View Poll Results: Warranty claim problems/ No claim problems.
Submitted claim, wasn't honored or had problems
129
58.90%
Submitted claim, no problems getting it fixed.
93
42.47%
Multiple Choice Poll. Voters: 219. You may not vote on this poll
Warranty Issues <Mega Merge>
Old Sep 23, 2005 | 07:03 PM
  #1291
KZEVO's Avatar
sorry to hear that.
My evo go thru a lot of oil too. I just make sure I keep topping it and check it a couple times a month or more depending on how many miles i put on, how hard i drive, etc. Your situation sucks cuz it honestly can happen to anyone. 7 months is a pretty long time for a car to go without an oil change even if not driven that much.
It happened to me once too though when the car was pretty new that i happen to check the oil and there was hardly anything in there. It took over 2 Quarts of oil. I think it just depends on luck if the motor burns thru oil or not. I broke in the car according to Mitsu specs but i still go thru quite a bit of oil.
I would suggest shopping around for a used motor off a junk EVO. Perhaps get the motor built if you plan on tracking the car.
good luck
Old Sep 24, 2005 | 04:53 AM
  #1292
shimla's Avatar
anymore infos?
Old Sep 24, 2005 | 05:46 AM
  #1293
350ztt's Avatar
so even if you reflash the ecu back to stock, mitsubishi would still be able to tell you had a reflash before and void your warranty?? On the 05's
Old Sep 24, 2005 | 06:02 AM
  #1294
8thWonder's Avatar
I don't know about that one. The only way they would be able to tell is, like the guy said earlier, was if they had a reason to check your ecu. How likely would that be. I have an '05 and decided the performance gain was worth that risk. I don't have any other mods, besides a fuel pump, so maybe they wouldn't be so quick to check either. I also saw a little bit better gas mileage too.
Old Sep 24, 2005 | 02:05 PM
  #1295
shimla's Avatar
did it!! all of 2 minutes was all it took for Al to work on my car w/ is bone stock.....ouch!! a bug bit me!! oh well....what's next? hhhmmmm???
Old Sep 24, 2005 | 02:07 PM
  #1296
deffro's Avatar
So how did the flash affect the performance vs. stock? I was thinking of doing the same on my stock '05.
Old Sep 24, 2005 | 02:10 PM
  #1297
F&I-EVO's Avatar
The flash is SO worth it, Just get it done. Your engine will run smoother, and it will pull hard all the way to 7400 rpm.
Old Sep 24, 2005 | 02:13 PM
  #1298
shimla's Avatar
feels like it's more well balanced now(the power)....i don't push my car too much but i did after it was done to make sure everything's ok and yes!! feels good!! seem more responsive the second you step on the pedal!!! best bang for the buck IMO!!!
thanks Al!!
Old Sep 24, 2005 | 02:22 PM
  #1299
TeamAccolade's Avatar
LISTEN, your warrent isn't voided unless it causes a problem... so if u get a flash and ur computer fails no warrenty, if u get a flash and ur passenger wheel studs break, ur wheel flies off, mitsu will cover it.
Old Sep 26, 2005 | 12:02 PM
  #1300
8thWonder's Avatar
I got Al's custom tune on the dyno and all I have is a Walbro 255 fuel pump and my base stock was 240 whp; after the flash, 270 whp & 280 torque. For the money, it's hard to beat.
Old Sep 26, 2005 | 05:54 PM
  #1301
evo3matt's Avatar
warranty
i need to have some warranty work done to my car, however i'm sitting here with a couple bolt ons (bov, intake, ic pipes, exhaust) and i'm wondering which, if not all, will boid warranty. Any experiences? I've heard both that none of that would void it and i've heard any of it will void it.
Old Sep 26, 2005 | 05:57 PM
  #1302
DanJ's Avatar
It all depends on your dealership. The bov and intake, is pretty much useless without a tune, and can actually hurt your car. If the problem is related to your mods mitsu will void your warranty in an instant, if the mods are not really involved in the warranty work that will be done, the dealership will still try to blame it on the mods. Different dealerships will have different opinions.
Old Sep 26, 2005 | 05:59 PM
  #1303
evo3matt's Avatar
the warranty work is on the transmission and the dealership has recongnised it prior to the mods, so i'd think they should still do the work even with the mods
Old Sep 26, 2005 | 06:02 PM
  #1304
AWDrift07's Avatar
mitsu will find any reason to void your warranty. imo swap out your parts back to stcok. it might be a pain but is worth it if you want to keep your warranty.
Old Sep 26, 2005 | 06:05 PM
  #1305
evo3matt's Avatar
that's what i figured....
