- ASC Service Required c121c c1290
- tuning for idiots
- Are OTS AccessPORT maps safe?
- HB Speed TUNE UPDATE.
- Need a tuner
- EvoScan GPS Navigator
- Is there a Tuning Option??
- Mivec Setting For Cosworth Cams (stock turbo)
- What do you guys think of these?
- AFR tuning theory
- E85 conversion question/help
- ECUFlash vs. COBB Accessport
- really bad knock all of a sudden
- When is a WB02 needed?
- 2010 EVO X AccessPORT Available Now!
- Harman Motive Intake - Messing MAF Readings
- KNOCK at low rpm's
- About to Tune - Keep OEM Parts?
- AccessPORT User Survey 2010
- Emergency please help !
- Any Tuners Close To Rapid City South Dakota?
- Datalogging Noob
- noob question on boost gauge
- ECU not giving the Timing you set it to ?
- Can the Access Port log data from a wideband?
- how to make knock sensor less sensitive?
- Noob tunner question
- Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
- Tuning impact on Canadian Emissions
- mode on wastegate actuator arm?
- ECU tune + upgraded solenoid??
- EVO X MR ECUflash Help
- Ecuflash Problem
- ECUFLASH: High Oct AFR Map will not let you lean out...
- boost problem
- Evc boost controller: Boost unable to hold
- Apexi Turbo Timer O2 Sensor Help?
- High IDC at 7k - stock turbo
- 09 Ralliart/2010 Evo X MAF scaling definitions
- EGT limit
- "service required" @ WOT after disabling asc
- Looking for 52360018 rom
- Help me make an economy map!
- ECU boost control
- Timing and Load Questions
- What do you guys think of my tune ?
- Quick noobie question...
- mode23... I screwed a buddy...
- NEED HELP with ECUflash
- How does the launch control actually work?
- Discuss: Disabling DTCs Yes or No
- reflash/tune
- Air Fuel Question
- Evo x mr
- How a LOAD is calculated?
- EvoScan 2.7beta5 weird problem!
- Do not change Max Downward WGDC%!
- What load do you reach?
- Viewing AP maps on excel?
- From Ferrari 360 to Evo X
- RE: Jumpy Idle
- AEM Meth Kit Failsafe
- AP lost/stolen, what to do?
- Evo X unable to read or write using Ecuflash
- Evo X evoscan amptracer
- Switched to AP stage 2... Mellon tune with no mods still faster..
- cobb ap or exhaust first?
- Got trouble with ECU for Evo X JDM
- New updated map for PERRIN EVO X AP customers
- A few small corrections in the 53600010 map...
- Limp Mode!?
- boost question about evo 10
- BCU+... any thoughts??
- F.....g Idle
- Accessport not connecting
- Cobb AP or Mellon Tune
- When will ecuflash or evoscan do sensor calibration on the tires?
- EVOscan.... customer service???
- Stock BOV
- Who's the best tuner for what I have
- COBB AP X MR Cold weather question
- AccessPORT EVOX Map Explosion!
- Service Required Help/SAWC not working
- Anyone has been able to get evoscan to work successfully with a 2010 MY
- O2 simulator
- my air/fuel look ok?
- MUT table address for 54070007?
- Ecu Reflash
- evoscan questions with 2010 evo x
- Cobb stage2-93
- ECUFLASH: Reactive Solenoid Maps: When do they interpolate?
- AMS tune???
- Help with zietronix software not logging but evoscan working
- Pulling and Clearing Codes
- Cobb AP compatibility
- Unstable idle
- How-To: DIY CAN Bus Cable
- Ignition Timing: Upper/Lower bound
- help with def-file for this rom
- Question about my ATR mapping
- Cobb AP: Fuel Economy Map
- Gauges needed for a turbo upgrade...
- When will Ecuflash
- Good software to check my Evo X's DTC?
- Replacing the upstream O2 sensor with wideband?
- Vacuum leak after install AEM intake
- Safe to install FMIC and LICP?
- zeitronix Zt2 or AEM wideband?
- 2008+ Evo X AEM EMS
- To Cobb Tuning...
- downpipe for the evo x
- Stock or tuned?
- 3-Port Boost Solenoid vs MBC
- 3-Port Bosst Solenoid vs MBC
- Wideband / Boost Gauge with a tune?
- Cobb Stage 2, TBE, Drop in and UICP?
- problem controlling boost
- Ecuflash and Ecutek
- evoscan problem
- curve smooth
- Following a trend... ECU Bricked...
- I want to log boost please explain?
- EvoScan Issue: SAVE AS window keeps popping up when analyzing logs? HELP!!!
- New Update and fix for AccessTUNER Race
- Minimizing Boost Taper at high RPM: Pill or WGA ?
- EvoScan V2.7 Beta 5 or V2.7
- COBB Stage 2 with catback and HFC
- Another Bricked EVOX ECU
- Need ECU for my evo x gt35r
- AP stage 2 question
- AP dyno log
- AEM intake ok with AMS base ECU tune?
