PDA
View Full Version : Evo X Engine Management / Tuning Forums
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14
  1. Problems after AP Stage 1 Reflash
  2. HELP - ADC Memory Address
  3. New to Evos. Few questions
  4. Overboosting after dynotune!
  5. Speedo is not working
  6. Dyno question
  7. Evo X stalling and hard start
  8. Opinions car running rich and AMR Performance
  9. Estimated power with these mods?
  10. Squeaky whine noise in high rpms?
  11. Tephra's timing chain reset tool
  12. Evo x MR and cams...
  13. Not holding full boost until 5th Gear?
  14. Phoenix AZ area Tuners?
  15. tuning recommendations in texas
  16. Timing Chain Reset App
  17. service light on after COBB AP install
  18. Reflashing a map to the ECU
  19. Ethanol
  20. Need help with 2015 Rom
  21. e85 or not with bolt ons
  22. Did I get a bad tune?
  23. ETS Intake
  24. Which ots map?
  25. Who would you recommend for tuning/dyno in SoCal?
  26. Too much knock?
  27. Chicagoland Tuner Recommendation Needed!
  28. evo x high flow cat installed car picks up slower :(
  29. P0137
  30. 2009 AUDM Evo X - Original Rom ID? / Small SST "niggles"
  31. How to Check if my car has a tune?
  32. new motor and still issues
  33. Cold Start Hesitation on E85
  34. [NOOB] Cobb AP stage 1 ACN91 + CHFF log
  35. Cobb AP + cosworth filter
  36. boost numbers off please help...
  37. dumb question but
  38. ECU will not learn new timing chain value
  39. CBRD Cobb Tune vs Open Source
  40. Evo X MR ASC
  41. NEWBIE to mods, PLEASE HELP
  42. Evo X flex fuel tuning on Accessport
  43. I absolutely LOVE this setup!
  44. how much timing r u guys running?
  45. EVOSCAN AEM wideband logging help
  46. What is really giving the car throaty exhaust backfires?
  47. Sakura street exhaust with TP, driving untuned question
  48. Stock Muffler Mod for 2011 GSR
  49. FP Red and supporting mods tune question
  50. Lean condition advice
  51. What is better for 1 st stage
  52. How to disable TephraXMOD's cruise control map switching feature?
  53. OEM solenoid with no pill
  54. Getting ready for a tune
  55. E85 tune. Lean/rich when +/- E85
  56. Power not like should be - help appreciated :)
  57. Need stock ported manifold
  58. Tune, or E-Tune?
  59. 4b11T combustion burn speed calculator / tuning tool
  60. Overboost/Loss of Power/Car emitting Smell
  61. My Mechanic Made Me Paranoid
  62. Evo X which EMS ?
  63. Flat torque across the rpm
  64. What really is safe for SST and stock block?
  65. 2008-2013 Mitsubishi Evolution X Cusco D1 Roll Cages (original from Japan)
  66. I want to build my top end what's most important?
  67. Noob AP Table Question for ProTune
  68. Anyone have ROM 55580010 or 55580009
  69. Used Evo X - Does it have a tune? 8K RPM rev limit :/
  70. Need a tuner
  71. Need a tuner
  72. WGDC Correction issue?
  73. Noob accessport question
  74. Newbie question with tuning and bolt ons
  75. Passing Smog with economy map
  76. Assistance TUNING fuel curve ASAP !
  77. Need advice on ebcs issue.
  78. evoscan ecu confusion.
  79. Replacing Narrow O2 with Wide O2
  80. Evo X problems
  81. Map EF4 Very Low Torque, need advice
  82. P0172 - Help Understanding Freeze Frame #'s
  83. my tuned evo
  84. noob question about timing
  85. Couple of newbie questions :)
  86. Evo x not listed in vehicle selection, please help!
  87. Latest Base Map SES
  88. populate menu EvoScan
  89. Virtual Dyno attempts
  90. Injectors
  91. problems starting while on a slanted driveway
  92. launch maps tephramod
  93. E85 or C16 race gas
  94. Used Tactrix wouldn't connect then it did
  95. new to tuning
  96. What are good numbers for monitoring.
  97. 2012 X - Tephra mod for dual maps available?
  98. Car is stuck in Program Mode?
  99. Extreme Power In a EVO
  100. Want more power for 2010 EvoX MR
  101. Stuck in open loop
  102. hesitation on cold start
  103. Help Me Reach 360WHP
  104. Idle issue
  105. Question about Cobb Stage 2 + tuning
  106. Used Car: is my car already tuned?
  107. Missing a lot of oil.....
  108. What Next (2)
  109. check engine light
  110. Do I need to tune?
  111. Dealer flash ECU on 2008 MR USDM without consulting me- lost tune
  112. Do I need tuning after small downgrade?
  113. Strange Boost Curve
  114. COBB map question
  115. Mode 23
  116. Tuning Question
  117. New to this need help
  118. John drenas
  119. P0139 and P0140 SES - Emissions
  120. Stage 1 and 2 Buschur Package or AMS STX400 Package
  121. Constantly throwing P0137
  122. ASC Service Required light
  123. Upgrade boost on stock turbo
  124. Resontor or Muffler
  125. Tuning Shop
  126. Exhaust help
  127. Best Tuner in CT
  128. Cannot get rid of P2096...
  129. Salvaged Evo X, do I need stock retune?
  130. exhaust and AP tune question
  131. Bolt on questions
  132. Buying Evo with bad air/fuel timing?
  133. Wastegate Flutter vs Compressor Surge
  134. p2253 this morning.
