PDA
View Full Version : For Sale/WTB - Engine / Drivetrain / Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. BNIB Wiseco Piston Kit 1400HD EVO/ 7bolt K626M86
  2. ets uicp, modded evo 9 stock bov, oem ported intake manifold
  3. Brand new Precision 6265SP turbo
  4. Used ETS 3.5 Intercooler
  5. evo 8/9 downpipe non acd
  6. FS: Cams - OEM, HKS, GSC (OH)
  7. MAP AFPR Install Kit w/ AEM FPR, Walbro High-Pressure 400lph, Modded Walbro Housing!
  8. Small clean out evo 8/9 parts
  9. FS TBE Exhaust
  10. PPI upper & lower intercooler pipes// Buschur Mini Battery KIT//Forge bov
  11. FS: Grimspeeed EBCS, GSC Behives BNIB
  12. FS: P&R evo 9 turbo, EPM o2, GSC S2, ported exhaust, exedy twin
  13. Nisei Engineering Intercooler Pipe Kit Evo 8/9 + Mini battery kit
  14. FS: cosworth 272 m2 cams evo 9
  15. FS: Ported 9 turbo, ETS LICP, TIAL 38mm, OEM, AEM, Megan
  16. F/S: Brand New AEM Series 2 EMS for Evo 9
  17. FS:bnib fidanza adjustable evo8/9 exhaust gear
  18. FS: aftermarket goodies
  19. buschur o2& dp, fx300 with flywheel, 1000cc's pte and evo 9 turbo
  20. AEM ems series 2 Excellent shape.
  21. FEELER: HKS gt2 7460r
  22. FS SHEARER T3 GT35R turbo kit complete!
  23. some good parts
  24. Intake Pipe, Shifter Bushings, and more
  25. SC: Brand new Evo 9 Water pump and bracket
  26. 1000cc injectors & more
  27. Mr bov not crushed
  28. FS: Front Facing Turbo Kit AC & Filter Compatable
  29. Odyssey PC680 Mini battery *Cheap*
  30. Top End Parts: Toxicfab O2 Dump, Shearer mani, JM Fab, Etc
  31. Fs: Grp aluminum rods & cp pistons
  32. Fs: Bnib tomei procam 270 evo ix
  33. Aem Tru Boost Gauges,stock evo 8 parts
  34. FS: BNIB kelfords 280's MIVEC
  35. 03 Evo 8 Cylinder Head
  36. AMS 5 bolt O2 housing recirculated
  37. Pte 1200
  38. Apexi AVC-R, HKS Downpipe CHEAP !!!
  39. FS: 2 Forge RS BOV's
  40. ACL race std bearing set
  41. Grimspeed MBC
  42. Evo 8 Turbo + Oil Cooler + Tial 44mm Wastegate
  43. FIC 1450 injectors
  44. FS: cosworth 272 s2 cams evo 9
  45. Equal Length T3 Manifold, NEVER USED!!!
  46. Intake pipe, OEM 8/9 FMIC
  47. Fs: Almost new fic 2150 high z cheap!
  48. FS: BW 362 kit...
  49. FS: Stock Crank..60k miles. MINT
  50. FS: Evo 8 / 9 OEM/aftermarket parts
  51. FS: WORKS Aperture Kit
  52. FS: PTE 1000cc Low Impedance & New FIC Viton Seals
  53. FS: PTE 6262 ball bearing turbo
  54. FS (NC): Stock IC and valve springs
  55. HALLMAN Boost controller;red; $65 shipped
  56. Exedy carbon twin plate and je 2.0 pistons brand new in boxes
  57. ATP GT3582r Stock Frame Turbo, Shearer Mani, Toxic Fab Dump, And More!!!!!
  58. OEM Stock Spark Plug Wires Evo 9 IX
  59. MAP H11 Headstuds
  60. Bltiz GFB BOV
  61. Evo 8 Turbo + Oil Cooler + Tial 44mm Wastegate
  62. WTS:Evo 9 Turbo-01571 / Black EPM / FP 25psi Actuator
  63. FS: Evo 8 Megan Down Pipe
  64. FS: Exedy twin disc clutch that needs rebuilt
  65. IX Turbo, New MAP Oil Feed Line + More
  66. FS/FT : 6262BB, ETS Manifold Tial 44mm WG, Aeromotive 800 LPH Pump, L19 stud
  67. dual 044 pump holder
  68. custom surge tank!
