- Cobb AP - How accurate is built-in dyno?
- soft modding for MR
- open port2.0 w/ evoscan
- Can someone clarify the difference between maps A, B, C, D in the EVO X?
- Misfire causing car to run lean and smell like fuel?
- Should I worry about 1 knock sum between 6000-7500 rpm's?
- OBDII Code Reader Compatible with the X
- Evoscan aem wb logging ?
- Question about EcuTeck and Cobb AP
- Tuning File for Evo X with SST Transmission
- Boost Tuning
- On vacation and need a tuner that's close
- Mivec Maps
- tuner in my area
- electronic throttle
- stock pump capability
- p0122 & P1233
- Limp mode problems
- P1241 Torque Limit Exceeded (COBB AP)
- Lookin for Tuner
- Flashing with ECUFlash....warranty work?
- EGT or INTAKE temp
- Evo X Mode 23 Logging/Dashboard/Gauges (hey tephra!)
- Problems with ECUFlash in parallels
- UICP with Cobb tune
- 91 octane HP/TQ
- need some input on how to smooth out my boost curve
- Tanabe Exhasut EVO X MR testing
- EvoScan EvoX Datalogger now supports 2byte Boost/Load/IPW
- plz look at my log
- Most Important Gauges
- Who does e-tuning for the evo X?
- Where to tune in Houston Area.
- Anyone running Cobb AP stage 1 w/ K&N drop in
- O2 location for logging
- X GSR ICS Waterspray ?
- turbo and torque
- Stage 1 + cobb ap = pill removal?
- Help, can someone identify which reflash I need, just bought Evo X
- How to finetune z-chip?
- Is boost determined by BTEL or Wastegate Duty Cycle maps in ECU?
- Has anyone bought any AP maps from any reputable tuners online?
- Which map for this intake?
- AFR Tuning Tips?
- Mut III?
- Code p1241 using Cobb Stg2 + SF
- cobb AP stage 1 real numbers???
- Opinions wanted, Where to get tuned?
- Question About COBB Stg. 2 w/Forge WGA & Boost Pill
- Holy balls the stock tune sucks
- Pro-tune to kill off any unwanted service lights/error codes?
- How do i log my evo with evoscan?
- 1/4 mile tunes vs stock
- Thrust Bearing!!!
- Stock tunes input
- Newb question - WORKS Mail in Flash
- p1235 & p1238 @1000rpm
- Harmon Motive intake installed. Cobb AP maps road tested.
- Knock Retard Amount Question?
- Noob boost read question on cobb AP.
- new car 2k in mods while keeping the car quiet ;)
- cobb AP for two?
- 3 - Port Boost Control Solenoid and Harness
- East Coast Tuner
- For the Cobb guys... question on intake maps and hp numbers..
- Cobb AP help: New computer doesn't recognize when plugged in
- Cobb AP reading low boost
- CVN!? Tuners feel free to chime in..
- Sigh. P1235 4 days in a row now.
- What should I do about tuning my X?
- AMS Intake Maps for EVOX Now available!!
- Any reliable tuners in wetern PA or eastern Ohio?
- looking for a tune md/va area
- evo x mr , how much should i be paying for a tune and dyno?
- TBE upgrade improvement to gas mileage
- AP owner; Question about factory reflash
- ECU Flash XML Definition Needed for EDM EVO X GSR
- correct stat rev limit ECUFlash definitions for USDM Evo 10 GSR
- Evo X MR Factory Reflash
- Anything that can be done to override traction control?
- Help On Going To Straight Pipe
- 2-step fail
- Trying to determine software for gauges...
- Lf 52360018
- Quick ? Need help!
- Boost Controllers and such...
- Limp mode again...
- Some Ideas to share
- EVO X MR Pro-Tune {no issues whatsoever} updated
- Help!! P0302
- Car acting weird when exhaust got installed
- Anybody Running The New Evo X Cobb AEM Intake Stage 1 Tune Yet?
- Help can't adjust stationary rev limiter
- Tune without adjusting boost levels?
- Funny Idle, Wierd Sounds when shifting
- MR ROM Definition
- cobb map boosting too much??
- How much knock is too much knock
- ECUflash and WORKS flashed ECU
- Evo X gauge setup pics
- IMPORTANT NEWS for MR Owners! READ!
- Will I lose my Custom Tune...
- Injector upgrade
- Stock Boost Pill Size?
- Tuning w/o wideband?
- Using Evoscan to determine why I pulled CEL (P1235)
- 08 EVO X MR noob Q regarding Cobb AP maps
- Cobb AP or other Tune - Issues with reliability?
- Tune with intake?
- Anyone running HKS VCON?
- Noob question about different maps
- Greddy InfoTouch or Traditional Gauges
- How to get ECM updates for USA Evos in Europe
- HKS drop in filter
- Intercooler Spray?
- evoscan and open port 2.0
- evoscan datalogger/gps display unit
- ATTENTION: EVO X AccessPORT Stage 2+AEM Intake Map Recall
- tuning?
