- I want to buy your mods.
- FS: OEM CAT, Downpipe, Muffler, Airbox, Clockspring and more
- New Full-Race T4 Twin-scroll EWG Manifold W/ Tial MVR's
- FS: AMS GT37R Turbo Kit
- MAP O2 eliminator down pipe open dump
- FS: evo 9 bov
- FS: AEM series 1 for Evo IX - $325 shipped!
- FS: Sparktech EVO 8 & 9 Coil on plug kit - non cdi
- Spoolin' Up Setup w/ new harness
- traded in my evo leftover parts sale
- FS: Hallman Cockpit Controller 72" cable for Hallman MBC
- ARP rod bolts super cheap
- FS: OEM TOB for 5 spd
- FS: Koyo Rad
- FS:Precision 50 Trim Turbo
- AEM wideband
- Evo 9 oem intake manifold, throttle body, ps pump, coil cover etc
- FS: EVO 9 MR 6speed Transmission
- IX Valve Cover.. ARP Studs.. HKS Grounding Kit**
- FS: COP harness for Evo 8/9
- Evo 8/9 Fic 1450cc injector brand new
- FS: Many OEM and Aftermarket Parts. Mitsu, Cosworth Injen, K&N, Gates, and More!
- FS: MAP O2 Eliminator Downpipe
- OEM boost solenoid
- Sparktech Non CDI COP - evo 8
- SFS upper/lower rad hoses
- Walbro 400 and sending unit
- EPM O2 Dump and Buschur Ported Exhaust Manifold
- Tactrix Cable- New!
- FS: FIC 2150 Hi-Imp injectors
- Hks Exhaust/ Custom Trunk Bar
- Magnaflow & Helix cat and cat-back
- BNIB DW301 Drop-In Fuel Pump w/ Install Kit
- Denso 7200 injectors apexi SAFC 2
- FS: EVO 8 OEM parts CHEAP
- Fs: 8 bnib ngk bpr8es
- BNIB evo 8 kelford 272s
- Stock Evo 8 Trubo, Down pipe.
- FS:GSC S1 and Supertech Dual springs
- FS: Odyssey PC680 Battery!!
- Evo 8 16g
- FS:WA FIC1450cc, Precision T3 .82 A/R
- ARP L19 head studs-used once-$120 shipped.
- Built Evo ix mivec head for sale
- FS: T3 Garrett GT3076R
- PTE 880cc Injectors, Steering Column Pod
- FS in PA: used black Perrin fmic, Injen ic piping, Forge bov, Hallman boost controler
- FS: *FEELER* EVO 8/9 Buschur Racing BULLET muffler
- NJ: Fuel Housing, FR Pro Stock Manifold, PTE 1200inj, 5spd IX, ARP Head Studs, 02 Hou
- FS: Brand New FIC 750cc Injectors
- Custom COP kit evo 8&9 cheap $225shipped
- FS: HKS ssqv BOV, Trust/Greddy MBC
- FS: XSPower T3 manifold
- Fs: Mn : Stm half radiator / id 2000cc injectors / ams / blitz / ralley armor / blox
- Evo 8/9 AEM intake with MAF
- ATP stealth stage 3 turbo kit
- Exedy twin disc clutch MM022HD 350 OBO
- EVO IX MIVEC gear and solenoid
- EVO IX valve cover
- FS: Evo 9 Catalytic Converter
- FS: New FP HTA82 1.06 Twin-Scroll T4
- FS: Ets 3.5" FMIC (MA)
- FS: GT3076R RNR Turbo Kit
- Fs. Pte 1200cc injectors and custom COP kit
- Tomei Ti exhaust, AMS plug cover and fuel rail, and OEM parts (WI)
- FS: new in box wally 225
- Evo 8 stuff FS
- Tomei genesis 2.3 from oil pan to valve cover
- For sale Stock cams, intake,snorkel
- Evo 9 AEM version 1 w/5 bar map
- FS 4g64 block , crank ,misc
- F/S (WI) Exedy HD Twin Disc Carbon Clutch
- FS - GFB Stealth BOV (Red/Silver) - 110$ shipped
- Cheap!!! Buschur, ams, 30r, oem mitsu.
- FS: Mitsu evo 8/9 cam sensor and Tactrix Cable
- FS: Power FC D Jetro evo 8
- JM FAB, FIC2150, wideband o2, injen UICP, LICP, Evo8 block and more
- 65mm Buschur Throttle body and evo 9 IX valve cover
- Fp Green hta73, COP Ignition, DARC2 box, jdm evo7 boost sensor, gm boost solenoid
- Greddy Type-S BOV
- FS: New Tial Q BOV 50mm/ETS UICP
- ARC japan
- FIC Bluemax 1650cc Injectors
- FS: Evo metal BOV
- FS: NIB Supertech manganese/bronze I/E valve guides
- FS: PTE 6262 FiD Buschur T3 Hot Parts
- FS/Las Vegas---AFI Turbo's T4 Twin Scroll kit (HOT PARTS)====>>>
- FS: MO ARK simple turbo timer
- OEM coils and plugs - '03
- FS: Skunk2, OEM, Top Speed Auto, DEI
- FS: (NC) FIC 1650cc injectors. Low Miles.
