View Full Version : For Sale/WTB - Engine / Drivetrain / Power
- WTB [MidWest]: aftermarket intake manifold and throttle body
- [WTB] EVO 8 head
- WTT [Mid-Atlantic]: WTT/WTB HKS Hi-power for Bullet or other LOUDER exhaust
- FS [SouthEast]: RS HVAC/Radio Panel with 42 draft designs triple gauge panel
- [WTB] WTB 44mm tial or 46mm precision
- FS [SouthEast]: AN fittings
- [FS] Build Part Out (STM, JDM, SpoolinUP, AEM, etc.)
- FS [Mid-Atlantic]: FS: Turbo XS rfl bov
- [WTB] OEM AC condenser fan
- [WTB] Stock Exhaust Manifold or BR ported
- [WTB] want to buy ams/moroso oil pan
- WTB [West]: OEM Engine Parts
- [FS] MAP Ported Manifold, Evo Turbo, Power Steering Pump
- [FS] FS: brand new curt brown 8 head
- FS [Mid-Atlantic]: WTB Evo 8 TPS
- [WTB] Turbine Housing (Hot Side) for Evo 9
- FS [South]: ECU, wire harness, vlave cover, front bumper and more
- [WTB] 3.5in fmic please
- FS [MidWest]: Injen pipe kit, o2 dump,unos, evo 9 turbo, etc
- WTB [Pacific NW]: ETS Short Route UICP + Stock Evo9 BOV
- FS [SouthEast]: Excedy clutch used parts
- FS [SouthEast]: 2150 high z's with pigtails and o-ring kit
- [FS] Carbonetics Twin Carbon clutch
- FS [Northeast]: Ets uicp, evo 9 bov, injen licp
- [WTB] Fuel injector resistor pack
- FS [Northeast]: Aem ems 2
- FS [Northeast]: Oem Evo 9 Mivec cams
- [WTB] WTB: GSC S1 Camshaft for Evo 8
- FS [Mid-Atlantic]: Evo 8 oem parts fs
- [WTB] BOV/DV or Recirc valve, 3" Catless test pipe, Evo 9 spark plug cover and intake pipe
- FS [MidWest]: Mivec FP5R Cams & Evo 8 10.5 Complete turbo
- FS [Mid-Atlantic]: Evo 8 BC272 Cams, AMS 880cc injectors, 3" downpipe
- FS [Mid-Atlantic]: Evo VIII alternator
- [WTB] Wiring for Mivec Solenoid and Intake Cam Sensor
- [FS] Fully Built 2.3l Aluminum Rod Short Block!!!
- [FS] Buschur, K&N, Evo 9 Turbo
- FS [Pacific NW]: FFTec 3076r Hot Parts Kit and extra parts
- FS [MidWest]: MAPerformance Rev2 Intake Manifold 70mm Throttle Body
- FS [MidWest]: Stock Evo 8 Injectors $130 Shipped
- FS [Northeast]: NYC: Stock Evo IX 4G63 Long Block & Transmission - Only 10,000 miles
- FS [Mid-Atlantic]: 8 Valve Cover, Throttle Body, Intake Manifold
- FS [Northeast]: Oem O2 housing
- [WTB] 6266 Full Kit (Topmount,FF,etc)
- [FS] Buschur Magnaflow Muffler Section
- [FS] Buschur Downpipe
- FS [Northeast]: JMF stock replacement exhaust manifold, stock cams
- FS [West]: Apexi WS Exhaust - Bay Area $200
- [FS] Evo parts,stock frame header,intake mani, tb ect..
- FS [Northeast]: 99.8% Brand New Gates Timing Belt... Cheap!
- [WTB] Evo 8 Comp twin disk or Exedy twin disk new
- [FS] Evo 8/9 FIC 1250 Bluemax Injectors - Cleaned and Flow Tested
- FS [West]: WTB bare 9 or bare 8 block
- FS [SouthEast]: Turbo Kit, Twin disc, Motor Mounts and More
- FS [Mid-Atlantic]: Zeitronix LCD wideband display
- WTB [MidWest]: Evo 8 complete short block.
