- FS: Tatrix 1.3U Cable
- ETS 3" Speed density intake, ARP Main Studs
- FS: HKS RS Intake
- FS: Eagle Rods/Evo9 T-stat housing/Forge DV/OEM turbo oil lines
- FS cobb,injen
- FS: Stock EVO 9 Intercooler and charge piping
- Forge RS BOV
- ETS intake and MAF adapter with K&N filter
- Blitz SSBOV
- Evo RS Turbo (10.5 hotside/mag/ti wheels), Ported & Coated stock Mani
- Omnipower 4 Bar Map + Optilux yellow fogs
- To many parts to list,,,TON OF PICS!!!
- Evo 8 passenger axle x2, Garrett 57 trim t3 4 bolt, stock o2 housing
- Buschur Battery Tray Evo 8/9
- FS: Ultimate Racing hi flow 3" cat
- FS: Mini Battery Mount /Radio Bezel
- FS: Precision/PTE 1600cc injectors
- Turbosmart dual port bov like new
- FS: (PA) Brand New Precision 5858 CEA Ball Bearing & Tial MV-R 44mm EWG
- MAP Stainless Steel O2 Eliminator Downpipe used 380.00
- Buschur Racing Custom Oil Catch Can (Fits w/ ABS)
- Satin Black EVO IX (MIVEC) Powder Coated Valve Cover w/ -6 AN Fittings
- (NJ) Catch can
- A few parts for sale from my big boy build (with updates as I pull the rest)
- FIC high Z 1680cc injectors FS
- FS: Forge RS BOV/Recirculating DV
- FS: Perrin Silicone Radiator Hose Set
- ID1000 Injectors
- Evo 7/8 AMS Oil Cooler
- AMS Downpipe
- CA FS Tactrix 1.3U Cable
- AMS 6262 ball bearing turbo kit! FS
- FS (UT) Forward Facing Tubular Manifold T3 Evo/DSM
- FS (UT) Precision 6262 BB turbo kit, Comp 280 Cams, Koyo Radiator
- CA: FS: Tactrix 1.3 cable
- FS: BR Small Battery Tray & Ported Intake Manifold
- AMS Small battery kit with Stinger battery.
- Zeitronix Ethanol Content Analyzer
- FS: shearer, buschur, tial
- Hyper Voltage Stabilizer grounding kit.
- FS: Black silicone intake pipe
- FS : t-3 tubular exhaust manifold
- FS: 9 Turbo for rebuild
- CA:exhaust manifold, intake manifold, injectors, valvetrain, cams, flywheel, fan, etc
- Sold FS:fpgreen turbo need rebuild
- tail lights, stock throttle body, and more
- Fs: Precision 6266 JB Turbo BNIB! (Pa)
- Fs: Evo 8/9 custom, coated& ported intake manifold=====>>>>
- FS: Kiggly springs w/ Titanium retainers
- FS: Exedy Twin, AMS FMIC, GrimmSpeed EBC, AMS battery, Perrin CAT delete, MAF, guages
- Complete Fuel injector oring/seal kits $15 shipped
- F/S black forge bov
- FIC 1100cc High Z
- FS: ARP L-19 Head Studs BNIB
- FS: AMS Front Crossmember
- FIC 1050cc injectors $265 shipped
- New Breather filter for catch can, new map turbo gasket
- FS: Evo 9 IX MIVEC head
- EVO IX Water Pump (USED) - $30(OBO) shipped Cont. US
- AEM Fuel Rail with AN Fittings - $105 Shipped Cont. US
- Military Hard Annodized AMS VSR Intake manifold
- FS:Defi BF Boost, Dsm Injectors, Test Pipe
- FS: ETS LICP, UICP, Tial, Speed Density, etc
- 2004 Evo Complete Motor, Toxicfab SF Manifold Clovis, California
- FS: OEM Radiator and fan
- FS Turbo XS RFL BOV
- 5 Speed Transmission and Converson Kit
- fs hks exhaust
- Sheptrans any way you want it! Look!
