- FS: TX - 2 Walbro fuel pumps (1 brand new)
- FS: TX - Megan O2 Housing
- OEM Mitsubishi MAP Sensor
- STM -6an Rear Head Breather *Brand New*
- ACT HDSS Clutch and Streetlite Flywheel Combo *1000 Miles*
- FS: (MD) CBRD BBK-B, FIC 1250's
- GSC S1 cams for evo8
- FS: RALLIART / Mitsu 1.3 Bar Radiator Cap
- FS: ARP Headstuds (Barely Used & Cheap)
- ID2000cc/Invidia /Buschur Racing and more.....
- FS: Buschur Racing Fabricated Sheetmetal Intake Manifold & 65mm Throttle Body
- Hks 272/272
- 4/S Brand New Braille Battery B2015/Mount Kit
- FS: Greddy Type RS
- OEM UICP w/ Samco Sport Couplers
- PERRIN PWI-1 Meth Kit NEW w/ Aquamist DDs3, BOVS: HKS, BLITZ, APEXI, GREDDY, TURBO XS
- fs: socal - Evo 8,9 AEM Short Ram Intake Brand New In Box!
- Stock Block & Other parts
- FS: o2 dump & Downpipe
- FS: Hyper Grounding System by sun automobile japan
- FS:AMS MBC, OEM TB, o2, intake tube, map sensor
- IAC valve needed ASAP!
- Magnus V5 Powder Coated Black
- IL:FS: AMS FMIC, AMS resonated TP and more
- FS: AMS Battery Tray with BRAND NEW!! Odyssey PC680 Mini Battery.
- FS: HAFE Turbo Kit Parts ($300) and Tial 44mm
- Evo 8 Stroker Block and Cranks and JE Pistons, 4G64 100mm and 4G63 crank
- Evo IX parts for sale. NJ
- FS: PA: Cosworth, Garrett, CBRD, Spoolin Up, AEM, ARC, etc.
- Turbosmart Dual port bov for sale $160
- AMS T3 5857 Ball Bearing turbo kit for sale
- FS: evo 9 block, head, transfer case, 6spd, diff
- FS PWR Aluminum Radiator
- Precision .63 housing for 35R
- Evo 8/9 Oil Cooler
- FS Tial 38mm and 44mm wastegates
- Exedy Twin Disk Clutch
- Output Shafts
- Stock Evo 8 Injectors
- FS: BLITZ Dual Drive Blow Off Valve
- FS: HKS SSQV Blow Off Valve - PURPLE FIN
- socal:Fs:Injen complete intake system and other evo parts
- SparkTech non CDI Coil on Plug
- FS: 15 gal RCI Fuel Cell with fuel level sender
- HKS 272 cams, low miles
- bnib kelford 272's evo 8
- precision 6768 turbo
- Bunch of stock 8 parts.
- bnib- L19 head studs, aem meth kit, bosch pumps.
- bnib twin disk competition clutch and fp 3794 feeler
- Evo 9 stock intake manifold
- PA-Invidia N1 catback exhaust
- FS: Denso Coils
- Feeler: AEM Meth kit plus Flow Guage
- F/S HKS BOV cheap
- fs:pte 1000cc injectors
- T3 Full Race Rep Manifold
- FS: Brand new ID1000 injectors with adapter plugs!!!!
- Feeler: 700whp Partout
- FS: ETS 3.5" standard tank intercooler
- FS:ETS Recirc pipe!
- evo 8 / 9 jdm trust ti-r titanium exhaust
- Fs: Arc intake
- Silver Tial 44mm Wastegate
- FS: Brand New Toxic Fab Forward Facing Manifold (Stock Frame) and o2 Dump
- FP T3 HTA3582R Twin scroll
- WTB EVO metal Diverter Valve
- F/S: (FL) ARP headstuds, Evo9
- FS: Megan O2 housing, never installed
- F/S: (FL) Evo 60k service - belts, waterpump
- FS: Rhys Millen (RMR) ceramic coated Full 3" dp
- *Pics added 5/29* Exedy twin, Evo IX Turbo
- FS: 4g64 Block and 4g64 Crank OEM Fresh/Virgin
- FS: Front subframe Brace
- Stock IX turbo
- FS: Stock EVO IX parts for sale
- FS: spec super twin
- F/S: T3 Manifold - HAFE CAST (Ported and Coated)
- FS: ETS UICP black, Tial Q BOV
- fp black, headers, fic, cobb, turbo xs, gsc and more
- FS precision 1600 cc injectors,GSC S2 and beehive springs
- Used Evo Turbo, 18" Rims & Misc. Parts
- fs:(nc) fp black journal bearing, buschur, stm, ams, oem!