- FS/ ProSport 80mm Tach, STRI 45PSI boost gauge, Turbosmart dual stg boost controller
- TiAL MVS 38mm wastegate
- FS: EvoIX Turbo
- FS/FT (IN) Sparktech CDI COP with pro 12 Microprocessor
- Exedy HD Twin Disc Clutch Evo 8, 9 5 Speed
- FS: Exedy Twin Disc and 6 speed Transmission
- FS/FT: AMS MOROSO wet sump oil pan in CT
- EVO IX parts, VC, MIVEC gear, turbo, ect
- FS: Perrin intake tube and heat shield
- FS MI: Brand new Manley 2.1L 20 over pistons
- FS/FT: BNIB PTE 6766 CEA turbo
- FS - Fidanza cam gears
- NEW OEM radiator, NEW OEM condenser
- Fs: Hks bov
- VIRGIN 88MM Crankshaft 40k all std!
- 6M/T Conversion Kit (All Parts Except Trans itself) [MI]
- FS - A/C condenser
- FS - Quartermaster 6 leg race twin disc
- JDM alloy oil pan for 8/9 block
- new 4g69 block
- F/S low mile Evo 9 turbo and Ams 3.5 inch FMIC
- freshly wrinkled black valve cover!!!
- Back to Stock High HP Setup!!! ProEFI HKS AEM Exedy 42R & Much More!!!
- 6 speed evo 9 transmission
- Lots of engine parts!
- FS: Nor Cal - Mitsu OEM 6-speed transmission fluid
- FS: Evo 8/9 New Fujita UICP and Intake
- Fic 1550
- Evo8 CDI COP kit
- Pull clutch parts. Clutch forks/TOBs
- F/S Many parts ets, bc, aem, quaife and much more!!!!
- BR Evolution 9 Stage 3 Cylinder Head
- FS: Forward facing bb6262 setup
- FS: NJ BNIB 3" resonated test pipe with gaskets and hardware
- FS/FT XS Power intercooler 3.5 and wastegate
- BNIB PTE CEA BB 6266 V-Band Turbo
- FS: Brand New Precision Billet CEA 6466 Ball Bearing Turbo T4 0.68 AR
- OEM Evo 9 Cams
- TX-FS STM's -12AN welded thermostat housing
- FS:NJ SD kit, injen, samco, maf, map
- BNIB Walboro 255lph + install kit
- FS: Perrin MBC
- Precision 780cc injectors
- NY- KOYO half size EVO radiator Thick Core
- FS(ND): *USED* FIC BlueMAX 1450cc injectors (4)
- FS: Perrin Intake & K&N Typhoon Filter with CF Heat Shield
- Brand New 850 CC Injectors Evo 8/9 - 6 Available
- Autronic Evo 8 ecu for sale
- FS: 2003 Evo 8 ECU
- Bnib fic bluemax 1250
- 4g64 Parts
- FS: FP HTA86 Twin Scroll w/1.00 AR
- FS (SC): NEW FB 70mm TB, Used Walbro 255, Stock injectors
- Hallman mbc, Evo9 oem radiator fan
- FS: K&N panel filter
- EVO 8/9 A/C compressor
- FS:Injen Intake pipe
- Wtt buschur racing 3" tbe catless/muffler delete
- For Sale: FP Red, Buschur manifold, Invidia O2, Intake Manifold ported
- FS: FIC 1050cc Fuel Injectors for EVO 8/9
- F/S (SC)HKS Type II BOV
- RRE Crank Case Breather / Catch Can
- Perrin catback Evo 8/9
- FS: QTP 3" cut out with Y adapter
- Evo 8/9 Forge Diverter valve
- EVO VIII parts(less than 30k miles)
- FS: Evo 6 OEM radiator fits Evo 8 & 9
- FIC 1050 injectors and Billet motor mount
- Real Hp For Sale,Ams,AEM,Stock 9 turbo,Headway head
- Fs evo 8 cylinder head
- evo 8 test pipe
- SPARKTECH non-cdi COP
- Fujita F5 Intake, Evo 9 MAF, ETS Recirculation Pipe
- NYC: Evo 8/9 Knock sensors
- NYC: Ross Pistons
- NYC: MAF+HKS Filter
- NYC: Idle air control valve
- FS(NY) Exedy SD Cover/OEM Turbo Gaskets
- Megan o2 housing, Walbro 255, OEM injectors, OEM MAP
- OEM Evo IX Cams
- NIB Evo 8 Water Pump
- Hallman Pro MBC
- Mini Battery Tray
- !!!!!ams street fmic for evo 7-9!!!!!!
