- Just got tuned...now I have problems.
- ATR - fuel maps
- Any Evo x MR's tuned on E85?!?
- Cranking Enrichment Address 52680015
- Remiving boost pill
- newb afr help
- Crappy Idle After Installing Bigger Cams
- zeitronix users - economy tuning question
- Recommended injectors
- LPG injection - AFR strange ....
- CBRD 3" New intake- and turbo build
- Cobb AP evoscan and mode 23
- Need Help! Tactrix Cable
- Need info cursed Evo x
- Spark plug question :]
- Clutch Installed, now my Tune seems to be gone?
- EvoScan GPSNav problem
- AP Cobb Stg. 1 with cone filter
- Flatline Rich Shifts (2010 Ralliart)
- Not being able to make more the 18psi!
- Access Port and ETS intake?
- Tunes for $$$$$?
- TephraMod Knock CEL threshold poll
- Noob starting with ecuflash, questions
- Stock exhaust
- CAN Mode 21 revealed
- Evo X Real CAN Packets
- Where did you learn how to tune?
- How's my log?
- Using Evoscan 2.7 for 2010 Evo MR
- ASC and 4 wheel drive issues...
- GSC S2 Mivec Maps
- Am I Running Rich?
- Question regarding tune
- Actuators commands MUT to CAN translation table
- Help reversing ECU
- Kansas tune
- air flow sensor
- ASC Service needed Light
- question about ecuflash and cobb ap
- Some advice for CAMs tuning
- Gas saving map?
- Need a little help with tuning
- S0S calling out for a lil help
- Direct Meth Injection for Evo X?
- Mustache March: We have a Winner!!!
- Wideband recalibration
- 3 port to EWG set up
- P0300 - just disable?
- Air flow sensor problem
- High Altitude Power Question(s)
- Cam phase TSB?
- Innovate LM-2 basic log to Evoscan, help
- how define "psi based boost error" formula for evoscan?
- APP/TPS Taper at WOT
- ARK MFD2 stock boost vs optional sensor
- DW 1000cc Injector settings - hard starts
- tuning near virginia
- help please ecuflash issue now car wont start
- How much $?
- .hex and .bin file types added
- Cobb AP on multiple cars
- evoscan navigator
- Evoscan Logging of Pin 8 voltage input on OP2?
- How to upload Cobb AP maps?
- Evo X Starting Issues
- EcuTek Question
- Wastegate flutters after Grimmspeed 3port install, why?
- Okay I am missing something
- Knock Knock... wtf is going on?
- Aquamist HFS-6 High Flow Water injection system
- Road tune Vs Dyno tune
- Anyone experiencing similar issues with COBB AP OTS maps?
- Little bit of knock normal?
- revs hanging
- Why doesn't my "RPM Per MPH Xover"-setting work?
- P0300 Random Cylinder Missfire
- Cobb AP compatibility?
- Tuner can't clear P0140 via ECU
- Tune in Tulsa
- Why does RPM go backwards?
- Problem on Read ECU
- Low boost problems
- Logging "Gear In Use" in EvoScan
- Needed tuning gauges
- IDC maxxed out?
- Can't Read or Test Write ECU - Error Log Provided
- Cobb LWG
- ASC system service req
- MacBook, Parallels and EcuFlash 1.43
- Want to know addresses of the lean spool tables
- Knocks at Low RPM & Load
- ecu flash not recognizing Rom file??
- Mail In Flash?
- Knock reported when hitting the rev limiter
- Can't pull rom on X after unmarrying AP?
- weird ****wittery with AFR and idle
- Do i not need tuning software to get tuned?
- Motec PNP EVO X??
- Full SD on X?
- Help on ECU swap WW to USDM SST
- ECU 3D map lookup and interpolation
- Need urgent help please!! Boost way too high!
- Absolute amateur looking for some tuning tips
- Mustache March!! Grow your Stache, Win an AccessPORT!!
- Any tuner with Zchip experience in Washington state?
- Anyone know where I can get a stage 0 rom I can flash
- Help wiring Innovate LC-1?
- Boost only @ 17-19psi max?
- Problems reading boost with Accesstuner
- Live tuning - User feedback question!
- ECUFlash can't read ECU
- Need stock Evo x MR map asap
- Can someone explain (timing related Q)
- Who would be interested in 1/3 timing increments?
- Where to get a tune in chicago area?
- EVO X SST no start
- A message from a COBB engineer
- Best Community(shared) Maps Available?
- fuel map changes
- Blaqops controller ?
- What could be cause this kind of knock?
- Error While Benching the ECU
- Meh, another monitoring question
- AP Vehicle Speed Wrong
- Part-throttle boost tuning (BWGDC & BTEL used?)
- ecuflash.exe has stopped working
- need confirmation for 53040007 maps: cranking IPW adder, MAF Scaling, Low Temp Timing
- Who can make dualmap for Evo X?