  135. Is there a way to make the evo x flex fuel compatable.
  136. Quick question about tuning.
  137. P0016 code
  138. Cobb accessport help
  139. O2 sensor Evo x
  140. U0167 - Whats the REAL reason for this code?
  141. "Bucking" issue. Any fix via tuning?
  142. ECU Locked/Cobb Question
  143. AEM UEGO logging help...
  144. 14 MR with Aem + CBE Datalogs HELPPPPPPPPP
  145. Tunes and emmision testing
  146. Will COBB Stage 3 void my warranty?
  147. Connecting Innovate LC-2 Wideband O2 sensor to factory ECU
  148. Chicago/Ohio Tuning Shop Decision
  149. Bought Used Evo X, Things seem out of place
  150. Stock Evo X GSR Timing Map
  151. HKS F-Con Pro
  152. Tuning needed for Mileage?
  153. ASC light on
  154. Advice on AP
  155. Cobb AP & Pro Tune?
  156. New owner/ General tuning questions with th MR
  157. Boost solenoid hose part number
  158. AEM/K&N Hybrid with AP
  159. Radium Engineering Catch Can
  160. Front and Rear O2 settings (voltage)
  161. BOV Flutter
  162. Garrett's 714 AWHP / 538 AWTQ Evo X - Mustang Dyno - Boostin Performance
  163. Grimspeed 3 port tuning?
  164. Idle Racing after tune
  165. New Sparkplugs
  166. F-con Vpro vs AEM infintiy
  167. e85 tuners in chicago?
  168. How much power will I make on a Mustang Dyno with a Evo X running E85?
  169. Need advice on tuning!
  170. Tuner review on my new 2014 Evo X
  171. 2014 gsr rear 02 wire colors
  172. Advice needed for newbie re: mods and Cobb AP
  173. minimum e85 setup
  174. P0420 code
  175. Cobb AP different #'s than AEM gauge
  176. first mods 2014 evo x gsr INTAKE?
  177. Exhaust manifolds
  178. Emissions check OBD Error - help
  179. Engine revving ''faster'' than normal
  180. Phase 2
  181. Grimmspeed 3 port is garbage?
  182. cobb stage 1 v403 idle question
  183. Looking for 340whp after Boltons?
  184. Logs from EF4 Built X - !!!!
  185. Looking for more power which turbo next?
  186. Norcal Tuners
  187. bogging and backfire at wot 2k rpm
  188. using evo cobb ap with wrx
  189. Installing turbo before tune?
  190. Innovative LC-2 not working after hitting dip
  191. Need an E-Tune
  192. Evo X overboosting
  193. What is ODBII code P35E0?
  194. ASC Service Light? (Searched)
  195. Tuning and Dyno result question.
  196. Stock 08 GSR, loss of power in high rpm
  197. Relay question
  198. CEL flashing uncer boost
  199. 2010 usdm 55570006
  200. Help please. 2009 Evo X MR Map
  201. Problem in data logging au evo x mr - data missing
  202. Accelerator pedal position sensor for pedal box.
  203. FIC's new 1650cc high-Z injector review
  204. TPS Logging issues
  205. Evo X Build?
  206. Help E85 timing
  207. Evo X ECU VIN and immobiliser reprogramming
  208. How does my log look?
  209. Best Evo X tuner on the east coast?
  210. ECU Flash after intake
  211. just got a 2011 evo gsr. new buyer! needhelp!
  212. ASC help please
  213. Fuel Pump for MHI 18k on E85
  214. upgrading fuel system
  215. maintenance required light
  216. New here just a couple questions
  217. Silver 08 GSR NJ Paramus Mitsubishi
  218. P0403, p0090
  219. Help with Fuel Map
  220. Cobb Stage 3 impressions requested
  221. Serial-to-USB - Acroname S27 Adapter
  222. injector question
  223. tuner recommendations
  224. Thoughts on my Logs
  225. Built block/ ~500 wtq --- longevity and maintenance
  226. EVO Stalls
  227. AEM UEGO wired directly to usb?
  228. 2014 EDM EVO X definition file - 50845084
  229. My tune is killing my car. Halp!
  230. Zeitronix Analog Output Serial to USB
  231. Deatschwerks Injectors
  232. Flat Foot Shifting
  233. Engine over boosting after going back to stock??
  234. Tial QR Bov without ams licp?
  235. new to EVO X
  236. help please
  237. Car feels jerky after full throttle let off 2-3rd gears
  238. only 16psi. any ideas
  239. Can someone take a peek at my data logs?
  240. Cobb Accessport with Aftermarket downpipe ?
  241. 2012 evo x tune
  242. Installed Cobb V403 got some logs
  243. Type of tune? Further Suggestions/remarks/help?
  244. ecu swap
  245. Help!!!
  246. Is there a way to tell if the ECU is bad?
  247. P3420 code
  248. ams stx300 tune
  249. Tune Advice
  250. TUTORIAL (Step-by-Step) - How to check your timing chain (Lancer 08 / Lancer CY0/CX0)
