PDA
View Full Version : Evo X Engine Management / Tuning Forums
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14
  1. NJ tuner
  2. tuning
  3. Rear O2 address
  4. South Florida Tuning
  5. Tuning noob needs help
  6. Super Sport Mode
  7. Really confused HELP!
  8. Help! Need a Tactrix 2.0 open port before the weekend
  9. Best tuner for the X?
  10. Weird codes: P0172 & P0365
  11. Help Needed
  12. Monitor AFR on Accessport without gauge?
  13. Mod list
  14. Evoscan Knocksum Explanation
  15. lean issue
  16. Flex Fuel & Midwest E85 blend changes
  17. Cobb Acces port
  18. afr problems
  19. high idle after stage 3 ots?
  20. Stage2+CHFF 93 LWG v403.ptm Datalog
  21. Cobb AP/ evo scan/ logging
  22. Looking for a tune in South Western ON
  23. ID1300 Scaling / Latency
  24. AFR Setup Recommendation
  25. motec c125 data logging
  26. AEM TruBoost
  27. Cobb Map Question
  28. EvoScan AFR logging with RAX help plz.
  29. Evoscan WB Compatability?
  30. Evo x tuning options?
  31. OBD2 to ETACS ECU Can_L no continuity
  32. Dtc p20a0
  33. Engine Blew up at 1,400 miles.
  34. Ran a log on my friends X can you take a look?
  35. Bench flash ecu voltage
  36. vacuum line for seafoam
  37. Ways to lock Evo X ECU/ROM - DTC C01A0
  38. tunners around los angeles?
  39. MR Tuning Options in NY area
  40. Do I need a Re-Tune?
  41. 08 X slower after TB exhaust, intake, 3 port, AP Stage3
  42. successful 4" maf housing scaling?
  43. Best Mitsubishi Lancer Evolution exhaust sounds
  44. AMS STX300 Tune Review
  45. torque app owners need assistance with afr
  46. question about a 2008 evox gsr
  47. Evo X Upgrades
  48. EVO X Tuners?
  49. DLPIO8 Evo Scan 2.9 RAX
  50. Another P0300 question.
  51. RPM Bounce
  52. help engine codes
  53. Heelp
  54. evo x ecu problems
  55. Read CAN Traffic
  56. Cobb accessport obdll connector broken, help
  57. Sputtering at 3k rpms
  58. UR Exhaust
  59. Exhaust on Evo X
  60. whats the best cams for the X
  61. EvoScan not logging idle?
  62. Windows 8 serial to usb best to use?
  63. ECU keeps bricking up when my tuner attempts to read the rom
  64. Mercedes A45/CLA45. Why can't we match this?
  65. AEM UEGO connect to rear o2 sensor to record AFR help
  66. HELP! Dealer reprogrammed ECM WITHOUT EVEN ASKING ME!!!
  67. Problems with Motec M800 P&P
  68. AP bricked my ecu
  69. No start issue
  70. Question on safety of mods right before tune
  71. Downpipe question
  72. Ets intake CEL
  73. Question on stage 3 it's maps
  74. campaign sc-13-004 to update the ecm software !!!
  75. Engine service light flash
  76. New to Cobb Accessport
  77. scheduled pro tune next week
  78. Cobb v3 or pro tune?
  79. Map sharing? Cobb or EvoScan?
  80. going back to stock
  81. Lean Idle, Rev Bounce, help
  82. Swapping out exhausts. Re-tune needed?
  83. Etuning??
  84. please give comment on my friend's tune
  85. Need some help please!
  86. AFR/cold weather question...
  87. Estimated #'s after tune??
  88. ecuflash to cobb
  89. Dealer Recall reflash?
  90. Looking for proper tune
  91. CEL under heavy load in 27degree temps
  92. need help with my tune
  93. Can you tune an MR's reaction to shifts and/or deceleration
  94. Set up
  95. Looking for East Coast Tuners
  96. C161F&P0137 help plz!
  97. SEL P0365 need help!!!
  98. HELP!!! o2 Sensor shorted out fuse...
  99. Dual MAP Toggle Switch
  100. *Better* fix for P0300
  101. Question about O2 sensor simulators and the P0139 code
  102. Is this real?
  103. How I'm fighting knock at the rev limit
  104. Anybody want to look over this tune for me?
  105. AMS 2014 stage 2 maps for AP?
  106. what does it mean when the car is idling and the afr shows ---?
  107. Should the SST be tuned to match added power?
  108. fitment question
  109. quick questions
  110. upgrading option
  111. Urgent tuning help!
  112. Should i tune my car after these upgrades?
  113. When to tune?
  114. AMS STX400 package... Thoughts?
  115. Need advice on parts
  116. Need e85 tuning help
  117. Omni 4bar
  118. Need Adivce
  119. cobb ap data logging.
  120. 2013 GSR Cobb V3/ Phantom Knock?
