- FS 8 shortblock, ACT clutch used
- Torque Solution Passenger Side Engine Mount
- ACD Transfer case and ACD pump, 36k miles
- F.S Brand new Walbro 400
- Fs- oem evo 9 cat & oem 02 housing
- HKS 272 Exhaust Camshaft: $150
- FS: TWM Short Shifter, EBC Red Stuff
- Ported Intake Mani - PTE 1000cc Injectors - Omni 4 bar - AND MORE!!
- FS TX:QUALITY PARTS Hks/Precision/Manley/CP/Tial
- FS: Borg Warner EFR 7670
- Pistons/rods..Valve Springs.. injectors ..etc
- FS: evo 8/9/X turbo smart bov
- FS: Perrin intake
- Invidia o2, evo 9 mani, evo 8 fmic
- FS: evo 8 rs tcase ***BLOWN
- Lots of Power Parts
- FS: OEM Evo 9 exhaust manifold
- FS: CO M&W Pro Drag 4 high power CDI unit
- F/s 2003 mitsubishi evolution evo8 full car part out !!!!!!!!
- FS: spec exh. mani, stock pistons/rods, ARP headstuds, two 7 bolt cranks
- FS: Spark Tech Non-CDI COP for Evo 8 & 9. Tested by ST & New Harness!
- AEM and Full Blown
- FS: HKS GTII 7460R Nasty spool!
- Garage cleanout: FF mani, GSC, AEM, AMS, BLOX, GSC, BC, FIC, ETS etc...
- Jdm mr bov
- NEW Blitz LM Type CS FMIC Evo 8/9
- Greddy Ti Catback rolled tip, ETS UICP
- FS: PTE 780 Injectors, Turbosmart MBC
- Evo 8/9 OEM O2 heat shield $20 and ebay test pipe $40
- OEM Evo 8/9 Fuel Pressure Regulator, Fuel Rail, Hoses $45 OEM Clutch Line $25
- PTE Precision 1200cc injectors ~8k 91/E85 $200
- ~5k Full Blown Double Pumper 255 Walbro w/ -8an feed -6an Return Lines Hoses Fuel Lab
- Tial MVR and Tial Q BOV
- FS: Blitz Dual Solenoid EBC drift edition
- Evo 8 downpipe uicp hks bov boostcontroller
- Exedy/Cusco Twin with new rebuilt kit!!!
- BRAND NEW - Supertech Valve Springs & Titanium Retainers
- FS:CA. Cams,boost controller,welbro 255,v band dump tube
- FS: New OEM Mitsubishi Evo 8 Head Gasket
- FS: Buschur Race Core Lower Intercooler Pipe LICP
- Evo 8 - COMPLETE Pro EFI 128-Pin ECU
- MI: FIC 1050sp ANSU HI-Z INJECTORS
- FS: BNIB oem BOV 9
- FS Odyessy PC680 and nice Trunk mount hold down
- FS: 4g63/Evo Timing Tensioner tool
- FS: Evo IX BOV
- Exedy twin
- FS NY-- Intercooler and piping
- ****garage clean out****
- Turbosmart Raceport BOV (2)
- HKS Valve springs
- FS/FT: Ball Bearing FP Black -NJ
- Trade Precision 6766 for FF Manifold Setup
- AMS CNC Mivec Head $1500
- FS: Forge Wastegate, HKS bov, turbo
- OEM Evo 9 MR Turbo
- FS: 1000cc inj, Greddy IC, oil cooler, cams, ARP
- Custom Stock Frame Hood Dump
- FS: Buschur O2 Housing *NEW*
- Fs: Mbc
- Used GSC S1 cams
- OEM Flywheel, Cams, ETS, Energy Suspension, ACT
- evo 9 stock turbo
- FS: T3 RamHorn manifold, PTE 5831, Tial wg, Full Blown radiator
- 3" exhaust
- Evo ix head low miles.
- fic 1050s
- evo 8 catback 3in ss exhaust vibrant muffler
- evo 8 long block.
- Fs
- FS: (FL) Evo 8/9 Greddy Evo2 Catback SS Exhaust
- FS:WA Saikou Michi Catch cans
- FS: AMS FMIC- Brand New
- Fs: pte 1600cc injectors
- FS: Buschur Racing Manual Boost Controller
- FS: HKS Racing Suction Intake Kit
- Pt 6262 bb F/s
- Ets uicp (nj)
- JB BBK Full (NJ)
- Evo ix oem ecu altenator spark plug cover
- COSWORTH 4G63 pistons
- BNIB series 1 AEM EMS for evo IX
- Bosch 044 Fuel Pump
- Mass Air Sensor, Throttle body, Coils wires, NEW EXHAUST SEAL
- FS Tactrix 1.3u cable
- FS: Custom 900whp(on E85) Fuel setup, Drag or Road Race
- FS: EVODROID7 Tablet PC Evoscan system
- Evo IX Turbo 36k Miles
- FS: oem evo 8 intercooler
- FS: evo viii turbo
- Feeler: 05 MR ACD tcase
- FS: Stock Clutch/Stock cams (evo 9)
- Arp, hks, hallman, uego, bc, stm, and stock parts
- FS: Cosworth Cams 272s Evo 9
- 03 Evo 8 transmission, CHEAP!