- FS: BR ported exhaust manifold, GSC Valve springs Brand new (#5039) Georgia
- Evo 8MAP beehive Springs ARP head studs NEW
- evo 9 20g turbo
- FS: New OEM piston, rods and JE FSR
- MAP Long Manifold - Coated
- Quartermaster twin, walbro 255, carbon wing, hks dli
- AN6 catch can lines
- FS: BNIB Megan Racing cat-back w/Ti tips
- Garage Clean Out - Evo/DSM parts - BR/JMF
- hallman pro boost controler & oem rad
- Florida Complete exhaust downpipe to muffler $150
- Exedy twin disc rebuild
- Spark tech non cdi fs low miles
- Bosch 044 fuel setup
- FS: PeakBoost HVS Topmount Manifold
- FS/FT OG FP White, WTB/Trade for HTA Green or FP Red
- Buschur Racing Bullet Exhaust
- JE Pistons +Eagle rods 10:1 85mm
- OMNI Power 4 Bar MAP, AIT and EGR Block Off
- Synapse DV & NRG Quick Release
- FS: Turbo Trix Tubular Manifold, Tial44, Dump
- FS: all brand new oem valves
- SpoolinUp under coil cover evo 8 coil on plug setup
- Evo 8/9 goodies MD - NEW ACT 6 puck disc, Evo 9 BOV, Magnecor 8.5, oe IC,
- FS: GSC S1 for MIVEC // BRIAN CROWER 272 NON MIVEC
- Exedy Twin Disk HD New with Extras
- Nisei Short Route UICP w/ Mini Battery Kit & Odyssey PC680
- FS: Injector Dynamics 1000cc
- AEM dry flow 4" air filter
- 2005 Evo 8 turbo 10.5 hotside
- Brand New ETS LP2 Lower IC Pipe
- (FS) HAFE cast manifold and 02 housing
- FS: 4094r turbo kit!
- Ams fpr
- FS: Manely H-beams Rods 150mm, Injen LICP, HKS BOV, JDM replicas
- AMS Fuel Rail
- FS: Evo 9 IX BOV
- mil.spec 65mm TB
- (FL) FS: Eagle rods
- FS: AEM, AMS, ic injectors, dnp, oem, garrett
- FS: OEM Parts in (OH) Turbo, OEM HID ballast, and more
- FS: Lucas 1200cc Injectors
- FS AMS t3 manifold,o2 housing,pte wastegate
- Evo 7 RS Engine, 5-speed Trans, X-Case, and Rear Diff FS
- FS: NEW QuarterMaster twin plate 7.25" V-Drive Clutch (6-speed trans)
- F/S- Evo 8/9 Competition Stage 5 4 puck 300Miles
- FS: Moroso Catch Can
- Evo 8 or 9 used OEM exhaust manifold
- Buschu racing 6 speed shifter bushings Brand new
- used 3" stainless Evo 9 downpipe
- HKS Kansai carbon fiber intake box
- Evo 8,9 OEM used ported Exhaust manifold
- Buschur Racing Dual Boost controller
- R/T Ernie Evo 9 Custom V band full 3" O2 housing and downpipe
- IX Turbo, Exedy, ACT, OEM parts FOR SALE in OHIO
- 6262 Billet ball bearing water cooled FS % bolt .63
- FS: PTE 6766 turbo
- GT35RHTA .82 4 bolt and .63 5 bolt housings FS
- AMS t3 turbo setup 38mm tial downpipe open and recirced o2 housings FS
- FS: Tactrix 1.3
- FS evo 9 ecu
- fs lower intercooler piping
- fs complete evo 9 stock turbo
- PTE5857 billet, old school RNR tubular manifold, WG dump
- Avid motor mount
- FS : Garrett T04S BB
- Megan racing, DoLuck...
- FS: Precision Turbo Injectors 1200cc
- FS: FP turbo Oil Feed Line
- Aem 10 channel peak & hold driver
- FS: Hallman Pro Boost Controller
- FS Tactrix cable
- Injen intake oem maf injen cone filter
- FS. Mia. FL. Evo 8 complete motor with turbo/acc. $3200 shipped. 60,+++ miles
- Tial .82 a/r exhaust housing F/S
- BR HTA 3582R Turbine housing and manifold
- FS EVO 8 Kelford 272s. $old shipped/paypalled
- Stock Evo 8/9 exhaust manifold
- Stock Evo 9 Ecu
- FS: Exedy Twin Disc HD
- FS/FT: AMS GT37R turbo kit (Feeler)
- FS: aem serial gauge new in box!
- FS: BNIB OEM Turbo Gaskets
- Rebuilt Exedy Twin - $1,100 OBO
- FS: SMC Water/Meth Kit
- BNIB manley forged crank! 88mm $400
- FS: Evo 7-9 AMS 3" Stainless Test Pipe
- AEM Tru Boost Controller/Gauge $175 shipped
- FS/MIAMI FL: Evo motor parts aftermarket and OEM
- FS: Stock valves
- FS: NH/MA Griffin Intercooler and OEM cat
- FS: Evo8/9 CAS heatshield
- FS: ARP stretch gauge
- pte 1000cc
- Built 2.4 longblock/ shortblock
- FS: 5152-0620 stage4 6pad ridid ceramic clutch
- garrett 57 trim t3 4 bolt Ported exhaust, powdercoated compressor
- Ams intercooler, hks bov, etc...