  69. evo8 performance parts
  70. Going back to stock? Stock parts part out!
  71. hks ssq bov black edition
  72. Saikou Michi Stage 1 Catch Can
  73. TiAL 50mm BOV (Blow Off Valve)
  74. JE 9:1 +0.20 pistons
  75. Fs:sun auto system
  76. Evo8 valve cover
  77. FS: Quater masters twindisk clutch and Cometic Head Gasket
  78. BR MBC for Sale (NJ)!!!
  79. Some parts need to go
  80. BR MBC for Sale (NJ)!!!
  81. PTE 6765 BB Turbo- BNIB
  82. FS EVO 8 PARTS...so cal
  83. FS/FT Mishimoto Radiator used/ Greddy EGT gauge
  84. FS: Tanabe DP, ARP HEADSTUDS
  85. FP HTA86 t4 twinscroll
  86. ETS LP2 Licp, Fujita uicp, BR o2 Housing
  87. Rear drive shafts - 2003
  88. FS Perrin HFC
  89. Openport 1.3 cable and usb to serial converter
  90. Stock VIII cams, O2, bov
  91. Bnib tial wastegate 38mm v-band
  92. BBK Full Ported $1625 shipped
  93. FS: AEM IAT, Cone Filter, OEM LICP, 2 ic couplers
  94. weldon 2035a pump
  95. Evo VIII - BC 272 Cams, HKS 4" Intake, XS Power FMIC
  96. Evo VII - BC 272 Cams, HKS 4" Intake, XS Power FMIC
  97. FS: Ingalls Stiffy Engine Damper (Silver)
  98. RC 1200cc injectors from EVO IX
  99. NC FS: Omni 4Bar MAP sensor BNIB
  100. Some oem parts driveshaft, axles, exhaust
  101. F/s- ets 3.5" ic (nj)
  102. FS evo 8/9 parts
  103. brian crower cams, pte 780cc injectors, acd t case
  104. AEM Wideband/Intake/Cams/Clutch/Flywheel...
  105. ETS LP2 LICP Gloss Black w/ Coupler
  106. FS: used Walbro 255 with filter/wiring
  107. New AWD Speed Density kit w/o bung.
  108. FS: Stock UICP, Stock Battery, AMSOIL, Green Filter, Various
  109. FS: Buschur FMIC
  110. F/S: AMS 3" TBE with cat/test pipes
  111. Fs: Bnib ets aluminum upper radiator pipe
  112. F/S:STRI gauges/Gruppe-S cluster
  113. FS: (CA) OEM intake manifold Evo 8/9
  114. Kelford 272's,BNIB Fidanza Cam Gears,ACL Race Bearings,Stock IG Coils,Springs/Ret,Cam
  115. FS: (CA) OEM Evo 02 housing with sensor
  116. FS: FP Black & ToxicFab Manifold
  117. FS: Hallman Pro Cockpit Controller Add-on Kit (brand new)
  118. Question on prices
  119. FP Green Turbo Kit w/ EPM O2 Dump & Extras
  120. Invidia Stainless Steel Manifold - Evo 8/9
  121. Misc Evo Parts I have Left - Injectors, Sensors, Piping
  122. Acd pump
  123. used evo 8/9 megan exhaust manifold - $130 shipped
  124. FIC 850cc DENSO 720cc Injectors CHEAP!!!! Harness bar, catch can
  125. $100 JM Fab Intake Pipe w/ (New) Vibrant Filter, couplers and Clamps!
  126. evo8 hks 264/264 today only. cheap.
