Kinugawa 25g turbo thread
Old Jun 16, 2013 | 10:01 AM
  #466
dimacoupe's Avatar
boost leaks tested, all ok
exhaust mani stock, invidia o2, dc sport downpipe, no exhaust leaks
Old Jun 16, 2013 | 10:03 AM
  #467
WikdEvo's Avatar
Your sure there are no leaks pre turbo? What about around the vbsnd clamp around the turbo? Like the guy who posted above
Old Jun 16, 2013 | 10:06 AM
  #468
dimacoupe's Avatar
when in shop man replace spring in actuator, I asked to see it,he did not notice anything
maybe it's gate?
Old Jun 16, 2013 | 09:39 PM
  #469
WikdEvo's Avatar
how's your preload look on teh wastegate? i'm able to hit 27# and i'm not even fully adjusted on teh preload. I'm going to crank it all the way down tomorrow and try to hit 30#
Old Jun 16, 2013 | 10:43 PM
  #470
dimacoupe's Avatar
twisted maximum that allowed thread
Today I will take downpipe and see with gate
Old Jun 16, 2013 | 11:25 PM
  #471
kiss_my_SS's Avatar
Fastgti69 is having similar issues
Old Jun 17, 2013 | 05:14 AM
  #472
WikdEvo's Avatar
You may have to cut some threads off if the rod to allow more preload. Or you can try adding some prongs to the arm.
Old Jun 17, 2013 | 08:27 AM
  #473
NousDefions's Avatar
I'm very interested in picking this turbo up. I'm nervous considering some of the WG issues that I've seen. But it seems that most are having success with it. And with a kid in college I'm all about the budget build
Old Jun 17, 2013 | 08:57 AM
  #474
WikdEvo's Avatar
There really isn't an issue. It just requires a lot of pre load.
Old Jun 17, 2013 | 09:16 AM
  #475
dimacoupe's Avatar
today took turbo. the gate is closed tight, all is well with turbine.
Only one comment, damaged diaphragm. but, it does not affect for maximum boost(for example, if throw a tube with actuator, stock turbo boost 2+ bar on 3k rpm, my kinugawa not boosted) .
and so, two questions remain open:
1. Why so late? (0.8 bar at 4000 RPM)
2. Why so little? (1.8 bar at 5500 RPM)
any issue? hope for your help. Thank you!
Old Jun 17, 2013 | 05:35 PM
  #476
FastGti69's Avatar
Yep, I know this is for the Evo's but I'm having the same problem. My preload is tightened to the maxiumum allowed thread. So I don't know if it's that anymore. I'm thinking I have a boost leak that's probably my problem. This weekend it will be fixed 100%. No more excuses. I found the guy to work on my car.
Old Jun 17, 2013 | 08:56 PM
  #477
WikdEvo's Avatar
What exactly is your issue fast? Dima. Something is def up with your car. Without any vac lines and weak pre load I am hitting 28# around 4300-4500
Old Jun 17, 2013 | 09:52 PM
  #478
VIIIdriver's Avatar
Sounds like a weak wastegate actuator to me, are you sure you have the stiffest springs in there? when i had the regular 25 psi wg actuator i actually took the nut away and threaded it all the way in, worked great after that.
Old Jun 17, 2013 | 10:09 PM
  #479
dimacoupe's Avatar
this is what I expect full boost 2+ bar on 4500 RPM. but, as we can see, the situation is very different from me, i have MAX 1.8 on 5500 RPM, it's so late...
100% sure, because kinugawa sent me set of spring and it's higher. i put 2.0 bar
Old Jun 17, 2013 | 11:14 PM
  #480
dimacoupe's Avatar
btw, i have some difference with my actuator from this pic:
1. no seal from actuator where arm out
2. preload part shorter(maybe and thread shorter)
3. no nut on nose adapter on actuator
