- FS: Wiesco - 2.3L Stroker Pistons - 10k Miles
- FS..06 MR 6 speed swap
- FS..Injen charge piping set
- Fs: Stock evo 9 parts for real chip on great conditions
- FS:NY Q45 Throttle Body $120 Shipped
- *** T3 Hafe manifold & Garrett T3 .82 Exh. Housing***
- black boomba 75mm throttle body
- FS: EVO9 stock parts: FMIC/pipes/intake box/MR gauges/test pipe
- FS: Synapse Synchronic BOV
- Buschur Mini battery tray & Megan O2
- F/S:FL: OEM Mitsu THROW OUT BEARING*NEW*
- FS: Precision Turbo 6262 Ball Bearing Turbo (NEW)
- FS: Precision Turbo 46mm External Wastegate (NEW)
- FS: Tial Q Blow-off Valve (NEW)
- FS: FP Bee Hive Valve Springs (NEW)
- FS: AEM Tru-Boost, ACT, Supertech, Crankshaft, Forge WG
- HKS 7460 Turbo and ARC Induction Box
- FS: Hallman Pro Manual Boost Controller
- FS Blitz Turbo Timer
- evo 8/9 aftermarket parts ETS/CUSCO/MAP/AP/GT SPEC/BRAILLE/GREDDY
- FS: Small after market part out
- Greddy Catch Can
- Bnib fic 2150cc
- ARC Heat Shield and Radiator Cover
- manely I beam rods wiseco pistons, and arp main bolts ext...
- Stock evo 8 cams and o2 housing
- Full Race GT3076R Turbo Kit HALF PRICE!!!!
- 3 axles from evo 8 cheap!
- Fs: Evo ix suspension, custom magnaflow sleeper exhaust, maf, oem flywheel and more!!
- FS: NEW- Helix 02 housing.
- FS: Boomba 75mm TB Evo 8/9 (TX)
- Stock exhaust manifold cheap!
- FS-[NY-Bklyn/Qns]Stock OEM pistons & rods & crank
- Fs: Oem viii bov
- NIB-stg3 comp clutch - Light flywheel- BC springs and retainers
- FS: SD kit, MAP o2 elim dp, ported ex mani, stock IM & Tb
- 3" Intake with HUGE K&N filter for stock appearing setups
- FS(Ca) Cobb Access Port for Evo 8/9 and some stock parts
- FS: JB FP Red
- aqua mist hfs3
- PTE GT35r kit w/ RnR exh manifold. SS coolant hard line.
- evo modded ported intake manifold 250 shipped
- Fp RED Turbo kit, Newer style, Complete with STM intake and more...
- Aem ems v1
- FS: 02 eliminator dp, catback, tubular mani..
- Ceramic Coated GT Spec coated Exhaust Manifold low low miles
- AEM uego wideband Tactrix 4bar grimspeed downpipe flywheel o2 housing
- Ralliart Oil cap & Coolant cap
- Custom Carbon Fiber Center Fuse box cover
- Buschur Racing Mini Battery kit
- Evo 8 Head, Evo 9 Transmission
- ets manifold 6262 intercooler and piping and more
- FS: DC Sports Test-Pipe-Eliminator DP
- FS Forge recirc blow off valve BOV black
- FS: Walbro 255lph fuel pump with install kit.
- Greddy Profec B Spec II EBC
- JB FP Black Priced Low No Hotside
- Bare VIII Head
- FS:Perrin full intake kit (NJ)
- STM upper, Stock exhaust manifold and XS Power
- ATP EVO8 Stage 3 Stealth Upgrade GT3071R Vesion 2 KIT (feeler)
- Fs: The Fp black you have been waiting for!!!
- FS: Precision 880cc Injectors
- exedy twin-disk
- FS FL *~*Melbourne Stock Catalytic Converter*~*
- Intercooler for sale/ stock evo 9 fmic great condition
- going back to stock sale gt30r
- FS: Cams, Cam Gear, Injectors, Fuel Pump
- FS: CA Synapse bov
- KAW mini battery tray
- FS: AEM boost gauge
- 2004 Evo 8 rs stock turbo + exhaust manifold w/42k miles, forge bov, MBC
- CA: GFB Stealth bov
- FS NY- Buschur Racing SD Muffler
- MIVEC GSC 2 CAMS fOrSaLe!******(IN)
- FS:Sun Hyperforce Ignition
- **FS: Great Condition Beatrush Solid Driveshaft Bushings (2)!!**
- F/S: (NY) GSC S1 Mivec Cams, OEM IM & TB
- Motec M48 plug and play ECU for evo 4-8 $1300 OBO
- Fp black ..great deal!!!