  127. boomba throttle body
  128. FS: BB 30r kit - Manley H beams - Front axles
  129. Bunch of good stuff!
  130. Lots of new and used performance parts here, must LOOK
  131. New pt 6265 jb turbo f/s
  132. Megan racing o2 housing
  133. GM 3 Port Solenoid
  134. For sale 1g race car parts
  135. Side exit o2 dump exhaust in 1. Must see!!!
  136. F.S. map ext dump 02, fic 850s, 3 port plug and play boost solenoid, megan mani
  137. Blox Billet Silver Front Motor Mount $60 shipped CONUS
  138. FS: GSC S2 Camshafts EVO 8 & EVO 8 MR 10.5 Turbo Cheap!
  139. Fs/nc gt4294r (451888-5009)
  140. Evo 9 head
  141. Wanted : Evo IX turbo.
  142. FS: AEM/Mac boost solenoid
  143. FS: Revolver cam shafts evo 8
  144. FS (WV) ETS Speed Density Intake w/ 9in Filter
  145. FS: (2) Stock Heat Shields
  146. Walbro 255lph Fuel Pump
  147. oem tailights
  148. Megan catback and no name downpipe
  149. stock UICP flanged for Tial bov + IAT
  150. Kelford 272 Cams Like New (Evo 8)
  151. Buschur BF272 Cams
  152. FS: 4" HKS (Green) filter
  153. high flow cat
  154. SS 02 Housing (EBAY) $30
  155. ACT Xtreme 6 Puck Clutch, ACT Light Weight Flywheel
  156. FS: HKS 280 Cams (Non-Mivec)
  157. FS: Cinci - 10.5 hotside, half radiator, custom 3" intercooler
  158. FS: Innovative 5 Wire Wideband Sensor
  159. Evo 8 Turbo $200 Shipped
  160. FS: 3" Catco Universal High Flow Catalytic Convertor
  161. FS: BNIB Forced Performance -4 AN Inline Filter .030" Orifice
  162. FS: Evolution 9 Head and Mivec Valve Cover
  163. FS: Need a Evolution OEM 8/9 Part that you cant find Anywhere? (I GOT IT)
  164. FS: Injen UICP - tial flanged
  165. ARC intake box
  166. Supertech High Tension Dual Valve Springs & Titanium Retainers
  167. FS: IX MR Turbo + Extras
  168. FS: ID1000 Injectors
  169. Evo 9 turbo, head, tubular manifold, ect
  170. FS: Intake Manifold Sensor Adapter 1/8" NPT
  171. FS: EVO 9 OEM Spark Plug Cover
  172. Evo 8 MAF sensor
  173. FS: Injen intake cheap
  174. FS: Accessport for evo 8/9
  175. FP Green Old Style
  176. FS: Stock Evo IX head, stock Evo IX oil cooler, and ARP headstuds! (NH)
  177. AMS 750r (3076r) turbo kit!!
  178. Shep trans, Hdss, fp red, ebay fmic, stock injectors
  179. --- FS: BNIB Kelford 280s EVO8 ---
  180. ebay FMIC w/ t-bolt clamps
  181. Hallman Pro MBC w/ in-cabin cable
  182. Speed Density kit
  183. PTE 1200cc injectors 500 miles
  184. Walbro 255lph fuel pump
  185. Buschur dipstick spring NEW
  186. Tial Q bov w/ flanged stock pipe
  187. ACT, Exedy, RPS clutch, FORGE BOV, stock flywheels and intake manifold
  188. FS (WV) Apexi Catback
  189. FS (WV) Megan Turbo Back
  190. FS: HKS intake
  191. FS:(CA) 2 Valve Covers Evo 8 needs paint, 1 is cracked
  192. FIC 1450's, Boomba, AEM EMS
  193. Supertech valve springs $ Retainers
  194. FS: Evo VIII turbo
  195. Mishimoto Racing Thermostat Evo VIII IX
  196. Precision 880cc Injectors
  197. AMS 5-speed aluminum shifter linkage bushings
  198. FS: Map Rev3 Intake Manifold and Buschur Racing Trottle Body
  199. Fs: Mishimoto radiator
  200. FS: ETS LICP brand new
  201. Forge BOV cheap, stock 9 parts, Apexi Intake
  202. Like new Cobb Accessport V2 Evo 8/9
  203. PTE 780cc Injectors for sale
  204. FS (WA): Journal Bearing FP Black - low miles, no shaft play!
  205. FS Mini RAD, tial, header, stk TB & more
  206. Evo 9 exhaust manifold (Stock)
  207. Parts for sale rr evo 8 bumper, cam gear, arp head studs, rear axels, ect..
  208. FS. Garrett GT4094r turbo.
  209. spoolin up cop
  210. Drag Brakes, CBRD Radiator, Hallman, BBK
  211. hks cam 272 and 264
  212. fp black-buscher uicp,licp,fmic, complete pull off
  213. FS: Evo8 turbo Complete
  214. FP Red, Full-Race manifold
  215. Quater Master Complete Rebuild
  216. FS: Boost Leak Tester (best one ever)
  217. FS: 4" intake, oil psi, exhaust mani, evo 8 turbo, and more
  218. Nitrous Express Direct Port Nitrous System w/Piranha Nozzles
  219. Feeler: Evo IX Turbo
  220. EVO VIII STOCK 02 HOUSING W/sensor included!!!
  221. EVO VIII Turbo CHEAP!!!!!
  222. ETS pipes-JMF intake-PTE1200-Grimmspeed-Deka
  223. Stock or Oem Evo 9 Radiator Rubber hoses KIT !
  224. Fs: Greddy rs bov
  225. TiAl Flanged UICP. complete !
  226. FS: Ets 4inch Fmic...9k miles
  227. FP Red with oil lines - Freshly Rebuilt
  228. FS: (OR) ARP Headstuds, OEM Evo 8 Bypass Valve
  229. turboxs bov
  230. Complete Evo 8 Head
  231. CA FS: Greddy Ti Racing Titanium ROLLED TIP
  232. FS: Exedy Clutch and Flywheel Combo
  233. evo 9 head complete
  234. FS: NY/NJ BNIB Hks ssqv4 bov Model 71008-ak001
  235. FS: Revolver Cams & Supertech High Tension Dual Valve Springs
  236. Tomei IX Procams, JIC Titanium Exhaust, OEM IX BOV, Evo 8 Cat.
  237. 10.5 Hotside
  238. FS: Buschur In-line MBC (BNIB) & OEM Evo 8 Iridium Spark Plugs (BNIB)
  239. PA: Beehive GSC Springs, Complete 9 turbo
  240. evo 9 oem bov
  241. K&N drop in filter with re-charge kit
  242. Mitsubishi MUT-3 Vehicle Communication Interface
  243. Cusco Catch can
  244. SC: Brand new water pump, evo9 timing belt kit, fmic
  245. New exedy twin carbon clutch
  246. Evo ix ecu $160
  247. FS: BNIB AMS fuel feed line
  248. FP Black - NEW!!!
  249. FS PC680 mini battery.
  250. FS Nisei mini battery kit.