- KOYO Radiator 8-9
- WORKS Exhale Exhaust (muffler/mid pipe/muffler delete)
- FS Hydro TOB (5 speed only)
- 8 turbo with 10.5 hotside
- Bnib Manley Turbo Tuff Ibeams
- Stock Evo VIII piston and rods
- Sparktech P&P Coil on plug
- AMS-Prec.GT35r w/Manifold, Tial bov/waste
- fs ams 3inch catback
- AMS Fuel Rail/RC1000's/340FuelPump Ect.
- FS: AMSoil Dry Fliter CA Bay Area
- Selling OEM evo 8 fuel pump
- 05 Evo VIII engine for sale (short or long block)
- FP Black / Toxic Fab Forward Facing / AEM 1313 EMS / Garage Sale
- FS: Lots of stock evo 8 parts and more!!!
- For Sale: Denso Toyota Coils for COP kit & Mounting Plate
- FS: Injen Lower IC pipe
- HKS 264 cams
- Buschur Racing Mini Battery Tray
- FS MI: Exedy, Kiggly, FP, AEM, HX40 turbo kit, bare evo 8 head
- FS: RRE GT30r turbo stealth kit.. Or FT for wheels.. SoCal.. New price!!
- Full race manifold map d/p STM
- FP Blsck Turbo kit
- gm maf,stock evo injectors with fuel rail,aeromotive frp with gauge
- FS: Stock Exhaust Manifold, Stock 16G Turbo, COBB DP, MEGAN 02, AEM Intake.
- Deatchwerks fuel pump 301 (IL)
- FS: EVO PARTS some aftermarket some OEM (PA)
- CT: ACT lightweight flywheel
- CT: Grimspeed and MAC valve 3 port ebc's fs
- FS: Brand New JDL T3 Turbo kit!!!!
- Fs: Buschur racing evo 8 9 intercooler piping kit w/ intake and tail bov
- FS: Quartermaster 8-Leg Race Clutch
- CA:F/T Tanabe Touring Medallion Exhaust
- ETS intake- Forge BOV/UNOS/Wastegate - Evo 8 Coils/Turbo
- AMS LICP, catch can, rad hoses, grounding kit
- Greddy FMIC kit APS BOV
- BNIB HKS 264 cams!
- Garret GT4202R Turbo
- Evo turbo kit 6262 bb
- FS: Walbro 255
- South Bend Clutch KIT BNIB $400
- Evo IX Turbo under 2k miles!
- FS: PTE 6766 Turbo
- F/S 300lph, 680cc inj, mafs, 3inch intake, etc.
- Sold
- ITS GT30R (Polished)
- 880cc injectors! (Precision)
- FS: custom GReddy upper ic pipe + 9 bov
- Bnib aem cam gears aeromotive fpr arp cam bolts
- Evo 8 maf sensor
- FS: Tial V44 Wastegate NEW
- Exedy Triple Disk
- piston and rods forsale also t3 manifold
- Tactrix 1.3U cable!!
- FS: HKS EVC Electronic Boost Controller
- AMS 3" Downpipe. With o2 Bung. Brand New condition
- 6 speed MR swap
- FS: Precision 680cc Fuel Injectors (Set of 4)
- Sold
- *SOLD FS - Synapse BOV + recirc.kit
- Old Style AMS front mount intercooler.
- FS: Ported Evo 9 turbo
- FS: Invidia 02 Housing for EVO 8 + 9
- Spoolinup COP evo 9 kit
- Ported Stock Intake Manifold
- Factory rebuilt 5 speed tranny ( DFW area)
- TurboXS 3" Stainless Steel Test Pipe
- JIC Spartan DE Type 2 Full Titanium Exhaust
- FS: nice IX turbo,CC stg 2 disk
- FP 25 psi wastegate, FP silicone intake
- 5558, synapse wg and bov.
- Toxic fab manifold, FP Black, ETS lower intercooler pipe
- Exhaust, Aem Uego And Hard Rad Hose- CHEAP!!!!
- Fs: Like new og fp green, less than 2k miles
- FS:MD: APS BOV ~ Greddy Catch Can ~ Monster UICP ~ Tial BOV Adapter
- Buschur short route, stm, grimmspeed, walbro, tial + more
- Evo 8 & 9 parts loaded!
- Selling some nice stuff!!
- FS: Evo 8 turbocharger and header
- AEM Boost/ Wideband, Torque Solution, Catch Can, ETS Intake!!!!CHEAP!!!!LOOK HERE!!!
- New HTA86r trade for GTX3576r