  121. Sakura 3.5" Intake
  122. Installed Hfc and injen Cold air have questions
  123. ~New 5150 E85 tune~
  124. First set of mods
  125. LTFT idle too rich!
  126. Fluid Changes (And Break-in Fluids)
  127. Dyno Tuning
  128. Pure Tuning, Toledo Ohio?
  129. Acd cold weather flash question?!
  130. Is a retune needed?
  131. Mitsubishi tuner shop map (Google Maps) link
  132. quick cobb sf intake question
  133. Going E85 question
  134. MAP and MAF Scaling / Tuning
  135. Can't log my AFR's
  136. Having problems with COBB SF Intake!
  137. Evo X mode23 issue HELP
  138. *Reaching MBT on low octane fuels*
  139. EvoScan Gauge design
  140. Need some help???
  141. Where to get GM 3-port?
  142. Evoscan not logging? says RPMs are 35k..
  143. New (Used) Evo X MR with Service Engine Light Looking for Help
  144. Grimmspeed 3-Port question?
  145. Tunes for different elevations?
  146. break your engine
  147. Cobb ap question.
  148. Bakauchi tune FTW
  149. another awesome noob question
  150. Asking for a refund on a tune. Question in short up top ;)
  151. Is my timing off?
  152. How much more power can be had from the X on 2011-2014 models?
  153. cobb 3 port help, low boost
  154. Looney tuned...another success! 2011 Evo X MR
  155. How you know know if your EVO X is tuned or has stock ECU setting?
  156. New to the platform.....need help.
  157. Severe knock under WOT
  158. grimmspeed 3 port tuning help
  159. launch control
  160. Sticky This! EcuFlash video guide
  161. logging issue
  162. Are the Torque Limiter tables used on GSR ?
  163. Shell cam2 race gas
  164. Will a bad ECU cause these problems?
  165. New ECU, Cobb AP, or ProTune?
  166. Need a more solid answer
  167. Scaling MAF and Inj
  168. lean issue and jumpy idle
  169. Over rev code p219
  170. engine load problem?
  171. Race gas?
  172. AEM Tru-Boost
  173. Can you brake boost?
  174. Weird/Slow EvoScan Logging Issue
  175. ecu problem
  176. Crank and no start. Advice?
  177. Open Source vs Cobb
  178. What do I need to do next?
  179. Revised MAP review
  180. P0219 code and only has 2,500 miles. =[
  181. 50/50 h2o meth no tune
  182. evo x weird noise
  183. Car is stuttering around 4,000 RPMS..
  184. k&n typhoon issues? help!!!
  185. upgrades without tune
  186. Tune for 87 octane
  187. Error Message
  188. Logging Parameters on Evoscan and Cobb AP
  189. 2013 Evo X GSR K&N No Tune DataLog
  190. Cobb AP Stage 2 Question
  191. AEM 320lph vs DeatchWerks 265lph
  192. Meth vs Water Meth
  193. Looking for a good set of valves
  194. Fuel Pump Question
  195. Ams cai
  196. Colorado Tuners
  197. AMS STX300 package first impressions
  198. Weird Knock at 2k RPM
  199. Tuning shops In Atlanta?
  200. Missing/Studderin Under WOT
  201. Pre Purchase Inspection Oceanside
  202. tune shops
  203. Question about valve&spring for aftermarket cams
  204. Differences between Cobb AP and ECUFlash
  205. Help with P2096 CEL!
  206. Need some help here
  207. P1876: Gear block 1st
  208. Wtf p0113
  209. Is it worth voiding the "Warranty"
  210. GrimmSpeed Electronic Boost Control Solenoid 3-Port
  211. Cant log AFR
  212. Looking to +/- fuel
  213. Need hlep logging evo x mr!!!!!!plzzzz
  214. Mods I'm getting, need opinions on the later parts...
  215. Pop When going WOT in 3rd
  216. Irratic bouncing idle
  217. Good set for e85?
  218. Evoscan sampling & multitasking
  219. Fine WGDC rq 100%
  220. Help! Car running lean!
  221. Cat Back
  222. First Data Log - Care to Give Feedback?
  223. ECU Harness
  224. The definitive way to tune an evo X
  225. Reading mode 23 addresses with elm327
  226. Is a cobb ots map right for me?
  227. Evo X MAP Sensor
  228. Intake without tune
  229. E85 the CONS!!!!
  230. Evo X 322whp/321tq Mustang Dyno Tuned vs VD
  231. Need some help!!
  232. ECU Flash FIC 2150's E85 Tuning Questions
  233. How to enable mode23 on 2011 Lancer?
  234. Tuning my evo x
  235. AMS STX400 on an MR?
  236. O2 tuning question
  237. Kelford 214-B cams
  238. Boost Spike Remedy??
  239. who can tune me for anti lag?!?
  240. finger throttle blipper (tm)
  241. How safe is the AMS STX300 tune?
  242. Just bought cobb ap and realize i have lc-1 in my used 08 gsr
  243. AP Logging - What to Log?
  244. Intermittent engine warning lamp and limp mode, please help!
  245. Tuning the SST...
  246. Was tuned for stock set up & made a few changes
  247. Turbo Timmer/ Launch control
  248. SST launch control maps
  249. Lots of knock all of a sudden
  250. Cobb AP Question
