PDA
View Full Version : Evo X Engine Management / Tuning Forums
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14
  1. needed help with aftermarket parts tuning
  2. Introducing the liteSPEC Titanium Exhaust System
  3. Asx 2010
  4. 2010 Raliart Definition
  5. Cobb AP Correct Boost Reading - wtf?
  6. Upper/Lower Bound Map for 54070007
  7. Cobb AP questions...
  8. Confirmed : SST 1st gear throttle limit MR vs RA
  9. Need Definition for EVO X JDM Ralli art
  10. EVO tuning in Arizona?
  11. EVO X not tumbling.
  12. Fuel level affects A/F ratio - look here
  13. Review Cobb Log - Stage 2
  14. How To Fix P0420
  15. JESTR tune. Stock turbo. Bolt on. 93
  16. tephra xmod ?
  17. FP Red tuning issues
  18. ecuflash help...im stupid...
  19. What all do I need to run e85?
  20. Found some right-angle USB cables for Tactrix users
  21. What Cobb map for KN Typhoon?
  22. big problem with zchip. help plzzz
  23. help with "service engine" codes
  24. Can someone look at this log file for me?
  25. Idc
  26. E15 and Evo X tune
  27. anyone using accessmanager yet?
  28. Who can donate an ACD ECU from an Evo X
  29. 3-Port Map help
  30. unknown rom image
  31. Firmware Update for "Hot AccessPORT" Issue Available Now
  32. AccessPORT Manager 2.0 Including Mac Support Available Now
  33. ECU controlled Boost upgrade
  34. about 2011 JDM
  35. Load fluctuations at high rpm
  36. Failing Walbro fuel pump...
  37. Torque Limiter
  38. Single source for EcuFlash table descriptions
  39. power loss with stock cat
  40. Cobb LWG Maps, what's it do?
  41. Octane Booster...?
  42. MAF + Crankcase Breather ?
  43. MR cruise afr's Cobb protune
  44. AP tune with cutout ?
  45. Hard knock at start and soft through the gears.
  46. stock fuel pump runs full voltage for 15 seconds after start.
  47. 2010 X MR xml
  48. FP Black & DW1000
  49. New exhaust after custom tune?
  50. Which 3 Port Boost Solenoid
  51. disable rear o2 sensor?
  52. Running a 3inch intake, have a ?
  53. Cold start problem - MR
  54. XML for Lancer X
  55. Omni 4bar writeup
  56. Maximum Safe Timing
  57. Help with cobb tune - ATR
  58. CEL codes...
  59. K&N drop in filter, which ap map?
  60. Cobb Accessport for EVO x gsr
  61. 2010 Evo X Tuning solutions
  62. ECPro vs. Motec PnP?
  63. Maxing out the Evo 10 MAF?
  64. Rear o2 sensor, which wire is what? *pic inside*
  65. How can I disable the EVAP system.
  66. Just got p1870 Service Required
  67. To ecuflash or to get tuned?
  68. WARNING: Check BLUE Fuel Relays (Blue Relays Fail)!!!
  69. cobb ap question
  70. What is the highest boost level that a stock turbo will hold by redline?
  71. How lean can a X run without knocking? My FPR hose popped off but got NO WOT knock
  72. Stock car, tuned, new problem...hesitation when hitting peak boost - log inside
  73. Zeitronix WB install
  74. LC1 free air calibration - quick question
  75. Cruise - getting best mileage
  76. Mitsu = Cheeky Buggers
  77. Cobb Access Port - only one LTFT can be logged
  78. Advices on my tuned map (ROM and Logs attached)
  79. Wideband Air Fuel Ratio
  80. Front o2 Sensor Problems Input Needed
  81. Thanks to Hollywood
  82. Should I sell my Cobb AP?
  83. Can you guys check my logs?
  84. ECU Options set #4 bit 1
  85. Unknown (for me) torque limiter tables
  86. EVO DW1000cc injector Spec Sheet anyone?
  87. Random knocking in 5th gear when going to WOT
  88. Haltech Sport 2000 PnP for EVO X by: Crispeed @ AWD Motorsports!!
  89. Which Solenoid Does GM 3 Port Replace?
  90. couple questions
  91. The 3xMAP/MAF tables
  92. Evoscan 2.7.0090 released
  93. HB Speed or RRE
  94. Need Definition file for 2010 EVO X MR AUS
  95. Tune change needed with test pipe or not?
  96. Do I need a replacement 02 front 02 sensor?
  97. Modified base map for GSR stock
  98. Protuned, tubo surge/oscillation
  99. Boost pressure COBB stage 1
  100. Wideband AFR reading is way off the target AFRMAP, help!
  101. Stock Boost Solenoid Limits
  102. P0171 Code on E85, Ideas?
  103. ASC off
  104. tuning ideas help plz
  105. GM 3 port
  106. Stall & High RPM Jerking
  107. seeking a table for 2008 Evo X GSR
  108. Enabling mode 23 on evoscan
  109. AccessTUNER Revised Update
  110. Pop noise from exhaust etc
  111. Internal VIN location.
  112. Preffered evo 10 management system or software?
  113. unlocking Evo X ecu?
  114. Minimum IPW Info AND Resolution patch
  115. New TBE new tune???
  116. EVO X AccessPORT and AccessTUNER Updates Now Available
  117. Injector Latency Algorithm change
  118. 52360018 clean xml needed
  119. MR with a manual boost controller?
  120. Another semi-useless fact about low load knocksum
  121. Engine heistation... not BOV... what else could it be?
  122. Need Help!!
  123. Filled up on E85, car won't start
  124. 2010 definitions?
