- 2 evo 8-9 flywheels 57.00 shipped per unit!
- Exedy Twin Disc! 4k Miles!!!
- GSC S1 Evo IX Mivec Cams
- BNIB: GSC Beehive Springs
- FS: SBR t3 manifold, Holset hx40 turbo, stock headgasket,
- FS: Stock VIII Wastegate, Brass Shifter Bushings, Steering wheel
- 05 evo 8 Center Diff Pump
- FS: So Cal - HKS Galore Part Out
- *new*Full Blown Walbro Dual Pump setup for evolution 8/9 (hanger and pumps) BNIB!!!
- Many Parts Available, stock and not
- fullrace ProStock Turbo Manifold
- Evo 8/9 OEM Intercooler (Great Condition!)
- 5 Gallon RCI Fuel cell F/S
- AMS/Precision 5 Bolt .63 AR Hotsides Slightly ported out so no surging issues!! NEW!!
- FS: HKS Racing suction intake, Megan 3 inch DP(clear ACD)
- Kelford 280 Cams EVO8 Like new
- FS: BNIB Deka EXT14 Battery
- Misc Part out Including: Tactrix Cable, AMSOIL, IAC's, TPS's, Speed Sensor 4trans,etc
- AMS Test Pipe
- OEM Exhaust Manifolds (x2)
- JM Fabrications small battery kit with battery
- FS: Evo 9 Stock Parts
- Exhaust Manifold Gasket
- F/s Tial 11psi spring and BNIB Tial Flange...
- Stock Injectors!!!
- Stock Throttle Body
- PTE Precision 880cc Injectors
- evo 9 head with supertech valve train
- evo9 20g and ported muse mani
- FS: ARP L19 head studs NIB
- F.S used Fujitsubo Cat Back System RM01A
- EVO IX stock ECU F/S
- Brand New SuperTech Valve Springs And Retainers F/S
- Bnib licp on ebay
- FS: Weldon 2025a External Fuel Pump
- FS: Garret 4294r turbo
- FS: Parts on Ebay (1 day auction) Avid, o2 sensor, Ams, ABS,Strictly Modified CHEAP
- o2 Sensor BEST OFFER
- stock evo 9rs parts
- Fs: New ams and ets licp, synapse bov, ets recirc pipe kit
- FS: new MAF Translator PRO, boost solenoid and harness.
- AMS EPM STOCK stuff
- evo 9 mr front diff lsd unit(2500miles)
- 4G63 Partout Cams, Rods Piston Arps
- FS: . . LOOK . . . Borla Catback Exhaust, 3"
- FS:Evo IX Rear Diff.(socal)
- FS: Greddy Profec-B Spec II
- FS: Greddy Turbo timer cheap
- F/s bnib ets fmic/used fp green stock parts
- Fs: Exedy Twin Disc Clutch (Needs Rebuild, Cheap)
- FS: Oxygen Sensor (02 Sensor) 03 Evo
- FS: Magnus Intake Manifold
- Utec
- Brian crower springs and retainers $190 SHIPPED
- SWAP - My FP Red 64mm for your HTA Green
- FS : Evo Stock exhuast
- 2002 mitsubishi lancer oz rally Stock parts for SALE!
- Forced Performance
- FS:6 Blade 20G Turbo
- Custom INLINE RACING 35r kit for sale
- FS: 2005 Evo VIII Motor!!! 39k Miles... Longblock Engine!!
- FS: Borla catback, helix test-pipe,a 3in DP, and a turboxs mid pipe
- FS: Tilton Carbon / Carbon Clutch...
- FS/FT/TW: Evo 9 Suede Seats (Chicago Area)
- FS: Stealthy Test Pipe (similar to RRE Rallycat)
- FS: K&N Typhoon Intake. CARB Legal
- FS: Alumium UCIP for Stock Battery
- Bunch of random stuff need gone.
- ported 10.5 hotside, evo 8 turbo, buschur intake
- F/S Evo IX perrin turboback exhaust,brand new qtp o2 dump,and ets intake
- New oem Evo 8 RS t-case transfer case
- Apexi intake with EVO IX Maf
- Block and crank Evo 8 brand new oem
- ETS uCIP and Muse LICP
- Labonte Stg 2 Meth kit
- Turbo XS Turboback Exhaust $550 NEW!
- FS: HKS Twin DLI Ign, BNIB Walbro 255, EBC Red Pads
- F/S Dual Port BOV
- f/s - GT35R .63 Turbine Housing V band
- **back to stock partout**
- Precision 1000cc Injectors
- FIC 1000cc injectors for sale
- aem ugeo wideband
- FS: NY...FEELER...Used, evo 8: GSC S2 cams, oem head, ported IM!!!
