- FS: Evo 8 Radiator Fan Controller Module + fan, oil cooler
- Turbo XS UTEC
- Jam Stage 4 Head.
- 2.4 stroker fully assembled longblock
- EVO IX fuel injectors, fuel rail, FPR
- Full Blown EVO 8/9 Dual Pump Housing with Walbro Pumps
- FS: Sheptrans 5 Spd Transmission / 4.11 Final Drive / Billet Output Shaft / REM ISF
- FS Custom Downpipe with QTP Cutout 3"
- FS NJ Walbro 255
- FS OEM O2 Housing from Evo IX
- FS OEM Mivec Evo IX Cams
- FS OEM Ignition Coils from EVO IX
- FS OEM Fuel Pump from EVO 9
- evo 9 head (has damage)
- FS: Forge Unos MBC
- Methanol Injection Kit
- MAPerformance o2 Dump Housing
- For sale 4g63 block (bronx,yonkers,mount vernon area)
- Zeitronix Data logger & JM Fab Radiator SS pipe kit BNIB
- FS: (CO) Evo IX Mivec Head
- Tactrix Cable and Brand New pullies, balance belt, water pump, New evo9 bracket
- Buschur Upper and Tial 50mm BOV
- AMS FMIC - New Cast End Tank Version
- Feeler: FP HTA3586...10k miles
- Precision 1200cc injectors
- hks, megan, orbital kit with jvc kw-nx7000
- FS: IL. PTE 1600cc injectors motivated seller.
- Random Silicone Couplers
- FS: ETS T3 kit, mini battery Tray, FP oil line...
- Brand New Double Pumper + Other stuff F/S
- FS: FIC Injectors & Walbro Pump
- Evo 8 longblock
- evo 9 valve cover
- FS: Aluminum MAP Sensor Adapter
- FS: OEM EVO IX Cams (7k miles like new)
- BNIB: Exedy Twin, Amsoil MTG, STM Clutch Line, STM Fork Stop, DV, FMIC, New RUG
- AEM EMS For Sale
- Greddy profec b spec 2 EBC
- FS: Starter, Alternator, AC compressor, mivec gear, manifold ect...
- FS: Evo 8 turbo and BINB Power steering pump
- FS: Tial V44 Wastegate
- FS: NY; Precision 1200cc injectors, BRAND NEW IN BOX
- FS: New B&M oil cooler part #70266 $50
- FS: Quartermaster twin
- Evo 8 factory Valve Cover-RED
- FS 8 & 9 parts
- f.s. exedy twin sd
- Kiggly Racing HLA
- Full Blown Double Pumper Setup Complete BRAND NEW!
- AMS Exhaust, Perrin Test Pipe
- Amsoil 20w50 oil , Tubular manidfold
- FS: (NY) 2003 Evo 8 Transmission, MAKE OFFER
- bnib forge 2.0 pistons
- Evo 8 Stock Turbo, Cams, Injectors, Springs
- FS: slim fan
- Forge recirculating bov
- Buschur Bullet mid-muffler and rear section
- FS: OEM: Radiator fan, Ex. mani shield, intake scoop, batt tray, lower o2 shield
- FS: forge recirc bov *cheap*
- evo 8 oem turbo 34k miles
- FL: EVO8 ECU 185.00 Shipped
- FS: (OR) Exedy Twin Disk Clutch, Hankook Studded Tires 235-45-17
- BNIB tilton disks
- T3 exhaust manifold 50mm runners
- Cobb Evo 8/9 Access Port
- FS: 2006 MR 6 Speed Shifter,Linkage & Motor Mount
- RC injectors
- FS:Brand New Exedy Carbon Twin Disc Clutch KIT
- Works Drop in Filter + Cleaning kit
- Evo Ix parts .. spark tech , custom valve cover , FP5R cams
- brand new battery odyssey pc925
- PTE 680 cc injectors $95
- Ets licp $90 shipped
- FS: OEM: BOV, MAF, Map Sensor, fuel rail
- BNIB Megan o2 Housing
- AEM Tru-Time Cam Gears (EVO 8)
- FS: Manley 2.3 Stroker kit (piston & rods) + AEM Meth kit (1gal)
- FS: Megan 02 housing (FL)
- Wtt gt4094r
- F/S: Megan exhaust manifold, O2 fowler, Forge MBC, Intake, etc.
- Aem 1313u cheap must go!!
- OEM Mitsubishi Waterpump ~20k miles
- Evo 9 Turbo , Walbro FP, Evo 9 Intercooler Pipe (All), Oil Lines, & turbo parts.
