- New EvoX MR
- Best Cold intake System for evo X
- CEL... any ideas?
- EDM EVO X ROM specifically 53040010.XML
- ECUFlash and EvoScan problems with Asus Eee PC
- help with tuning to eliminate p1235?
- P0300 multiple cylinder misfire..wtf
- editing 2-step for no lift to shift
- COBB PROTUNED for 11.5 AFR ECU Slowly leaning car out to dangerous AFR???? Help!!!
- P0133 & u0184..??
- Knock on stock X - WOT ~6k RPM
- MAFs gone bad!
- mode23 load innacurate?
- boost limiters+ rpm/mph crossover
- need to nerf/valet mode my evo
- def file needed for 08/09 jdm sst! pls help,,
- Anyone in Houston area with tactrix 2.0 cable?
- Causes of knock retard
- Works air filter vrs. OEM air filter using DLL.
- Tuning within warranty?
- Checksum error? Afraid to reflash using 1.42
- Stock gsr data log
- FP RED or AP GT35R kit
- Grimspeed EBCS Testing
- Cobb Stage 2 AP to Stage 1 AP something is acting up?
- Manual Boost Control
- evo 10 EDM 53040007 - need help
- Source for Tactrix Cables
- speed limit
- on stock boost control.. yea again! :-(
- COBB AP & tuned Evo X
- Perrin in Europe
- Evoscan: documentation for bit fields?
- evoscan
- Using a wideband with AccessPort?
- Need TEPHRA mod info for Aquamist setup on EVO X
- Greddy Informeter Touch boost sensor option question?
- LCD / touchscreen carputer options??
- shortcut to set LTFT Idle
- Will EvoScan monitor fuel pressure?
- Innovate OpenTune IPhone Interface
- Need help with boost control....
- just wondering if anyone here got there X tuned my DGMOTORS ?
- Need the full Definition for 5304007 EDM
- Boost solenoid question
- air/fuel ratio on initial boost?
- Tuned by Tobz in Colorado
- Can't Decide
- can't decide
- at what point in modding is Tuning NECESSARY?
- AMS 02 Sensor spacer
- Cobb AP & FP Red turbo
- Evoscan or Cobb?
- What would cause this kind of randomness?
- Cobb AP plus K&N Typhoon
- Question for ppl who had gotten a tune.
- Boost values logging in Evoscan read higher than reality?
- 54070007
- Purchased Motec
- Throwing a p0139 with MXP testpipe??? Any fixes???
- Formerly EcuTeK tuned car, can I overwrite with Ecuflash?
- How to up MAX boost with ecuflash?
- help!!!! thermostat location?
- Knock Retard values from my AP datalog, are these of concern?
- low gear boost...
- Updates to EVO X AccessPORT and AccessTUNER
- evoscan via mmcs
- 2010 USDM Evo 10
- EVoscan Maptracer ???
- Methanol injection?
- HowTo: Logging Wideband AFR via Rear O2 ECU ADC Input (Logging AFR without serial)
- Cams for the Xs
- Official COBB Racetuner (EVO X) Discussion
- Resetting codes
- WORKS reflash
- are the torque limiters tables used on GSR ?
- Getting Best MPG during Cruise
- LTFT question
- Any Tuner can read my log and tell me ?
- limp mode
- Low Timing and hesitation during cold start
- Training on Tuning the ECU and Anti-Lag
- Stock Boost Pressure?
- Evoscan: Custom Display Gauge Layout
- Cobb and Injen
- How to permanently disable the ASC ?
- Launch control problems
- injectors not closing on deceleration
- Tuner advice in MD
- Newest factory ECU reflash?
- Quick WB Question
- Cobb AP Question
- Fighting Hard Limp Mode with Airflow Mod
- Can't find the MAF table anywhere in ECUFLASH
- Fuel Trims for a stock X?
- Wideband Positioning in Stock Downpipe?
- Best pump gas brand
- cel fix for downpipe/testpipe help
- cobb stg 1 93oc runs rich?
- Is there a way to get a custom tune by mail?
- Cosworth drop in cams for evo X
- Throwing P0137 and P1235 after EBC
- I know this is a stretch but....
- 97/98 Octane Pros and Cons
- Q:Idea: EvoScan Alarms function?
- AMS Intake Install. Flutter Sound help
- Boost Map Difference
- Tune preferences
- Higl load - low knock - is ti OK?
- problems tuning fpred
- Evo Scan Updates?
- Mini service at 11250 miles....
- NC Tuner Needed
- EvoScan 2.6
- Install now, or wait?
- car tuned finally
- Noob using 91oct CA gas, tried out Gunzo's base maps w/ success
- Best Guess HP Calculator
- Downshifting the X and going into Limp Mode
- knocking at low RPM
- Good widebands?
- Rev Limiter vs Throttle Limiter
- Removing Pill
- Alaskan DGmotors Email Tuned X
- MAF Scaling Table in grams/second
- Logging Wideband AFR via Rear O2 ECU ADC Input
- Evo X MR EBC question
- i need a mobil tuner for montreal canada( from the us)
- Service Engine soon-light on a stock evo
- Access Tuner question
- Wideband and multiuse guages
- To those with Forge WGA and MBC
- Cobb AP EDM maps ?!