- FS [West]: Evo IX Turbo, Comp Stage 3 Clutch
- [FS] Fp black complete turbo kit
- [WTB] 3" DP Evo 8/9
- WTB [SouthEast]: Driver Side Rear Axle for Evo IX
- [WTB] Evo 9 Coil Pack
- [FS] new tial 44mm wastegate (black)
- [FS] Brand New AEM INFINITY PnP for EVO 8
- WTB [Northeast]: Stock OEM FlyWheel - Evo 8
- [WTB] Evo 8 Camshaft Angle Sensor Trigger Wheel
- FS [SouthEast]: FullBlown Twin Pump E85/E98 Safe Anodized 900HP
- [WTB] 2.3 pistons and rods
- [WTB] EVO IX metal bov
- FS [Northeast]: six speed trans 62xxx miles
- FS [SouthEast]: ETS Turbo Kit 6266 CEA Ball Bearing 500-800hp
- [WTB] Aftermarket Lower Intercooler Pipe
- [FS] BNIB GTX3582 tial 0.82 A/R
- [WTT] FEELER- fp black jb turbo kit trade for 6266 turbo kit
- [FS] AEM EMS Series 2 (Evo 8)
- [FS] K&N Drop in Filter
- FS [Northeast]: CT - Parts - Clutch, turbo kit, etc
- FS [MidWest]: BNIB Precision T3/V-Band Out Ball Bearing 6266 Turbo
- [WTB] o2 dump
- WTB [Northeast]: WTB - Evo 8 O2 dump
- [WTB] T3 Hot Parts
- WTB [Northeast]: Evo 8 lightweight parts...
- [FS] Evo VIII Alternator
- [WTB] Evo VIII injector pigtails
- [WTB] evo mr built 6 speed trans or oil cooler setup
- [WTB] 87mm bore head gasket and L19 Head studs
- [WTB] kinugawa 25G or other affordable upgrade turbocharger
- WTB [West]: Evo 8 Coil Pack
- FS [Pacific NW]: Brand New NGK O2 sensor
- FS [Pacific NW]: 0 mile, Recently Refreshed EVO 9 Cylinder Head
- FS [Pacific NW]: MAP Evo 8/9 Intake Pipe - Turbo Inlet Hose BNIB
- FS [Pacific NW]: BNIB: Wiseco Piston and Ring kit
- FS [Mid-Atlantic]: FS FP intake, Cam gears, Intercooler piping
- [WTB] AEM EMS Series 2
- [FS] Kelford 272 evo 8 cams
- [FS] Evo 8 oem parts
- [FS] 4g63 bare short block
- [FS] FullRace manifold Dual WG T4
- [FS] Evo9 MIVEC stock cylinder head + OEM rods + 4.529 gears + 60mm coilover springs
- [WTB] Evo 9 turbo
- [WTB] 6 SPEED / MR transmission wiring harness for speedo
- FS [Northeast]: FP4R Cams
- FS [South]: New Okada plasma coil, rear diff axles and valve cover
- [WTB] Catch can & cf handle brake cover
- [WTB] MIVEC Solenoid, Intake Cam Sensor, MIVEC Conversion Parts, MIVEC Valve Cover
- WTB [MidWest]: ETS 3.5" intercooler
- [WTB] 4 inch SD intake
- FS [Northeast]: STM FF kit, Uncut engine harness, Tail 44mm MV-R
- [FS] EXEDY TRIPLE NEW REBUILD + AEM INFINITY PnP
- FS [Mid-Atlantic]: BNIB GSC S1, Competition clutch stage 3
- FS [Northeast]: Evo ix fuel sending unit with walbro 255
- FS [Northeast]: Comp stage 3 clutch with act streetlite flywheel
- FS [Northeast]: ETS 4" intercooler
- WTT [Northeast]: Forge WG Actuator, Gates Timing Belt, Gates Balance Belt, Stock Exhaust Manifold
- FS [Northeast]: NGK Iridium spark plugs EVO 8
- FS [Northeast]: AMS Exhaust Manifold and O2 Housing, Stock lifters, Stock Mivec Cam Gear
- [FS] AEM sequential ignition setup - 1000HP+ capable
- FS [Northeast]: Evo 8/9 Buschur 3" Magnaflow Muffler & CBE SCCA Legal JDM Bumper
- FS [Northeast]: Evo 8/9 Tomei Extreme Ti-CBE JDM Bumper
