PDA
View Full Version : Evo X Engine Management / Tuning Forums
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. 2103 Euro Evo X locked by Swiss tuner....
  2. Effect of MIVEC on exhaust temperatures
  3. Asc light
  4. Newbie question: Turning up boost
  5. 08 Evo x mr e-tune
  6. Evo X Front O2 Sensor Replacement
  7. OEM ECU controlled DIY dual voltage big pump controller
  8. P1220 & p1260
  9. Stx500 ams
  10. Cobb 3 Port question
  11. Ayc code c2204 help!!!! Don’t have evo scan
  12. Code P2096 - post catalyst fuel trim system too lean on bank 1
  13. Wire tuck codes p0010 and p0013
  14. Crank but not starting it could be open loop engine load or fule cut ? Help
  15. What all do I need for Flex fuel
  16. EVO X not makoing any power on WOT
  17. Help P0172 rich cell
  18. Better dyno numbers?
  19. 13 GSR, exhaust, hfc and intake
  20. Tuning advice
  21. E85 need info!
  22. Best flex fuel setup
  23. Emu black has anyone installed
  24. +timing for power if knock deaf
  25. Does anyone have a EVO 8 4g63 HKS 2.3 Step2
  26. Can't legally tune a non-race car?!
  27. 2008 Evo X GSR ECUflash Defintions
  28. Can I use innovate flex fuel sensor for both gauge and ecu (w/ tephramod)
  29. No error codes
  30. Looking for tephra
  31. NJ Car inspection failed - Oxygen Sensors
  32. Help please Lancer Turbo OEM ECU
  33. Signs of Failing Fuel Pump
  34. ABS & TCS problem for tuning?
  35. AEM Boost Gauge Reading Wrong
  36. Intake bung to old ports on stock EBCS
  37. 2 step setting
  38. Mysterious Issue with random idle surge and running lean.
  39. SST to 5MT, Tephra V2 problem
  40. Sonata Turbo - Theta engine
  41. Stage 2 COBB OTS Lean WOT
  42. When is it necesarry to rescale your MAF?
  43. 2010 evolution x need connecting rod bearings specs
  44. I need help
  45. Injector Dynamics 1700X on Pump?
  46. Question for those with AMS UICP
  47. Odd WOT event...
  48. Irregular idle after bricking eco
  49. Possible to Monitor with AP with EvoScan tune
  50. Gauge Not matching Evoscan Logs
  51. Evo X bad tune - use cobb AP map?
  52. Is my ECU going bad?
  53. Disabling Air Bag Light
  54. Need help with getting Flex Fuel set up on currently completly stock Evo X MR
  55. P0AE0 Error (ABS Off ASC Off)
  56. Boost sensor Gauge when engine is Off
  57. Tactrix SD Logging
  58. Good remote tuner Accessport/Meth
  59. 2015 Evo running rich at idle
  60. ECU disconnects under acceleration
  61. P2096 code 2015 EVO X MR
  62. download patch
  63. URGENT PROBLEM - Cobb AP Target Vs Real Value - Intake and Exhaust Cam
  64. Download patch
  65. cobb accessport data log
  66. The Mysterious evo x engine flooding
  67. 5000-6000rpm problems
  68. E85 cold start help with 2150s
  69. need rom Xml 58010105 Please Help
  70. Will it need a retune?
  71. Help!! erratic idle-rich afr-radio not working
  72. Advice on my FIRST tune/mods
  73. 2013 USDM Evo X GSR Dilemma
  74. Tephra V2 XML Help!
  75. Saving Maps
  76. Tuner Knock Monitor Software Writeup
  77. new engine tuning questions
  78. Low load knock (SST) - need opinion
  79. SST hitting torque limit
  80. Knock gain on stock block 400whp+
  81. Evo x engine build
  82. Not Hitting target boost.
  83. P0365 Code thrown..... Just bought the car
  84. Planning e85 conversion could use some tips
  85. Evo X Blue Tooth Wideband?
  86. 2008 JDM EVO X Stock Rom Required 52360118
  87. MAP based load calc tune
  88. First Evo build
  89. ABS and ASC Light on after using ETACSDECODER
  90. 2012 Rom on 2014 Evo GSR?
