View Poll Results: Warranty claim problems/ No claim problems.
Submitted claim, wasn't honored or had problems
129
58.90%
Submitted claim, no problems getting it fixed.
93
42.47%
Multiple Choice Poll. Voters: 219. You may not vote on this poll
Warranty Issues <Mega Merge>
Old Mar 22, 2006 | 08:55 AM
  #2266
Jim_Patterson's Avatar
I wouldnt call the oil changes a warranty. They should have no reason to not do the oil changes like theyre suppose to, a mod isnt going to change the way they change the oil.
Old Mar 22, 2006 | 09:00 AM
  #2267
fwspeedcart's Avatar
Oh & keep all your invoices & note the mileage of any changes.. & yes a lot depends on the dealer as f-dub says
Old Mar 22, 2006 | 10:26 AM
  #2268
bigfishs's Avatar
If you purchased an extended warrenty through the dealer you can normally cancell it and claim the remaining cash value. I cancelled mine within a month and got all the cash back. check what it says on the extended warrenty booklet.
Old Mar 22, 2006 | 10:32 AM
  #2269
4WS Tuning's Avatar
sry i wasn't clear....i have the maintnence plan through mitsubishi..i have some mods on my car so i was worried about them saying somethign to see once they open up the car for somethign as simple as an oil change...well i went to the dealer and they didn't say anything to me. i got my tires rotated and oil changed with no problems
cheers
Old Mar 31, 2006 | 12:21 PM
  #2270
nutrulz's Avatar
Throw out bearing warranty
Is this under warranty or not?
Old Mar 31, 2006 | 12:22 PM
  #2271
Tristar's Avatar
My guess is no, because I know for a fact Nissan doesnt cover it for their cars. Plus Mitsu doesnt like to cover much of anything
Old Mar 31, 2006 | 12:23 PM
  #2272
fromWRXtoEVO's Avatar
I would have to say NO. This part is consider wear and tear from the factory.
Carlos
Old Apr 4, 2006 | 08:12 PM
  #2273
acidandroid's Avatar
Transmission warranty issue, Help!~
Hi guys
i had a tilton twin plate clutch put in couple weeks ago
and it drives great, it makes squeaking noise when u slip it during changing gears, or get the car to move at 1st gear, whcih doesn't bother me, i thought it's normal
last week, i just noticed some oil leak underneath the transmission
it's not so bad, couple drips every night, guessing it's the half shaft seal?
and i also noticed some noise that comes from the transmission when the car is slowly moving at 1st gear
ANYWAYS, MY QUESTION IS :
my car's got some mods, cams, injectors, fuel pump, aftermarket clutch, exhaust, intake, no cat.......etc
and for 03 evo, we have 36000miles warranty for transmission
my car's at 35600 miles right now.........
with all the mods i have, is it possible that the transmission is still under warranty?
i set up an appointment with dealer tomorrow, but right now i'm having 2nd thought, not sure if i will bring my car in or not
please advice............thanks!!!!!!!
Old Apr 4, 2006 | 08:20 PM
  #2274
2hot2handle's Avatar
dont waste your time.......w/ your mods, im surprised you even thought about it.
Old Apr 4, 2006 | 08:23 PM
  #2275
992gnt's Avatar
Did the dealer put the clutch in? If not, why would it be under warranty? For the fluid leak that popped up after you had the tranny out of the car? Or the noises after putting in a twin disk? I would think not. The t-case o-ring was probably damaged during the clutch job, causing the leak. Twin disk clutches are noisy, the dealer can't do a thing about that.
Old Apr 4, 2006 | 08:35 PM
  #2276
thanks for quick reply, i think u guys r right, i'm stupid going to the dealer
ok i made up my mind now,
the leak popped up after the clutch install, but the noise, i thought it's been there before
but before the tilton, i had exedy twin plate
the noise doesn't sound like normal clutch noise, sounds something wrong with transmission
i'm not 100% sure tho
by the way, 992qnt
1:55.4 seems very fast at mid ohio
my friend timed me when i was there, i was around 2:05 , with the chicans
Old Apr 5, 2006 | 05:15 AM
  #2277
992gnt's Avatar
If you had a tranny noise before the clutch change, you should have taken it in then, you may have had a chance. You don't have that many power mods, so you would have had a decent argument.
1:55 is pretty slow actually. It was my first time there and my instructor was ****. I'm going back there on the 21st, and I'll be disappointed if I don't get into the 1:40's. Weather permitting of course.
Old Apr 5, 2006 | 05:38 AM
  #2278
joeymia's Avatar
by the way, 992qnt
can you describe the noise?
Old Apr 5, 2006 | 08:31 AM
  #2279
we had the car up on the air, rolling in 1st gear
then u hear this ticking noise coming out of transmission
Old Apr 5, 2006 | 10:19 AM
  #2280
mrcox's Avatar
The tilton makes alot of noise. It sounds like stuff is broke and it is not. The leak could be brake fluid from your throwout bearing leaking from the fittings or just out of the cylnder.
