- CT: JB FP Black w/ 0 miles on rebuild, MAP heat shield
- Comp Clutch Stage 3 NIB
- 700HP+ Evo 9 - Motor, Turbo, Exedy Triple, Injectors & More!
- Ets 3.5" fmic
- Like New: Hallman PRO RX MBC
- Blitz Nur-Spec Axleback
- Torque Solutions 6 Speed Tranny Mount
- Nisei Short Route UICP with AIT Bung
- Buschur Racing 2.5" Downpipe with 2.5" HFC
- FS: ARP Main studs - $25 Shipped!
- Black Friday Only! TiAL 38mm Wastegate
- FS: Evo 8/9 Buschur Ported Intake Manifold
- Greddy Ti-C catback
- AMS Front Mount Intercooler Black Friday Price
- FS: Evo 8 5 speed trans, evo IX turbo, BNIB cosworth m2 IX
- FS: CXRacing 3.5" FMIC, LICP
- GSC S2 (VIII), GSC S1, AEM tru times, GSC springs
- FS: 1000cc Bosch Injectors
- AMS Cam gear tool + Timing belt Tension tool
- Blitz sbc-id
- ETS 3.5 Intercooler Upgrade Kit Wide WITH ETS Air Intake Kit, Brand NEW!!!!
- FS: FIC Fuel Rail & FIC 1550cc Inejectors
- FS: Forced Performance HTA GT3586R Turbocharger (.82 A/R T3 3" V-Band Outlet)
- For sale used Unorthodox Pulley Set EVO 8 9 & 2 new belts (PIC)
- Throttle Body, Manual Boost Controller, coupler
- looking for Rods
- FS: AEM uego wideband w/ new sensor
- FEELER: BNIB HTA 73 GREEN $1399 shipped
- FS: Evo IX stock turbo
- OEM Used Lower Intercooler Pipe LICP
- OEM MAP Sensor off Evo 8
- OEM Exhaust Manifold Gasket
- Agency Power Fuel Rail
- AEM TruTime Adjustable Cam Gear
- FS: BRAND NEW Garrett Gt2860RS Turbo
- FS:(CO) JM Fab Intake pipe
- ets uicp
- FS: Greddy Profec B Spec II
- FS: PTE 880cc injectors, Like new!
- FS: Revolver Cams & UR Cam Gears
- FS: EVO 8, 9, Sonata Parts
- FS: EVO 8 Parts
- (NJ) fs evo 9 turbo
- Tactrix Cable & Prosport Gauges
- FS: Borla Exhaust, XSPower Manifold, BC s&r's and Waterpump
- FS: ACT "heavy Duty" Clutch and Fidanza Flywheel - $250 SHIPPED!
- FS: TX: evo 8 turbo low miles
- GT4202 Turbo w/ Tial Turbine Housing
- FS: Boomba Fuel rail
- IL - evo 9 lancer Parts for sale
- FS: Sparktech Coil-On Plug Evo IX/Evolution 9
- Ultimate ratio gearset/ evo9 head gasket/ vibrant vacuum and more
- FS: Almost new 255 Walbro
- Skunk 68mm Throttle Body
- Grimspeed 3 port
- Evo 8 stock fuel hanger/walbro pump
- BNIB FIC BlueMax 1250 Evo 8/9
- Looking for the washers for the acd banjo fitting
- FS: BNIB OEM Evo 8 NGK Laser Iridium Spark Plugs IGR7A-G
- Stock evo9 map sensor
- BNIB Snow Performance Full Meth Kit
- FS: Evo 9 & Forge DV
- Front axle
- FS: Works Shifter Base Bushings BNIB
- Hallman MBC....SOLD!!!!!!!!!!!!
- QM 8 leg street (new version)
- 2 sets of FIC 1650 BlueMax Low-Z injectors, Bosch 1680 High Impedance injectors.
- FS: Grimmspeed 3-Port EBCS
- EVO Parts TURBO CAMS SPRINGS
- FS: Evo 9 RS Complete Stock Intake system / MAF/ Stock Cat / ACD ECU / Evo 8 bov
- AMS, toxicfab, quartermaster, precision, arp, stock
- Evo 5-speed whole shift setup
- FS: (CT/NY) Performance & Stock parts
- FS Greddy tic exhaust system.
- Coil on Plug Setup shift knob oil cap ACD/AYC Bleeder
- FS: FEELER: FP Red setup
- fs: Evo IX Stock Maf, Walboro 400lph pump
- NY- Garrett t3 .82 back housing
- FP HTA 3586 (only 3500 miles)
- Intake - MAF - Adapter - Air Box
- FS: Like new Quartermaster Twin disc 6 leg with hydraulic release bearing,
- FS: Magnus V5 cast aluminum intake manifold
- FS: FIC 1680 High Impedence injectors- best driveability!
