompusa2's Avatar
comments please....
you need to trim that log, its actually only about 265whp. why the hell are you running 12psi? are you running over 20* of timing? You can run more then 12psi on 90 octane.
Old Nov 2, 2010 | 09:55 AM
  #695
Egolution's Avatar
jajajajajaja its cus that guy r using the boost of the actuator 12 psi no ecu nobody ar controlling boost
Old Nov 2, 2010 | 10:44 AM
  #696
jojobanks's Avatar
sorry but your english is a little rough... you mean the wastegate limits the boost to 12psi?
Old Nov 2, 2010 | 04:46 PM
  #697
Egolution's Avatar
hes not installed the boost solenoid, vacum line direct to wastegate actuator in result 12 psi of boost (12psi actuator)
Old Nov 3, 2010 | 05:49 AM
  #698
mt057's Avatar
I would grab a cheap mbc
Old Nov 4, 2010 | 03:08 PM
  #699
Egolution's Avatar
jajaja
Old Nov 4, 2010 | 06:07 PM
  #700
project_skyline's Avatar
What do you guys think about 14*-17* peak load on e85 stock turbo 26psi? Stock 2.0L, stock cams, bolts-ons and stuff. 5200-5500ft above sea level.
Old Nov 4, 2010 | 06:10 PM
  #701
GST Motorsports's Avatar
Not only are you way past MBT and actually losing torque, I think your going to chuck a rod.
- Bryan
Old Nov 4, 2010 | 06:53 PM
  #702
mrfred's Avatar
+1 on Bryan's comment. Its insane. 26 psi gauge at 6000 ft is roughly equivalent to 23 psi gauge at sea level. I imagine that load is around 240, and if that's the case, I wouldn't be any higher than 5 deg timing. Didn't you do timing sweeps to look for diminishing returns?
Old Nov 5, 2010 | 06:32 AM
  #703
no knock but pain
Old Nov 5, 2010 | 07:29 AM
  #704
l2r99gst's Avatar
I sure hope you meant peak RPM and not peak load. Otherwise, I'll be reading your rebuild thread.
Old Nov 5, 2010 | 10:10 AM
  #705
evo8426's Avatar
huh? all stock cams are the same in the usa
