- Can't hold boost above 7k rpm (evoXGSRefr7670)
- Aem failsafe wideband install
- Ecu not responding after Cobb flash.. Help!
- Need some help with ots map`
- Cobb AP not showing Live Data after Flashing Stage 1?
- Exo X tuners in Phila, Pa area?
- Having an abnormal sound coming from my Evo X MR engine. Thoughts?
- Built Eng/High HP/Cobb AP/late Gen X
- Afr is constant 11.4?!?
- HKS F-Con
- Where did the cobb ots maps for AMS CAI+CEBCS go??
- Southern WI tuners?
- evo x mr tuning questions
- 2008 Evo X MR tuning with the ets o2 dump problem
- Evoscan not logging
- LC-1 wideband stopped working, crazy gauge readings
- Oxygen Sensor
- Accessports from Cobb Tuning, views and ideas?
- Stock tune: Intake vs Fuel Trims
- Any one fitted a K&N typhoon filter?
- looking for EVO X BPV
- cobb accessport and tuning ?
- Cobb vs Grimmspeed 3 port boost controller
- need help engine is jumping on low rpm
- Question about evoscan
- Which one?
- Problem after english racing tune
- Aem failsafe guage with tactrix openport 2.0
- newbe question about closed loop control
- 2013 gsr tuning tool?
- Is it safe?
- 2008 evo x mr tuning question!!
- Anyone have some good feedback on the Cobb AP???
- Innovate LC-1 (No gauge)
- ROM inquiry. Help! :(
- Am I running lean 32 mpg
- Test & Down pipes
- Cobb AP
- How do I log afr / boost / and knock
- P0170
- Perfect timing
- Help with open loop
- ECU FLASH FOR 2012 Ralliart?
- Need factory base tune on a modded car being returned to stock.
- How to start tuning my Evo X
- Logging A/F using AEM Analog Wideband question
- whats going to blow up first?
- Will r35 ID1000 fuel injectors fit evo x
- Looking for a custom Evoscan tune
- Drop-In Filter / UR Test Pipe Requires Tune?
- Swapping ECU
- Oxygen Sensor - Intermittent Check Engine
- DW or Walbro?
- Cobb AP ?'s
- Can't get TPS 100 using EVOSCAN
- Engine noise while idle
- P011C and C2500 Error codes!
- Does new intake and new uicp = new tune?
- MAF can be replaced with a resistor
- ID or RC Engineering injectors?
- COBB AP for 2010 MR
- MAP or tuning issue?
- Battery sign Blinking HELP ASAP!!
- Need All tuners/ cobb people to help me!
- Best Tuner in Wisconsin? Opinons?
- EvoSCAN BOOST guide
- Newb here, at what point do I need a tune?
- Where to tune near me?
- could my car be set up for e-85?
- EVO X MR Blitz Advance Power Induction Kit
- Engine Code P0017- Cam Sensor
- Etacs system error
- Warming up engine
- How safe is my car right now ????? AMS. turboXS
- Downpipe-Back Exhaust
- Recommend turbo for 400/400 on stock block plus pump gas
- ACD-tuning
- What is this code? P0012
- Analyze logs: Boost and Knock Issues
- Cobb AP Problem
- evo x turbo upgrade-tuning
- 08 mr bolt on questions
- Please help with P0107 P0108
- EvoScan Logging Parameters
- Car wont start after errored reflash
- MR Issue
- not sure about this one: p0138 and p2253 ...
- EVOX - stock ECU Deatsch Werks injectors
- Strange CEL Codes
- Installing parts & Professional Tune..?
- 08 evo x upstream and downstream o2 sensor same?
- evo 9 stock
- bad ecu please help before I buy one
- 1000cc injectors good for 550whp on 93?
- AEM Boost & AFR Gauge
- Tuner needed possible recommendation on EMS
- Virtual Dyno help
- Evo IV OBD2 Scanner
- After market ECU and SST
- E85 to 93? How to?
- Is there a factory tune?
- How much should a Pro Tune cost?
- AEM Serial Dataloggin issue with ATR - reading 0.00
- Speed density tune for EVO X
- New Data for DW Injectors and Pumps (Battery Offset Included!)
- My car died while idling.. ????
- Body Control Module (BCM)
- Boost Cut Issues
- Is upper and lower intercooler piping worth it?
- Cobb Beta Program
- Issue
- Noob question about wideband AFR sensor
- Re-tune for LICP?
- ? About 3 port & tune
- Ralliart ECU into a GSR?
- Need help with a Tune!!!!
- DIY stock tune?
- U0100 and P2052 Need Help PLZ!!
- New tuner, need some advice.
- Warm motor starting issues
- Tuner needed
- SST experienced Tuners in Florida?
- Please help with Tuning Question
- EcuFlash vs AP
- need advise how to go back to stock Evo X SST MR 09 ?