- who removed pin 9?
- Issues With the Cobb Tune
- new X owner from Cyprus, need guidance
- Break-thru: Reading Evo X ACD ECU
- Wideband Setup Questions
- stock solenold connector
- Cobb AccessPort 1.08 Maps
- Bad day worse?!
- Another happy AMS E-tune service customer
- Ecu's
- Help needed for Gear Based Boost Control
- deciphering knock on a built motor (4B11T)
- FIC1680s on an Evo 10
- noob question, how i can get up the boost?
- Cobb AP/ECUflash Question
- should i stick with current EcuFlash or get protuned AP?
- Evo X ECU Blocked
- what the hell is U0100?
- I am new here i drive EVOX MR i want to tuning and make friends
- Dyno Run on AP.
- AP on/off relay switch?
- Questions re: Setting AFR map with WB02, lean spool off
- ecu pins
- i can not read a evo X. Help
- Where to read up about tuning?
- Major Updates for Mitsubishi AccessPORT Firmware and AccessTUNER Race!
- 2010/11 stock rom flash for 2008 MR
- boost restrictor pill
- Better fuel economy in CRUISE
- COBB OTS Issues.. Please Help
- Can I log correct MAP at high load?
- tuning help needed
- How to make foglights stay ON with highbeams ???
- MAF Scaling for AEM Intake (box)
- Update relays....
- Part-throttle Knock on an 08 Evo X
- help with disable
- ECU keep track of being Flashes
- Problems dealing with Cobb
- Pull #9 pin on OpenPort2.0?
- Evo X No Crank No Start
- Pivot Tables
- Idle timing
- Can MIVEC alone do THIS!?!?! (Virtual Dyno inside with pics!)
- Difference between TPS, TPS2 & APP?
- Problems Linking to ECU
- Is there on OTS Cobb AP Map for my mods?
- Can you display Cobb AP on video Head Unit?
- After AP stage 1 smoke
- Choppy power band on stage 1 :/
- Wierd scaling when logging directly to microSD
- Got the tactrix cable... now what?
- logcfg.txt for logging onto microSD for ROM ID 53050009
- HKS F-CON V-Pro - Problems After Tuning
- AMS Tested Motec PnP Evo X
- P0243 wastage malfunction
- EvoScan-Select ECU & Serial to USB???
- Cheaper Tactrix Cable?
- royally screwed with AEM UEGO and PERRIN TBE
- Confused Newbie / Need help regarding Wideband installation
- rear 02 sensor ?
- Trouble codes with a hesitant evo x gsr 08
- Password JDM: UICP fitment issues?
- Knock on first part-throttle pull?
- Which etune?
- the clutch down map
- WBO2 sensor install question
- Help!!!! My X would go into limp mode!!!
- Cobb AP Screen dead?
- All of a sudden getting CEL 2096
- Cobb AP stage2+ AEM overboosting
- The perfect tune for 91 octane gas and whp numbers
- 53050006 to 53050011?
- Help Logging AFR
- Cobb ap question
- Cobb stages
- Stealership got me!!!
- Progressively Worse Misfire; Need Help
- SE model ... ECUFLASH or EVOSCAN problems?
- got a P0171, what should i do?
- Quick ?'s on buying cobb ap(searched already)
- Diagnose a problem. WOT and engine shutters.
- Traveling Tuners?
- Question: Cams or Turbo
- Help me get the most of my tune
- EvoScan 2.8 wont log using my 2.0 Tactrix cable
- dtc codes p0098 & p0365
- Works Brain Flash P2?
- car whistles @ idle and while moving.
- Trowing P0137, P0513, P0171
- Entering negative values in Igntion Warmup Retard table?
- Evap Map #1
- idle ignition advance
- The mysterious "U" in MRs and other problems
- going from 3 inch cat back to gutted muffler factory catback
- The watered-down tuning guide please..
- What RPM do you idle at?
- Evoscan Datalog Graph Help!
- post your 3 port wgdc settings
- exhaust makes consegative poping noises?
- MR throttle maps
- "Problem" in 1st gear - SST
- any free upgraded mivec maps for evo gsr
- lets talk rrm
- looking to start tuning... what hardware do I need for logging?
- openport issues
- clear service engine soon?
- JDM Evo X xmls wanted please
- Am i safe to run AP stage 2
- Anyone out there with a turbo timer on a evo x MR w/ fast key
- MR with manual boost controller; help me
- Issue Logging Wideband on RA
- 28 psi of boost with cobb stage 2 safe??
- car hesitation..
- 2011 EDM GSR definition file 56910007
- A better Speed log item
- How to connect to EcuFlash
- Anyone try this --> Bt OBDII Android scanner/monitor
- OH NOES... my tacho is broken
- OT - Valve lifter
- EVO X ECU connection.
