PDA
View Full Version : Evo X Engine Management / Tuning Forums
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14
  1. professional tuning necessary?
  2. 55570006 Definition
  3. Quick FYI If You Get the 08 GSR 52680022 Factory Flash ROM Upgrade
  4. ROM ID 52680022, Drop In K&N, downpipe back race exhaust Share Tables PLEASE!!!!!
  5. Cold Map Interpolation Tuning
  6. EvoScan 2.7b Error in graph "vs rpm"
  7. ECU locked
  8. where to tune?
  9. Installed WB today... questions..
  10. How accurate are the readings on a AEM UEGO?
  11. Unknown Rom: 2010 USDM Evo X GSR
  12. Starting to tune
  13. AP won't load
  14. Cobb AP new or used?
  15. P1676 attn gearheads!!!
  16. Help ! P2096 - cel -
  17. 2009 EVOX definition file
  18. ROM needed for 2010 Rally Art
  19. WB02 comes in tomorrow... tips?
  20. need some help please
  21. Evolution X Intake Tuning
  22. Help Tephra or anyone else capable!!
  23. EvoScan sub-forum?
  24. So who knows a lot about tuning….
  25. Tuned by Devin @ Boomba Racing
  26. Unable To Access Tables In My ROM (52680022)
  27. EVOScan problems
  28. Any MIVEC love for cosworth cams?
  29. Attn tephra<clipse3gt<acamus<xprimnt<!!
  30. Plug and Play Cobb Wideband Sensor
  31. free power for 2007-2009 evo x's
  32. Check out my log
  33. Detonating with exhaust?
  34. Cobb AP: Injen CAI affecting boost levels??
  35. Stage 2 Boost Restrictor Pill Question
  36. EVO X ECU Flash Recomendations Vishnu vs Turbotrix
  37. Raising 2 Step limiter
  38. Stop the fuel trims affecting WOT kill MPG
  39. Maf Scaling
  40. What laptop to buy?
  41. Cobb access port??
  42. Anyone have the Harman stage 2 power package?
  43. Lets See your E85 EvoX Timing Maps
  44. 2008 EVOX MR, updated dealer flash, need help ASAP
  45. Tune Very Inconsistent
  46. Stock EVO 8 injectors "vs" RC Injectors
  47. Critique my tune please
  48. is cobb ap the way to go w/ a stock car?
  49. Tuning Noob
  50. throttle problem
  51. 5th gear wot boost ?
  52. Stock A/F Datalogging
  53. What should i choose?
  54. Evoscan Registration Question
  55. car will not start
  56. Numbers from a tune ?
  57. need urgent help...!
  58. What do you think?
  59. Turn off P0140???
  60. Some GTR Goodness in the EvoScan GPS
  61. Logging Target Load
  62. EvoScan Problem - VIDEO
  63. Green fuel pump relay versus Blue relay
  64. tuning help
  65. Little help please on a guage combo Boost and AFR
  66. Atr to EcuFlash - MR Shifts Jerky now..
  67. Do I need to tune?
  68. MODE 23 now car won't start
  69. 53040007
  70. AP for me?
  71. Email tunes for E85
  72. Wastegate 40hp
  73. weird codes??
  74. Tuning 101
  75. Stock Turbo New Injectors?
  76. AP freezing... ?
  77. 2010 USDM MR Evo Scan popped check light?
  78. AP accessport tune. Need injector help E85
  79. RPM Idle/AC
  80. hks downpipe and catalyser
  81. Injectors
  82. EvoScan Help
  83. Added Stage 2 AP, but... :/
  84. Cranking Encrichment for Evo X
  85. Blitz Throttle Controller for 08 EVO X
  86. definition for 2010 mr x 55580006
  87. Initial modifications to Evo X Engine
  88. Dealership Changing Tune Back To Stock?
  89. LC-1 installation and usage?
  90. Need your help!!
  91. ECU Tuning Options.....
  92. Need Some Help
  93. Can someone explain these boost differences?
  94. 3 port on stock turbo hold 21psi
  95. Torque Limiter Evo X
  96. ECU Help?!
  97. VDR analysis
  98. S-AWC Twitching.
  99. Thorttle Sticking Occasionally?
  100. my ecu bit the dust
  101. Boost Curve Help - EC not a factor
  102. HKS SQV BOV recirculation
  103. Acd c1000?
  104. Help Required: LM-1 Product Users in USA
  105. can you make a definition file
  106. Cobb AP issues - Cylinder 2 misfire
  107. Questions on which Cobb AP map to use
  108. RC 750cc Injector Scaling and Latency
  109. Idling problems - solved
  110. Is this normal?
  111. evo x ecu questions
  112. E-85 vs Race Gas (109/110)
  113. Flash/tune before parts?
  114. ecu error codes
  115. Hypertech tuning device
  116. High idling RPM problem
  117. LM-2 and evoscan
  118. Need Help!
  119. number all over the place (AWHP)
  120. Corrupt XML?
  121. 08 evo x piggyback anyone
  122. Cobb AP Stage 1 Target Load Boost/Fuel
  123. Cobb Intake with stock airbox
  124. ready to move for exhaust and intake
  125. NeeD HelP.. im getting this code .. P2096
  126. Blow off Valve Question
  127. can not load the maps, is it normal?