- FS: Red Tial Q BOV VTA mint
- FS: Evo 7 oem SAS / ANTILAG system
- FS: Gloss black powdercoated valve cover- super nice
- FS: IAC idle air controller Evo 8-9, TPS throttle position sensor
- turbosmart dual port
- New Perrin Metallic Substrate HFC (200 Cell)
- new oem pistons/rods, used crank, used cosworth m2
- Evo 8 MAF
- Synapse DV newer smaller version
- ASPEC Titanium test pipe
- FS Td06h-20g Turbo
- CT: Evo 9 C.O.P $200 Shipped
- Fs: Ets uicp
- Synapse DV Synchronic BOV
- T4 twin scroll exhaust manifold, 1200CC inj
- Stock Intercooler piping and MR BOV
- MAPerformance 6266 dbb COMPLETE TURBO KIT - BRAND NEW -
- FS: NEW 65mm t/b, New Walbro FP, Custom Intake & filter, Exh & intake manifolds!
- OEM Evo XI Cat - Low Mileage
- stock exhaust manifold(great for porting) CHEAP!
- forward facing hot parts,spec, 4g64 block
- FS:WA K&N and Ingalls Torque dampener
- bunch of parts must go dirt cheap... 6sp trans
- FS:WA Intake Manifold, Sun Auto HyperForce etc
- FS: Tactrix 1.3u
- FS: ATP GTX3076R, only 500 miles.
- fp 4"intake pipe
- HKS Power Flow Filter
- WTS NEW O2 housing and O2 Sensor!
- Exedy wave lock retaining clip
- FS: Buschur Racing pro cdi, Greddy TIC, Injen intake and piping, Tein strut bars
- FS- Mivec Cosworth M2s, BR UICP
- FS: Brand new EFR 8374 T3 SS
- ARC TI heat shield and 1.3 bar rad cap{{$ drop}}
- FS: TX - Speed Density K&N intake kit
- For Sale: Megan racing Manifold and o2 housing
- FS: Stock intake with piping!
- Stock Injectors, lifters, MAF sensor, Turbosmart, Perrin filter, Toda, and more
- Ams fmic
- AFX AFR Gauge
- HKS DLi-2
- (FS) FP Red good condition
- LF: stock 8/9 injector. only need one
- Feeler: T4 TS HTA86 kit for trade with 3076 kit
- ATP gt35r stock location turbo kit F/S
- AMS, Shep, Exedy, AWDMotorsport, Sparktech part out
- FS Buschur Cross Member TPS IAC Motor Headlight Parts
- FS: TX - Exedy Twin HD only 1500 miles
- OEM evo throw out bearing
- Perrin Upper IC pipe, silicone
- DSS lv5 Axles
- FS: Magnecor wires + Coils & HKS BOV (CA)
- FB Black JB, MAP Rev 3 IM, MAP Tubular EM, FB TB, Cam gears, cams and more!!!
- FS: Cusco Oil Catch Can
- BR EVO driveshaft loop kit
- HKS 272 cams for EVO 8
- FS: Buschur uicp, HKS, Maf
- Sts/turbo smart raceport bov, and wastegate BNIB
- Shep Trans Transfer Case Force Performance FP3794 Evo 8
- FS: HKS DLI II Twin power ignition cheap ($100)
- FS: TX - Vibrant MAF adapter
- FS: TX - stock location adapter for Tial bov
- FS: TX - STM clutch fork stop
- FS: TX - Grimmspeed 3 port EBC
- FS: TX - JmFab Deluxe Catch Can
- FS: TX - Omni 4 Bar
- FS: TX - FP Black DBB Ported - Like New
- Tomioka Racing Stainless Exhaust Manifold - EVO 8/9 - Has 2 weld cracks
- Finally cleaning out the garage.
- Hallman Pro MBC with in car extension.
- Evo 8/9 Aeromotive fuel system
- serpentine belt. Stock FMIC undertray, etc
- HKS VPRO EVO 9 pnp harness
- Brand New 88mm Eagle Crankshaft
- FS: Brand New MAP EF3 turbo
- EVO ECU from AN EVO 4
- FS: ETS licp
- BNIB! exedy hyper twin disc
- FIC BlueMax 1450 injectors
- Greddy Full Titanium Catback Cheap!
