PDA
View Full Version : Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 [2] 3 4 5
  1. 2008 Evo rims on 2011 ES
  2. Noisy lowering spring, need help.
  3. Spare tire is noisy!?
  4. Will VMR V710 fit my '10 GTS?
  5. Strut bar opinions
  6. Eibach sportline lowering springs
  7. Front brake noise GTS 2009
  8. Upgrading brakes on the ES
  9. Stock shocks handle drop?
  10. xxr 521 rims on a 2011 "ES"
  11. Going down
  12. 19" rim fitment on stock ride height
  13. Can't Decide!
  14. Sens.it vs Orange TPMS Clone Sensor
  15. EBC Rotors on 08 GTS
  16. Will 05 Ralliart 16"OEM rims fit on my 09 Lancer DE?
  17. Evolution X wheels on Lancer DE/ES/GTS/Ralliart
  18. 2011 Lance "es" Wheel help
  19. HELP! Best rim size '10 GTS!
  20. coilovers
  21. Parking brake squeel
  22. stock ralliart rear brake swap
  23. Trouble Removing Rim!
  24. Stance Help Pleasee
  25. Tire Options, 225 or 235????!!!!(HELP)
  26. XXR 527's tire stretch
  27. Ground Control Kit
  28. 18x8.5 or 18x9
  29. 2010 Lancer GTS factory rims
  30. what parts should i buy
  31. stock es brakes
  32. Sticky wheel weights
  33. stock tire life.
  34. 4 Enkei GW8
  35. Input on eBay rotors???
  36. Wheel info
  37. Control Arm replacement?
  38. rear sub frame
  39. Will these fit?
  40. 08 Lancer Pulling to the left?
  41. HELP!!!! w/ rims n tires
  42. Lancer GTS Motor mounts Upgrade
  43. Looking to soften my ride, any ideas?
  44. need some ideas please
  45. Lancer rim ideas
  46. Land Rover 18" wheels on lancer ?
  47. coilovers my head hurts
  48. B&G Springs Installed
  49. Coilovers?
  50. 2012 Summer Tires
  51. Possible Control Arm Damage
  52. EVO X suspension compatible with GTS?
  53. Loose e-brake handle?
  54. Stock spring sounds like they are breaking
  55. What will fit / What to get
  56. Looking for a summer set
  57. Will these winter tires fit?
  58. brake disk brands?
  59. Rotor fitment guide... Is there one?
  60. Annual Winter Time Message "Change your tires for winter"
  61. What Other Vehicles do we share wheel size with?
  62. Issues with suspension on 2010 GTS
  63. 2010 Lancer ES - Continental DWS
  64. MB battles + tpms sensor
  65. Center caps on GTS wheels.
  66. thick rims
  67. Hsd coilover setup idea
  68. offset?
  69. Tire Suggestions for 09 ES?
  70. 08 GTS Megan Coilovers!!!
  71. Lowering Spring Help
  72. hella flush?!?!?
  73. Sailun Tires
  74. GTS vs Ralliart wheels
  75. Does any1 have 16's
  76. My new RPF1 Enkei wheels
  77. What upgrades should I get?
  78. What do you guys think?
  79. Best tire brand
  80. What is the minimum wheel offset for 2008 lancer es?
  81. FS: flat black GTS wheels in San Antonio area
  82. What is the minimum wheel offset for 08 lancer es?
  83. Will this rim/suspension combo work?
  84. Just got my Rota GRIDS
  85. Ralliart stock 2 piston front brake calipers on lancer gts
  86. Eibach Sportlines question
  87. shops in Indy area
  88. Will this fit?
  89. Negative camber?
  90. Eibach Front Camber Bolts...
  91. Possible Tire Rub? Lancer GTS 18x8 +40 245/40?
  92. TONS of Lancer Brakes- ROAD/RACE
  93. Front disc is lose (need help fast)
  94. Will these wheels fit?
  95. Eibach Pro-Kit bump stop question
  96. when breaking hard, the brakes stay locked for a few minutes
  97. blown shocks! recommendations?
  98. HELP!! - Spring Install
  99. Lancer newbie with snow tire question
  100. lancer GT brake compatibility
  101. BC coilover and sway bar install
  102. Clacking sound with TR Motorsports C2
  103. Coilovers for lancers
  104. New Tire Rcommendations!!
  105. rrm front strutbar question
  106. Evo x supension on a GTS
  107. 11' ES Rear Drums to Disc?
  108. lugs
  109. bulge on tire wall
  110. 18x8.5 offset 30?
