PDA
View Full Version : Evo X Engine Management / Tuning Forums
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14
  1. lancer 4b11 cvt transmission sport mode
  2. impotrant about tune stock ecu 4b11-4b12 n/a
  3. Tephra Brake Switch Patch
  4. "Antilag" on stock ECU works!
  5. Tephra / Spark cut patch not working
  6. Mitsubishi Lancer Evolution X 4B10 (ECU Part No. 1860B204) BIN File Share + Request f
  7. Looking for TephraMod XML for ROM 56870008 (Evo X JDM)
  8. Tune for E85/91
  9. EcuFlash unknown rom need rom definition
  10. Original File
  11. I Need HELP 54550007XML
  12. Dwell tables for ecuflash?
  13. 93 octane to e85
  14. Standalone ECU Recommendations for Evo X
  15. Need tephraxmod v2
  16. Ralliart ECU not changing vin
  17. X Inection Timing or Phasing, Stock ECU
  18. xml definition lancer gt 2.0l
  19. adding brake pedal switch for tehpraxmod v3
  20. Custom Car Modifications?
  21. 2008 lancer need help with DTC off
  22. ECU Cobb Retune
  23. P00B8 code
  24. 17 counts of knock, 105% injector duty cycle at autocross
  25. Reliable EGT sensor manufacturers
  26. How much will replace the Steering rack in my Evo X cost?
  27. What happen to my ecu?
  28. reserve tank issue
  29. Problem some time with idle rpm
  30. P0171 System Too Lean Bank 1
  31. Innovate ECB-1 Logging to EvoScan
  32. How to tell if your ccv or pcv valve has gone bad?
  33. R35 coils on EVO X
  34. Evo X Camshaft Scratches
  35. Need tuning shop?
  36. XML needed for 52360016
  37. remove rev hang and use AFR sensor at rear o2
  38. Bad Warm Start until Closed Loop
  39. Repinning the ECU harness
  40. Lancer VRX spark cut launch control compatibility? EDM/AUDM 53770004
  41. Ecuflash help
  42. Break-in Tune or not?
  43. ETACS decoder program file
  44. ETACS Decoder Project Shutting Down
  45. Rpm drop after complete stop
  46. help with ida pro
  47. Benefits of link ecu?
  48. P420 Code
  49. Changing the VIN Number on KOS ECU
  50. Ralliart MAF work on an Evo X?
  51. Oil return route
  52. HELP: Need archived OTS Stage 4 Map
  53. 2014 Evo X MR Stock Map
  54. Seeking ecu stock rom and map files - 55580010 & 55580009
  55. OBDII Help
  56. p0420 Code after tuning with HFC
  57. Big cam big head tuning
  58. Fuel Pressure/Oil Pressure/Oil Temp Logging
  59. Tephra response time on online orders ?
  60. Evo X tuning evaluation
  61. Looking for help with previously tuned vehicle
  62. AFR All over the place
  63. Starting the build
  64. Lancer Ralliart 53600017 Def
  65. Lancer Evo X 2013r No crank and no click relay after rebuild engine
  66. Dyno tune
  67. Recently bought Evo, boost seems high...
  68. Need Motec tuner in SoCal for Evo X.
  69. AEM Wideband not matching displayed value in Cobb ATR
  70. Evo x vacuume lines mixed up?
  71. cranking on E17 a problem
  72. Evo X WOT Fuel trims
  73. 2.2 stroker idle help
  74. evo x rough idle and dies quickly after
  75. Looking for Cobb OTS map, and AMS intake map download
  76. Driving cross country from utah to nj need help
  77. Updated definitions for 56890013/56890014 (inside)
  78. Evoscan 3.0?
  79. Powertune Digital dash for data logging
  80. STFT wont log below 0% in evoscan
  81. USDM 2013 SST 59590005 Tephra V3 barometric sensor scaling
  82. Remote Tuners Familiar with EMU Black?
  83. CEL Flashing, No Knock
  84. NEED HELP!!! Evo X stays in overrun after shifting gears (-10 ignition timing)
  85. HELP WANTED code p0171, p0463, p0183
  86. PassThruCAN issue: Unnecessary reprogramming on flash
  87. Flutter/power loss 4-5K rpm
  88. Diff / Tcase control
  89. Are all EBCS created equal?
  90. Can't Read Rom from evo x
  91. help logging JDM ROM Evo X
  92. Help with tuning TephraModV3
  93. ECU Questions / Hesitation / Problems /Help Requested Please
  94. Code P0171 help
  95. wont start after flash
  96. Cobb Stage 2+ chff lwg overboost or normal
  97. 58010105 definition
  98. Help needed: definition for Evo 10 2015
  99. Self tune help
  100. P0140 on tephramod v3
  101. ecuflash DTC's
  102. Cobb accessport tune
  103. 2008 evo gsr cuts out and spuddering around 3000rpm
  104. Evo x ECM into ASX 2.0 4wd CVT bolt on turbo setup.
  105. Engine code P0247
  106. AEM X series gauge issue
  107. Bare minimum for Cali smog test?
  108. Colorado Springs- Denver
  109. input voltage to MAF?
  110. XML for 50855085 EDM 2014 SST now available
  111. LC-2 Wideband logging through Evoscan
  112. English Racing remote tuning alternative?
  113. Lots of Evo X EvoScan questions
  114. 05 Lancer Ralliart Cold Air Intake Issues?
