- 16-in Multifit steel rims?? will they fit on my car?
- 225/45/18??
- Largest wheel I can fit on my 09 lancer gts
- Rear Sway Bar: RRM vs Works
- Brake Calipers
- anyone with a a 1.1 drop and lower
- New Tires and wheels question?
- Front Right tire broken off
- ES Wheels
- 19" on at 2009 GTS
- Which is better?
- Lug Adapters
- What's the best springs in your opinion?
- Tire Issue - Winter tires
- Ok, I dont know what I'm talking about
- Fixing tire rub issues
- How much does the stock GTS rim weight?
- meagan upper front strut bar....
- camber kit for Lancer GTS 2009
- T1R S-Coil Springs installed on 08 Lancer GTS (pics)
- Any Feed Back On These?
- New wheels
- help!!!!
- Need advise
- questions on lowering spring, shock and strut
- OEM Tail Lights
- Just another question, need ur guys opinions =]
- Weired noise from brakes
- Evo 8 Brembo on 09 GTS?
- New Dunlop D1 Direzza Star Specs
- 18x8 +42..
- Potenza RE960AS Pole Position
- 18x8.5 +46 with 225/45/18's, will it work!?
- OEM X rear sway bar on regular lancers
- 09 GTS 16in. wheel fitment
- 18x7.5 or 18x8 fitment???
- Which lowering springs for 09 GTS?
- Strut Top Mount - Part number/replacement?
- Slotted Rotors
- Black Rims blue lip
- 2008 retro projectors installed
- Best All-Seasons! I need opinions!
- What rim is this?
- 18x8.5 +48 fitment
- got these springs?
- 2008 Lancer GTS OEM brake fluid
- Gunmetal or Black?
- LOOK what arrived today :D
- spray or powdercoat my rims?
- Rear Brakes
- Different Look For a Lancer
- Black On Black GTS Wheels?
- Opinion on Wheels
- Rota Grid 18x8.5 for the 2008+ Lancer *Concave*
- RRM springs ROCK!!!!
- 215/45/18 stretch...
- OEM SP Sport 5000
- 18x8+35
- Issue with stock tires, please help
- MMR-GT1 (Black) 18x8.5 5x114.3?
- Suggestions?
- 08 RRM camber bolts
- Wheels for 2009 Mitsubishi Lancer GTS [Octane Blue]
- RRM Grip Spring ?'s
- GSR Mags on Lancer GT 2009
- 09 lancer rims
- My Wicked White Gts 09
- Winter tires and steel rims
- Suspension Technical Article - Issue #1 - JRZ USA
- Need to shave rotors when replacing brake pads?
- Megan Racing Coilovers
- 18x9.5 test fit on my car...is it possible?!
- B&G Suspension is looking for a test car
- Gram lights Time Attack or Silver??
- Best size rims for 2008 GTS
- Graphite Gray GTS with painted rims?
- tein basics!!!!?????
- rrm spring install ?
- Axis Widetrack fitment?
- Endlinks Kaput
- Can I use 225/40/18's?
- What do you think rims would look like?
- Anybody got a pic of these rims on a 08/09 Lancer?
- PCD Question
- I need help on set of rims/tire!!! on GTS 09
- 5-Zigen's installed
- Will this setup work??
- Eibach Springs?
- between the two wheels....
- Gold or White rims?
- Will this work?
- Works Ride springs
- 09 Wicked White Lancer - New wheels
- Do i need new rotors?!!
- Blown struts??
- Pulling to the left.
- This Brand of wheels any good?
- RIMS: which would look better on 08 lancer
- High Quality rims
- Rotors... FYI they get really stuck!
- Killing tires
- Best 235/45/18 Tire for 2009 Lancer GTS?
- How do the brakes compare to past models?
- Just dropped off at my house today
- Would these work
- Camber Bolts
- what do you think?
- Identify this car's suspension...
- Camber Bolts Question
- Will this fit?
- Aftermarket wheels worth it???
- calibrating tire sensors???
- Lightest 18" Rims on GTS ?
- Interested in painting calipers?
- Stock airbox with RRM Strut bar?
- Suspension Upgrade
- 2008 Lancer alignment specs
- gts with stock black rims?
- 2009 GTS 5 Speed Steering & Suspension Upgrades?
- Eibach Pro & Sportline Kit
- Nail/Screw In Tire, Is It Covered?
- AM wheel problems??
- Works springs alignment
- Which wheel set would you consider for the evo x conversion kit.
- 4200 miles and i need new tires?!?!
