View Full Version : For Sale/WTB - Engine / Drivetrain / Power
- FS [Mid-Atlantic]: Low Mileage GSC S2 Mivec Cams
- [FS] Working Knock Sensor EVO 8
- [FS] High flow cat
- [WTB] Wtb: exedy IM02 both intermediate plates for triple disc clutch
- [WTB] Throttle position sensor for Evo 9
- FS [West]: Shearer/BR T3 HTA3582 Turbo Kit *Complete*
- [FS] FS cam alignment tool
- [FS] kelford cams 272
- FS [SouthEast]: Evo IX Turbo
- [WTB] magnafuel 750
- [WTB] stock bore high comp pistons needed asap... used is ok
- WTB [Northeast]: Looking for a MINT Evo 7 valve cover. May settle for an 8
- FS [MidWest]: WTB rear diff 03
- [WTB] Evo 8 camshaft reluctor.
- [WTB] 05 EVO or EVO MR ECU
- [FS] GSC Zero Tick Lifters
- FS [Northwest]: ID 2000cc injectors
- [WTB] Vented oil catch can
- FS [West]: Evo 9 ACD Tcase
- WTB [Canadian]: intake MAF WTB
- [WTB] Wanted Cheap Evo 8 plastic BOV
- FS [SouthEast]: FS: Freshly Rebuilt BB black, 25psi actuator, Ported MHI housing, OFH Oil feed
- [FS] Brand new Sheepey Vband forward facing hot parts
- [FS] BNIB Walbro 450 pump (F90000267) with Kit.
- [WTB] Acd ecu
- [WTB] Evo 8/9 Magnus v5 intake manifold & 75mm TB
- WTB [MidWest]: d2 coilovers evo 8
- WTB [Australian]: 4G64 Long Rod Parts, FP Black Turbo,Double Pumper Fuel Pump
- [FS] Brand New Forged Manley 88mm EVO Crank
- FS [Pacific NW]: AMS/TMS T1 head studs
- FS [MidWest]: Gates Timing & Balance Belt T167RB NIB
- FS [South]: AEM short ram intake
- WTB [West]: Fuel rail & fuelab regulator
- WTB [Northeast]: Stock oem evo 8 ecu
- FS [West]: Zeitonix ZT-3 Wideband & Defi Red Racer Boost Gauge
- WTB [SouthEast]: Stock Airbox
- [WTB] Evo 8 oil squirters, banjo bolt, crush washers
- FS [Northeast]: 40mm Wastegate
- FS [Northeast]: JDL Auto Design Full turbo Kit
- [WTB] ACD pump - Working Or NOT
- WTB [West]: Fan Control module
- FS [Northeast]: Gsc evo 9 cams s1
- FS [SouthEast]: Brand New Holset HX35 divided ex. gate t3 housing, Fresh Rebuild!
- [FS] Fp hta71 turbo
- FS [Northeast]: F/s pte-6262-cea turbo
- WTB [Northwest]: Wtb test pipe!
- FS [Northeast]: Exedy Twin, Muse UICP, AFI Industries Exhaust Manifold
- FS [Mid-Atlantic]: Map o2 Dump
- FS [South]: AMS F1-i and boomba throttle body
- FS [South]: AMS 900x turbo kit
- [FS] oem intercooler
- FS [South]: PPG Dogbox
- [WTB] Power Steering pump bracket
- [WTB] 156mm rods
- WTB [West]: OEM IX thermostat and thermostat housing
- [WTB] WTB: 8-9 transmissions in need of rebuild
- FS [Northeast]: Fs ets 3" fmic
- [FS] Complete CBRD BB BBK-B turbo with upgraded tubular mani, O2 dump, LICP & intake
- FS [Northeast]: Buschur Intake and OEM MAF
- FS [South]: Must go! Make offers iac, head, injectors, etc...
- WTB [South]: Bov to hold 30 psi vta
- FS [Northeast]: Taylor battery box
- WTB [MidWest]: WTB Evo 9 Head
- [FS] Evo 8/9 RC1000, GM 3-port boost solenoid
- [WTB] Ralliart Cooling Panel
- [FS] The last fuel system you will ever need!