- FS:FP Red 64mm
- AEM ECU for sale
- AMS turbo kit o2 housing and dump tube
- fs: stock 9 cams and valve spring make offer
- FS: tial 38mm wastegate silver
- Stock Radiator with Mini Fan
- Stock Intake Manifold and Throttle Body
- Ported 65mm Thorttle Body
- BNIB ARC heat shield
- FS: Tactrix 1.3 Cable Evo 8/9 ( ON EBAY)
- Buschur SS 3" downpipe -- thermal coated 2200 degree
- FS: Stock Intake manifold- $110 shipped
- FS: Tonnes of Aftermarket Parts
- WTB: Evo 8 Valve Cover
- FS: Greddy Turbo Timer with harness
- FS: Forge RS BOV
- Custom Turbo Kit minus turbo/intake/oil and water lines
- FS: Stock 9 Injectors, TBE, O2H
- *** buschur ported coated cast manifold***
- *Stock Parts: OHIO NEED GONE*
- hks racing suction filter and MAF adapter...40$
- FP RED/FERREA DUALSPRINGS/PTE 1000cc/BLOX RACING/STOCK IX TURBO
- JMF Intake nanifold Evo 8/9 *PICS INSIDE*
- FS: Evo VIII Fuel pump
- 2003 evo 8 block nice low miles
- greddy ti cat back
- Fs= injen lower intercooler pipe
- Mitsubishi Montero Coils for use with Dynatek CDI
- FS: Tilton Carbon/Carbon clutch!!
- BR intake for SD (brand new)
- FS: Authentic UK "EVOLUTION VIII" trunk emblem
- FS: AMS Intake Manifold/ BBK 76mm Tb combo!
- FS: Hallman Pro MBC, and boost gauge
- Hks racing wastegate
- HKS Manifold
- FIC 850cc injectors
- Coil on Plug Setup with CDI Box
- FS Aquamist HSF-5
- EVO 9 TURBO FOR SALE 19k MILES
- Catco 3" High-Flow Cat
- injen upper intercooler pipe
- Stock Evo 8 Injectors
- (NJ) FS Perrin HFC
- Dc sports down pipe and greddy ti....
- FS: GT45 turbo new
- SOME TOP OF THE LINE PARTS!! l@@k inside!
- FS: Extreme Motorsports COP
- FS: Buschur Racing Mini Battery Kit
- FS: Buschur Racing Evolution Mass Air Pipe & Filter Kit
- FS: Buschur UICP
- clutch master cyl and brake master cyl
- FS:evo 9 mr stock cams and stock valvetrain...
- FS: Evo VIII Stock Cams
- FS: Stock Evo VIII Injectors
- FS: Stock Evo VIII Intercooler
- Billet Precision PTE6265 dual ball bearing, watercooled, vband, t3 CHEAP!
- GSC 272/264 cams
- FS: Front O2 sensor from 05 GSR, 5500 miles
- FS: Injen MAF adapter with K&N shorty filter
- FS: Stock IX MR BPV
- Forge Wastegate, hotside, tactrix
- FS: BRAND NEW.. ETS LP2 LICP, Walbro 255, Hallman Pro MBC & S2K push button start
- FS: FIC 1600cc
- FS: Complete uncut 05 GSR wiring harness, make offer!
- Driven Innovations Intake Manifold (brand new)
- FS: 2005 stock clutch make offer!
- anyone interested in a br deluxe fmic and ported 8 turbo?
- FS: 6262 Turbo kit, Shep Trans, TRE T-case, Buschur, Kelford, Supertech, Tial, etc
- EPM o2 dump
- WTB : Rear Passenger Side Axle (Good ABS ring)
- FS: Ams 850 r Turbo Kit, Ams 2.3 , Pte 1000cc
- FS: Ams , Arp , Buschur Racing, Avid, Beehive Springs (Need to go)
- turbo xs turbo back exhaust CHEAP!!!!
- SMC Meth Kit
- FS: Misc Stock/Aftermarket Parts
- Exhaust Mani 38mm tial WG Custom dump tube!
- Red Hallman Pro Boost Controller
- Evo 8 cheap Act clutch + flywheel!
- Shep fully built Trans for sale
- FS: LICP For Buschar FMIC or Similar -$45bux
- Stock Evo IX cat convertor
- WTS/WTT Buschur Intake
- FS:Buschur stage 3 head
- FS ported ix turbo, ported exhaust mani, 02 housing
- fs: stock evo 9 mr cams...
