PDA
View Full Version : For Sale/WTB - Engine / Drivetrain / Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. FS: Miscellaneous/Maintenance/OEM Parts.
  2. JDL Stock Replacement Hot Parts Kit - Ceramic Coated
  3. MAP EF3 - Ported, Anti-Surge, Oil Lines, Etc...
  4. FS:FP Green,GT35R T4,JMFab,ETS,MAP etc
  5. FS: 4-Bolt Precision .82ar
  6. FS: Built 2.0L Filled Block
  7. FS: Map performance Heat shield
  8. FS: Forge RS Bov
  9. FS: HKS 280 camsshaft evo8
  10. FS: HTA Fp Green Turbo kit
  11. FS: walbro 255
  12. feeler: Bbk Full
  13. FS Evo 8 Hks272s, Throttlebodies(upgraded shaft seals) intake manifold, springs/retai
  14. FS: Wiseco HD pistons
  15. FS: DS OEM Throttle Body+TPS+IAC
  16. FS: STM Standard placement 6466 BB
  17. FS: Buschur 3.5" Intercooler *NYC*
  18. FS new turbotrix vband mani, dp, tial44
  19. Boostin Performance built NON ACD tcase
  20. Synapse synchronic bov 16002A $140
  21. BNIB Muse o2 Dump
  22. Test
  23. Evo 8 catalytic converter
  24. Basically brand new Purple Tial Q BOV
  25. ETS intercooler and UICP
  26. FS: Stock Evo IX parts, Evo VIII Camshafts, Titek 02 housing
  27. fs: evo ix injectors
  28. FS: ID 2000 and ECU
  29. FS/FT: Saikou Michi Dual Chamber Catch Can
  30. Fs Used OEM Evo 9 turbo in great condition.
  31. Aluminium Fly Wheel, Clutch Disk, GSC, Ichiba Spacers, BW Turbo,
  32. WTB 2.3 Stoker kit or parts
  33. FS HKS 264/272 cams
  34. stock intake/exhaust manifold, spark cover
  35. fully built parts, buschur hat86, wiseco, manley, evo 8 GSC S3, walbro 485 and more.
  36. Brand New Balance Shafts
  37. FS Mia FL. New Precision 6466 BB Turbo with stainless rear housing. $1700 Shipped
  38. jm fab evo 8-9 manifold new.
  39. Aftermarket O2 Housing- Free Shipping!
  40. Competition Clutch Release Bearing Kit- Free Shipping!
  41. FS CA Milspec 100cell 3' cat, Stock Evo IX Cams, ARP headstuds
  42. 2006 Evolution ix Engine Wiring Harness F/S
  43. Brand New Extreme Psi Air Intake
  44. F/S: "New" Stock DENSO FPR
  45. FS: CBRD OEM replacement radiator - Evo8/9
  46. tons of parts..intakes, boost controller, manifold, bovs, wristpins, 4 bolt o2, ecu
