Log In
View Full Version : Evo X Engine Management / Tuning Forums
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14
  1. Already tuned, can I add a I/C?
  2. Stock car. Only makes 17psi boost?
  3. Need some help
  4. Need stock boost solenoid
  5. ECU/Load based Fuel pump Control
  6. HKS heat range 9 spark plug??
  7. Android App: Torque themes
  8. mods before tune?
  9. 336whp 312tq X
  10. GrimmSpeed 3-Port tuning question
  11. Which wideband to buy?
  12. multiple map setting?
  13. Tuning and MPG
  14. Break in and tuning
  15. Fmic worth it before tune..
  16. 2012 Evo X SST and 5 Speed definitions available
  17. DW850s
  18. need some help : DTC P2001 code
  19. Overboosting GSR
  20. Mac, EvoScan, Tactrix 2.0 compatibility?
  21. Cant edit rom file
  22. Individual-cylinder widebands....
  23. Tuning from stock
  24. New exhaust=tuning???
  25. Getting started with EcuFlash, ROM 56890013
  26. PLEASE HELP! WOT Jerk/Bump As Approaching Redline in 3rd
  27. Can someone check my logs?
  28. 2010 SST tables and ACD tables??
  29. AEM intake
  30. What to ask, what to expect?
  31. P1235
  32. Question while tuning on E85
  33. Wide band calibration
  34. What do I do? Help Please
  35. What changes to make in ECU flash after ETS intake install
  36. Tuning after upgrades?
  37. DO you really need a fuel pump?
  38. Advice needed on AVC-R
  39. Attn XML gurus: info regarding rev hang/deceleration
  40. Rough timing guide please! (built motor and EF4)
  41. Tunner v.Ohio
  42. TPS in 2011 gsr
  43. Some help, What other parts needed
  44. MAF Sensor Calibration helper app.
  45. Knock count when entering 1st gear HELP
  46. EvoScan command line problem
  47. Upper Intercooler Pipe
  48. Any ecu aftermarket, for the evo 10 GRS edm?¿?
  49. Need help diagnosing this ANNOYING problem.
  50. Split second power loss...CEL is now on. Ideas??
  51. perrin ebcs pro vs grimmspeed
  52. ICS switch not working after flashing with new Rom ID
  53. Is this normal A/F
  54. latency table for ID1000
  55. Need halp asap LEAN WOT !!!
  56. EvoScan, boost, and Virtual dyno
  57. stock injectors/fuel pump
  58. aem uego logging keeps stopping
  59. Reset ECU - learning
  60. question about tuning and going back to stock
  61. 2.2 Idle control, 2010 EVO X
  62. Greddy Informeter, ARK MFD2, Dashdaq, Evoscan GPS?
  63. Accessport data logging without flash
  64. Nevermind
  65. When to do fuel managment
  66. Pros and Cons on EcuFlash / CobbAccess
  67. P0068 maf/map tps correlation help
  68. Timing Reduction vs Load/RPM
  69. cable for virtualdyno
  70. 0-5v logging evoscan
  71. tunning 2010 evo x se tonight at rre
  72. P050B After Tune
  73. do i hear knocking in idle?
  74. How to check for flashed ECU?
  75. Unknown ROM Image on map from tuner
  76. Service Engine Soon Light
  77. Driving on an AEM UEGO with no power
  78. how can i hold more boost?
  79. Tranny Service required
  80. Ghost SEL
  81. perrin exhaust
  82. CAN ID's for TPMS Logging?
  83. mode 23 + passive solenoind - does it log it correctly
  84. Low boost because of weather?
  85. AEM inline controller serial logging
  86. AutoEnginuity Anyone?
  87. Synapse dv surge/flutter
  88. Evoscan software help
  89. Tune cost...
  90. Wideband o2: have some questions, answers welcome
  91. Lancer Model ECU compatibility
  92. Kelford 214B idle issues
  93. zietronix afr being weird
  94. P2096
  95. Best OBD-II windows software
  96. P0171 and injector scaling issue
  97. motor blew :( help
  98. Custom Tune: Stock Car
  99. MBT on Evo X
  100. Proefi
  101. Hesitation and bucking under wot after tune
  102. Help help help
  103. Low RPM Knocking Sound
  104. AMS Stage 1/2 or Cobb Stage 2/400s with SSP clutch packs?
  105. Email tunes?
  106. New sub-forums!
  107. Can someone explain "load" and load cells?
  108. Need help isolating an issue!
  109. Is this an indication of a boost leak?
  110. Want to freak an ECU out?
  111. SST Modes, Clutch Pressure and Clutch Slip
  112. MAF Scaling help.
  113. 2011 GSR Brake Boosting
  114. Logging SST useful parameters
  115. Ultimate Racing 800cc Injectors
  116. Blitz Throttle Controller with the 1st Gear Limiter removed?
  117. Mac OS X Lion + Parallels: Tactrix USB fix
  118. Logging SST fluid temps
  119. Setting up new ROM for locked unknown ECU
  120. Lean spike around 3800rpm, any ideas?
  121. ECU Locked?
  122. Random Misfire
  123. custom 3" exhaust questions
  124. maf volt reading input question
  125. What AFR for partial throttle accel.
  126. Is Mellon tuning open on labor day?
  127. I am on the fence...ECUFlash with EVOSCAN Vs. COBB ATR
  128. Reading from TPMS
  129. Getting my Evo Tuned at RRE today!
  130. OBD Logging speed
  131. what tune should i get for my 2010 GSR
  132. LCD logger?
  133. Failed flash fixed my car???
  134. Evo X - P0219 code help
  135. Black Fuel Pump Relay - Dead One Cut Open - Pics
  136. Question about Cone Filter
  137. mini battery flashing issues?