  111. Will I rub?
  112. picks of 225 45r18 tires om stock gts rims
  113. wheel question
  114. Barum bravuris 2
  115. Best lowering springs to get?
  116. quick question about RRM strut bars
  117. finished painting my wheels installed pics/problem
  118. Brake pad suggestions for a GTS?
  119. Are the GTS and Ralliart Wheels the same?
  120. All season performance, any suggestions?
  121. Need a 215/45/18 tire...
  122. different look for DE and ES owners
  123. TPMS question
  124. 2008 de
  125. ~ Dunlop SP5000M Trade-Up Program For Mitsubishi Lancer / Ralliart Owners
  126. Rotors and brakes
  127. Suspension help!!
  128. painting my stock wheels.... help me pick a color
  129. Hankook V12 tires.........and snow?
  130. Stock wheel weight?
  131. does this look normal
  132. 215/45 on 18x8 +40
  133. EDR9's or Motegi MR118's
  134. sway bar
  135. Torn between wheels...
  136. Wheels & springs
  137. 2011 es
  138. 2010 GTS 18" wheels for sale
  139. hood deflector
  140. 16 oem rims for sale (lancer de)
  141. About to get rims question
  142. Sumi HTR ZIII
  143. will these rotors fit?
  144. 2008 lancer DE w/ EVO X enkei's
  145. help with eibach sportline
  146. Wheel Question
  147. Issue with factory rims?
  148. Quarter Panel Help Please
  149. TPMS Valve stem replacements??
  150. 2011 GTS disc brake small enough for 17's?
  151. Help with rims
  152. 2011 GTS TPMS sensors?
  153. Dunlop Star 5000m series
  154. Outlander sport (RVR) tires and rims on Lancer?
  155. New Wheels
  156. Where to get tie rod ends
  157. Eibach pro-kit springs
  158. Lancer Ralliart Gunmetal Rims
  159. Rim help!!!
  160. Ran over a curb
  161. any1 know when brake fluid flush needs to be done on this car?
  162. flush.stance
  163. Mitsubishi is still gay
  164. real simple question
  165. Eibach Sportline Springs.
  166. Evo X MR BBS on a GTS
  167. Painting rims
  168. Motive Power bleeder
  169. Winter and YOU!!!
  170. continental semperit speed grips?
  171. 16" SE winter rims & tires on an Evo?
  172. Rear tower brace
  173. Shakie tires Suck!
  174. tire chain for gts
  175. Brake Proportioning Valve
  176. Ralliart tien springs on GTS?
  177. Best(bang for your buck) Winter Tires
  178. GTS pads on ES
  179. Rear Disk brake Convertion???
  180. Where to get spacers?
  181. Are 09 Es and 10 GTS Front Suspension components the same??
  182. Spring Silencers
  183. Ralliart Stuts and Springs on Lancer
  184. Brakes!!??
  185. Tire Pics??
  186. Widest i can go with rota grids for my 10' lancer without fender work ?
  187. 17x9 rota grid
  188. wheels size help
  189. quick question
  190. Tire fitment
  191. Mitsubishi has done it again.
  192. Pls help with wheels
  193. What is the largest tire size for stock GTS 18s?
  194. xxr 522 17x9
  195. 18s to 17s...will my gap get bigger or smaller
  196. lowering caps
  197. '10 Lancer GTS - smallest wheel
  198. eibach or progress rear sway bar?
  199. Works SS Brake Line Kit
  200. Help! New tires on GTS and something's not right
  201. BC Motorsports or HSD Coilovers?
  202. Question on tires/rims
  203. alignment help
  204. Brand new GTS Sprtback makes clunk when backing up
  205. spacer help
  206. Weird problem with acceleration
  207. Heavy steering and bump steer???
  208. KYB GR2 shocks?
  209. Eibach Pro Kit
  210. New brake rotors all around
  211. Really quick question.
  212. Stock Height
  213. Lug Adapters
  214. Megans Installed w/ pics
  215. Rota DPT 18x8.5 for the 2008+ Lancer *NEW SHOES INSIDE*
  216. Slotted / Dimpled / X-Drilled Rotors:
  217. Tein Coilovers
  218. Help with springs
  219. In need for new tires help
  220. evo8 stock
  221. Hankook ventus v12 evo
  222. Solution for blown shocks, Works put Ralliart shocks on, and they're amazing!
  223. Vented Rotors? Worth it?
  224. wheels for 2009 gts lancer
  225. Nex Coilover
  226. Will this rim work?
  227. Anyone have problems with the RRM V2 grip springs?
  228. 2010 Lancer GTS
  229. 2009+ GTS with Eibach Pro Kit, Camber Bolts Req?
  230. newbie with tires and rims questions :P
  231. Front Sway Bar
  232. Got my ROTAS.
  233. Reprogramming for tire sizes???
  234. Should I be worried...
  235. stiffer spring without lowering
  236. Whiteline Swaybars.
  237. Anyone know anything about tires?
  238. Tire Valve with Sensor
  239. New Springs - Question
  240. Question
  241. Stock Evo X Wheels and Tires on Lancer SE?
  242. Prices for Eibach Prokit?
  243. Camber plates
  244. Swaybar end link
  245. Coilover Adjustments
  246. Help with Brake pads and Rotors
  247. Tire size question...
  248. stock wheel weight?
  249. New wheels, tires, and springs getting put on today :)
  250. Compare ride quality with diff springs
