- QTP External Dump O2 Housing
- NY: FS Stock Evo 8 VIII 16G Turbo**************
- WTB V9 aquamist circuit board for good price
- Evo8 HKS 280 cams,Ams fuel line kit,ID 1000's,fp actuator
- FS: Evo IX Factory ECU
- Evo Parts..Stock Turbo kit//ix bov Need this crap gone!!
- FS - Evo 9 MAF (10k miles used) + Perrin air filter + MAF adapter! Has to go now!
- FS - Saikou Michi baffled catch can Brand New! Needs to go!
- ARC super induction Box
- evo 8 & 9 complete rear diff
- FS: ported manifold, evo 9 catalytic converter
- FS in FL: 2-Walbro 255lph fuel pumps--both new
- BNIB O2 Housing w/ Gasket and Bolts
- BR licp
- Kelford 280's brand new never opened for Evo 8...
- K&N Intake Pipe & Filter
- FS FL: Stainless 3 Bolt Evo VIII test pipe
- FS: Maf sensor w/ K&N filter and adapter kit
- For sale: Gt3582r with .82 ar housing
- *Feeler* 84mm FP Red
- FS: ETS UICP with TiAL QR BOV
- Innovate LC-1 wideband, NGK PFR7G-11S spark plugs
- WTT FP Red+Cash for FP Black
- EVO 8 Turbo
- FS: Socal - Used Tilton Twin Clutch, Helix 3" SS Downpipe, Stock Evo IX Cams
- Spark Tech CDI basic
- FS PA BNIB Exedy pressure plate surface
- FS: NRG Engine torque damper
- FS: Shep Trans, Transfercase, Clutch Priced to sell
- FS: 05 Evo 8 10.5 hotside turbo
- FS: Ported stock exhaust manifold
- **FS: JMFab Non-Recirc MAF Pipe, Great Condition, Take a look!!**
- **FS: Great Condition Coated MAP 02 dump, Check it out!!
- **FS: Brand New Shearer 02 dump, Take a look!!**
- **FS: Great Condition Megan Heat Coated 02 Housing, Check it out!!**
- **FS: Brand New STM Oil Return line for a Stock Appearing Turbo!!**
- **FS: BBK Full, Ported, Good Condition, Only 2400 miles!!**
- **FS: Tab Fab Custom Stock Exhaust manifold Heat Shield, Perfect Condition!**
- FS: driven innovations intake!
- Garage Clean out
- Stock Evo 9 turbo (5,000 miles)
- Cusco Turbo Heat sheild.
- FS: BR SS Fabricated O2 housing
- FS: Buschur Racing 65mm TB w/ MIL.SPEC shaft seals
- Oem oil pump evo 9
- New OEM Head Gasket, OEM Turbo Gaskets, ARP Head Studs
- FS: BC 280/280 cams
- FS: Rear Diff
- FS WA: Precision 6057 Turbo T3
- f/s B and m short shifter
- DC Sport Downpipe - Heat Shield
- Feeler: Trade Precision 6262 Turbo with mani for HTA Green or Red with mani
- Freshly Rebuilt Transmission (NC)
- BNIB: AEM 5 bar MAP sensor
- 2 Evo 8 DVs for sale
- WTB Stock Injectors
- F/s ams high flow cat for evo 8 9
- FS Greddy Ti Catback w/ Rolled Tip - Full Titanium, rare! Priced to sell! NYC
- hks bov for sale with piping
- Precision 46mm wastegate. $210 shipped
- DSM flanged FP3065 Dual BB turbo, $900 shipped
- Precision 1000cc injectors, $200 shipped
- XMAS Special
- a couple used parts
- Collin@ToxicFabs FOR SALE THREAD!!! PICS!!!!
- FS: Fully Built 2.1L Motor
- WTB: Short shifter
- FS:OEM maf pipe, uicp, licp
- WTB FIC/PTE Injectors
- ets 3" intake pipe
- FS: JDM Evo 4 Engine and Transmission
- Clutch stops
- New divided t4 turbine housing for 67mm/p trim
- WTB: T3 Exhaust manifold111 WHAT U GOT???
- Fs: Ets 3.5" fmic
- FS: Evo 9 Mr Full A/C
- F/S: ACT 6 puck clutch and flywheel MINTY under 2,800 miles
- Cheap HKS Hi-power and Espelir jgt500 cat back exhaust
- WTB: ACD Transfer Case
- EVO IX turbo
- ID 2000's and ID 1000's for sale
- FS: MR 6 speed Trans swap kit
- FS- Evo 8 Tasteful Parts!!!!!!!!!!!!