  125. Can't read maps?
  126. BIG MAPS oh where art thou?
  127. Engine Management Preferences Survey
  128. AFR Map? MIVEC not following map?
  129. Research and Development
  130. Do i need a tune for a turbo inlet/drop in?
  131. anyone have any tuning info on fic 1100s
  132. Which map?
  133. Suddenly lean throw me some ideas
  134. EcuFlash ROM ID Help
  135. Hot start fix for the EVOX's.
  136. Judging HP before a DYNO
  137. 10' MR owners.. need some advice!
  138. How to determine which flash I have? (no code reader)
  139. Camshafts and bad idle, could it be fuel rail?
  140. Perrin 3 port ATR startup setting
  141. Critical Map Update for all Cobb EVO X Off the Shelf Maps
  142. Super Lean At 9v To 12V Crossover
  143. Intake MIVEC
  144. AEM injector driver fried question???
  145. What would cause sparkplugs to back out?
  146. p1037 code
  147. Just Installed Kelford 214B and...
  148. Can I use Economy Mode?
  149. Signs of a defective GM 3-port?
  150. what romid is this ?
  151. Boost problems!
  152. error protected area (ecuflash)
  153. tuning
  154. how to tune out the gap
  155. Engine Tune?
  156. P0140 dtc - cobb ap
  157. Reflash question
  158. Engine Ticking noise
  159. ECU Problems Cobb AP to OpenSource
  160. 02 sensor removal/SES disable
  161. Going Lean at High RPM WOT
  162. Reduction of load values, what could cause?
  163. Cobb tune w test pipe?
  164. Newbie AP Log Q?
  165. psi based boost control
  166. New Fuel Pump Relay Failing Or Something Else?
  167. 30psi? ASC OFF? SST OFF? Fixed!
  168. Tune/more fuel/Help
  169. Question about intakes with regards to the stock MAF housing
  170. MIVEC + FP Red + Surging
  171. What would be the recommended cut off amount of boost for a stock turbo?
  172. XML file for 2010 Australian EVO X manual (53040013)
  173. HOW TO: Reset your Fuel trims
  174. immobilizer malfunction?
  175. Dyno question
  176. Mellon tuning to be in KC July 24th-25th
  177. ecu defs
  178. who wants to test the +30psi = ASC OFF fix?
  179. Controlling 3 sport
  180. I think ECU_OPTIONS_3 bit14 is cruise control enable/disable
  181. What can caused this?
  182. ASC Off / service required message while at the track
  183. ASC off light comes on...
  184. Car trouble...
  185. Need help with a definition file
  186. Motec Install on Stock EVO X :)
  187. Cobb AP option
  188. HOW TO: Recover your EvoX ecu after a failed reflash.
  189. 52360018 xml
  190. evoscan problem: less than 5 volts
  191. Correct throttle axis for boost maps
  192. COBB Tuning AccessPORT Product Line Consolidation
  193. MAF voltage reading question
  194. XML file for 2008 Australian EVO X manual (530400100)
  195. Extremely Lean ARF's Under Boost
  196. filter upgrade
  197. Bent my UICP.. can i still use it?
  198. Fuel Trims on DW1300s
  199. Soft antilag. Low power engine response.
  200. Tactrix Cable and Flashing Questions
  201. Deatsch werks 1300cc injectors review / Scale / Latency
  202. DW 1300s
  203. Stock Tune?
  204. Tephra LC-1 question..
  205. Help First time Tuning
  206. which injectors 4 my set up..
  207. Need .xml for EDM GSR SST ID 53050006
  208. logging issues
  209. New AP, idle question
  210. P1025 code?
  211. Mail-in AP tuners
  212. just installed tactrix cable... can't find which rom to read?
  213. How to disable P0141 and REAR O2 on Otlander XL3.0
  214. Calculate load from WGDC?
  215. HELP! Can`t read ROM from tuned Lancer X id 52320006
  216. HELP!! ECU tuning question??
  217. Help... Something is off with my Turbo Boost Error Correction
  218. AFR question/problem
  219. My tuning journey begins...
  220. COBB AP doesn't start up in hot weather
  221. Erratic AFRs
  222. Tuning lesson... Tephra and Golden!
  223. How many mods before custom tune?
  224. Stationary Speed limit problem
  225. Help with 3 Port
  226. COBB AP with speed circuit CAI
  227. COBB AP torque limiter removal for MR
  228. Should I sell my AP and just use the ECUtek stuff?
  229. 2010 X GSR (USDM) - can't view idle tables in ECUFlash
  230. Whats a fair amount to pay for a tune?
  231. Gauge or No Gauge
  232. To those who have done weight reduction...
  233. AP reference Log
  234. When WGDC #1A, #1B, and 2 maps are used?
  235. Tactrix Cable Problem
  236. Where is Evoscan Serial Number?
  237. AFR calibration map
  238. Retune?
  239. Have big cams? Using ECUflash? Come on in!
  240. Discussion: Increasing Spool Up : AFR, Timing, MIVEC
  241. Need 2008 JDM GSR 5MT ROM
  242. How to flash car after COBB?
  243. Stage 2 questions
  244. AP Dyno question
  245. Why a serial cable?
  246. Help Lancer X
  247. Tuning Theory? Newb...
  248. Narrowband to wideband
  249. Used AP question
  250. Help with ODBII Readiness for Smog Inspection