  47. FS: AEM Tru Boost w/ Gauge Pod
  48. FS: FP4R mivec evo 9 cams and FIC 1450 bluemax
  49. Evo 9 Mivec Kelford 272
  50. Exedy Triple Cerametallic HR Clutch Kit 5/6-speed (MM023HR)
  51. FS:ND *USED* MAP Evo8/9 Short Runner Tubular Header
  52. hks cam gear
  53. Turbo timers CHEAP
  54. Innovative wideband
  55. AGP 3.5" intercooler
  56. FP HTA Super 94
  57. Buschur Racing Stage 3 Evo 8 Cylinder Head
  58. EVO 8 kelfors 280/280 cams brand new
  59. FS (MO): OEM MAF Sensor
  60. Fs: RS Rear Diff Assembly and tcase 15k
  61. FS: MAP tubular manifold and MAP o2 dump
  62. FS: OEM Intake Manifold And Throttle Body
  63. FS: Buschur Racing cast 30/35R kit, cheap!
  64. Brand New HKS 272 Cam
  65. FS: AMS FMIC V1 AMS LICP V2 , Extreme PSi, Forge, OEM
  66. fs 3" intake with big maf,bov and filter
  67. fic 1050 and evo 8 ecu
  68. F/S EvO rear wiper assembly
  69. FS: AEM Series 2 EMS for EVO 9
  70. FS: AMS/EXEDY PUSH STYLE Twin HD Clutch Kit with PULL STYLE components.
  71. FS: Evo 8/9 aftermarket HTA FP green, HKS280 cams etc. And stock
  72. FS: Evo 8 ECU
  73. F/S ODYSSEY PC925MJ-A battery
  74. wtb precsion 66 trim vband in/out
  75. "new" gsc s3's and zero tick lifters - $475 shipped
  76. Shep Stage 2 t-case w/Quaife
  77. 100mm Mitsu Crank
  78. 4" Speed Density Intake for Stock Turbo
  79. Ball Bearing 6765
  80. Fs: Turbo trix uipc with AIT bung & synapse bov
  81. Evo 8/9 Test Pipe
  82. WTB valve cover for EVO 8!
  83. Parts for sale
  84. EF2, HKS Cams
  85. WANTED: t3 4 bolt outlet .63 or .82 turbine housing
  86. FS: Autometer Ultra-Lite Gauges (Fuel Pressure, Boost, & Air/Fuel)
  87. FS: EVO 8 MAF & AEM Adapter Plate & Filter (CHEAP!)
  88. Forge WG Acuator, JDL Autodesign O2 dump, FP Intake Pipe
  89. Prepped 4g64 block $250
  90. Custom tray for Miata battery, CAS, delete belt, Greddy BOV flange, vacuum block
  91. [FS] Evo 8 turbo kit garret gt30
  92. Wanting AMS race fuel rail or Magnus with -10AN fittings.
  93. FS: GSC S2 / MAP Valve Springs / TiAl QR Lower
  94. [FS] Kelford 272 and more
  95. FS: ID 2000 injectors only
  96. FS: nice brembo rear calipers
  97. FS: New headstuds, New headgasket, new MAP springs/retainers
  98. Stainless brake lines + STM Full Clutch Line (BNIB)
  99. FS (MI): Evo8 AEM EMS V2 part# 6310 + Motec Map + IAT sensors
  100. FS:Tial 44mm v-band Wastegate (PA)
  101. ToxicFab baffled aluminum race catch can. Brand new, battery location
  102. Fs: buschur Cdi harness, evo mr gauges, intake manifold ect
  103. WTB: stock evo9 turbo
  104. WTB ATS clutch repad kit & GSC S3 non mivec cams
  105. STM std Hotparts kit + more
  106. Evo IX BOV
  107. FS: Snow meth kit, Stock intake manifold &TB
  108. BNIB Evolved Components Forward Facing Half Condenser AC set up!!!! F/S
  109. FS Invidia o2 Housing
  110. Wtb stock evo 8 or 9 turbo
  111. GA: Spring Cleaning Sale
  112. FS: FIC 1450cc BlueMAX Injectors
  113. Walbro 400 fuel pump
  114. FS: LICP, Downpipe, Test Pipe
  115. Greddy ti 3' full titanium exhaust
  116. Stock Evo 8 Catalytic Convertor- OH
  117. FS: AEM EMS-1313 ECU for Evolution 8 (CT9A) 03 04 05 *FREE GAUGE & POD*
  118. Need a downpipe for my 6262 t/3t4 set up
  119. Driven Concepts FF half Condenser ac kit F/S
  120. Wtb: Evo 8 Compressor
  121. FS: FID Fuel Rail, Perrin, JMF, CC, OEM Crank and TONS of OEM Parts/Sensors
  122. Kinugawa WG 1.2bar brand new
  123. FS: New T-Clamps - Variety of Sizes.
  124. Cleaning my garage out-LSD,Stock Injectors,Stock exhaust manifold
  125. FS: Injector Dynamics I.D. 2000 Adapter Harnesses
  126. Clutch fork postion JUST installed clutch 5 minutes ago
  127. FS: OEM Intake manifold/TB, 3" test pipe, Sensors, MAP adatper, etc
  128. FS: Brand New - FP Race J-Pipe
  129. WTB- CF Steering wheel gauge pod
  130. 10.5 hotside, Evo 9 Turbo, misc stock parts
  131. Mint set of kelford 272 cams evolution 8
  132. F/S EvO Autometer steering column gauge holder
  133. F/S EvO 8 front strut bar
  134. F/S EvO 8 OEM ECU case
  135. F/S EvO 8 OEM Radiator Fan
  136. Fs hks exhaust and test pipe
  137. FS: Fujita Intake
  138. Fs:ny koyo R 4/5/6 radiator
  139. Ball Bearing 6765
  140. ETS LICP, Injen Intake, Megan Exhaust Manifold, OEM Intercooler
  141. FS: TurboTrix Hot Parts and Tial 44mm gate
  142. FS-NY: walbro 450lph e85 fuel pump
  143. FS: 4G64 Bare Block
  144. FP 84mm intake and HKS Mega Flow filter