- [WTB] EVO 8 head stock or modified & cams if possible
- WTB [Northeast]: Good 5 speed trans
- [FS] PTE CEA 7275 for sale
- [FS] FIC 1120, Tactrix, Grimmspeed, Omnipower
- WTB [Northeast]: Wtb OEM 100mm 4g64 crank
- [FS] Mass Air Flow Sensor MAF
- FS [Mid-Atlantic]: evo 8/9 turboxs rfl blow off valve
- FS [SouthEast]: JDM EVO X MAP Sensor
- WTB [West]: Alternator for IX
- [WTB] WTB T4 turbo manifold
- FS [MidWest]: Greddy Ti-C Cat-back Exhaust - Evo IX
- WTB [Canadian]: wtb jdm map sensor
- [FS] Engine Goodies *Must Sell*
- WTB [West]: 4" SD complete intake kit for FP Black
- WTB [Northeast]: WTB Evo 9 aftermarket exhaust manifold heatshield
- FS [West]: Shearer ff kit full v band complete
- FS [Northeast]: Boomba racing front mount
- FS [Northeast]: Spoolinup COP CDI evo 9
- [WTB] Evo 8 TPS Sensor
- [WTB] Working Evo 8-9 Rear diff with axles.
- WTB [Canadian]: fujitsubo legalis r OE other quiet exhaust
- FS [Canadian]: Evo 8 Stock Turbo TDO5HR-16G6/9.8T
- WTB [Canadian]: evo 9 turbo, FP green,bbk lite/full
- WTB [West]: Small battery kit compete
- FS [MidWest]: ACD Tcase, ACD ecu, ACD pump
- FS [SouthEast]: FS: Mass Air Flow Sensor MAF
- FS [SouthEast]: Ets licp, jdm mr bov
- [WTB] Exedy Twin CM06S pressure plate + more
- FS [South]: FIC 1650cc Low Z Injectors 1k miles
- FS [Northeast]: Evo 8 koyo rad
- [FS] Wiseco 85.5 pistons (9:0:1 ) low miles
- [WTB] Greddy or Apexi EBC
- WTB [Northeast]: 5 speed swap parts
- WTB [MidWest]: oil catch can setup!!
- [WTB] OEM Timing belt kit, Serpentine, L19, Oil Cooler
- WTB [MidWest]: NON Acd Tcase
- FS [Northeast]: Twin 450 fuel pump setups
- [WTB] Need Ignition Coils for EVO 9 OEM new or used
- [WTB] Fuel Level sensor
- [WTB] Evo 8 LICP
- [WTB] Map Rev o2 housing..
- FS [South]: Evo 8/9 parts "offers accepted
- FS [Northeast]: 6266 top mount kit, shep ulti w/4.11, 280 cams, FIC inj ETC.!!
- WTB [Northeast]: Stock evo 9 bov
- FS [MidWest]: Aeromotive A1000 FPR
- FS [Canadian]: OEM Rear Main Seal and 4G63 ARP Flywheel Bolts
- [WTB] uncrushed, OEM IX recirc/BOV
- FS [SouthEast]: Carbonetic triple disc clutch
- FS [MidWest]: CP 2.0 Pistons
- [FS] Evo 7 valve cover,Sard fuel rail, fuel lab fpr, carbon fiber ebrake, ralliart oil cap
- FS [Northeast]: EVO 9 turbo converted to a 25G
- FS [Pacific NW]: GSC S2 Cams, Springs and Cam Gears Evo 8
- [FS] Evo 8/9 clutch kit/act flywheel jm fab intake pipe and catch can
- [FS] Curt Brown ported intake manifold. .never used!!
- FS [West]: FS: Diaqueen LSD Gear Oil. CHEAP!
- FS [West]: Brand new Injen UICP- still wrapped
- [FS] 0-tick/testpipe/motor mount/spring&retainers
- [FS] 2.2L, AFI T4 turbo kit
- WTB [Canadian]: EVO 9 Turbo in excellent condition
- FS [SouthEast]: Comp cams, coilovers, speed density intake
- FS [SouthEast]: Buschur O2 housing, FIC 1450cc inj, APS BOV, Forge BOV, and Orbital DD Kit
- FS [Northeast]: Carbon fiber valve cover ..cover
- FS [Northeast]: Jm fab ss turbo outlet housing external dump
- [WTB] exhaust manifold gasket and turbo to manifold gasket
- [FS] Brand New FF 6466 and ETS Hot parts kit
- FS [Northeast]: BNIB 2.3 Rotating Assembly.... Cheap!!