- WTS Evo 8 Turbo w/ 10.5 Hotside-Complete
- FS: Greddy Competition TI-C Turboback Exhaust (Willing to separate)
- FS: GSC S1 Mivec Cams
- FS: Invidia o2 Housing (Less Than 6 Months Old!)
- fs evo 9 part
- FS: OEM Evo IX 9 bov
- NM: Evo 6.5 Tommi Makkinen Edition Titanium Alumnide Turbo
- Omni 4-bar MAP sensor
- FS(NJ):MAP O2,DNP Manifold, Perrin Intake, OEM MR BOV
- Precision Tuning 880cc Injectors-
- stock & aftermarket stuff for sale.
- RC 1200 fuel injectors, excellent shape and low miles
- FS epm u2 dump
- FS:OEM stock Evo 8 camgears and thermostat housing.
- F/S: HKS SSQ, Aluminum LICP, OEM Pieces
- NEW: HTA 3582R turbo
- FS FL: TurboXS Catback Exhaust Evolution 8-9 LOW MILEAGE
- FS: Buschur Racing Test Pipe
- FS: HTA3586r ETS turbo kit
- FS NJ turbosmart bov
- Quick Sale- Brand New GSC S2 Cams*****LOOK HERE
- 2 Evo 8 throttle bodies for sale (Georgia)
- FS.Evo IX turbo PPI ported
- FS: Toxic Cam sensor shield
- FS: Evo 8 560cc oem injectors
- FS: Buschur Racing Stage 3 Head CHEAP!!!
- FS:Evo IX Damaged ported and Polished Head
- 6262 turbo kit, Haltech Platinum Pro, beehive valve springs
- FS FP Green and 272 cams
- FS: JDM 3 bar MAP Sensor (plug-and-play)
- FS: Crushed IX MR Metal BOV - Holds 30+psi
- FS: New External Walbro Inline Fuel Pump & Hobbs Switch
- FS: AGP 3.5" Intercooler (FMIC)
- INJEN LICP/WALBRO/FIC1050cc/AEM/TURBOSMART!!
- FS: Walbro 400lph with universal install kit and DW hardwire kit BNIB
- GT Spec manifold
- FS : NYC : Injen UICP , hellman boost controller, HKS timer, HKS BOV, L CEL fix
- FS: Shearer stock replacement manifold (used)
- FS:(SD)header,o2 dump,heat sheild,rad pipe,arp studs,maf/adapter,tow hook
- WTD Mivec Valve and Power Steering Pump
- FS: Evo IX OEM Injectors and Compressor Cover
- Fs samco radiator hose
- FS AMS Motor Mounts
- Fs:f/l: Engine torque damper & gt spec front ladder brace
- Stock 9 turbo, boomba, Ets, and more!!!
- FS: Turbo XS UTEC
- FS: Evo 8 Rods
- Evolution IX Turbo - 35k
- FS: aftermarket and stock parts
- FS: FL forge/wg, 3'' Exhaust w/test-pipe, Airbox, 8 turbo, manifolds, 02's, bov, bcs
- FS: Evo 9 Cams
- F/S: BNIB Kelford 272 EVO IX MIVEC
- FS: barely used Invidia test pipe w/02 bung
- AMS Turbo Back Exhaust
- Muse Coated LICP
- injen intake and bov's, megan exhaust manifold
- Evo 9 OEM Starter
- FS: ACL Race Series Rod Bearings BNIB
- ACL Race Bearings BNIB CHEAP!!!!!