- Post-Build Parts Thread (FL) - EVO 9 Block/GT35R/Ramhorn Mani/Tial/Hallman/MISC Items
- FS: OEM Exhaust ,Test Pipe, Downpipe
- FIC 1650cc Injectors...under 500 miles
- Stock Evo 8 Head Parts!
- FS: Evo IX 10.5 Compressor Housing
- HKS Cams/Buschur HTA3582 kit/Piston and Rods/AND MORE
- [FS] Injectors, MAP Oil Line, Ported OEM Ex Mani, RFL BOV, Alcohol Injection..etc
- FS: Stock Injectors
- FS: Tomei Turbo, Buschur UICP, AEM Intake
- FS: Brand New Spark Tech Basic CDI Kit (Evo 8)
- FS: Mishimoto Racing Thermostat (63 C) CHEAP!
- fully built 4g64LR (with oil squirters),carillo rods,cp pistons
- FS: Complete Engine Swaps (Evo 8/9)
- setrab oil cooler setup
- FS: forced performance 18psi wastegate actuator
- FS: 4G63 Evo VIII crankshaft
- FS EVO9 Turbo , 18 PSI HP Actuator , Stock actuator
- FS: 2006 Evo Ix Stock Injectors
- FS: AMS Cam Gear Tool 40 shipped
- FS: BNIB ARP Head Studs $110 Shipped OBO
- K&N Drop-in, ARP Headstuds & Tactrix Cable
- AMS Spark plug cover in chrome
- f/s Evo 9 mr bov and megan manifold (IL)
- Oil/Water Pump & Custom UICP
- Zeitronix Wideband and Screen FS (black)
- Huge partout (600-700 hp+ setup)
- Evo Sheptrans ultimate ratio 2k miles for Sale
- Evo 8 radiator and 4 fuel pump sending units cheap
- For sale: OE Intercooler
- Map Rev2 Intake manifold-coated/egr BRAND NEW!!
- BC Springs/Retainers
- Turbo, 2150's, brakes, MBC, ect.
- FS: FP intake tube
- FS: Mini FUELAB fuel press regulator
- Apexi Super air flow converter For sale
- FS: turbo oil/coolant lines
- F/S: Parts parts parts! Cheap! Lowballers LOVE this thread!!!
- Full Titanium cat back system (magnaflow)
- rare evo 4 valve cover, magnus fuel rail, perrin catch can, billet depot catch can
- new 8-9 oil pan
- Evo 9 Forge WGA
- FS:SPEC SuperTwin P-Spec clutch
- FS- Stock Fuel Injectors
- For Sale Aftermarket goodies of Recent Build
- dual chamber billet depot baffled catch can
- FS: Precision 6262 Ball bearing t3
- Looking for t3 mani for hta35r evo 9
- FS: Evo9 mivec valve cover white/black
- Speed density Kit. Spoolin up harness, 4bar, IAT
- Buschur Racing Hta86 Turbo Kit
- FS:IN: GREDDY Ti-C TBE
- F/S BNIB Exedy clutch kit, lightly used JMFab mini battery kit (Illinois)
- evo 9 boost controller turbo timer ect....
- Ebc
- tomei o2 housing and tomei downpipe
- FS: Tactrix 1.3u
- FS: Stock Evo 9 Injectors...good condition
- EVO 8/VIII Barely Used AEM EMS CHEAPPPPPP!
- FS: Greddy RS BOV
- FS:FL: GT Spec EVO 8 Exhaust Manifold.