- Stage 1 Boost?
- AEM Analog Wideband Gague 30-5130
- ecuflash?
- Question for COBB.
- cat back effect on tune?
- Race Gas Timing?
- How Long Does it Take to Tune a Evo X?
- HELP: CEL after installing UR Test pipe and o2/dump??
- COBB Stage 1 JDM Tune
- Petition: Evo X EcuFlash Forum
- AP tuner and 64- bit operating syatem
- Intake mivec map does not line up with evoscan datalog?
- Help me tune my evo x
- Service Engine Soon Light
- Overboost while Datalogging w/ Cobb AP
- Pulling DTC codes: any option other than PCM Scan?
- Intakes, Fuel Trims, and AFR
- Dyno's hp numbers, how much is a lot?
- Help, Car going into limp mode only on roadcourse
- Which WB02?
- New Evo owner + ECUTek
- Cobb guys...
- Tuning help
- Calling all self tuners...
- Question regarding stock turbo efficiency and boost control (X MR)
- Anyone use the HKS panel filter with the AP's map for it?
- need some help on tuning options...
- Do I Need To Flash Back To Stock...
- HBspeed on Socal
- CMD - Dynojet Combustion Management Device
- Evo X JDM Map! HELP!!!
- Shooting Flames
- P103 (or was it 107) MASS VOLUME AIR somethingsomething SES light :(
- CBE and Drop In Without Tune =?
- cable for evo x tuning
- cobb AP for 2009 MR?
- Safe to drive untuned?
- Boost Spiking/Cobb AP Stage 2?
- accessport vs. rre tune
- Need Help asap .. while reading Ecuflash error, engine stop
- Cobb AP: Can I...
- DTC Scanner for the x?
- EvoScan, Innovate LM2, and tuning the Evo X!! few questions help pls :)
- O2 Sensor Disable
- Someone want to test airflow check disable mod?
- Want to take my car to get tuned by an AP tuner... WHO near San Diego?
- Low-Load High Knock Explained
- problems after pushing the car a little
- There is official reflash for 53040007 rom?
- cannot get rid of knocks above 6000rpm
- how to Vibrant Performance O2 Sensor Spacer???
- Vishnu Tune
- **Is there anyone in Westchester, NY that can do a tune??***
- 2009 Lancer Ralliart CJ 4B11 (AuDM, OzDM, AusDM, Aussie, Oz)
- Recommend shop? Initial research...
- gains from Aftermarket Exhaust
- 09 evo x. Cobb ap vehicle not supported issues
- Evo X & E85?
- injector scaling for RC 750?
- Is a 4.2 second 0-60 normal for this tune?
- Need Definition File for JDM Evo X
- Latency & Scaling for DW 800cc for COBB AP???
- Custom E-Flash For EVO X
- We are at it again!
- SES light fix?
- Knock when slipping clutch from a stop? Up to 6 knock sum at 1200 rpm's
- Perrin Stage 1 92+ w/ 91oct?
- Stock log
- Has anyone blow an engine with the Cobb AP stage 1 or 2 ?
- Tuner near WV?
- Knock after shifting to next gear
- reflash problem on Evo X GSR JDM version .. Help .. Thanks
- Xo2 racing? Anyone heard of them?
- What kind of TBE do you have for your X?
- Ecuflash reading prolem
- EVO X HKS FCON PNP Harness: FINALLY
- Headers
- Cobb AP w/ Cone Filter
- someone with a SST test something for me
- E85 mileage question
- after tune
- Greddy Oil Catch can placement....help!!
- Stock evo x mr using dataloglab...
- Evoscan + AEM UEGO
- Testpipe+Downpipe+Dropin airfilter(Without Tuning)
- ECUflash "ECU options" What do they do?
- Conditions for ECU to switch from High to Low Octane Maps?
- Tuning basics for the X
- While trying to play with a GTR
- nvidia n1 exhaust
- Evoscan WB log ?
- New to the community
- Anyone adjust the stationary rev limiter..?
- $400 what to get?
- How can I get more power from a stock car? What timing are you running?
- COBB Stage 2 vacuum hose diameter
- Anyone know who has the AP on sale
- Warmup and Aggressive MIVEC Maps
- How to make 300/300 on Evo X?
- Lost both smart keys
- Torque limiter #1-#4 in ECUflash for EVO X MR
- P1235 code after tuning... need some help!
- Stock Cat with Catback Exhaust and Stage 2 AP?
- Flash Tune in Winston Salem area
- If I have aftermarket already installed with AP work ok ??
- 15K service w/ reflash problems?
- Disable DRL in ETACS
- Anyone use the new AEM Needle style Wideband gauge yet?
- Boost Spike @ 4+ 2nd 3rd 4th gear.
- dyno tune vs road tune
- Modded EVO X's, normal to smoke under WOT?
- How does my log look?
- Cobb Stage II AMS Map, AFR's 12+???
- New ECUFlash 1.422595
- P1241 CODE questions
- Altering X and Y values in EcuFlash
- Ecuflash error on X
