- WTT: HKS SQV Bov for Tial Bov
- greddy 750cc injectors $220!!
- FS: FP SS O2 housing, ported and thermal coated
- T Cases + ACD Pump + Diffs + 6 Speed Gear Box
- FS: EVO VIII wastegate actuator OEM
- Aem ems for evo9 with 5bar map and ita sensor
- FS: SoCal, ATP GT3071 Bolt On Turbo Kit $1000 NEED IT GONE TODAY!
- Evo 8/9 awesome sale!!!
- evo 9 turbo
- FS: Black BLOX Racing Front Engine Mount
- 634WHP Evo 8 Complete Part Out!
- TW: Exedy Twin needing rebuild
- Stock exhaust manifold
- WTB: Built NON-acd transfercase
- Aquamist HFS-5
- A/c compressor w/ lines
- FRONT AXLES - 22K miles
- Power Steering Reservoir Can
- Piston and rods and more!!!
- hks, forge, kenwood for sale
- Feeler: Non HTA FP Green & PTE 750 injectors
- FP 84mm intake pipe (2k miles)
- Stock IX MR Turbo
- injectors and meth
- FS: New JM Fab catch can
- wtb clutch
- FS: Custom turbotrix intercooler
- FS: Custom Turbotrix gt42r manifold
- Kelford 280's used for sale
- New In Box FP Black - Trade for HTA Green
- ACT 6 Puck Unsprung w/ ACT Streetlite Flywheel
- GSC Beehive Valve Springs, Unorthodox Racing Cam Gears, ACL rod/main bearings, etc...
- FS: evo 8 stock cams
- WORKS* Evo 9 DV
- BNIB FIC 2150's
- FP Oil Line Kit (2K miles)
- Grimmspeed air/oil seperator
- WTB : Evo 8 Bare Block and Head.
- Misc Parts
- K&N, MAF Sensor, Oil Cooler, Throttle Body, Boost Gauge. Brake Ducts Kit, EVO 9 Grill
- Billet motor mounts, clutch line
- hks 280's and Megan o2 with manifold
- Nisei LICP
- Nj-2006 MR 6SPD Transmission
- PTE 1000cc injectors
- FEELER: Buschur GT35R turbo kit for sale. and HFS 5.
- FS: Innovate LC-1 Wide Band O2 - Brand New
- FS: greddy rs bov(used),AMS moustache bar(new)
- WTB Stock Evo 9 BOV
- Evo 8/9 Parts
- Feeler: F/T 6262 turbo kit
- Megan 02 housing $60 shipped paypal only
- FS:NY: Greddy Profec Type S Electronic Boost Controller- $100!
- Exedy HD Stage 4 Twin Disc Clutch Kit
- FS: Greddy Turbo Kit
- K & N Filter intake W/ MAF
- Hks uicp w/hks bov
- Ets licp
- Gsc s1 cams
- FS: Evo RS Helical Front Diff (LSD)
- FS: Evo8 Ecu w/bracket
- ETS LIP 4 Sale
- ETS Short Route UIP 4 Sale
- WTB: Stock (OEM) Intercooler+Uicp+Licp
- WTB: 3" stainless downpipe for Evo 8 with ACD
- FP BLACK 0 miles BNIB
- FS: Custom purple Samco lower radiator hose
- PTE 880cc Injectors
- FS 2.4L Crank manley I Beam Rods and Wiseco Pistons
- FIC 850 CC injectors for sale
- NEW OEM timing belt
- Nisei Engineering Genesis Mini Battery Kit
- FS: Koyo half width radiator
- FS: Fabworx 4.5 inch IC with 3" inlet/outlet
- INJEN intake kit and upper intercooler pipe...
- FS:Evo9 cams/valve springs/clutch parts
- FS. AEM EMS 1313-U with wideband sensor
- WTB VIII engine stuff
- FS: HKS 280 cams VIII
- Brand New Hallman, Walbro fuel pump, and tires!!!
- WTB: RS TCase
- Forced Performance 3794 etc f/s
- FS: AEM TruBoost EBC Gauge
- FS: Non CDI Spoolinup COP Kit
- WTB good reliable DD clutch kit
- FS: axles/hubs, mustache bar, radiator, o2, downpipe, trans, struts, trunk, etc!