- EVO IX RS ecu
- Forge BOV
- FOR SALE - EvO 8 OEM throttlebody
- FS: EVO 8 Crank ready to use.
- FS/FT New Stage II Snow Performance meth kit with failsafe
- Buschur Racing Evo 8 D.P and Straight rear section- CHEAP-
- FS oem Evo ix turbo manifold and heat shield.
- FS: Maperformance REV 2 ported intake manifold
- New Built Long Rod 2.4 Map ultimate Rods ,Acl,Arp,Wiseco hd 1400
- FS(NY): OEM 02 Housings x2
- Thermostat housing, thermostat and temp sensor
- EVvo VIII head
- ECU + for VIII or IX must see price!!!
- HKS twin power DLI-II
- Metal 5spd Shifter Cable Bushings
- stock turbo tubular mani
- FS: New JMF Deluxe Oil Catchcan
- FS: Hal Landry -10 Oil Cap Vent
- FS: FIC 1450 BlueMAX Fuel Injectors (4) - Like New
- FS GSC Beehive BNIB
- FS 2.0L Manley H beams
- EVO IX Stock Exhaust w/Cat & Megan O2 (never installed)
- MAPerformance stg 2 2.4l shortblock
- fs: xs power fmic
- Hallman Pro Manual Boost Controller Cheap!
- Fs bb 6765
- 05/06 stock throttle body w/sensors
- FS: Zeitronix ZR multi guages and LCD screen
- Synapse short route and DV
- Tial V44, Test Pipe, Greddy EO1 and More
- Evo 6 engine transmission tcase Seattle
- Evo 9 Turbo, HKS 272,ACT HDSS Clutch, Megan O2 Housing, NGK SparkPlugs, OEM Fuel Pump
- Alum 150mm Rods, XI V/C, Valve Springs, Throttle, XI Cams
- Cusco Polished SS Heatshield
- Fs mil spec cat and hks dp
- Evo 8 Stock Throttle Body No Sensors
- BNIB ACT Xtreme pressure plate, solid hub 6 puck disc
- FS: Stock frame turbo compatible LICP (lower intercooler pipe) $110 shipped
- Energy Suspension urethane mustache bar bushings, NEW (eliminate rear diff clunk)
- F.S FP White for Evo 4-9
- EVO 8/9 Parts For Sale!!!!
- FS: Hallman Pro RX (purple)
- FS: TiAL 44mm wastegate
- FS: Forced Performance HTA 3852 Turbo
- GFB Stealth FX BOV $100 shipped
- AEM Intake with MAF
- FS 10.5 Hotside
- FP Black turbo kit... manifold,o2 housing black and fp oil filter line
- EVO 8 GSC s2 HKS TWIN POWER ect....
- Buschur Street FMIC + LICP + Couplers + Clamps 500 picked up
- performance and stock parts for sale or trade
- F/S evo 8 plastic bov
- OEM cams and springs for an 8
- FS/FT: Buschur LICP (Stock IC Style) and Long route UICP
- FL: FS borg warner S300 T4 .88AR ET brand new
- FS: HKS Fcon Vpro Evolution IX
- FS: Neisei I/C pipes, Buschur I/C pipes, HSK IX cams, Cosworth IX cams, APS 3.5" I/C
- Evo 9 AEM EMS
- FS/FT RRE 3076R stealth kit
- EvO VIII & IX parts FOR SALE
- Act HD pressure plate, Fidanza Flywheel
- Evo VIII/IX: Okada, ETS Upper Pipe, HKS
- FS: AMS small battery tray and 1 month old Odyssey pc680
- fs gsc s2 cams
- 3 Walbro 255 pumps, 64mm Red comp housing
- F.S. LSD ACD transfer case, 35k miles
- FS: Aem, Cosworth, Precision, Gruppe-S
- FS: COBB intake, Zeitronix ZT-2, Swift coilover springs, OEM brake air guides
- Sold
- evo 9 aem ems ecu cheap
- Evo 8 Kelford 272 cams, Blox cam gears, intake filter
- FS: Tomei Cam 280 for Evo 9
- FS(NY): 02 Dump
- Buschur Racing UICP and Hard Intake Pipe
- New OEM Exedy Pressure Plate
- quatermaster twin / exedy twin / bushur race interooler / 5 speed trans/ and more
- F/S: GM 3 port bcs with SpoolinUP PnP harness Amsoil 10w30
- FS:epsi intake,downpipe,clutch line
- FS Non Acd Tcase
- Evo 9 crank. 30k
- OEM EVO VIII parts: Injectors, Cat, Cams
- evo 8/9 intake/downpipe/clutch etc.