- [WTB] CDI ignition
- [FS] GSC S2 Cams, FP Beehive Springs and Valve Cover Gasket Kit
- FS [West]: *BNIB* FIC 2150cc Injectors with Clips & Resistor Plug
- FS [Northeast]: 6466 with T3 AND T4 divided housing
- [FS] Evo 8 Mishimoto radiator hoses - Orange
- [FS] Gsc s1 cams mivec evo 9
- FS [West]: Fujitsubo RM01A Exhaust, Megan test pipe
- FS [West]: New 264 Comp Cams
- FS [Mid-Atlantic]: EVO 8 OEM & Extras
- [WTB] Evo 8/9 Lower Intercooler Pipe & Coupler to i/c
- [FS] Evo 8 Adjustable Cam Gears
- [WTB] Tial 42r housing
- WTB [Australian]: 94mm Crank Evo 8-9
- [WTB] Evo 8 Valve Cover
- [WTB] Evo 8 Rear differential
- [WTB] Front 02 sensor
- FS [SouthEast]: Garage Sale GSC S1, Invidia, MAP, Megan, Mil Spec
- WTB [SouthEast]: DSS axles
- [WTB] Small battery tray
- [FS] EVO 8 big HP part out ,aem infinity,2.4lr lots of parts
- WTB [MidWest]: junk Tial 38mm wastegate
- [FS] FS PTE 6466 Turbo with ported T4 TS 1.15
- [WTB] Want to buy: Fujita UICP
- FS [MidWest]: Cheap FP Green
- [FS] BNIB 10.5 MHI JB FP Black Turbo
- [WTB] WTB bad evo 8/9 engine harness
- FS [Northeast]: New Exedy twin disk-mm022hd
- WTB [MidWest]: Journal bearing FP Red / Black (WTT + cash for my BBK Full)
- [WTB] wtb boomba 75mm
- [WTB] STM 3 port catch can 5 speed
- FS [Mid-Atlantic]: New ARP Head Studs
- WTB [Northeast]: 05 acd pump needed ASAP
- [WTB] Evo 8 fuel pressure regulator selonoid
- WTB [Mid-Atlantic]: Evo 8 Axles
- WTB [Mid-Atlantic]: Evo 8/9 Rear Differential
- [WTB] short route piping!!
- [WTB] Vband side exit exhaust/downpipe for a 0.82 Tial.....PIC inside!
- WTB [West]: 3" downpipe, catless mid pipe, Hallman boost controller
- [FS] evolution acd tcase 30k miles
- [FS] Evo 8 ecu, Aeromotive Fpr, ARP l19 head studs
- [FS] Tactrix 1.3U Cable
- [WTB] MIVEC solenoid needed ASAP
- [FS] buschur racing parachute mount
- [FS] Full-race efr downpipe
- [WTB] Evo 9 turbo
- [WTB] Looking for Fluidampr Evo 8
- [WTB] Evo 8-9 rear diff
- FS [Northwest]: Precision T3 6766 Dual Ball Bearing For Sale
- FS [Mid-Atlantic]: Skunk2, STM 650's, valve cover
- WTB [West]: ETS Lower Intercooler Pipe LICP
- FS [South]: 16k mile e8 ecu,ss radiator hard pipe,a1000 pump,oem wheels,cams and rear diff comple
- [FS] Rebuilt 8 turbo, 10.5 housing, TurboSmart actuator
- FS [Northeast]: English Racing “Race Port” Evo IX head
- FS [Northeast]: AEM EMS V2 $900 Shipped!!!
- [WTB] FIC 1450s
- [WTB] Catch can setup
- FS [Northwest]: kelford 272 evo9 cams
- [FS] AMS FMIC $500 shipped firm
- FS [Mid-Atlantic]: Double pumper, 2200cc injs, ACD pump, Perrin, misc stock parts
- [WTB] High Flow Cat w/ O2 Bung!
- [FS] Vipec ECU plug&play for Lancer Evo IX
- WTB [Northeast]: Wtb: Stock bare evo 8 head
- WTB [MidWest]: Kelford 272 or S2's and springs
- FS [SouthEast]: FS: 05 MR Bilsteins and Eibach springs
- FS [Mid-Atlantic]: fp green
- [WTB] Pistons and Rods
- WTB [Pacific NW]: WTB PCV 90 degree elbow/ where to buy help!!!