- DI Intake Manifold
- FS: Tools
- Exedy Triple Carbon Great Condition!
- FS/PA hks 264 cams for evo 8
- Walbro GSS342 Fuel Pump (FL)
- Ets short ram intake
- EVO 8 valvecover
- EVO 8 stock injectors
- EVO 8 turbo for sale
- Black Forge RS DV - perfect! $90
- F/S Stock Evo9 Turbo less than 5k miles
- Need a bad head
- Bnib evo9 mivec hks272 cams
- For Sale AMS Downpipe
- For SALE: HKS MIVEC 272 CAMS
- FS: HKS DLi2 ignition system---------300.00
- Evo I-IX 5 speed brass shifter bushings for sale
- BRAND NEW NGK AFX wideband
- FS: oem Evo 9 MR bov
- K&N drop in for evo 8-9 1,550 miles old 30 shipped!
- .82 garret hot side, gsc s3, ams intake, 2 evo 9 head, cosworth dual springs retainer
- Buschur Air Filter (direct MAF bolt on)
- ets exhaust for sale.
- FS IL: Greddy Profec B Spec 2 II ebc
- F/S..........Hallman Pro RX MBC
- FS: Greddy Profec B Spec 2/Synapse Super Synchronic Bov
- FS: DEI Titanium Turbo Blanket CHEAP fits OEM Turbo
- FS: (NC) Used stock rods and pistons
- FS: 1k mile BC 280 IX cams, stock IX fuel pump 30k mi
- Buschur Battery Tray
- manifold, meth kit, injectors ect.
- FS NEW FP Green 73 HTA Ported, w/ 18psi actuator, and oil line kit: So Cal
- AMS Licp, Megan o2/Mani, Greddy boost, IX bov, etc
- 4G64 Block and evo parts
- F/S: Ingalls "Stiffy" Engine Torque Dampener
- RC 1200cc injectors
- Holiday sale! BNIB parts as well as used...all obo
- FS: IL Buschur racing V-Band exhaust for JDM/USDM bumper *pic's*
- Ralliart Engine E.C.U. EVO IX (MIVEC)
- HYDRA EMS EVO IX (USDM, JDM and Euro *CL MIVEC)
- Ingalls Stiffy Engine Torque Damper!
- oem drop in filter with 1k on it $30 shipped
- FS: AC parts, EGRs, Evap parts, ACT Clutch disk, and more
- Nisei UICP Short Route $110 + Shipping
- megasquirt ems used for 200 miles!!
- crank sensor 33.00 shipped!
- F.S Aps twin vent blow off valve
- FS - M&W Ignition - Mini Battery Kit - Injector Driver
- FS: 2.3L Evo IX Stroker Shortblock - NEW
- FS: Garret 30R Turbo VERY Low Miles
- Vishnu turbo kits for sale
- FS: Used Exedy Twin Disc .. cheeeeap
- FS: Used Magnus V5 Cast Aluminum EVO Intake Manifold
- 1260cc injectors, Brake Pads F, CB Exhaust
- FS: FP RED 80mm ported and coated - less than 1k miles!
- NJ stock 02 housing licp uicp airbox exhuast ect..
- Shearer Turbo Kit
- FS ,, NY area HKS intake and tein springs on stock shocks/struts
- FS: BlueMax Injectors
- arc titanium plug cover - brushed -
- f/s stock crank
- f/s: eagle rods
- FS: Perrin EBCS Electronic Boost Control Solenoid
- FS. ETS// evo9// fujita
- ATP GT35R Turbine Housing .63 a/r
- fs:stock evo 8/9 cat-back and stock cat!!!
- Evo 9 Turbo w/ 10.5 hotside.. /other Evo parts
- APS 3.5 inch exhaust PERFECT!!
- FS ACT clutch (part#MB017X)
- FS; AEM EMS, Cometic headgasket, ARP rod bolts, Bushur O2 housing, ACL race bearings
- Turbo XS, Blue gauge overlay, OEM FS / Trade
- FS: Greddy TI, Megan, AMS
- FS: APS Twin Vent BOV
- FS: Garrett GT4088 GT40R turbo NEW !!!
- Rev Hard Manifold, Tial 38mm & GT3076 FS
- PTE 1200cc injectors
- Evo 7/8/9 Full Titanium exhaust
- Fs ams ross spec pistons .20 over
- Fs aem injector controller box
- FS: sun auto hyper force
- FS Cheap T4 DNP manifold