- Evo 8 Fuel Pump Hanger
- FS NJ OEM 2005 Evo 8 downpipe (1000 miles on it)
- 4g63 shortblock
- works ck2 clutch and pressure plate with resurface flywheel
- FS/WTT FP Black, JMF 02 dump, Spec Mani, FP race outlet, downpipe etc
- Egr block off plate
- FS: AEM 50psi/3.5 bar map sensor kit
- OEM Stock Front Diff
- FS Brand New Parts: AMS UICP/LICP/Mounts- Shearer Exh Mani- JMFab Catch Can and more
- TPS, IAC, HID BULBS, ALT, Works, FPR
- ETS 4" intercooler Brand new
- FS- VA Evo 8 5 speed Transmission- FRESH
- F/S: JDL Front Facing T3 Turbo manifold w/ 44mm WG Vband
- FS: FL Buschur Down Pipe, Intakes, Walbro, DiaQueen, Gaskets
- evo/dsm parts. crank, undertray, intake, JIC exhaust
- FS: S. FL - Aftermarket and OEM IX MR
- FS: 3" 02 Dump, OEM 02 Housing, OEM Alternator, Evo 9 WGA, OEM Motor Mounts, etc.
- Evo 9 5sped transmission (damaged bell housing)
- FS: AMS F1-I/UICP, 65mm TB, Synapse, Vibrant
- FS-NY: FIC 2150cc blue max fuel injectors (high-Z)
- FS-NY: Magnus v5 cast aluminum intake manifold powder coated satin black
- Full Race Exhaust Manifold (Coated)
- feeler, ported tb, quartermaster twin,
- Custom Intake Manifold for 8 injector
- AEM 30-3020 Water/Methanol Failsafe Device
- Used Exedy Twin, BR Intake, Blox, Seibon
- FS: Used GSC S1 cams for EVO 8
- New ID 2000cc injectors
- 2 new IAC valves cheap!!!
- Short Runner TwinScroll manifold/turbine housing/downpipe - GT35r
- FS:AMS ECM V1/Double Din Kit/Exedy Twin Flywheel/ OEM Injectors&Turbo/More listed
- FS: Forced Performance Super99 HTZ Turbo
- NY-F/S GSC S2 cam evo 9 less then 3,000 miles
- Used evo 9 oem flywheel and exedy clutch
- FS (MN) Buschur Stage 3 MIVEC Head/Cosworth M2 cams.
- FS: Evo9 stock full exhaust, battery tray, intake box w/k&n
- Evo IX OEM short block
- ETS Intake, Evo IX Turbo, Maf, Metal IX BOV, etc!
- F/S: Shop Clearance Sale - BOV, Turbos, Twin Disk, AEM Boost, + Misc
- Evo 8 Cylinder Head Un touched 25k Miles
- fs:ny tial 44mm wastegate, tial bov , (2) hallman boost controllers
- MAP EF4 For Sale
- Fs: FP 25# WGA
- FS: Koyo Racing Radiator Evo 7-9
- FS: Boost gauge Autometer
- Evo IX Turbo $450 shipped O.B.O.
- FS: WORKS 65mm Throttle Body/Heat Barrier TB Gasket
- FS: Tactrix Cable 1.3u
- Stock intake manifold and stock dip stick
- BBK Full, Full Race Manifold, Nisei LICP, 1200CC RC Injectors
- FS: evo 8 short block, evo 9 turbo with extras, je pistons and rods!!!!
- Boomba Fuel Rail
- HTA 73 Brand New
- FS exedy twin//manley rods// etc
- Evo 8 Cylinder Head / Intake mani
- Stock injectors
- FS: Brand New Parts- AMS-Shearer-TQ Solution-JM Fab
- FS exedy triple new single spare disc
- FS: MoTeC MDC, SDL and DHB
- evo8 alternator
- 2 FP Black turbos need rebuild, FP Black oil line and filter
- Fs: Evo 9 crate motor brand new with warranty!!!! Everything included!!!
- ETS intercooler piping with intake and 3.5" intercooler
- Ingalls motor strap forsale $120 shipped.
- FS: OEM Fuel Rail & FPR
- FS: PTE 1000cc Injectors
- Turboxs boost controller
- Stock 2003 evo 8 parts
- For sale: Evo 5 speed trans, rear end, Exedy triple and cylinder head
- FS: RC Injectors, APS BOV, AEM Fuel Rail
- FS: full blown double pumper
- FS: Evo 8 Valvo Cover, Evo 8 Un Touched Head, Evo 8 Oil Pan
- Evo 9 ACD Pump
- Down Pipes and a test pipe
- EVO 8 shortblock+exedy/cusco twin disc 43000 miles, runs perfect!