  138. Tune needed for replaced downpipe with stock cat?
  139. Too much knock?
  140. Suggestions?
  141. bucking problem
  142. P1871 Trouble
  143. Advice on tune
  144. Best way to check if you have good or bad e85?
  145. AC map question
  146. Lean-out issue around 3000rpm
  147. ECU/Wiring Gurus: Need fueling adivce
  148. Introducing AcidTune, a Cross Platform OpenGL Map Tracing Package
  149. Ran out of injector, gone static!
  150. Help Getting 2150's Dialed In
  151. Trouble starting
  152. Custom Tune on fully stock MR
  153. Access tuner race, Questions & help/tips
  154. Tuning my FP Green for 3-port (and 1100cc injectors to come...)
  155. MR/SE/RA SST R&D soldiers on...
  156. injector scaling in ecuflash messed up??
  157. E-85 Info for everyone
  158. Copying from Map Tracer in Evoscan 2.7+
  159. Unsupported Rom?
  160. Injector size for an FP Black, E85 build?
  161. Crappy idle followed by stalling out
  162. Sf stage 2 93 boost issue
  163. e85 and a walbro 255??? Problems???
  164. Tactrix stolen-League City, TX
  165. noob... is tune a must?
  166. Cobb AP Stage 1 AEM map question
  167. Vishnu 380HP tune removal help
  168. Anyone running a MAP SRI with the Cobb AP?
  169. Ivey tune
  170. MAF scaling units
  171. Any good X MR/SST tuner close to E TN/VA/NC area?
  172. Idle fuel trim always goes to -12.5%
  173. Air filter shield to fix unstable idle on Evo 10s
  174. cobb tunes for 2011 evo x gsr ???
  175. Evo X Rally Antilag
  176. Tune
  177. AC controlled by the ecu?
  178. Warm Start Problem - Stock Pump & Injectors
  179. Is a replacement ECU plug and play?
  180. AccessTUNER BETA Updates for Mitsubishi EVO X and Ralliart
  181. NEED help guys
  182. OEM BCS vacuum line help
  183. Is OBD PIN1 connected to ECU?
  184. Need Info on ecuflash roms and copying maps over.
  185. Heat Soak issue. Looking for Air and Coolant temp related fuel trims!
  186. EcuFlash And 52690021 Stock Rom No Tables XML installed
  187. What Pin and or color wire on the ECU is the speed sensor??
  188. 2011 stock evo X reflash,worth it?
  189. AFE/Takeda intake, Cobb map?
  190. Car won't start up...help!
  191. How to figure out ROM definitions for an ECU
  192. Reading DTC's (CELs) without a reader/laptop
  193. question about cobb AP
  194. Different reading between Rear O2 & Com Port for LC-1
  195. Cobb Stage 2 Logs
  196. need advise on mod n tuning
  197. Having something weird going on
  198. AEM xwifi and evoscan
  199. Bogging down and black smoke.
  200. cobb accessport map
  201. COBB A/P 2011 update for years 2008 - 2010
  202. GSC S2 & FIC 1680 Idle Help
  203. Questions Concerning Injector Scaling and Latency
  204. 5th gear high rpm throttle closure
  205. best tunner in miami
  206. AEM wideband and Evoscan
  207. where to buy cobb ap custom maps for my mods
  208. what's your awhp?
  209. '11 GSR better baseline vs '08 GSR
  210. tune needed?
  211. ECU-power windows
  212. weird cut@wot
  213. innovate lm-2 kit
  214. Need Help with P0037
  215. MIVEC - high overlap
  216. Found a flashing counter
  217. Question on E85 Tune poor MPG
  218. gas mileage after tuning
  219. Ecuflash wont connect
  220. Reasons for slow fuelling response at spool-up?
  221. Cobb stage 2 dyno numbers
  222. tune a must before turbo back 2011?
  223. ASC OFF / ABS service require
  224. phantom knock or real knock...need help with logs
  225. can't open ecuflash file
  226. cobb ap or ams e flash?
  227. Basic questions about Evoscan, ECUFlash and connectors
  228. Factory Reflash
  229. P1235 p0420 p0234
  230. O2 sensor connector
  231. stage 2 over boost question
  232. What table or parameters do I modify to get rid of the ASC overboost light Cobb ATR?
  233. q: some items address for mode23 JDM/EUDM/AUDM
  234. Questions for the Cobb experts
  235. Resetting CEL's With Accessport (but not learned parameters)
  236. Some questions about a tune.
  237. AP ots maps that will get me by
  238. ecuflash Problem with this Evo X
  239. LPG tuning guide
  240. HELP - Odd Warm-Start Issue
  241. Boost surges in powerband with AP
  242. ltft's
  243. ATR Stupid Question about Load Boost/Fuel Value
  244. Evoscan settings for 55580006
  245. Worth it for a protune with current mods?
  246. Will I need a tune ,pliz help.
  247. are there two cranking tables?
  248. AEM UEGO Install Headaches
  249. 3.5" Maf Scaling Table??
  250. first datalog