- Need some help with reading stock rom
- Got P1870 after tuning, what gives?
- Dimensions of stock compressor-side boost pill?
- Decisions.... Decisions.....
- My car Hiccups!
- WGDC High Gear vs Low Gear
- Official Injector Scaling and Latency Values
- Where to buy 3 PORT Solenoid Harness Connector?
- misconception about tuning e85
- COBB AccessPORT Challenge!
- Stopping the fuel trims affecting WOT fueling
- Cobb AP: Best way to solve this without Custom Tune
- LTFT/STFT question
- Hesitating of course
- Quick AP question...
- What can you do with the Cobb AP?
- Tactrix not working, Help!
- DW 1000cc's injector scaling needed
- Question Regarding AFRs....
- Does anyone know how to fix/cause of my idle issue?
- knock problem - Cobb stage1 -93 map
- New to tuning, what is a good starting map or starting point?
- Difference between '08 and '10 GSR stock tune (ROMs 52680020 and 55570005)
- Tuning a 2010 JDM Evo X
- can i switch from 53040007 to 52360018
- Does the AP lock the ECU so ppl cant look at it?
- Help P0107
- Help, Cobb Stage 2 breaking up at high RPM
- Anyway to disable P0300 misfire after cam install?
- Has anybody tried this
- how to tune e85
- Help! COBB & ARC~~~~~~
- AWC Reflash = service light??
- Re-scalling maps
- Cobb Stage 2 Map and Perrin Stage 3 map logs.
- How long did you wait for your link to download COBB Access Tuner Race???
- Boost Solenoid Table for a GM BCS & MAC Valve...
- 2010 EVO X and Accessport?
- Cobb Stage 2 map stronger than Perrin Stage 3????
- Zeitronix widebank installation
- MIVEC tuning for aftermarket turbo?
- LANCER 2009 GT can reflash?
- Downshift Synchro Rev Control
- Internal EGR
- Cobb the way to go for my purposes?
- Perrin Ecutek ECU Reflash question
- Manual boost controller Question?
- Which ECUflash maps need to be changed for running bigger injectors?
- The vishnu map on a cobb accessport ? ?
- Evoscan beta software
- I want the latest factory tune for the mr help?
- Stock evo x ECU
- Wrong definition and address of some tables in the Ralliart
- Can EvoScan Be loaded into This???
- Locked ECU?? ECUTEK??
- EVO X b411t going into a baja, need help with ECU
- Largest scaling limit for Evo X injectors?
- Using ecuflash got a check engine?
- How To remove 120km/h ding-dong sound warning
- Rookie Evo X MR Tuning question and opinons
- Newbie question on Wideband - why would you want/need one?
- is this to much knock
- Which brand Boost Gauge is the best?
- Aspiring Tuner
- factory ecu map + fp red and boltons, will my car start?
- Problems using map tracer in EvoScan.
- Increased in boost due to weather/temperature changes?
- quick question about AP
- cobb_ will it work on other car
- Defi gauge showing 28-29 boost spike
- How to: Cobb tuner race bypass: Get atr to work w/o driver install
- Question about COBB AP Maps
- Mode23 help!
- Question about the ECU
- kelford stage 2 and 1241
- Hks ssqv3 evo x problems, help please!
- Bad Flash? Knock?
- ASC light still comes on after DTC codes disabled, any ideas?
- Cobb AP can only read up to 22.3 psi correct?
- Help me I need rom definition (xml) for EVO X
- ECUFLASH tuning Evo X with Mac using Bootcamp
- Dom 2.0 Early Impressions
- Finally got the evo x to the dyno
- Enabling mode23 question
- Need help / suggestion
- LM-2 with ecuflash & evoscan
- ECUFLash + Fastkey
- How better is an aftermarket ecu compared to ecuflash ?
- ECUFLASH: Which table/map do you modify to raise your idle rpm?
- (PICS) KNOCK when your LTFT's lean out...check it out
- Need URGENT HELP ! ROM definition needed.
- If you have a Cobb AP please read and respond
- Please Help, Bricked Evo X ECU via EcuFlash
- Tactrix Cable 2.0 - Who has em in stock?
- Question about Knock
- I need help! Looking for tuner in New England!
- looking for a good shop in the dc area
- car going into limp mode
- why is evo x not in ecuflash list?
- Flashing Cobb AP in Winter
- 2008 MR AMS tuned @ 303HP and 311 TQ
- Is it possible to modify your own stock map via Cobb ATR?
- Blitz SBC i-color A/F Box II Question
- TunerPro RT
- Disabling the boost cut?
- How to find that MUT table & others
- JDM Speed Limit
- ecuFlash noob questions
- Injen Intake Cobb AP Maps are out
- Boost Gauge q.
- GM solenoid question
- Two odd behaviors I have observed
- Injector scaling for DW 1000?
- Limp mode P1241 with big bore throttle body.
- Definition XML for 52360018 ROM ID
- Dangerously lean / Hesitation
- Boost psi peak with Cobb AP?
- Speed density