- used evo 8 pistons and rod.evo 9 bov
- FS: Intake Pipe with t-clamps.
- FS: GA: Huge partout! Garrett, GT35, turbosmart, kinugawa
- FS Buschur street FMIC
- Torque Solutions front motor mount and shifter base bushings
- FS evo 8/9 uicp
- NY: Like NEW EVO IX DC sports catless downpipe *500 miles if that*
- F/S BR light weight side diff brackets
- FS : (VA) Buschur Downpipe $80 Picked up
- Evo 9 Metal Diverter Valve
- FS: Perrin Catback exhaust
- Turbo smart kompact dp bov
- FS: Quartermaster 6-Leg, Walbro 400, Stock Throttle Body/Turb, Pyrometer, Gauge Pod,
- FS: MAF, INJEN pipes, 02 housing, FP turbo oil filter
- Complete LICP for STM Foward Facing mani/kit
- FS:CO Carbonetics Problade and QM Hyd. TOB
- FS: Jun B.L Cat-Back exhaust system Evo 8 & 9
- Some stuff for sale at give away prices!
- FS (NJ): OEM 4g64 Crankshaft -used-
- Evo VIII block, 4G64 100mm crank
- FP Oil Feed Line
- Low Mile Evo IX Turbo
- Evo vlll oem turbo and A/C
- Buschur Racing Manual Boost Controller
- ETS FMIC, OEM alternator, Titanium midpipe
- Fs: long island Buschur Exhaust
- FS: AMS F1i Stock TB Flange
- FS (MO) Forced Performance FP Inline Filter
- FS (MO) Evo IX 9 Turbo
- FS (MO) Evo VIII Valve Cover
- FS: walbro 400 fuel pump (e85 compatible) + O Rings (needed for install)
- FS (MO) AMS Custom Dipstick
- FS- Hallman MBC (NJ)
- FS- Walbro 255 (NJ)
- FS- 4" ETS SD Intake (NJ)
- FS- BB FP Red (NJ)
- Tactrix cable $100 shipped
- HKS FCON V with Harness. Cheap Price
- FS: HKS F-CON Vpro Evo IX *NYC*
- FS: Evo 9 Turbo - Excellent Condition
- FS: Ported intake, GSC Zero Tick, MAP Headstuds
- FS: Evo 9 Turbo, 20g anti surge
- FS: Forge BOV
- **Great condition WORKS Turbo Back Exhaust System!! Check it out!!**
- FS: Evo 9 turbo
- Spoolin Speed Density harness, Omni 4-bar, and GM IAT!
- AEM FPR with liquid filled gauge!
- GSC S2 Cams Evo8 FS/FT
- Skunk2 Cam gears Evo 8
- Torque solutions short shifter
- wiseco pistons for sale
- Christmas sale
- Spoolin' UP Coil On Plug Kit (EVO 8/9)
- Nisei Competition Intercooler 3.75"
- IL: Fp red turbo,with map manifold and 02 dump
- Quartermaster V drive 7.25 with AMS throw out bearing extra set of disc
- Buschur Hi-Flow Cat - Used - Good condition
- FS: SpoolinUp Non-CDI COP
- GSC S2 Camshafts - EVO9 - Less than 100 miles
- quartermaster 8 leg twin disk
- Evolution 8 cylinder head, cams & gears!!! 30k miles!
- AR design hood dump o2 housing!!!!
- FS stock parts and new Prosport Evo series Boost gauge green/white
- FS: OEM Ported Exhaust Manifold (Curt Brown)
- For Sale: Evo 8 MR 6 Speed Transmission
- For Sale: OEM Evo 8/9 Alternator
- Fs/Ft: 6262 Jb t3 v-band out. 800.00
- Evo 8 engine part out
- FS: Spoolinup cop Evo 9 and ets mini battery tray wrinkle black
- Fuel lab fuel pressure regulator
- Kiggly HLA
- FS:Buschur 65mm TB,Titek v2 O2 Housing,Omni 4bar MAP,EvoScan 1.3U,3port GM BCS &More!
- Arc Box $120
- AMS uicp, AMS batt tray, ralliart radiator shroud, greedy catch can solid mounts
- FS: AMS 3in Turbo-Back Exhaust
- CA- Brand NEW Evo 9 Cosworth built head
- FS water pump
- GT3076R, Stock Evo 8 w/ manifold
- FS: ETS, BUSCHUR, JB FP RED, SYNAPSE, RC, OEM PARTS, ZEITRONIX, KELFORD-Low Prices-
- FS: T3 6266 bnib