  91. Evoscan and Torque app boost display???
  92. PASSThru CAN Utility ECU communication error
  93. ECUFlash removing tables from ecu
  94. AUDM EVO X MR Stock Rom needed
  95. Evo X fuel system diagram
  96. Safe boost levels?
  97. 3 bar map sensor
  98. Labor Costs (head job)
  99. Help! AMS STX500
  100. What should I do first?
  101. E85 Question
  102. What is the most compatible Failsalfe for evoscan AEM or Innovate ?
  103. 08 evo x Help
  104. I want to make 350 awhp
  105. DTC: P23E0 and/or P23B0
  106. Cobb V3 AP stock EVO X
  107. Need EVO 7 JDM Tephra ROM & XML file
  108. Evoscan log issue
  109. Higher boost or Higher timing
  110. EVO 4 OBDII port HUD
  111. Rich at 4200 RPM
  112. Stumbling at idle and under load
  113. Rich A/F's?
  114. Logging with evoscan for dummies?
  115. Gunzo ROMS
  116. any tuners around here?.. looking for an Etune
  117. BOV not swooshing....
  118. Tuners please take a look and help out
  119. Lean under WOT and low fuel pressure
  120. P03e0 / p03b0 dtc
  121. AEM Flex fuel failsafe gauge output
  122. Best 14 Evo MR 2.2 builds
  123. Failing DEQ test, help needed
  124. Track Tune
  125. Getting from Point A to B to get your tune
  126. Fuel Pump + Injectors + Fuel Rail
  127. Anybody been e-tuned by m-tuned?
  128. Should I reset fuel trims?
  129. Look at my data log, is anything wrong?
  130. "1000cc" Bosch EV14 Injectors
  131. Live Tuner error opeing xmod v3 59610309
  132. Any feedback on JMS RACING in SA,TX??
  133. MR did not start - Issue with Cranking
  134. manifold with previous tune
  135. Motec m150 patch harness
  136. High Knock at 1100 rpm on first gear
  137. Evoscan and AEM UEGO A/F
  138. BOV question?
  139. Surface Turbulence
  140. Older Cobb Maps
  141. Exhaust mix n match
  142. Need help!!
  143. Turning off SRS
  144. E85 on Evo X
  145. E85 Converstion Help/Questions/Suggestions
  146. is this normal boost spike/knock?
  147. Review: Delicious Tuning Flex Fuel Kit for EVO X
  148. Looking for an exhaust - Anyone have experience with Pro Tuning Labs?
  149. anyone good with electronics? solid state pump hardwire
  150. Test Pipe w/ Accessport safe or unsafe?
  151. E85 NO MORE!!! Now called ethanol flex fuel and is lowered to E54
  152. Definition for 52690028
  153. Flex Fuel Tuners
  154. Evo X car cranks but won't turn over
  155. Spooling Up – Tuning DOHC Variable Valve Timing For Boost
  156. Need some help
  157. reflashing ECU back to stock
  158. Found these old rec'd Evo X bolt-on mod levels from RRE
  159. Is this normal for ID injectors?
  160. Question on tuning and catted exhaust
  161. Maryland tuners or DC, VIRGINIA
  162. Injector Duty Cycle logging
  163. 3 Port Boost Tuning Help Please
  164. AFR before and after LICP w/o tune
  165. Asc off service required help
  166. looking for ecu connectors
  167. Questions about my boost curve
  168. Evo X ECU Not communicating
  169. New owner need help
  170. Alternate switching of maps with v3 tephramod
  171. New owner and need help...
  172. Dyno tuning near Toronto
  173. SST boost spike advanced tuning help!
  174. 2015 lancer evolution help!!
  175. Flex fuel questions
  176. 8857008 cold start cranking enrichment
  177. Please Explain The Difference Between A Mustang & Dynojet & looking for gauges!
  178. Looking for Tactrix 2.0 cable - Denver, Colorado Area
  179. Knock and no knock same tune
  180. Evo X FE definitions
  181. Cosworth MX1 rev limit
  182. Upgrade List? 400whp goal
  183. Modded oil pan: any interest?
  184. Accessport New Features and 2015 Final Edition Support
  185. Flex fuel from delicious tuning
  186. intake filter change
  187. Topping off coolant
  188. ETS intake, testpipe, and 3port solenoid on evo X MR
  189. Quick Question about possible tune
  190. Intake without a tune
  191. AFR closed-loop behavior
  192. Can i run these parts without a tune for a couple days???
  193. boost pill vs MBC vs EBC
  194. Accessrace tuner program
  195. How to prepare for dyno tune? TephraXMod w/o Tactrix?
  196. Looking for a tuner on a build.
  197. Cobb Stage 3 threw CEL & P0830 & P0170
  198. Mivec map advice
  199. What to Tune After Installing Testpipe?
  200. Cobb/Tactrix compatability windows 10
  201. Need Recommendations for an install + Tune
  202. troubleshooting
  203. Help with Logs?
  204. Cobb access port problems.
  205. Cl light
  206. stage 3 COBB performance package , do I need a protune?
  207. Still trying to figure out E85 vs Flex Fuel
  208. Looking for a decent tuner/chip
  209. Evo X Where to tune!
  210. Going from UR mini muff to ETS test pipe
  211. Evo X MR E85 Build
  212. P0017 code
  213. Prosport Wideband Formula
  214. advancing timing problems
  215. 2010 Evo x ecu dead. Need replacement, what interchanges?
  216. Downloaded AccessTuner Race from Cobb... .exe file?
  217. AEM UEGO inline wideband serial port logging not working
  218. COBB Stg1 K&N Typhoon Calibration
  219. Nevada Tuners
  220. Cobb access port GSR tune work on MR?
  221. tuners: knock at strange time - pic - tune out?
  222. FE Evo too lean?
  223. 28-30 psi on stock block / turbo ..
  224. P0133 code /stalling/ rough and lean idle
  225. RPM dips at idle
  226. Best upgrades
  227. hp, and torque E85 + bolt ons
  228. MR tuning
  229. ECU VIN Coding Help
  230. bad lean spot at 4k that i cant fix
  231. uh-oh?
  232. Help me tune mivec for s2 cams
  233. My first Evo/Recalls
  234. 10% off everything at cobb! Now through midnight, november 29th!
  235. Gauges
  236. Connecting Wideband to Rear O2 Harness
  237. Live Data Logging Device?
  238. Haltech reviews
  239. Cobb Access Port V2 - No Cables, what to do?
  240. defi smart adapter?
  241. Stock BOV to Synapse DV retune?
  242. MAP calibration using tener helper app
  243. Psi based boost control question
  244. WTF is going on with my ride! HELP!!!
  245. Dont starts evo x
  246. Atmosphere DP to Recirculating DP ??
  247. Tunning
  248. Definitely a NOOB question but please help me out.
  249. How to install AEM UEGO Inline wideband?
  250. Disabling DTC using TephraMOD V7