- afe intake map?
- 2011 Gsr stage 2 injen map over boostin
- Throwing Exhaust Cam Sensor Code
- Question about 3 port solenoid and altitude
- Check engine light on w/ weird information warning on screen
- sticky wastegate ?
- Help a noob out...boost spike vs over boosting
- Could use some help!
- Rear 02 CEL's on 2011 and up: Test Pipe and Cobb
- Cobb can't tune my 2011 Euro spec Evo X :(
- mass air flow issue? or tune issue?
- P1320, and P0420! need help
- Adding Catback Exhaust - affect on tune?
- Good Tuner in CT/New England Area?
- BakaUnchi Tuned
- Over boosting - Mechanical or Tune | please help
- Looking for a tuner
- I need a good tuner - help
- TPMS can be turned off!!! (thanks Vadimus for help)
- Stock oil level sensor in the oil pan
- 5th gear flutter/stutter under throttle after tune
- Effective Compression Ratio
- blobits? what are they?
- New to the Evo, can you point me in the right direction?
- 1st o2 sensor throwing a cel
- Evoscan on Andriod Nexus 7
- Tune help and questions? built engine power
- tubular manifold
- P0140 code
- Need Help with tuning EvoX 1200cc injectors
- Tune
- Logging with Innovate MTX-L in Evoscan
- WANTED: Reputable tuner in NorCal/Bay Area
- Reputable tuners in New England
- I need help with tuning with respect to constraints
- Cold start problem with Walbro400 & FIC1100
- AEM wideband completely stopped working
- Are 3 port boost controllers tuned the same?
- Turbo Timer
- Boost pill
- NEED help 2011 gsr tune
- Who tunes partial throttle really well?
- Leaning out at high rpm in hot weather, then back to normal?
- Bought an Evo.. where to get tuned on Long Island?
- Cars been sitting... what fuse do I pull to turn the engine over without starting it?
- Running perfectly then it started knocking
- o2 Adaptor for ARK MFD2
- Cruise Control
- Which ECU to choose in evoscan for 2011 evo?
- Tuning for tire sizes
- Run out of fuel pump and injector
- Slightly lean and knock
- EvoScan Crashes, Fatal Error, wtf
- 1000cc injector = Retune?
- O2 Elim TBE + Drop-in Filter = Tune ?
- MBC Uninstall
- Timing Chain Learned Value
- engine immobilizer disable?
- IveyTune Or EFI Logics
- Passing Emissions
- Resetting ECU question
- LTFT during cranking?
- GUI Scaling Wizard Desktop App
- MAPerformance 1000cc PNP injectors; Scale & Latency numbers!
- a plea to programmers
- Tuning Questions
- p0098 WONT GO!
- adjusting boost with a MBC
- Innovate MTX-L problem
- P1235 code!
- Is this safe to run with just an intake and exhaust?
- ECU pin out help please
- Knock at top of RPM part 2
- Tuning advice - protune or not?
- P3520 Code
- Noisy Exhaust
- OverBoosting and / or Underboosting, whats missing?
- These numbers do not make sense...
- Stock Fuel Pump Limits supplying a Surge Tank
- Newb wanting to tune
- Jerk and knock at WOT
- Which ams tune?
- 11 GSR Multiple Map Flash
- Knock at top end of RPM
- Looking for Evo X ECU repair experts
- AEM Uego issue, hear me out. Video included
- Best Intake for gains without Warranty Void!
- AMS cold air intake doesn't fit
- EvoScan Log Parsing Tool - Source Code in C
- Logging Motec PLM w/evoscan
- Need tuner help!!
- Road Race Engineering
- Is there a OBDII Force pass for Tephra V1, rom: 55570106??
- stage 2 cobb, perrin, or ams?
- Fuel to air ratio for 11 and 12 Evo X
- Who can tune me today?
- Strange issue with 2009 Ralliart. Input/advice please?
- Question for a DV softer spring and it's leaking problem (I need an expert).
- Should I tune my car? Ecu remapping
- Power FC - car won't start
- Evoscan GPS
- AFR during peak boost, need someone to help point me in the right direction
- Question about boost peaking
- Tamioka Header?
- Unknow rom
- Boost spike over 30lb on my 08 evo x need guidance
- Running Lean??
- first time evo owner- what is this?
- Innovate LC-1 logging AFR via ECU
- Power Cut/Lean at 6.5k rpm
- What is wideband?
- Can't log for the life of me!
- EVO Transfer Case
- WANTED street tuner in South Florida
- Whats in the Box? Professional Tune.
- Att: Delano Evo tuner
- psi and inhg?
- What would you do with 2 grand?
- Bogging down on highway
- Anybody got a 2008 MR MIVEC map?
- Hopefully useful Excel sheet
- Resistor to replace stock o2 sensor?
- break in tune
- 96 Evo IV rpm drops