- FS [Northeast]: Small Garage Sale Evo 8/9 Parts
- [FS] Evolution 9 BOV and DC Sports tubular manifold
- FS [West]: ARP Head Studs
- FS [SouthEast]: FS: evo 8 tb, small battery tray, koyo radiator, spark plug cover, and valvecover
- FS [West]: ETS intake pipe & couplers
- FS [Northeast]: Evo 6 valve cover and carbon fiber cover
- [WTB] Built motor
- FS [Northeast]: Buschur ported exhaust manifold
- [WTB] 4g63 block
- FS [West]: [CA] XS Engineering Intercooler
- FS [MidWest]: Sheepey Forward Facing hot parts, PTE 6262, Feed/Drain lines
- [FS] OEM parts, a/c condensor, mesh, etc.
- [FS] Buschur 272 cams, AEM cam gears, ETS upper IC pipes
- FS [Pacific NW]: Buschur HTA35R Turbo Kit
- FS [West]: Evo 8/9 Stock Exhaust Manifold
- [WTB] FIC 1450cc Injectors
- FS [West]: [CA] ID 2000cc Injectors
- FS [Northeast]: windshield washer hose parts
- WTB [Mid-Atlantic]: EVO 8-9 oem mustache bar
- FS [MidWest]: Forge Evo BOV - cheap
- [WTB] Parts
- [FS] Brand New Manley 4340 Billet Crank 100mm stroke Mitsubishi 7 Bolt Stroker
- [FS] Manley Platinum Series Lightweight Pistons (2.3L Stroker 7 Bolt DSM / Evo)
- FS [Northeast]: 600hp Parts ( Full Blown 70mm TB, Full Blown Double Pumper, ID 2000cc etc )
- FS [Northeast]: evo block
- FS [Northeast]: EVO 8 crank polished ready to bolt in
- FS [Northeast]: SRP std size piston
- FS [West]: Perrin Intake, Forge DV
- FS [West]: Rebuilt(Works) OEM Evo IX Turbine
- WTB [MidWest]: WTB: QuarterMaster Hydraulic TOB
- [FS] OEM Exhaust manifold - OEM MAF sensor
- [FS] 3" High flow cat
- [FS] FP HTA3586 with Tial .82 Vband
- [WTB] Evo ix bare block
- FS [MidWest]: AMS Polished VIII Spark Plug Cover
- [WTB] Ext cam 280 degree duration and above
- FS [SouthEast]: 05 Evo 8 5 Speed Trans - Built by Jacks Trans (Stage 1)
- [WTB] Blown 8 turbo
- [FS] brand new OEM head gasket 4G63
- FS [South]: JB FPBLACK full kit
- WTB [Northeast]: Id1300
- FS [West]: FS: Redline MT-85 (3 Quarts)
- WTB [Pacific NW]: ETS Intercooler 3 or 3.5 for an 8
- [FS] Evo 8: JB FP Black, Invidia O2 housing, Invidia DP
- WTB [Northeast]: Bare stock evo 8 head
- WTB [MidWest]: ISO intercooler pipe set (upper and lower)
- [WTB] Injen uicp and muse or ets licp
- [WTB] BLACK avid racing motor mounts
- WTB [West]: WTB E9 good cond Drive Shaft.