- FS: FIC 2150cc
- RC 1000cc injectors
- HKS 280 cams for evo 8
- WTB GSC S1 EVO 9 mivec
- FS in FL:Evo 9 turbo, Buschur ported exh mani, Forge WGA, EPM O2 dump & all lines...
- WTB : Evo 8 stock ECU
- fs:aps 3.5" tbe for evo 8/9. $250 for today only.2/3/11
- EVOSCAN GPS touch screen
- FS: Synapse universal DV
- FS: Exedy Racing Lightweight Flywheel and Clutch
- FS:Exedy twin disc & ACT throwout bearing
- 06 EVO IX stock parts for sale!!
- FS: EVO IX Throttle Body
- Evo 8 Radiator 66,000 miles..
- APS Twin Vent Blow Off Valve
- FS: Stock Evo 8 Parts
- FS: OEM Timing Belt Tensioner & OEM Turbo Water/Oil Lines
- FS: Buschur Racing Upper Intercooler Pipe
- Evo 8 OEM Crossmember - Make your best offer
- exhaust manifold gasket
- FS: (2005) 10.5 Evo VIII Turbo
- FS: Custom Megan o2 Housing/Dump
- FS: Comp 272 Cams
- WTB: 5 speed trans
- AMS oil pan
- FS: NEW DNP T4/44 Manifold
- WTB Evo 9 piston rings (I need one oil ring)
- Like New AMS/Buschur Racing Parts
- 4in Intake pipe for s.d. and stock frame turbo
- FS: Evo 9 shortblock 21,000 miles
- FS: Ported FP-BLACK
- PTE 1000cc Injectors
- FS: Evo 8 10.5 hotside turbo
- Megan racing catback NJ
- Evo 8 Garage clean out! Valve cover/Forge BOV etc...
- WTB HTA3582r with 5-bolt GT35r Turbine housing
- WTT:entire fp green set-up+cash for ur 30R, 35R may be fpred setup
- WTB 5-bolt GT35r Turbine housing
- BRAND NEW: Competition twin disc Front Mount Super Tech Valve Springs Megan Turbobac
- FS: (TX) Nice Parts---ARC, Buschur, Tactrix, Vishnu!!!
- FS: ARP headstuds BNIB
- Evo 9 Kelford 272's and Kelford beehive valve springs NIB
- Evo 8 piston and rods
- Fs/ stock and aftermarket parts
- 3' inch test pipe with cutout
- Wtb: Evo ix turbo asap
- Snow Performance Meth Kit
- [F/S] Full Blown Double Pumper with Pumps BRAND NEW
- Evo MR Turbo & Stock Intake System
- 3 inch Test pipe used in good condition
- IL:WTB: FMIC + Uicp + Licp
- FS-Authentic GReddy blue oil cap
- Arp Head Studs
- fs/ft particle turbo kit
- Tial Q Bov
- Stock Motor Mounts with AMS Red Poly Inserts
- Stuff for Sale
- CHEAP ARP studs and supertech dual valve springs/retainers
- FS:05 Evo 8 ACD Pump
- New in package ARP rod bolts 4G63!!
- evo 8 greddy exhaust/dp (nj)
- Stock cams,downpipe,intake, and cat plus K&N
- FS: Greddy Type-S BOV + Recirc adapter
- Snow perf stg 2 meth injection kit
- Ets uicp + licp
- Buschur Racing Catch Can for sale
- WTB ACD T-Case
- FS: Ngk Spark plugs for sale for Evo 8
- Synapse BOV Evo Flange (Updated version: 2 port)
- FS: GFB deceptor BOV
- WTB: Evo IX Motor Bottom end
- HKS EVC VI / FCON V-Pro
- HKS 264 Cams for Evo 8
- denso 880cc injectors...
- Injen Intake+UICP & SAMCO BOV
- FS: AMS lightweight front cross member
- FS: BNIB PT&E 46 mm wastegate & ID 2200cc injectors
- Fs
- FIC 1550's EVO 8
- WTB: Tilton Twin Carbon Clutch
- Stock evo ix mr ( intercooler & muffler )
- FS : 6 spd trans
- WTB 5 spd conversion parts
- FS: MilSpec 65mm Throttle Body
- injector, tial,6262,intake
- fs:ebay o2 dump,stock intercooler,oem 8 cams
- OEM Cam gear cover
- FS: AEM Blue Cam Gear
- BNIB Aquamist HFS-6, Greddy catchcan
- WTB: 3" K&N intake cone filter ASAP
- FS: Evo 8 Cylinder Head, Turbo Parts, Injectors, Etc.