- Perrin silicone intake+ adapter
- Evo IX turbo 60K
- F/S:FL: MAP 02/DUMP housing/GT SPEC MANIFOLD
- FS: ARP L19 Head Studs & ARP Main Studs
- FS: Evo 8/9 Tanabe Downpipe. $175shipped
- Buschur Racing Evolution Intake Tube
- Evo 8 AEM cam gears/TB/megan headers (CA)
- AEM Hybrid Filter w/MAF Adapter
- Green USA High Performance Filter
- OEM Evo X Metal BOV
- Like New Synapse DV & Flanges
- FS-TX Ingall's engine damper
- FS-TX AMS mini-batt kit with CDI mount
- O2 Sensor
- Precision 6765 Turbo F/S
- For Sale Go Fast Bits BOV
- FS: Buschur Racing UICP (tial flanged)
- F/s:fl: Greddy cooling plate evo 8(black)
- F/s:fl: Spoolinup cop evo 8..super shape
- FS: evo9 turbo with FP anti-surge cover (FAPC)
- F/s/fl: Braille battery and mounting kit
- F/s:fl: Ets upper intercooler pipe(short route) gloss black
- BR Race intercooler and lower...cheap
- Stock Parts, Fuel Pump, Wheel Bearing, Idler Pulley, Air Deflector
- FS: Evo 06 IX 56k longblock (mivec head) cosworth m2 cams
- Grimmspeed 3 port, ETS LICP
- FS: Evo 9 Stock ECU -immobilizer disable
- FS: A/C Compressor fits 03-06 Evo 8-9
- FS: ACD pump 2005-2006 - Great condition
- FS: Evo IX 5sp Stock transmission 56k
- FS: FIC 1650cc fuel injectors for pump, racefuel, q16 or e85
- FS: Evo 8 ECU
- STM 4" intake with MAF delete
- FS: Turbosmart BOV $80
- ARC Heat Shield
- Ingalls Stiffy Torque Dampner
- FS: 100% Genuine Buschur Racing Mini Battery Tray
- FS: Competition Clutch (Twin Disc)
- Evo 8 parts for sale
- FIC 950cc injectors + Walbro 255lph FP - BRAND NEW
- FS/WTT in NM: Evo 7 "EVOLUTION" valve cover
- FP Green and parts for sale
- Selling Brand New Walker Rear o2 Sensor 250-24631
- Misc fuel lines, brackets,etc, cheap and free stuff
- BNIB Gates timing belt 4g63 Cheap
- BNIB Wiseco 1400HD 10.0:1 Pistons CHEAP!!!
- FS: OH – Exedy Triple Cerametallic
- EVO INJECTORS 560cc
- Muse Motorsports Small Battery Kit Evo 8 & 9
- Stock EVO 8 FMIC
- FEELER: [NY] BNIB Invidia DP
- FS: STM clutch fork stop
- FS: BRAND NEW! ETS Evo 8/9 air intake
- FS: (NY) HKS intake filter
- FS: BBK full turbo UNUSED
- Custom Intake pipe + Blitz SUS Power LM Filter
- FS: Evo IX Turbo w/ Forge Actuator.
- FS: Aftermarket o2 Housing CT/NYC
- FS: FP Evo VIII Install Kit - Used
- FS: New AVID Front motor mount
- Fidanza cam gears
- FS: HKS Turbo timer, Ingalls torque damper
- FS: Boomslang EVO IX ECU Harness
- ported evo intake manifold made 866hp
- FS: Exedy Twin Plate HD and Clutch Fork Stop
- F/S power steering line's
- FS: Magnus V5 and Boomba 75mm TB
- Garage cleaning sale
- Rebuilt ACD pump
- Perrin foam air filter, OEM downpipe bolts (new)
- FS: Intake Pipes and Couplers Dirt Cheap
- Nology Hotwire set For EVO 8
- (fs) aem cai
- FS:(nc) buschur racing catchcan
- FS/PA: OEM Intercooler
- FS/PA: Injen IC Piping Kit w/intake & BOV
- stock parts cheap
- FS: Walbro 255
- FS: Socal - Greddy GR1 10w-60 racing oil
- FS: FP Black 1300 miles w/ FP Install Kit $1500
- stock ix turbo, pro stock manifold, stock mani, nisei, works, map o2
- Aem ems & hks mivec 272 cams!!!
- FS:Evo VIII/IX parts
- FS: Full blown hanger and evo 8 stock ic and LP.
- custom ets 4" intake with brand new aem dryflow filter
- MAP o2 housing with dump.
- FS: Kinugawa Install Kit. Evo4-8
- FFTEC Stainless O2 Housing and Tial WG
- FFTEC Tubular Exhaust Manifold
- Garret GT3076R A/R .6
- Brand New Exedy Discs
- Fujitsubo Downpipe / HKS intake pipe
- ( FL ) exedy twin disk and flywheel $545 shipped!
- FS: FIC 850cc injectors (delphi), BRAND NEW - $220
- Fic 1250cc injectors - 10k miles
- ebay turboback exhaust
- Exedy twin-disk
- FS APEXI power intake evo 7,8,9
- T3 manifold /Speed density harness/ walbro 255
- FS: 2006 Evo 9, OEM used Power Steering Pump
- FS: Oem Evo 8 Intercooler, Ebay Intercooler, Oem TB, bov, etc.
- Fs (ca): Br smim
- FS (CA): BR FF HTA 86 Turbokit
- FS: Sun Auto Hyper Voltage
- FS: Forge RS DV (Low Price) (Arizona)
- ARP L19 Headstuds
- EVO VIII head.
- FS: Injector Dynamics ID2200cc Injectors
- NJ: AMS built head, Kelford Cams, HKS cam, Curt Brown IM, plus more
- FS: TiAL bov & TiAL wastegate 44mm v-band
- FP WGA BRAND NEW Forced Performance 25psi Wastegate Actuator
