- FS:OH GSC S2,FIC 1050's,MAP o2, Crower springs+ti retainers
- FS: stock 9 turbo, forge bov , and more
- Perrin Catch Can (Red)
- FS: Fujita F5 UICP and Intake Kit w/ Filter
- FS: Evo 9 AEM Series 2 ECU CHEAP-NYC
- Exedy Twin Disk Rebuild Kit
- Fs: Muse licp - $130
- FS: CARBONETICS Pro-Blade Clutch/ Flywheel Set EVO8/9::::
- FS-TX Vibrant ferrules, Russell fittings
- FS-TX Clevite rod bearings .25 over
- FS: Helix O2 and Downpipe
- FS: ACT Flywheel freshly resurfaced and ready for use!!!
- FS: Like new Bullseye S256 Turbo
- Megan and Fujitsubo Downpipes
- Southern Grind Performance COP
- FS, Perrin Intake, Resirc, Ported manifold, fuel rail, etc (PA)
- FIC 1450, BR LICP, BR exh man, j-pipe, 80mm boost leak tester, oem fuel rail, oil pan
- stock evo 8 fmic, licp resonated test pipe
- FS: TurboXS UTEC
- Brand new mitshimoto radiator evo 8/9
- FS - 2 88mm cranks
- Greddy 24V FMIC, Megan Manifold
- Tactrix 2.0 cable
- Cam angle sensor heat shield
- FS: ToxicFab 02, Mishimoto radiator
- Used Evo 8 exhaust manifold and Evo 9 Diverter valve both have 60xxx miles
- Injen uicp w/t-bolts cheap!!
- Brand new eagle 2.2l 94mm stroker crank!
- Brand new ID1000's. Plug and play for evo 8/9
- 10 bucks a part!!!!
- Magnus,FIC,Gt35r,DNP,Tial,GSC,Hawk,Audio
- Exedy twin disc, aem ems, gsc, skunk2
- FS (FL) - ARP Head Studs - $70 shipped/paypaled
- Fluidyne Aluminum Half-Size With fan AND thermo housing with matching an fitting!
- FS (FL) - Taylor Battery Relocation Kit - $90 shipped/paypaled
- FS (FL) - BNIB OEM Head Gasket 4G63 - $80 shipped/paypaled
- FS (FL) - Boomba Red Oil Catch Can - $90 shipped/paypaled
- Exedy Twin Disc HD
- FS Cometic Evo 8 Head Gasket NEW
- TWB: 2.2 or 2.3 stroker
- Kelford vrsf fp gates all must go
- FS: FIC 1050cc Injectors only 80 miles on them w/ Brand new seals. Make me an offer!!
- FS: MANLEY IBEAM TURBOTUFF RODS, PTE 1200cc Injectors, Walbro 400, Tq Sol Brackets
- FS: ETS Polished Upper Short Route I/C Kit
- FS: Perrin Intake
- BNIB Weapon-R Torque Damper
- Walbro 255HP (GSS340)
- FS: Boomba step down adapter plate and 60mm hose adapter
- Tomei cam gear bnib evo 8/9
- (NYC) '05 MR ACD Transfer Case
- FS: Spoolin Up COP, ETS, Tial, MAP EF3 Turbo
- Precision 6262 jb turbo for sale!!
- Forced performance HTA3794R Perfect condition!
- Injectors, Fuel Pump, and DP!
- FP 18 PSI WGA, Evo 9 turbo
- Evo8 AEM EMS V1
- FS: Perrin Exhaust (Modded for JDM rear, Can be used on stock)
- FS: BRAND NEW Precision 6466 HOT DEAL!
- Fs: AEM standalone v1 with ait sensor!!!
- FS Exedy twin, ACT and OEM TOB
- CA FS: Cobb AP Evo 8/9
- ARC! Airbox, Exhaust Cover, Cooling Panel, UICP. RARE Parts!
- Close Please!
- Synapse BOV
- Sold
- FS: Exedy, MSD, Tein, Mitsu stock parts
- FS: HKS 272 Cams New!
- GSC Valve Spring BNIB, Evo 9 BOV, Evo 9 intercooler setup
- FS STM SD Intake, Adjustable Cam Gear, 38MM WG
- FS: BR Intake, Custom Double Pumper
- Innovate MTX Wideband
- FS: Perrin recirc BOV
- Garage Clean Out!!
