Log In
View Full Version : Evo X Engine Management / Tuning Forums
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14
  1. Just installed ZChip, so now what??
  2. TQ limit Info
  3. Where can i find a good shop in MD?
  4. Need to tune again after FMIC install?
  5. What upgrades to get / remian a Daily Driver
  6. Ecuflash with a JDM evox rs
  7. Cobb AP Tunes...
  8. Evoscan question
  9. Jestr Tuned
  10. Cobb AP Digital Speedometer.
  11. Ecu tune in south jersey
  12. EcuFlash - Mivec Tuning 101
  13. Cobb Access Port review and where to put it !
  14. Anybody have the Stage 2 93oc Map?
  15. Idle problems...Will a Cobb AP HELP???
  16. Gems ECU for the Evo X
  17. HKS F-Con V Pro just put on my Evo X
  18. ACD error after ECUflash
  19. Evo X RS rom Ecuflash help
  20. MR with MBC
  21. ECU Reset Help ASAP
  22. ECU Flash on P1245 code
  23. Few tuning questions...
  24. Oil catch can Install help!
  25. tune causing engine light
  26. Just got the Vishnu reflash.
  27. ECUFlash 1.41 released
  28. Limp mode [merge]
  29. Oil Type Question
  30. Just had my ECU flashed by mail in AMS
  31. Zchip/ZT-2 installation questions
  32. Was there a factory reflash in the US?
  33. Remote Tuning Request
  34. AccessPort the problem?
  35. Tuning questions
  36. ap maps
  37. First Open Port 2 data logger released
  38. Innovate Wideband
  39. Someone Please Help me With my AP
  40. Software gauges: HKS Camp 2 vs Magden M.1b vs ...
  41. installing the Apexi AVC-R in my X
  42. drop in intake ?
  43. OEM reflash or Cobb Stage 1 for fuel/oil problem
  44. How well does a custom tune on the X work?? Look Inside!!
  45. How much power can be had?
  46. What is a Pill
  47. Tuning/ECU/Reflash
  48. Mivec advantage?
  49. anyone have a picture of the MAT sensor tip?
  50. OEM Tune Revisted
  51. Anyone know the locations of the intake air temp sensors?
  52. Stupid Tune Questions
  53. How does the ECU determine load?
  54. Disable Day Time Running Lights using Engine Management
  55. Poll: What intake maps for your AccessPORT? AEM avab now!
  56. EcuEdit logger don't see EvoX RS Ecu
  57. Z chip or Cobb Accessport for the X
  58. What kind of tune do I need for my current setup?
  59. HKS EVC VI mapping for EVO X SST
  60. Anyone know/found the speed sensor on EVO X?
  61. Evo X tuning day at Buschur Racing Mid January
  62. Want to tune but do I NEED gauges?
  63. How the Zchip works
  64. Perrin Stage 1 AP Map
  65. AMS Test Pipe.
  66. Is there any way to get rid of the annoying "rev hang" with a tune?
  67. popping??
  68. MBC boost peak settings for Evo X w/Zchip
  69. My Zchip on an independent dyno
  70. Evo X ROM disassembly/interpretation discussion
  71. I want to learn how to tune
  72. Tuning suggestions? Zchip or AMS tune for my car?
  73. AccessPort Accessmanager Stock question
  74. stock Flash
  75. To all X owners using the Profec B
  76. tuning question
  77. Wide band logging questions
  78. i need to tune my EVO X ? plz help me
  79. JDM MIVEC Map results?
  80. Cobb AP data log - knock retard?
  81. Optimal and maximum EGT levels for Evo X?
  82. Can the Cobb AP?
  83. AP from Dynoflash, did not receive maps (resolution in progress)
  84. Noob AP question
  85. Any way to tell if running too lean?
  86. Using Tactrix Cable to load Cobb Maps onto EVO X
  87. need help with evo x edm PLEASE
  88. CEL from overboosting on part throttle
  89. Purchasing a car with an Ecutek, want to reflash to stock
  90. Smoke
  91. ABS module working in an RS EVO X?
  92. HKS drop-in filter with AP...
  93. Tune recommendation
  94. Zchip gains in the MR
  95. AP, Evo X MR, stage 1 CA map, HKS drop in
  96. ECUTEK or Cobb AP?
  97. When to Tune
  98. How much boost can a stock turbo take?
  99. How Much Power Will The Stock 'X' Air Flow Sensor Handle b4 reaching max Voltage?
  100. Its cold and dry beware of static
  101. Cobb Access port question
  102. Beta Jestr Evo X tune .....
  103. Do we Still need an Intake mod with ECUFlash
  104. What's Cobb cooking up?
  105. Tactrix OpenPort 2.0 Connection Instructions
  106. Warranty Issues With Tuning
  107. ECUFlash I think I Bricked my ECU
  108. Suggestions for Access Port Evo X Install and Use
  109. EcuTek and Z chip compared on the same dyno
  110. EcuFlash 09 Ralliart tables Vs. Evolution 10 tables
  111. Aem Ems ??
  112. EVO MR Tune Q's
  113. bov/intake
  114. Problem With the MR please help.
  115. ECU flash- 91 vs 90 Oct- advice please tuners
  116. Cobb Tuning Access Port Is Now Available For The Evo X!
  117. Z-chip problem
  118. COBB AccessTUNER Pro for 2008 EVO X (merge)
  119. What parameters can be modified with EcuTek?
  120. Turbosmart E-Boost 2.
  121. Blitz SBC i-Color Boost Controller
  122. UpRev Tuning
  123. No immobilizer code
  124. AEM tru Boost controller question?
  125. ECU CANbus - bug found
  126. Tuning, Flashing?
  127. Launch Control....MR question.
  128. iPhone/iPod-touch OBD II datalogging?