- Evo 8 Kelford 272 Camshafts
- FS: Act HDSS clutch kit (PA)
- fs- stock evo8 licp
- fs-stock evo9 down pipe
- CA/stock evo9 air box
- aftermarket 02 haousing and stock for sale
- FS: CHEAP* HKS 272 (Excellent), ETS Mini-Battery Kit (Brand New)
- Perrin 3 port, Clutch Fork Stop
- FS GSC, Manley, Crower, MAP, EVO 9 built head LAS VEGAS
- Low Miles Oliver Rods From AMS 2.3L Stroker
- Brand new recirculating Tial BOV
- SoCal: HKS EVO 8 272 cams
- Shep Stage 2 T Case ACD
- FS: Tactrix Openport 2.0 w/ Mitsubishi reflashing cable & SD card
- Ported Intake Mani, Sun Auto
- FS FP Green Turbo
- Omni-Power 4 Bar MAP Sensor - For Sale
- FS: Haltech, PTE, AMS, Avc-r, IX seats + much more
- FS: Tilton Twin Disk Clutch - Brand New Discs - Evo 8/9
- FS: Hallman Pro Boost Controller
- FS: 100mm 4G64 OEM Crank
- red perrin catch can
- rare jdm evo 4 valve cover
- HKS Intercooler, Turbo XS Intercooler, 16G 10.5
- FS: (IL) AEM EMS Series 2, #30-6310
- high end parts.. magnus' slowboy' shep'avid'ams'stm'arp' cp' manley' buschur
- Fs: FP HTA 3794
- Fs: Ets, cobb & oem
- FS: AMS VSR/BBK body, AEM EMS/AEM 5Bar, Hallman Pro/**** pit, Boomba Adapter/More
- Magnus v5
- Precision 46mm Wastegate
- Greddy Informeter v.1 , $125 shipped
- MAP Sensor - OEM for an EVO 8
- OEM Evo 9 Coil Cover
- Cheap Parts All Under 40 Shipped
- Black Samco Inlet Hose
- Feeler
- COMP Clutch Flywheel / WORKS drop-in filter
- Fresh FP Black 0 miles,FP intake and oil lines
- FS: Stock FMIC, LICP, O2, VIII Cams, Injectors, Springs, Headstuds [MERGED]
- Stock evo IX intercooler, stock evo IX cat
- AMS F1-i intake manifold and stock oem evo 9 throttle body
- 3" TurboXs Testpipe, Stock Muffler & stock Cat
- FS-(NJ) Cusco Twin Plate Clutch (**BRAND NEW**)
- FS: FIC Fuel Rail
- FS: Torque Solution Motor Mounts - 3pc.
- FS: STM Oil Feed Kit
- FS: STM Oil Return Kit ~ NEW
- FS: STM FF Manifold
- F.S. (GA) Feeler on JunB.L catback, cams etc
- FS: Megan Racing Exhaust Manifold
- FS: 50 trim turbo kit
- FEELER FS *** EVO 8 LONGBLOCK *** obo
- FS: Kelford 272 MIVEC Evo IX cams
- FS: ID 2000 (2200cc) Injector Dynamics
- FS: NEW Garrett GTX35R Cheap!
- FS: FIC 1050 Injectors Evo8/9
- FS: 8/9 OEM Exhaust Manifold and Gasket
- FS: ARC Exhaust Manifold Heat Shield
- FS: Fuel Pump Assembly + Stock Evo 9 Cams
- Acd pump *** super cheap ***
- FS: HKS Twin Power DLI II
- FS PA: few stock parts, apexi filter,maf adapter
- Sparktech Pro 12 CDI Setup, Stock EVO 8 Intake Mani, 1600cc injectors
- f/s evolution text pipe
- Exedy Twin rebuildable flywheel turned
- Tactrix Openport 2.0 w/ reflash adaptor NIB
- Aquamist system
- PTE 1000CC Injectors
- Megan 8/9 Catback-Used & Testpipe-New, QTP 3in Cutout Valve-NEW!
- Fs: Walbro fuel pump
- Fs: Hallman pro rx in cabin boost controller
- FS: ARC Induction Box, Injen LICP, UICP, Intake
- 10.5 2005 evo 8 turbo kit with Forge WGA
- o2 Simulator/ CEL fix
- FS: Miscallaneous Intake Parts Evo 8
- FS: Full A/C Airconditiong Unit/Kit OEM Evo 8
- FS: Stock Evo 8 Catback Exhaust System
- FS: Evo 8 Turbo
- FS: (MD) Evo VIII 5spd trans plus swap parts
- FS: OEM O2 housing, IX WGA, clutch slave
- Kelford 280 cams for sale
- FullRace TwinScroll DownPipe
- FS NJ evo 8 fully built head
- FS: OEM VIII Antenna
- FS: OEM VIII Bypass Valve
- FS: OEM VIII Fuel Pump
- FS: Aeromotive Fuel Rail & PTE 1000cc Injectors.
- FS: Brand New EVO 8/9 Front Plate Bracket
- Turbosmart Dualport Bov
- Brand New GT35.82R
- fs - Powerflex side engine (or tranny) mount PFF44-105
- fs - Helix 3" SS High Flow Cat RARE and MINT
- HKS Intake Pipe for stock turbo
- !!! BNIB Long Route UICP !!!
- Wanted stock evo 9 pump
- GT37r Pt67 t67 67mm Ball Bearing Turbo 750hp+
- FS: GReddy TIC and other OEM parts
- Hallman Cockpit Cable Add-On
- FS: HKS SSQV low miles
- f/s tanabe medalion touring evo ix exhaust
- FS: Haltech Platinum Sport 1000 (PA)
- FS: used FIC 1050 Injectors
- FS NJ: Kiggly HLA - BNIB
- For Sale: Helix High Flow Cat barely used!
- NY: AMS race intercooler
- F/S: HKS CAMS Priced to MOVE PERFECT shape NO Issues Look inside