  145. FS: 1100cc high z injectors
  146. FP White $1000
  147. brand new o2 housing
  148. Omni 4 bar
  149. Basically New Exedy Twin for sale!!
  150. FS: Cubby Hole & Coil Wires
  151. V-band o2 Housing
  152. WTB: Evo 8 Ecu
  153. fp white, basically new. 1200
  154. 30psi Greddy Boost Gauge $100
  155. Evo 8 10.5 Hotside turbo
  156. FS: Supertech Valve Springs/Retainers $250 Negotiable
  157. FS: Evo 9 Transmission - 49k Miles
  158. FS: Evo 9 Rear Diff - 42k Miles
  159. FS: Evo 8 Block - Virgin Block
  160. FS: Three Speed Scatter Shield
  161. FS: Full race Exhaust Manifold - TwinScroll - T4
  162. FS: Fullrace Exhaust Manifold - T3
  163. WTB: cobb access port
  164. FS: (CA) ACD Pump
  165. FS: GSC balance shaft delete kit. NIB
  166. FS Stock Fuel Injectors
  167. WTB: Small Battery Kit
  168. Hallman Pro Rx MBC & BOV
  169. WTB AEM V2 for evo8
  170. FS: OEM EVO 9 Idle Air Control Motor (IAC)
  171. WTB 1000cc Injectors and stock frame turbo
  172. CA: BORG WARNER S200SX 7670 Turbo
  173. FS: Freshly built Evo 8 shortblock
  174. 2x 8 lifters
  175. WTB: TQ Solution mottor mount
  176. FS: 06 Evo 9 SE ACD t-case 20k miles
  177. Build Part out!!! GSC, RPF1, AEM, T3 Kit, SD set up, fuel, sparktech
  178. Ef4 ported, Doc race mani, muse dump, BR
  179. half radiator with SPAL 1770cfm fan-new, unused
  180. FS: NOS Direct-Port Fogger Wet Nitrous Kit
  181. FAL Shrouded Puller Slim Fan - New
  182. F/S EvO AMS 6 speed transmission mount
  183. F/S EvO 8 Mishimoto Radiator
  184. Arc intake box evo 8/9 150 obo
  185. Stock exhaust mani, injectors, arp headstuds
  186. EVO 8/9 - IAC, MAF, MORE Parts!!!
  187. Arc intake box evo 8/9
  188. ETS Intake w/ Perrin filter , oem 9 MAF
  189. Lots of parts, clearing garage, Forge Motorsport,Tial,TeamTech,Autometer,Link,etc
  190. FS: Evo V turbo with manifold
  191. FS: FP Red BB,cam gears etc
  192. FS: EVO 8 MAF w/ AEM Adapter Plate & Air Filter
  193. ETS Battery Tray
  194. NJ--Grimmspeed 3 port EBC
  195. FS: ACD Transfer Case - Evo 9 - 28k Miles
  196. FS: EVO 8/9 Torque Solution 5-spd Short Throw Shifter
  197. FS: FIC 1050cc Injectors
  198. FS: Front O2 Sensors *NEW*
  199. evo coil on plug ignition
  200. F/S- Mini-battery (NJ)
  201. Tial mv-s 38, stock evo ix throttle body ecu and ets bpv return hose
  202. FS: Evo 8 Stock Turbo (NM)
  203. Precision 6262, T3 turbo
  204. FS: Brian Crower 272 Cams and Evo 8 Stock Cams (NM)
  205. New OEM Evo IX Thermostat
  206. HKS Panel Filters (2) and Stock Intake Box
  207. FS: Wiseco 1400 hd 10.5:1 pistons BNIB
  208. FIC 2150s, COP, Perrin, Invidia, Etc
  209. evo coil on plug ($100.00)
  210. FS: OEM IX Cams
  211. ARC super induction air box
  212. FS:gt3076R
  213. fp green hta 73
  214. Evolution ix wire harness and AEM F/S
  215. Race Intake Manifold + BBK Throtle body
  216. AMS modified Head Gasket 87mm for 2.4 BNIB
  217. WTT: USDM bumper buschur sd catback exhaust for jdm rear bumper exhaust.
  218. FS: ARP Head Studs
  219. Go fast parts. Aem ets mishimoto hks, arp
  220. OEM Evo 9 Turbo (16G)
  221. FS: STM 3" Intake Pipe Kit - Blaine, MN
  222. Evo 9 turbo 20k Miles w/ Jpipe
  223. FS: Used Tial 50mm BOV
  224. BNIB OEM Evo 9 Thermostat
  225. Mishimoto radiator fan with shroud
  226. F/S Fuelab fuel filter
  227. FS: Walbro 450lph E85 pump 9000267...
  228. FS: BME aluminum rods *NEW*
  229. FS: Stock IX shortblock, FP4 cams, stock evo 9 turbo
  230. Hot Earth EVO 7-9 Spark Plug Cover
  231. HKS Carbon Ti exhaust
  232. 2006 Evo ix A/C Fan F/S
  233. FS: Cobb Exhaust
  234. FS: Walbro 255 Fuel Pump
  235. AL: FS BNIB Evo VIII Kelford 272 cams, BC springs and retainer, and more!!
  236. FS: OEM Carbon Fiber E-Brake Handle, Redline MT82, OEM Battery Tie Down
  237. Autometer Ultra-Lite Gauges (EGT, FPR, Boost, & Air/Fuel)
  238. FS: NM Precision 46mm external wastegate
  239. Garage sale: FP 25 WGA, megan 02, greddy
  240. Tomei Expreme O2 housing + Downpipe, evo 8 turbo, evo 9 single flapper 10.5 hotside
  241. Quartermaster 8-Leg Clutch
  242. Precision 6262BB
  243. ACD system for sale
  244. FS: Evo 8/9 6speed ACT flywheel
  245. FS: AEM carb legal sticker
  246. Evo 8 Head.
  247. Evo 8 head, built complete minus cams.
  248. Manley Turbo Tuff 100mm Crank, Rods and Pistons (New)
  249. Grimmspeed EBCS & FIC 1150's
  250. FS: AMS clutch lines Buschur racing catch can WR catch can