  129. WORKS evo X flash
  130. Greddy Profec B 2 EBC HELP!
  131. evo x 1st mod
  132. Which boost controller do you recommend
  133. TT Help..
  134. Help! zchip installed + forge unos = 18psi
  135. Z-chip installed - Finally threw ASC Light
  136. Question about ECU Reflashing.
  137. HKS Releases VALCON II Controller
  138. Cobb access port
  139. Ecutek with ARC upper intercooler pipe lost power??!!!???
  140. maintenance - coolant 16k miles?
  141. HKS EVC VI Issues
  142. HKS Kansai Computer
  143. WORKS REFLASH looking for EVO X on 11/13 and 11/14
  144. WORKS REFLASH looking for EVO X on 11/13 and 11/14
  145. Tuning Technologies tuned my EVO X MR!
  146. Which makes aftermarket MAF housing for X?
  147. Which turbo inlet do you recommend?
  148. Custom and base map tuning @ Awd in So Fl this week
  149. Air Intakes vs Drop In and Intake Pipe
  150. HKS EVC 6 Installed... But..
  151. any mbc users on the x?
  152. AEM Cold Air Induction System
  153. San Antonio Tuning Event this weekend the 8th
  154. How do you install the zchip!!
  155. Real-time data logging?
  156. ECU and CAN bus pairing?
  157. Evo X gets Reflash by HB Speed
  158. AEM’s Six-In-One Gauge Type UEGO Controller. Has anyone used this?
  159. Turbo XS Knock Lite or anything else?
  160. What Flash should i go for? Or is it all the same?
  161. Uicp/licp
  162. The working flash 1.40 download
  163. How does the EVO x react to increasing boost?
  164. Works brain flash.
  165. WORKS Flashing on the East Coast
  166. evo x mr, will the trany and the car hold more then 400 ?
  167. ECUFlash 1.40 is out!!!
  168. Is AEM planning an EMS for the Evo X?
  169. Evo X MR Dyno Results
  170. WORKS drop in filter or AEM cold air intake?
  171. ECUTEK remote tuning?
  172. Basic Evo X ROM XML definition
  173. Evo X Dyno With Only A Cat-Back No Tune No Flash
  174. emanage ultimate
  175. R-VIT DS Data Link Station
  176. Thoughts on the HKS EVC VI
  177. Self Tune with Open Port 2.0 anyone?
  178. Cel
  179. Does EVO SCAN work on the X?
  180. Methanol injection tune ?
  181. AEM Air/Fuel Ratio Gauge - Is it necessary?
  182. AEM Connection Issues - Please help
  183. Blitz Throttle Controller
  184. Can Mitsu track ECU changes?
  185. ECUtek tuned or tuners & dtc's
  186. P1241 code + limp mode
  187. EVO X MR Buschur stage 3 results.
  188. AEM Tru-Boost Settings
  189. WORKS P2 helps score Targa Newfoundland victory
  190. RRE Ecutek Tune. Very impressed.
  191. Full Throttle = 87.8 %?
  192. Newb tuning questions
  193. Any reviews for Tuning Technologies?
  194. ECUTEK CAR w/ NO MODS goes 107+mph Trap Speed!!!
  195. Installing Buschur Stage II on the Robi Spec Evo X !
  196. How hot is too hot? Tuners please read
  197. las vegas tuning
  198. Tuning Trip to Buschur Racing in 2 weeks
  199. COBB tuning
  200. Boost spike?!
  201. MAF sensor problems!
  202. Evo X Plus Iveytune
  203. ecu flash or tune
  204. methanol
  205. Injector Update?
  206. Chicago Owners Club
  207. TurboXS Knock Light
  208. Any places for an ECU Tune LI NY
  209. WORKS P2 Mail-in Flash *Review*
  210. Any Evo X tuner between NM and Las Vages
  211. *Evo X Tune Near Utah/Idaho*
  212. ~~RRE tune 338whp/324lbft
  213. Evo X Gsr Mod/ Our Evo X Mr Mod?
  214. AMS Tune with boltons
  215. quick question
  216. my AMS tune
  217. uk evo x fq 360 at only 10 psi
  218. Tuning/Datalogging options for the Evo X
  219. Got my AEM intake..question...
  220. EVO X with WORKS P2 tune - dyno graphs
  221. My Ivey Tuned X
  222. HP differance a silencer makes on an exhaust
  223. test pipe...cel..!!
  224. Buschur EcuTek Tune: 289awhp
  225. Tuned by Ivey this afternoon...
  226. Evo X - Testing Performance
  227. More EVOX hYdra EMS info!
  228. Question for X MR Guys Who've Dyno'd
  229. Any Evo X owners in SE Washington want to help me beta test ECUFlash/Openport 2.0?
  230. Panel Filter Testing HKS Vs Works
  231. Blow off valve and Boost gauge question
  232. Tune w/ Road Race Engineering
  233. Denver Area Evo X tuners?
  234. AEM Tru Boost Tuning - Need some advice please!
  235. Phoenix AZ tuners
  236. Ams Mail In Flash ?
  237. Tuning and Shops
  238. AMS Tuned
  239. EVOX hYdra EMS around the corner! First EVOX standalone?
  240. waiting for a tune?
  241. Ecutek Tuning Guide??
  242. Help!!!!
  243. P1235 code
  244. Evo X MR - WORKS P2 Flash and Tune
  245. dealer ecu flash failed
  246. Stage 2 with Ecutek Tune from Sean Ivey
  247. MR tuning available yet
  248. Dyno4mance Tests Factory Reflashes....
  249. Evo X tuning day at Buschur Racing August 14 - 15
  250. Ecutek tune or mail in flash