- Fp black for your fp green
- FS: Injen intake & uicp
- Fuel rails, fuel cell, surge tank, grimspeed ebcs, UTEC, shifter
- High End Parts Like New/ AMS/Buschur Racing
- pa evo ix need these parts asap brakes abs injectors ignition tcase hood rims slicks
- FS Exedy twin HD AMS push style clutch
- PTE 1200cc injectors
- FS: PTE 1200cc Injectors
- Perrin intake tube
- FS/FT:NJ Turbo XS TB exhaust
- full blown /transmission/radiator and more
- wtb: EPM evo 8 dump tube
- FS: NIB Sychronic DV
- Evo 8 Stock Cams and Head Studs
- FS - Shearer O2 Dump Housing for stock/green/red/black turbo MINT
- fs: MXP heatwrapped 3" downpipe
- WTB: serpentine belt tensioner
- FS: PTE 1000 injectors $320 shipped
- Testing waters FS DC: FP HTA Green
- FS: Jackson Auto Machine Evo8 bare head with damage
- 3" intake with recir tube, maf, filter.
- FOR SALE: Greddy Ti Titanium Catback Exhaust (non-rolled tip)
- Pivot Raizin volt Stabilizer Regulator
- Mini battery tray
- AMS Evo Small Battery Kit
- Dejon Tools modded MR BOV (leak stop kit)
- FS: AEM EMS Series 2 Evo VIII
- FS PA/NJ/NY Surge tank fuel system
- SS Clutch Line Brand New
- EVO 8 Turbo w/10.5HS
- OEM VIII Cams $75
- FS: Nisei UICP EVO 8/9 & AEM Intake
- Ets licp
- Nisei Engineering UICP
- FS:Driven Innovations Large Plenum Intake Manifold
- Evo IX BOV
- Throttle Body, Intake Manifold, Mishimoto Radiator, MAF Sensor, ARP, FPR and MORE!!!
- Fs intake,injectors,dump,ic pipe
- FS/FT, ETS 61mm(gt35r) trade 4green or better stock appearing
- ACT Streetlite Flywheel
- Stock 8/9 Intake Manifold w/ Sensors
- Wtb : Iac hardware
- WTB Tactrix 2.0
- wtb rear diff parts
- Wtb: Uicp
- FS 780cc percision injectors.
- Apexi s-afc ii @ usd 200 bloomslang harness @ 90
- Exedy Twin HD replacement Disk
- FS: Turbo XS FMIC & HKS SSQV BOV
- FS: Precision 1000cc and Stock injectors for sale
- FS-NYC-Evo 9 Turbo for sale under 20k priced to sell!!
- F/S OEM Mid-pipe- NJ
- FS: Buschur Racing JDM Ported Intake Manifold (New)
- PTE ball bearing TURBO kit feeler
- FS: Buschur Racing Stainless Steel Fabricated o2 Housing
- FS: Buschur Racing Lower I/C Pipe for BR Race FMIC
- Magnus Manifold w/ Direct port nitrous Injections and 75mm TB!
- wtb stock 8 injectors cheap
- FS: Precision 880cc AMS Injectors $390 Shipped
- Wtb non hid headlight lenses..
- Walbro 255 Fuel pump
- WTB:: MAP sensor adapter plate for aftermarket intakes
- Evo8 10.5 turbo/Oil Drain/Buschur Manifold/LICP/
- Shearer, GSC, Aeromotive, AEM, Beatrush, HKS, PLX,OEM
- F/S Stock Front diff
- ~~~Tial 50mm Q Blow Off Valve~~~
- Evo super sale!!!
- Mounts, Abs Unit, SS Clutch Line, Undertray Garage Sale
- FS- Evo parts Aftermarket & Stock!!!!
- WTB: ELECTRONIC BOOST CONTROLLER for Evo 8
- FS: Stock exhaust manifold/ Injectors
- FS: Tactrix 1.3