- Are stock rear shocks adjustable?
- Stock GTS tire thread, pull to the left ?
- Help - Tire Rotation
- What about these Pirelli tires?
- ROAD/RACE- Worked with TEIN last week
- Knocking after Installing H&Rs
- Hub bolt broken
- RRM Springs Pictures Tommorow!
- Megan Coilovers $850 Shipped!
- 2008 coil overs from Megan Racing
- Road///Race - 08 Megan Coilovers
- 08 Lancer LSD
- Works spring/swaybar installed - review coming
- Should I consider lowering my Lancer?
- Big rubber for 08 ES - fitment question
- Removing center cap on stock GTS wheels
- DBA Rotors???
- V2 G.R.I.P. springs RRM
- Will These Fit?
- Wheel Spacers
- 2008+ Mitsubishi Lancer Progress Lowering Springs
- Caution GTS owners
- Powder Coat My Rims?
- Stock EVO X wheels
- G.R.I.P springs?
- Will you guys do alignment on tire change?
- 30mph pass thru the speedbump Nooo
- RRM Upper Strut Bar question...
- Already lowered but wanting to drop an extra inch
- Improved Handeling
- Brake pads...mmmmmm
- Tenzo Type-M
- Drop/Tire Question
- Changing Rims/Tires
- RRM Slotted Disc Brakes/Pads/Braided steel bake lines
- Tenzo DC-6 Version 1
- H&R Lowering springs
- 18" x 8" Too Wide??
- Strut Tower Bars...
- Need an opinion on a rim Company
- Progress Technology Sport Springs
- rattling noise
- Lowering Springs
- Possible rear endlink upgrade?
- Coilovers?
- 04-06 RalliArt Rims on 2008 Lancer?
- Hit a Curb
- Price of ES Rims
- Vibrating steering caused by suspension?
- widest rim set up?
- 18x8 Axis Penta
- rota wheels
- Tein H-Tech Lowering Springs for 2008
- Chrome stock GTS rims?
- Brake Lines
- Braided SS brake hoses - interest?
- rear sway bar
- Question for ES owners!
- Valve Stem Failure = Flat Tire
- Control Arm
- BBS Rims?
- Tanabe Springs
- What are your favourite rims?
- Buying Advan RS wheels
- Lancer DE brakes
- What's happening to my lancer when I shift from 1st - 2nd gear?
- RRM Rear lip spoiler
- 18x7.5 38mm offset.
- Will 17x8 +35 with 245/45/17 work?
- brembo brakes
- Lugnuts - Thread size/pitch?
- Biggest wheel's for GTS
- EBC brake pads
- Smallest rim
- Brake Truthiness
- APR front splitter
- Wheel coming loose
- Chassis Truthiness
- Works rear swaybar
- DE/ES owners - what tires?
- X rims
- Coilovers installed in my 08
- So the Evo Vortex Generator does fit on an 08 Lancer?
- TPMS - the ultimate FAQ
- Help me decide on rims for my DE! 17x7"
- Tire sensors on new wheels
- WORKS Adjustable Rear Sway Bar
- Rally Innovations
- Where to buy stock 18in. GTS rim?
- Rally inspired?!?!?!
- GTS Recommended Wheel/Tire combo
- First time in the snow with my Lancer DE (16" factory tires)
- Tire sizes and stock rims
- Low offset wheels on the GTS
- First winter snow + ice = Not fun
- My new Katana's GR4 wheels , pictures
- 2008 Lancer LSD
- 16" wheels ruin brakes on the GTS???
- Springs/Coilovers
- ~~~ Fighting Winter with WinterForce Tires! Review
- ROAD/RACE-GRIP springs Improved.
- Offset question help
- Tire questions
- Strut bar
- Best Lowering Springs for 08 GTS?
- New Rims
- ROAD/RACE- Big Brake Conversion 2008
- Big Brake Kit!!!
- RRM Camber kit
- Running 14's or 15's for autocross?
- Brakes, stopping distance, and weight
- EXTREMELY Bumpy Ride? new UNHAPPY GTS owner...
- Installed: Tein S-techs
- Mazda 3 rims on GTS ?
- rims size and tires for 08 lancer gts
- Balancing Chassis Rigidity with Suspension Stiffness
- help with lowering from people w/RRM springs
- Plan on Painting GTS Rims?
- Rim Sizes?
- WORKs springs installed
- Brake Pad Compatibility
- Anyone running Tein H Tech Springs?
- These should fit?
- Custom Suspension Group Buy?
- T. P. M. S.