- Gruppe-s / ProDrive / Pierburg 3 port boost solenoid
- Upgraded Internal Wastegate Actuator: EVO X - Gain 40whp?
- noob what flash to get?
- Perrin Stage 1 Map Giving Me Problems...
- GSR ECU vs. MR ECU
- Missed shift
- AccessPort Maps and Mileage
- thinking of adding *more* water/meth
- Seems oddly slow lately... (AP help)
- Evo X 437hp 26 libras
- Intake or Drop In
- Which flash is better?
- EvoScan for Evo X Beta Parameter CAN-ID's? Log attached
- WORKS P2 flash REVIEW
- Evo X RS Mivec on Base Evo X?
- Anyone with 53040008 xlm for X ?
- Read CEL code with Tactrix?
- 1000 cc Injectors
- This years goals for tuner for evo x power suspension etc
- EVOX MR EDM definition
- Swapping Roms on the Evo X
- Leaning out under WOT
- How Is This Possible?
- Resetting ECU= Lost Tune?
- Tuning an evo X mr questions
- Evo 10 MFI basic block diagram from FSM
- Aem standalone on evox
- weird: cant see my X map definitions all of a sudden, help !
- overboost CEL
- Best I can do with OTS maps?
- Throttle Body
- Very good read.
- have a problem
- Tune Required?
- 52360016 xml update 110409
- conical cone filter and stock blow off valve...wow
- adjusting mivec on evox
- ecu questions
- Jestr tuning
- need some help?
- Which does tuners do E-Tune for COBB AP???
- AF Ratios
- Kiwi wifi + ECUFlash?
- 100% stock DG motors baseline
- Service Engine Soon, running lean
- Anyone install the buschur mass air pipe?
- drop-in filters -- results from tricking the MAF or less restriction?
- Anyone have any issues with their tuned X?
- Question about the AP and boost
- Question about air/fuel numbers
- Works P2
- ECUFlash Price Ballpark
- methanol injection
- ecu flash or ecutek on my evo x
- Stationary Rev Limiter
- Where to pull Speedo and Engine RPM signal from?
- Evo X OBDII output parameters?
- conservative tweaking with my MR
- What to watch for at the tuning shop?
- Evo X owners: What engine management are you running currently?
- How much boost should I be tuning for?
- WGDC maps
- U0167 code?
- Zt-2 Wideband MAP sensor install
- EvoX solenoids question
- Question for tuned X's?
- rev limit
- AFR very very rich after bolt ons
- z chip problem
- ECUTek for MR
- Evo X with water injection
- Can't tune...running to lean HELP!!!
- Need to re-tune?
- Crappy idle and hitting a brick wall
- What exactly is needed for stage 2...
- evoscan
- So whos afraid to get a tune?
- ECUFLASH for X: Glossary for Dummies !
- What is wrong with my turbo timer!?
- Hbspeed satisfied customer
- ASC light going off under boost!!!??
- Blitz SBC i-D + Cobb AP
- Anyone have Experience with just the AMS Evo X flash?
- P0140 Question
- TephraMODs for the X
- Fuel Cut? What happened?
- What logger can I use for Evo X
- Bolt ons w/ no tune
- Tuner in Eastern North Carolina
- going lean after 2 weeks of perfect AFR
- Z Chip is the ****!
- Auto Enginuity
- What am I missing?
- service engine soon?
- Is MR version of the Evo X undesirable for tuning?
- Cobb AccessPORT 1/4 mile results and review
- Vacuum leak?
- Wierd tuning question
- SES B3813 Undefined Code
- Question about the Cobb AP?
- Will loading JDM SST Rom onto EDM ECU work?
- Interesting find yesterday with the AP @ the track
- who is the BEST TRI-STATE Cobb AP tuner - NY, NJ, CT?????
- quick question abotu intakes with an ecu flash
- boost solenoid replacement evo x
- Head gasket
- cobb AP and boost
- Review of Vishnu Evo X MR Tune
- How do you know your fuel pump is maxed out?
- EDM Evo X SST Rom Definition needed (same as AUS)
- Anyone bought Cobb AP from them?
- ~~~~~~~~Greddy type RS bov questions ~~
- Who Should I Get to Tune My MR via Ecuflash
- You big turbo guys! What load numbers are you seeing?
- Question about the AP?
- share your ECUflash maps!
- very need to know how to recover ecu with ecuflash
- Quick modding question
- EcuTek question?
- Exhaust - Welded vs Mandril Bent
- The PCMScan Thread
- PCMScan Boost Logging, negative boost?
- DTC codes ? free program
- What are the HP differences between an X running 91 and 93 octane?
- vent to air bov
- Has anyone on here made their own maps for the AP with ATR?
- Questions about Cold Air intakes
- How many miles on car before reflashing?
- ECUFLASH + MBC or EBC
- Cobb AP 91 or 93 map for 92 gas
- ECUFLash speedcut on JDM