- Valve cover,Cams,pulleys, misc engine parts
- FS: HKS Hi Power Catback Exhaust
- FS: Evo8 Hks 264/272 Cams, Ams Mini Battery Tray
- hks mushroom filter with 4' intake pipe
- Tactrix CABLE/OEM ITEMS/non OEM/ MBC/BCS
- Evo 4 Pistons and rods
- FS: (VA) XS Power Exhaust, Mishimoto Radiator
- Custom Vishnu 3in Downpipe and V-band Test Pipe High Flow Cat Look-a-like
- BNIB Mishimoto slim fan w/shroud
- Evoscan openport 1.3u cable and evoscan
- Evo 6 Speed Transmission
- Buschur Slip Fit Testpipe
- FS: HKS 272, HKS belt, REXPEED, PARTS
- Hallman boost controller MIVEC valve cover complete manifold evo 9 motor part out
- Sold: DSS 900HP Front Axles
- fs APS 3.5 tbe
- FS: Complete MIVEC System/Part Out
- FS: ARP 207-4203 Head Studs (EVO 8-9)
- FS. evo 8/9 t3 44MM manifold
- FS: BNIB Denso IKH24 Iridium EVO 9 Spark Plugs
- FS:WA ARC and oem spark plug cover
- Looking for silencer for trust ti-R
- FS WV MAP 02 Housing Gasket Stainless
- FS WV Stock MIVEC Cams IX
- FS WV COBB Intake
- BNIB FIC 1450 $380 T3 tubular manifold $330
- FS: Fuel Pressure Regulator
- FS: Non ACD T-Case Cheap
- FS: Evo DC Catless Downpipe
- FS: Evo 9 Turbo Low Miles..Misc Parts
- Evo VIII/IX stock throttle body
- evo9 stock turbo, agency bov, injectors, invidia, ecu
- FS: Brand new PTE 6766 T4 TS 1.15A/R
- precision 880, walbro, fp wga
- F.s Qns/Bklyn:Manley Crank,Seibon Hood,HID Ballast,Starter,Left JDM tail,Stock Coils
- FS: OEM Evo 9 Manifold Low Miles
- F/S OEM MIVEC cams, LICP and aftermarket intake pipe
- (NJ) FS: Apexi avcr black digital boost controller
- Fs: Oem mr bov
- Torque solution 6spd mount & other 6spd parts 4/s
- F/S AMS Tubo kit
- Evo 8 Ecu
- Stock TB; Stock Intake Manifold w/sensors
- FS: Kelford 272 mivec less than 2K miles on them
- Sold
- FS: Ams VSR V1 & BBK 75mm TB w/tps + pigtail
- FS: BNIB BR TB and MBC
- Supertech Dual valve springs & ti retainers BNIB-Norcal
- Carbonetics Twin Disk Clutch
- FS: Stock Evo 8 o2 housing
- bolt-on BB Garrett 3076R kit, 9bov, 9 billet wga
- Evo 9 FMIC
- fs: used stock evo 9 injectors
- STM 3" intake w/filter (SD)
- Brakeman drag brakes, EVO 9 Cylinder head
- NEW: STM FF Mani, Tomei Pro-cam 280 MIVEC
- FS:(PA) Greddy, AEM, Stock turbo, OEM parts.
- wanted fp green or simular turbo
- FS: FIC 2150 Injectors
- Evo 8 Stock Cams and Intake Mani
- Evo 8 stock crank uncut perfect
- F/S: REBUILT HKS GTII 7460R KAI Evo 8, HKS 272 Cams and more!
- Ceramic Coated Powersteering Pump Reservoir
- turbosmart WG NEW
- Kelford 272, Aem Boost, and Aem Wideband
- FS: AMS Cat-Back Evo + Test Pipe VIII/IX *Modified*
- FS: stock intercooler, Megan O2, stock ex. manifold. PA
- Aem 1313
- Sold!!!
- Nisei polished battery tray $70
- FS: NON ACD Transfer case, X-case
- (NJ) FS: Wiseco Pistons 9.0.1
- valve cover $95
- MAP Rev3, IX S1's, etc..