- ETS intake pipe $ 40 brand new!
- Fic, forge
- FS: SQS sequential shifter
- Stock valve springs
- FS: Ets LICP v2
- FS: Cosworth 272 M2 400 shipped!
- Forced Performance Turbos & Accessories!!! FP's #1 East Coast Dealer!!!
- FS: Matte Black Nisei UICP
- shearer fabrication manifold with 5 bolt housing.
- Evo 9 Parts
- Injen maf adapter
- evo 9 stock valve springs
- FS: Open dump tube
- Fs:nj: Stock intake manifold
- OMG BRAND NEW still in plastic ARP headstuds!!! [pics inside]
- Misc Parts- Flanges, BOV, Hood, Oddysey Terminals, Cams
- FS: EVO8 ARP Head Studs 207-4203
- epm o2 dump
- Garret 4094r Turbo
- WTT or WTB: 5sp Gearbox to suit Evo 8/9
- FS: Setrab oil cooler, 40 rows.
- FS: 8 trans/tc, MBC, Spec Clutch, Rear axles, 8 turbo
- FS: BLOX front engine mount
- evo 9. motor
- GSC S2 Evo 8 cams
- FS: Stock Evo 8 MAF
- FS: 05 Evo 8 Stock Valves
- FS: Stock Evo 9 Coils
- FS: Stock 05 Evo 8 FMIC
- FS: Evo 8 Downpipe and Perrin High Flow Cat
- Bushcur Racing Air filter kit
- FP Evo 9 oil filter housing oil line kit (complete)
- FS: Used Open Diff from Evo 8
- FS AMS VSR + BBK 75mm TB
- FS: Oem springs/retainerrs,injectors,IX bov
- WTB: Aquamist V9 circuit board
- FS: 2 Evo 8 stock ECUs Mint condition
- FS: ID2000 injectors
- WTB + Battery Terminal / Fusible Link ASAP
- evo 8 head
- F.S. hta 3586
- FS: Great Condition OEM Coil Packs & Wires, Check them out!**
- Howards Ultimate Duty Connecting Rods & Je Pistons!!!
- FS: GT3076r, Tial 38mm, Bushur LICP, JDM
- FS: BNIB Wiseco k548M87 pistons
- Maperformance o2 dump, FP 25psi WGA
- Exedy Single Disc Clutch
- BR mini battery Tray
- FIC 1350s
- wtb rear axels
- Evo Coils, Koyo Radiator, OEM exhaust and more....
- FS: Strictly Modified Built Trans and Exedy Tripple Clutch
- PTE1000cc injectors in perfect shape with all O-rings
- WTB EVO 5 speed BELLHOUSING
- FS: ETS intake cheap/stock exhaust manny and O2
- FP HTA3582r 1.06 A/R (chromed/jet-hot coated)
- FS: (MD) BNIB IX Water Pump
- AMS shifter base bushings
- Wtb valve cover
- OEM EVO 8 or 9 Fuel Sending Unit
- Feeler: ETS intake pipe, AEM filter, Outerwear prefilter package
- FS: FP 18psi WGA
- Need, Injector plastic end caps PTE's
- Stock TB and Manifold
- FS: Diff - Axles - Subframe - etc
- Used walbro fuel pump
- FS: A'pexi Racing Wastegate.
- FP upgraded oil supply kit!!
- EVO 8/9 Parts PRICES AND OFFERS
- FS: OEM valve cover
- fp turbo cheap!!!
- Fidanza flywheel, WORKS croxx plate, OEM-TB-IM-Brackets-Clutch-Trans CHEAP- ARP Bolts
- FS: AMS FMIC & Stock Evo IX MIVEC VC
- WTB: Stock 5 Speed Shifter
- FS: BB 6262 (with .63 5-bolt exhaust housing)
- FS:HTA3582r .82 hotside
- 35r bb turbo kit complete For Sale
- evo 4-9 5 speed transmission..tranny in good condition
- FS: KOYO Racing Radiator,TB,stock ignition,Ams slim Shroud fan and More Super cheap
- Front Driver's Side Axle
- OEM UICP, Exhaust Mani, Complete A/C, o2 sensor and housing, HKS Intake
- Race Cat
- 6-speed shifter, knob, and cables
- FS: Factroy TB w/sensors, exhaust manifolds
- Akmee 5-Bolt Cam Gears
- Precision 46mm wastegate - NIB
- FS: Evolution 8 transmission
- FS: Exhaust Manifold $75
- Bnib speed density set up!! Cheap
- F/S Tial 44mm vband wastegate!