  115. 56940014 or 56940013 ROM Definitions and mode23
  116. Motec Acd Ecu
  117. First tune
  118. Grinding noise when off the throttle
  119. Sd conversion Evo 5
  120. MR/ SST Tuner NC and surrounding area
  121. New Engine, Lean Under Load w/ No Boost. (ALSO only ~9 PSI max)
  122. Is EvoScan Dead?!?
  123. AWD Service light after lower IC and 4” core upgrade
  124. GTS question
  125. Lean under boost during peak
  126. Cobb accessport
  127. Inquire ROM ID 53040007
  128. EvoScan wideband setup
  129. Tuners in the South/Southeast?
  130. XML Definition
  131. Is operating without a retune dangerous in my case?
  132. Newbie Here: Cobb Tuning
  133. Help! Diagram needed for replacing oil pressure regulator
  134. Fuel cut on decel
  135. MIVEC by gear? Whats the theory behind it?
  136. Helper Tuner Software
  137. Bricked!
  138. Evo 10 RS (no ayc) Mapping file and Etacs Kon File
  139. Looking to get a tune
  140. EVO X problem 4WD after changing settings
  141. Hello, everyone. Please let me know the setting of POPs to make my car easier to driv
  142. live tuner no funciona
  143. Remote tuning
  144. Boost Controller
  145. WTF happened!? / Codes C121C, C1219, U0100, U1417
  146. Light weight water pump pulley evo x
  147. Tuning for ECU with ID 50850002
  148. Coil pack #1 not getting power causing misfire
  149. Basic tuning help
  150. P0007
  151. ISO South Carolina tuner for evo x MR.
  152. Help
  153. 4 Bar Definition for 2015 MR
  154. Evo x lean issue
  155. Looking for Evo X tuner in GA
  156. ECUMaster ADU Problems
  157. Wasatch Tuning Factory closed?
  158. Tuning
  159. What's everyone using?
  160. 2010 MR with some mods
  161. Trying to bench ECU, "no response to any known code"
  162. Evo ECM Vs Ralliart ECM? Need advice
  163. New to Open Source - Looking for Clarification
  164. EvoScan won's log fuel trims
  165. evo x 2.2 L
  166. multiple lost communication in different module
  167. Expected boost taper?
  168. AEM wideband wiring help....
  169. EVOSCAN 2.9 opening issue
  170. Evoscan definitions for 2014 EDM GSR
  171. No signal from pin 112 (AUDM GSR)
  172. MAP Sensor & MAF Code
  173. AFR Leaning Over Time
  174. Changing Dash Display Logo/Splash Screen?
  175. ThephraV3 bricks ECU
  176. Help, my buddy ecu got bricked by low voltage
  177. How To Unlock ECU????
  178. Uknow rom ID, FF FF FF FF
  179. SST BILLET TIMING CHAIN reviews?
  180. Help Setting up ID1050x
  181. Some recalls
  182. How aggressive with tune?
  183. Losing Fuel Pressure and Missing Under Boost
  184. Does this log seem normal?
  185. Of cruise rich condition
  186. Oxygen Sensor not ready
  187. AEM UEGO display
  188. Max hp and torque
  189. Old plug, thoughts on wear
  190. Running an AEM Intake without the top cover?
  191. First time Tuner !!!
  192. What ROM Id is this?
  193. AMS 2.2L stroker short block/ engine Experiences?
  194. Open Loop/Idle AFR wander
  195. Pre-existing Tephra
  196. Will Installing a CAI be a bad choice for one of my first mods?
  197. Somebody give me a raw 56910009. Bin? Thank you
  198. Fuel Return Line Connection Help
  199. Flex fuel
  200. Tune in Vegas or drive 4 hours to 5150
  201. What should I expect to see power wise
  202. Help. Can you give me a complete map or code? Thank you!
  203. Can someone provide the internal circuit drawing of ECU? Thank you! Evo X 1860
  204. torque app logging omni 4 bar?
  205. AFR rich then stoich when stopping
  206. Which 3 port boost controller to use
  207. Stock ROMs collection (?)
  208. Need help with intake options
  209. Tephramod
  210. Tuning fuel question
  211. New to tuning think I'm figuring it out
  212. ecuflash
  213. Evo x Tuning - Help
  214. Tuning Help
  215. Decision making in NYC (tuners and parts)
  216. help with tuning, i went from motec m800 to original ecu
  217. just bought a evo x.. tuning, benchflashing, from motec to ecuflash :) help
  218. Repairing evo x in cleveland ohio
  219. Evoscan 2.9 logging with aem failsafe - rear o2 sensor connection
  220. What to do...?
  221. evo x gsr map
  222. Hello from Germany - EVO X and Scooby STI GDB (EVO Scan Question)
  223. 2015 evo x gsr catless options for echeck
  224. New 2015 Evo X Owner
  225. Love My Tune!!
  226. I’m new ! Here for some help !
  227. No Start - P0335 on freshly assembled car
  228. Help!! 80210122 XML?
  229. Help!!!!! Unknown Rom Image
  230. Aem wideband reads 0 on evoscan
  231. FID 1300 (fuel injector development) latency scaling
  232. Timing set to factory default while I had a stage 2 plus filter tune installed
  233. Zeitronix zt-3 narrowband output
  234. Bad tune?
  235. Tuned car, part change concerns
  236. More help with EvoScan please...
  237. Base map for boost pill
  238. 57140001 Tephra V1 ROM
  239. need help on first few issues
  240. mode 23 evoscan log help
  241. Help With 57140101 - Evoscan and Ecuflash
  242. Enable DTC/CEL Light?
  243. Going back to stock
  244. Hi, I'm new Evo X MR owner from Brazil
  245. North jersey O2 sensor not ready help
  246. EcuFlash/Evoscan Help!
  247. Evo x GSR help
  248. Lean spike/ stumble at highway speed
  249. Issues with EvoScan
  250. P0171 code popped up during city driving after tune.