- Precision/PTE 1600 injectors cheap
- New Greddy Profec OLED Boost Controller
- COP DIY Setup $250.00 ship
- Competition Clutch Stage 2
- 4g64 block std bore and 4g64 crank
- 4g63 & 4g64 crank for sale 4g64 block
- CT: Evo 9 20G, ACT HDSS Clutch & F/W, IC pipes
- FS:Buschur LICP, Precision 1200cc injectors
- WRC Spec Catalytic Converters Race or Road
- FS/FT Perrin fuel rail/under drive pulley, ARC heat shield, xs power IC
- F.S GSC s3 Mivec cams
- FS: 2000hp+ Fuel setup
- FS/FL: NIB Heavy Duty "HD"Wiseco Pistons bored .020 over
- FS MI: HX40 Turbo kit
- FS: Evo 8 turbo, Stock fram Tubular Manifold,
- GM 3 Port EBC
- Everything sold delete
- FS Evo 8 HKS Evo8 274/274 camshafts and valve springs
- FS: (BNIB) Kelford 272 Evo 8 Camshafts
- Evo 8 turbo w/ 10.5 upgrade
- High flow compressor 3" inlet elbow intake pipe
- Fs: Evo 8 turbo 9.8 and buschur j-pipe
- FS (OH): ETS Lower Intercooler Pipe LP2
- D/S front Axle
- FS: Stock Evo VIII/IX 560cc injectors
- Evo VIII/IX stock injectors
- Quality Parts Exedy STM OEM AEM JDM Heads VII Tails
- Qtp 3" down pipe with cutout
- FS: NC, Exedy triple with rebuild kit $1900 shipped!
- BNIB AEM Fuel pump, Tial BOV spring
- AMS (Allstar) Catch Can
- Sheptrans PPG drag DOGBOX
- Fs: Bnib act tob
- FS: Deatschwerks DW300 320LPH fuel pump
- FS: BNIB Competition Clutch TOB:::
- FS: Perrin HFC
- Buschur Racing Downpipe
- FS/FT Weapon-R aluminum intake manifold
- 560 injectors / forge BOV
- AMS 850R Turbo Kit
- Delete
- JMF ams jdm 7 valve cover much more 272kelford
- AEM Digital Boost Gauge
- Complete EVO 9 MIVEC Engine motor Part out 37k miles!
- BNIB greddy easy mivec easy cams
- WTT FP Red
- Custom Mini Battery Tray with multiple adjustments.
- FS PA: SIMPSON Parachute Kit for Drag Cars
- AEM Intake / Evo IX BOV (crushed) / BR Manual Boost Controller
- 2 evo 9 heads, few other parts, STM, Perrin, aem, etc
- 4g64 100mm crank,stock, uncut
- 03 evo 8 stock ecu
- FIC bluemax 1450's
- FS GSC S2 cams for evo 8
- Ultimate Racing 3" high flow cat
- 2003 VIII Head and Intake manifold
- Megan o2 housing
- Fs: Ets 3.5" fmic
- Selling 4g63 Right Axle Assembly!
- FS: Revolver 264 Evo 8 Cams
- FS: STM Intake, APS BOV, Hallman Pro, MAF
- mods delete please
- Mivec GSC cams! Whiteline! Injectors!
- FS: Evo IX BOV
- WANTED: 8 parts/cams/ebc
- FS: 1320 Fab Exhaust Manifold [new]
- AEM Aquamist Kit, PTE 880cc
- (IN) Minty Evo 9/IX shortblock! Local pick up
- FS: Invidia Test Pipe (Evo 8)
- F/s: Acd pump and acd ecu
- FS: Evo 9 AEM EMS, FIC 1450cc, 4" to 3" intake and filter
- Bw efr7670 bnib - 1,700.00
- FS Evo IX Buschur downpipe
- FS: Used AEM EMS Series 1 for Evo 8
- hd exedy twin plate carbon almost brand new
- EVO 9 Turbo (cheap)
- FS...Blitz Air Filter, Injen UICP/LICP, BOV & M.A.F.
- PTE 780cc evo 8/9 injectors
- Quartermaster hydraulic TOB for 6-speed
- (BNIB) ToxicFab Tucked Power Steering Reservoir
- FS (SoCal): Evo 9 turbo + stock O2 housing, Tactrix 2.0
- FS: OEM Evo 8 Injectors
- Fs: Hks ssqv
- FS: OEM Intercooler, Intercooler Pipes & Couplers
- Synapse Blow Off Valve
- FS: EVO 8 Stock Intercooler
- Fs: FP RED TUBULAR MANIFOLD O2 HOUSING
- ACT clutch, IX bov, TurboSmart, VIII Turbo, AMS lines
- Evo 9 cams Hks 272, kelford 272, gsc stage 1
- Complete evo 8 head
- FS: Forge RS bov (MD)
- Fs: BNIB QM TWIN+HRB+RACE FLYWHEEL
- Garrett T4 "King Kahuna"
- FS: Black Perrin Upper Intercooler Pipe
- FS: Stock OEM Evo 8 Injectors
- FS Evo 8/9 AMS Test pipe
- Sold!!!
- AMS Resonated Test Pipe
- FS: Buschur 65mm Ported throttle body
- BNIB: STM IC Pipes w/ IAT Bung and Tucked BOV
- (ny) fs: Map rev3 intake manifold. Low miles
- evo 8 valve cover
- F.S GSC s3 cams