- FS BB 6262 turbo W/ V band hotside
- FS: PTE 1000cc injectors barely used Ready to ship
- 2005 Evo 8 GSR 10.5 Turbo/Downpipe/Cams/O2 Outlet
- fs: megan o2
- FS: Evo 9 Stock Exhaust and Intake Manifolds
- Feeler: HKS SSQV V2 Bov
- FS: 3" Test Pipe
- Exedy Triple/FIC easy squeez clips/BLE tbelt tensioner
- EVO 8/9 AMS High Flow Cat
- .63 gt35r, tial 44mm WG (BRAND NEW!)
- FS: stock ported exhaust mani, 3" downpipe
- FS: Excedy Triple Disk; HKS DLi2; PTE 1200s Injectors;
- stock valve springs/retainers
- 38k EVO 8 head
- ACD ECU $65 shipped
- **actual pics** exedy twin carbon clutch
- FS: Mil.Spec ported intake mani, PTE 880cc injectors, FP Green (1st gen)
- FS: AMS VSR, PTE 1600cc, Shearer Exhaust manifold
- For sale 06 evo mr trans
- FS: hks hi power(15k miles)
- Stock Exhaust Manifold Heat Shield x2
- Kelford 8 cams, 9 BOV, FP RED
- Greddy SP2
- Milspec built and ported stock throttle body.
- FS: Invidia o2,DC dp cat delete
- Parts for sale.
- FS: Greddy Stage 1 Evo 9 cams BNIB $100
- FS" AMS 4g63 Cam tool
- Dynatek ARC-2 CDI Ignition w/ Coils $300 shipped
- Cosworth m2 272 cams, springs & retainers
- Tial bov red and silver
- Hallman PRO RX,300 cell HFC
- Stock evo ix ecu
- Feeler Map o2 eliminator dp bnib
- WTT: HFC for Test Pipe
- WTT: omni 4bar map sensor for AEM map sensor
- 272 cams for sale. CHEAP!
- Brand new Supertech dual Springs for sale
- w.t.b acd hydraulic pump 2005 ix
- Alot of parts for sale :) !!!
- Shep Stage 3 Transfer Case w/ Quaife.. BRAND NEW!!!!
- Wtb asap
- feeler AMS TURBO KIT!!!!
- FS: GT3582 Ball Bearing
- wtb: evo OEM catalytic converter
- Standard bore AMS spec Ross pistons
- WTB: Stock EVO 8/9 air box
- FS: (NC) BNIB!! Black Tial V44 Wastegates $300 ea
- WTB: Stock diverter valve intake tube
- Pistons, Rods, Perrin, BOV
- FS: (NC) Exedy Triple with 200 miles on it
- feeler: FP green(old style)6k miles!
- FS: Stock evo8 injectors
- Aftermarket and Stock (2.0L 9 MR mivec motor, head, gsc s2's, Turbo XS mbc and more)
- Omni 4 bar
- Fs: Evo viii oem ecu
- FS: Evo ECU & Tactrix Cable
- For sale. Buschur licp. And .63 turbine housing.
- HKS GT7640 GTII turbo only: $1450
- 03 Evo Shortblock Complete / Exedy HD Twin / Manley Pistons
- 2003 EVO 8 Pistons & Rods
- Greedy profec b boost control ********
- FS: Gates Timing Belt. Brand new.
- Computer
- Forge RS Bypass Valve (polished)
- FS: Tial 50mm BOV
- Nisei Mini Battery Tray & Odyssey PC680 Mini Battery
- FS: Stock unported exhaust manifold
- Anyone wanna trade trunk lids???
- 3 Stock Exhaust Manis...CHEAP!!!
- WTB: Looking to purchase Evo 9 Turbo
- 10second to Stock Sale. FP turbo, injectors, cams, supporting mods, more!!
- F/S precision 880cc injectors
- FS: New Shepard Racing Stage 3 Non ACD Tcase
- FS: JUN B.L. cat-back
- FS: Evo 8 cat delete pipe (used), Down pipe (new)
- AEM EMS Evo IX For Sale