- [FS] FS: Buschur UICP
- WTB [Northeast]: STM 20 mm spacer and studs
- FS [Northeast]: FS: IX BOV 12k Miles -- WW *MINT* WING
- [WTB] EVO 8/9 fuel tank, lines
- FS [Northeast]: Evo IX Turbo (ported, 29k miles)
- [WTB] 2004 EVO RS t-case (with LS), non-acd, stock
- FS [SouthEast]: NEED GONE! ETS, Sparktech, PTE, Borg Warner, Tial and More
- FS [MidWest]: *NEW* OEM Mits Evo8 Metal Head Gasket
- FS [SouthEast]: Evo 9 valve cover
- FS [Northeast]: HTA30r turbo kit, muse licp, perrin dp, &more (pics heavy)
- FS [South]: **cheap**Ported and polished Intake manifold. perrin boost controller .Fighters LICP
- FS [Northeast]: Kelford 280 Evo 8 cams NJ
- WTB [MidWest]: wtb: works 3" downpipe or turboxs 3" downpipr
- [FS] Buschur FS635 turbo and cast manifold
- [WTB] Tranny for my 04 VIII
- FS [MidWest]: APR Mirrors, APR Spark/Timing Covers, DW Fuel Pump and FIC Injectors.. and more
- WTB [West]: 4G63 Bare block or built block
- [FS] Tomei procam 280 mivec
- [FS] Synapse DV CHEAP!!
- WTB [Northeast]: looking for perrin intake evo 8
- FS [Northeast]: Buschur double pumper fuel filter
- WTB [South]: Bov "hold 30 psi +"
- WTB [Northeast]: Looking for a shortblock , built preferably
- [FS] Exedy twin disc hd
- [WTB] Old Style AMS RACE FMIC 3" inlet/outlet
- FS [SouthEast]: New Exedy Twin+ more
- [FS] Modified Valve Covers: Evo 8 with -8AN Fittings & Evo 9 MIVEC with -10AN Fittings
- [WTB] cam Intake 272 or 264
- [FS] Buschur Racing / TCC - 3" turn down exhaust / cut-out pipe
- [FS] Buschur Racing / TCC - 2.5" Intercooler Piping (UICP/LICP) + Tial 50mm BOV
- WTB [MidWest]: WTB Evo 9 oil return line
- WTB [Canadian]: WTB Evo 4 Intercooler Pipes
- FS [Northeast]: AMS Intercooler FMIC
- FS [South]: Fs Spoolinup cop & Flossy shift knob.
- [FS] STM vented dip stick, BNIB -6 AN fittings (11 total)
- FS [MidWest]: Evo 8/9 Parts
- FS [Northeast]: AEM EMS V1 Evo 8
- WTB [Northeast]: Tactrix Cable
- WTB [Northeast]: Half radiator
- WTB [Northeast]: Looking for stock undertray 8/9
- WTB [Northeast]: Spooling up cop cdi or non cdi
- [FS] GSC & JAM Lifters
- [WTB] WTB: EVO 8 ECU & MR o2 housing
- [FS] Wiseco pistons, Manley rods, ets 3", burschur uicp, Perrin fuel rail
- WTB [SouthEast]: Stock or ported stock exhaust manifold...
- WTB [SouthEast]: Wtb stock evo 8 head
- [FS] new stage 2 shep evo 8 t case!
- FS [Northeast]: Nisei mini battery tray/ 5 speed bracket
- FS [MidWest]: Stock Evo 8 Air Box, Tial 44mm WG, AEM filter
- [FS] Shop clean out
- WTB [MidWest]: WTB Evo IX Turbo
- WTB [Northeast]: WTB: Evo 8/9 oem motormounts
- [WTB] Fp black bb
- [FS] Buschur 272 cams, Evo 8 head, kiggly springs, regulator, L19s, Fic 950cc injectors.
- [FS] FS evo 9 valve cover $220.00
- WTB [MidWest]: mivec fitting for head
- FS [Northeast]: EVO 7 valve cover
- [WTB] t3 manifold
- FS [Northeast]: Evo 8 Valve Cover $250 Shipped
- [WTB] Manual Boost Controller MBC
- [FS] FP Red turbo, BR race FMIC, Mini battery kit
- FS [West]: Garrett .82 A/R Divided T3 inlet w/ 3" v band Exhaust housing GT3582R,GTX3582R
- WTB [Northeast]: Oem parts/JM Fab
- FS [Northeast]: Comp stage 3 clutch and ACT street lite flywheel
- FS [Northeast]: JE pistons std bore
- [FS] Stock evo9 turbo
- [WTB] 3inch dp
- WTB [Northeast]: WTB evo 8 head!!
- [FS] TurboTrix Manifold T4 44mm Vband Tial Flange