- FIC 1050cc $245
- NJ: Evo 8 and 9 3" high flow cat catalytic converter
- NJ: Evo 8 5 speed transmission
- Tx- Forge, K&N, and KYB w/Swift sport springs.
- AMS evo 7,8,9, downpipe mint condition $175 shipped obo
- 6 speed shifter assembly 50 shipped
- Tanabe ultra medalion touring exhaust $350.00
- Greddy profec b spec 2 boost controller $140 SHIPPED OBO
- Buschur racing wrinkle black powder coated turbo air inlet pipe $130 shipped
- Buschur maf filter adapter kit. $35.00 shipped
- MASS AIR FLOW SENSOR maf. perfect condition. 75 shipped
- Cosworth M2 evo 9 cam set. 815 miles. 400 shipped.
- FS: Fuel Pump (Evo IX Stock pump)
- Halteck Sport 2000 platinum
- FS: HKS 272's, Greedyevo2, and more
- FS:CO BNIB 4xWiseco HD 6596M855AP $540shipped
- FS: GrimmSpeed 3-Port
- FS: Tial Q/QR BOV Black Spring - 7psi
- FS: Tial Q/QR BOV White Spring - 9psi
- FS KN Typhoon, VIII OEM Fuel Pump and DV
- FS: Tial 50mm QR BOV Bottom Section
- FS: Forge MBC - Black
- Injen Intake, Buschur Racing Exhaust Manifold Heatshield, Weapon R Oil Catch Can
- AEM EMS V1, RC 1000cc, FIC 950cc
- Wiseco 1400HD 85MM PN# K626M85 pistons F/S
- MiTech Part out Sale need gone
- AMS UICP! Brand new!
- (FS) Gt3076 ball bearing
- Denso UNDER COVER COP COILS
- Stm 4" intake, MAP, oem
- Works Exhale Catback exhaust
- FS: JDM 3bar MAP
- 2 Stock FMIC $40 plus shipping for each!
- Evo 8 OEM Master Gasket Kit
- Evo 8/9 Double Pumper
- Ets 4" fmic
- Manley Pistons
- Exedy twin disk
- Bnib Cosmetic 85mm headgasket evo 8&9 $80 shipped
- ETS intake, Hypertune IM
- **FS** Buschur Coil Cover/Evo 8 Coils/Wires/MAF
- Grimmspeed EBCS and PPI O2 housing
- Alpha stuff. All kinds of chick magnet parts!
- FS: 3 inch Short Route Intake Pipe ACD and MAF compatible
- Oem Ignition coils/ Oem MAF/ more ....
- BNIB HTA71 $1100 shipped (48 states)
- RMR Speed Density Intake
- FS; OH: 04 aftermarket 05 03 evo 8 viii apexi exhaust, valve cover, intake manifold
- AEM intake evo 8/9
- FS MI: Evo 8 shortblock, Manley crank
- FS: Complete Injen Intake & Intercooler Piping Kit and custom LICP
- FS: Built Evo 9 2.0 10.5:1 & Headgames Evo 9 head w/ GSC S3's
- Short shifter, Licp, maf intek
- AEM EMS Series 2 EVO VIII
- FS: Competition twin disc clutch - 200 miles
- 700whp+/567TQ Entire Setup up for Grabs.
- Evo Heads, Evo 9 Tails MINTY Condition
- FS: MI BR Speed Density UCIP with IAT bung and Tial Bov flange
- FS: MI 3.5'' BR Delux intercooler
- FS: MI Evo 8/9 SparkTech Non CDI Ignittion system
- FS: MI-Modded Walboro 255 with only 50 miles on it....Perfect condition!
- FS: dsm 2g EPROM ECU
- FS: BNIB FIC 1250CC Injectors $370 Shipped
- FS: Tactrix 2.0, Omni 4 bar, Stock ECU
- Fs: arp head studs and Pte 1000cc injectors PA
- FIC 1450cc Injectors $320 shipped
- Precision 1000cc injectors APR Front Splitter
- Tactrix 1.3 Cable
- Apexi Intake, ACT Streetlite and OEM Flywheels!
- FS: Valve cover & intake manifold.
- Baby on the way sale!
- T3 FF Man., ID 2000cc Inj, DIY Double Pumper STM Rad Bracket and Clutch Stop, OEM
- Braille small battery kit