- EvoSvan 1.3r datalogging/reflash cable
- F/S: Evo 9 bov only 2k mi on it. LIKE NEW
- F/s: Oem evo 8 fmic *clean*
- AEM 5 bar map sensor $25 shipped
- HELP.. Balance Shaft sprocket needed :(
- CT: Go Fast Parts(QM Twin Disc,Buschur,Injen,Hafe,Koyo,FIC,Omni,Garrett)
- Post build stuff.. Ets kit, 2.0 cranks, wepon r intake manifold, coolant hoses
- Dejon tool 3" intake pipe w/ filter
- Buschur Racing Lower I/C Pipe's
- Fs: Ams licp
- FS: BOV, Test pipe, AMS mount
- FS : Stock evo IX fuel injectors
- K1 rods 162mm cheap
- BNIB evo 8/9 L19 headstuds
- Aquamist HFS-6 Methanol Injection Kit, Turn key kit
- RC 1200cc Injectors Low Miles!
- FS: Alternator off 2005 evo 8 ssl
- FS: Evo 8 Stock turbo $250 shipped
- quartermaster 6leg twin disk
- New Competition Flywheel! $225 shipped!
- Spark Tech Non CDI System 4K miles
- Map 02 dump/down pipe 4k miles
- 1000cc injector dynamics 4k miles
- Ets upper icp & ets lower icp
- Full-race exhaust mani ported/coated 4k miles
- FS: OEM Evo 9 metal bov
- Back to Stock sale (ETS, Buscher Raching,ARC,Greddy)
- PPG 4speed Dog Box + Ikeya & Ghost Shifter
- FS: PTE 6262, Kelford 272's, HKS, STM, & more
- NNY: Stock intake mani exhaust mani and tb for sale
- FS/WTT : SparkTech Non-cdi COP evo IX/VIII
- Buschur Racing UICP short route
- FP Red --Megan Racing 02--ported stock manifold
- FS synapse bpv (new version) ny/nj/pa
- FS: Cleaning out my cam closet - Lots o cams
- WTT GReddy Type RS for Evo 9 MR BOV
- Walbro 400 with Sending Unit
- FS: ACD Pump Assembly, Valve Cover with AN fittings, Evo 8 Stock Turbo Set Up
- BSE stub shaft
- HKS EVC 5 Electronic Boost Controller
- Cusco Oil Catch Can - Brand New
- FIC 1450CC BlueMAX Fuel Injectors
- Defi Gauges, Ported Intake manifold, stock TB, Nvidia 02 Housing, etc
- FS: Ikeya Sequential Shifter
- New HTA71/84MM Cover/Ported 10.5
- FS: megan racing cat-back exhaust with test pipe
- FS: (CT) Hi flow Cat
- STM Koyo Half Radiator w/ FAL Fan
- FS: GSC Stage 1 EVO IX Cams
- 4/S Buschur racing Dual stage Boost Controllers
- DNP Twin Scroll Exhaust manifold
- Precision 1000cc injectors for sale: $200 OBO
- PTE 1000cc Injectors FOR SALE QUICK
- DBB 6262/.82AR with coolant lines
- FS: Evo 8 stock turbo, uicp w/bov, stock fmic, etc
- evo 9 oem turbo and oem catback
- FS: PPI 65 mm Throttlebody
- F/s- t3 steel braided turbo return line kit with fittings
- FS: ACT/BUSCHUR/DC/HKS/OEM/SBR Parts! Great Stuff!!!
- FS: Bushur Racing DBB GT35R Cast Kit (CA)
- FS: Old School FPGreen Turbo Kit (CA)
- AEM EMS Series 2 / Walbro 400 LPH - Barely Used
- FS (PA) AMS Front Mount NEW
- AMS fuel line, injectors, rail fittings
- Forced Performance HTA GT3586R (.82 A/R T3 with V-band outlet)
- BNIB Agency Power Exhaust
- Gasket,stock FMIC, Serpentine Belt, etc
- NY: FS Evoscan Tactrix Cable 1.3 $100 shipped
- MAF assembly includes K&N filter and adapter/coupler
- Ebay? o2 Housing $65 Shipped
- Evo 9 Clutch master cyl
- Evo 9 knock sensor
- FS: OEM Evo 8 MAF
- FS: Evo 8 ECU
- FS: ARP studs, trans housing, Oil Cooler, 1st gear, PPI, Water pump
- FS: APS High Volume Twin Vent Blow Off Valve PRICE DROP!!!
- Feeler/FS: Garrett-Honeywell GT4088R Twinscroll Turbo Kit -Atlanta-
- FS: Ralliart 4G69 2.4l Block w/crank
- Spoolinup COP kit for EVO 8
- ETS 3" IC, AEM EMS, Aquamist HFS-5, Greddy IC pipe, HKS Intake
- FS: Good Core 4g63 Evo block with oil squirters, ARP mains, girdle
- FS: Rebuidable Exedy Twin HD
- FS: Timing Belt Kit Evo 8
- FS: NH/MA Fujutsubo RM01A, the classiest EVO exhaust
- Rps pressure plate< custom 6 puck
- FS: ets intercooler and ets licp