- [WTB] Small Stock Frame Evo 9 Turbo: EF2, HTA71, BBK-Lite
- FS [MidWest]: Exedy Twin Disk FS/FT, oem cams, blox lug nuts
- FS [Northwest]: Random atermarket parts
- WTB [South]: wtb a set of e8-9 rocker arms
- [FS] OEM Front Axles and Intermediate Shafts!!!
- [FS] OEM Wheel bearing hubs w/ ARP Extended studs & Tuner nuts
- [FS] 2006 IX MR Rear Differential ---- "Cheapest I've seen here!!!
- FS [West]: CA: ARC Cooling panel and ARC exhaust manifold shield / cover
- [WTB] FIC 1650 high-z or 2150 injectors
- [WTB] Mivec camshaft position sensor
- FS [South]: T3 Hot Parts Kit with 44mm Dump Pipe $480
- [WTB] Tial 44mm Wastegate
- [FS] brand new evo 8/9 ARP head stud kit
- FS [Mid-Atlantic]: Evo 2003 - 5 Speed Conversion Kit
- [FS] injectors
- WTT [West]: Evo 9 cylinder head
- FS [West]: HKS 280 cams for EVO 8
- FS [West]: EVO 9 Compressor housing and wheel
- [WTB] Driveshafts Evo IX, front&rear
- [WTB] Evo 8/9 crankshaft
- [FS] Shep 12 plate max lock rear diff
- [FS] jdm evolution 7 GT-A automatic transmission and transfer case with lsd
- FS [South]: Tilton Carbon Tripple clutch for 8/9
- FS [West]: Qtr Master 8 leg Race clutch for 8/9
- FS [West]: Torque Solutions rear Trans mount 8/9
- FS [West]: BR 3 inch SS intake for MAF with filter
- FS [SouthEast]: New ACT Full Face Sprung Disc & Stock used flywheel
- FS [West]: BR 3 inch turboback V-band exhaust
- [WTB] 1400cc + injectors
- WTB [West]: wtb: APS twin vent Bov
- FS [SouthEast]: Quartermaster 8-leg Twin Disc w/ Street Flywheel HRB push type clutch 900tq!
- [WTB] Fp red/green
- [FS] Shep 12 plate rear diff
- FS [West]: New Cometic Head Gasket for 2.4 (87.5mm)
- FS [Northeast]: NJ 4g64 100mm crankshaft
- FS [West]: NEW BNIB Fujitsubo RM01A Exhaust for EVO XI
- FS [MidWest]: Stock evo 9 turbo
- FS [MidWest]: Kelford 264 cams evo 8
- FS [Northeast]: Evo 9 turbo +
- [WTB] Evo 9 mivec head
- [FS] Injen black intake pipe re-circ
- [FS] BNIB OEM Thermostat + water temp sensor EVO VIII
- [FS] Evo IX Brian Crower 272 cams
- [FS] BLE Solid Lifter Pairs!
- FS [West]: Aftrmarket stock frame turbo manifold for Evo 8 9
- [FS] oem injectors
- FS [Mid-Atlantic]: Evo IX Stock intercooler/piping, fan, MR springs
- [WTB] Tomei 270 cams or similar for Evo 9
- WTB [South]: good set of stock evo 8-9 valves
- FS [MidWest]: ETS Battery tray
- FS [SouthEast]: Turbo XS 3.5" FMIC - Intercooler
- FS [SouthEast]: 4G64 crank
- FS [SouthEast]: MIVEC Valve Cover with AN fittings
- [FS] Turbo XS Dual Stage Boost Controller
- [FS] Fairclough -10 Valve Cover Fitting
- WTB [Pacific NW]: EVO 8 or 9 COMPLETE intercooler piping kit
- [WTB] WTB EVO 8 Head CNC 1mm oversize valves
- FS [SouthEast]: FS AL: Precision 6768 Turbo
- [FS] Manley Turbo Tuff I-Beam Long Rods
- [FS] Hafe T3 cast hot parts, PTE housing, MR 3" DP, Grimmspeed MCB, Denso coil clips
- WTB [South]: WTB:tourqe solution drivers and passenger side mount
- [FS] Gruppe-S 52mm Guage bezel + radio relocation kit
- FS [West]: Evo 8/9 stock BCS and lines. $30 shipped
- FS [Northeast]: Buschur V-band 6466 BB
- FS [West]: Forge UNOS manual boost controller. $60 shipped