  128. HOW-TO: Bench ECU (w/ Pictures!)
  129. Airflow dips in next gear after shifting normal? Data log chart inside.
  130. Bouncing afr reading
  131. STFT +7% - -7% between 2.5k-2.9k rpm
  132. Tuning changes for AEM intake
  133. HM intake map
  134. Adjust Injector Scale or Disable Fuel Trim affecting WOT?
  135. Help!!!
  136. ecu flash issues
  137. AFR readings using AEM Wideband and other observations
  138. AGP Cold Air Intake idle problem~
  139. Ninjas! help with underboosting!
  140. Gear Based Mivec works!
  141. ReTUNE CAI to SRI
  142. FIC 1100's Experience?
  143. reading octane in evoscan along with other questions.
  144. selection of AFR gauges
  145. Anyone using the Perrin Stage 3 AP map?
  146. E85 Question
  147. HELP!!!more then just p codes
  148. code reader other then pcmscan
  149. Omni 4 bar scaling??
  150. Thoughts on my future setup..?
  151. logging with 2010 evoscan
  152. Cobb Stage 2 map quesitons
  153. Kill Immo..
  154. K&N Intake Kit - Evo X
  155. Tech Service Bullentine TSB-10-13-002
  156. Unstable boost after installation of 3port and retune
  157. Cobb AP Question re: Injectors
  158. Fuel Pump Relay=New Tune ?
  159. P0133!?!?!?
  160. Reflashed, car won't start, all sorts of errors... Help?
  161. HKS LEGAMAX vs 5ZIGEN PRORACER ZZ?
  162. Questions in regards to custom tune OPENECU
  163. Rev hanging
  164. dynojet cmd
  165. #$&*# Fuel pump relay
  166. p0090 fuel pressure regulator and p0403 egr after boost leak test
  167. logging with ap
  168. anyone tried loading the 2010 ROM onto an 08?
  169. HELP! cobb stage 1 not hitting boost target
  170. ASC Off Light under high load??
  171. accessport map ?s
  172. map sensor question
  173. How do my plugs look?
  174. greddy turbo timer question
  175. anyone please help me
  176. Cant figure this out
  177. Should I be concerned?
  178. P1235 Overboost Problem (MR)
  179. Richness
  180. Cobb AP Dynamometer Testing and Results
  181. Throwing P0420 and p0300 Brand New off lot!
  182. Changing Maps With the AP
  183. World Market 2009 EVOX AccessPORT Available Now!
  184. seeking working xml 52360016 for jdm Evo X
  185. Logging
  186. Launch Limiter help
  187. At the track-need help
  188. Front O2 sensor voltage offset?
  189. Accessport wont connect to ECU
  190. exhaust fireing
  191. Map switching between E85 and 91oct
  192. Calculating injector latencies w/Accesstuner RACE v.math my head hurts
  193. question, cobb AP
  194. I Need Your Dyno Sheets! All Of Them!
  195. Lost all power...crap load of codes....
  196. speed limiter problem on 52360018
  197. Cobb AP Stage 1 reflash @ 600 miles?
  198. Evo X ECU Bench Process
  199. Help with OBD Monitor Readiness
  200. Throwing P0300!!!
  201. AEM Analog Boost Gauge Problem, no Vacuum Reading
  202. Revs drop very very slow in gear
  203. X reflashing
  204. Slow mivec
  205. E-85 is your friend!
  206. Cobb AP First Impression Stage 2 93 + AMS CAI
  207. ASC / 4WD / ABS Service Required
  208. OBD II stopped working looks to be car
  209. Does my engine have a knock???
  210. Forged WG and Perrin 3 port Test w/Data
  211. Difference between SM-AFR Module & O2 Sensor and Innovate LC-1 AFR Kit
  212. Overboosing
  213. Cobb AP: can u delete preloaded maps?
  214. o2 directly to 5v analog output
  215. Need stock .hex for EcuFlash 52680015
  216. Issues with Evoscan and LC-1
  217. Problem downloading Evoscan
  218. 2008 accessport on 2010 NEED QUICK ANSWER
  219. meth ignition timing
  220. P&L Motorsports tune??
  221. Completely stock X - LTFT Idle = -4.7, LTFT Cruise = +3.7
  222. EvoScan questions
  223. someone running 52690021 can you...?
  224. Got some knock, should I adjust timing or fuel
  225. P0302 with cobb stage 1
  226. Questions about Cobb SRI
  227. Motec 800 plug 'n play evo x
  228. knock issues
  229. Definition for rom 53050007 - EDM GSR SST
  230. A few n00b questions on re-tune / and AMS tuning
  231. ecu faults - need help
  232. AMS Evo X tuning Prices ?
  233. cobb ap knock retard ?
  234. X E85(E70) Cold Starts
  235. COBB AP Stage 1 + AEM + 91
  236. who runs a turbo timer?
  237. funny issue
  238. What ECU learns?
  239. Problems flashing ECU on '10 MR, 2m old car
  240. ECUFlash Tutorial for EVO X
  241. 97 Octane?
  242. looking for stock rom (52690019)
  243. Has anyone compared Cobb and Perrin maps for the AccessPort?
  244. Vishnu Setup Questions..
  245. Evo X Problem After Exhaust install!!!
  246. Works Brain - flash - p2
  247. How Many Are Running Cobb Stage 2
  248. electrical boost gauge question
  249. 51520020 EVO X RS definition file
  250. a/f ratio results stock tune w ALL BOLT ONS