- EvO ACT upper clutch line. BRAND NEW...
- EvO VIII-IX rear energy suspension sway bar bushings..
- EvO VIII-IX front strut bar.. EXCELLENT CONDITION
- EvO VIII-IX 03-07 Torque Solution Base Bushings..
- 6265 Precison Turbo
- HD Exedy Twin Clutch
- FS: Kelford 272 Cams, Precision Injectors, ACL Bearings, Evo 8 Coils, 4g64 timing be
- FS(NY): Megan 02 w/Gasket
- FS Brand new Samco Rad hoses
- EvO 8-9 transmission motor mount 6 speed. GREAT DEAL.
- EvO 8-9 front motor mount for GREAT deal !!
- sold
- FS: Buschur SD Rear Muffler!
- Evo 9 Cams, CAT, A/C and P/S Pumps, and lots more check it out:)
- nisei small battery kit with odessey batt...
- FS: (CA) Like new Spearco Intercooler $200
- FS: Secondary inline double pumper fuel system upgrade (600hp)
- water meth kit Snow Performance
- FS: Garrett Turbo oil feed and drain lines
- FS: Exedy Twin Disc, Shep Trans, Shep ACD T-Case
- Brand New aem 30psi boost gauge/Evo 8 Alternator
- 6765 Turbo Exedy Triple
- FS:evo 9 turbo 63k, never over 23psi, sun hyperforce ignition
- STM front drag brakes
- Buschur Racing COP
- FP 11R exhaust cam
- Crane cams for sale
- Evo fuel rail/regulator/feed line FS
- walbro 255 for free just pay shipping..
- Precision 880cc injectors f/s
- EvO 8-9 NEW intake FS
- EvO 8 OEM throttlebody FS
- MAP o2 Dump, EVO VIII Cosworth M3 cams
- Fs: Hks ssqv v1
- FS: Tactrix openport 2.0 cable
- FS: Amsoil airfilter with vibrant maf adaptor
- fs: stock 32k evo8 shortblock 4g63
- t3 turbo kit
- FS Evo 8 Head
- Brand new QM 8 leg, 5 speed, street flywheel
- Fp black ! Brand new!
- EvO 8 parts FS
- EvO 8 parts FS
- EvO 8 parts FS
- EvO 8 parts FS
- snow performance
- Kelford 272 for evo 8
- Muse o2 Dump/Injen LICP
- BBK Full Complete Turbo Setup, MAP o2 Dump, Forge gate, Comp 280 Cams
- FS Mini Radiator
- USED: OEM Evo 9 Oil Cooler with lines
- NIB: OEM Mitsubishi Evo 9 Head gasket
- OMNI 4 Bar Map Sensor
- Curt Brown ported intake manifold! *65mm*
- FS: HI Evo 8 Parts: AFI turbo kit, flywheel, piping, hood vent, fan, cams
- FS: Forge Motorsports Wastegate Actuator (Evo 8)
- FS: Used Shearer 3" o2 housing and Vband DP
- FS: AMS SS Cat-back Exhaust *NYC*
- FS: Brand new Buschur DP and coated o2
- FS: BR JE drop-in pistons, ACL Bearings, ARP Rod Bolts
- Evo 8 Cobb Accessport
- Built 2.0L 10:1 Shortblock JE Eagle ARP
- Evo IX Catalytic conv
- FS: NJ-Lots of good stuff
- FS: Evo VIII Turbo. Manifold to J-Pipe w/ Lines. Grimspeed 3-Port ECU Boost Control
- Agency Power Race Crank Pulley Mitsubishi Evo VIII/IX
- ACD Pump 4/s 20k miles
- BNIB Fuel LAb FPR
- evo 8 engine harness pics of my tuck lol
- FS (MD): BB FP Red 600 miles
- FS: ARC heatshield, Forge WGA, Synapse intake, o2 housing
- FS uicp,licp, airbox+ maf
- For Sale Mint Greddy Cat back
- FS: ETS Speed Density Intake/Spoolin' Up SD Harness
- FS: (NYC) Evo 9 Stock Turbo
- FS: NIB ARP Head Studs
- Perrin Metallic Substrate High Flow
- FS: K&N Panel Air Filter
- evo 8 alternator for sale
- Great condition FORGE BOV!!!
- F/S: (NY) Driven Innovations Intake Manifold
- 6spd transmission (and/or 6spd mount, clutch fork, speed sensor, reverse sensor)
- Evo 8 powder coated black valve cover
- AEM 5.2 Bar Map Sensor, S90 70mm TB, Buschur Sparkplug Cover, GSC s2 274 Cams+ Spring
- Post build sale: Trans case, pulleys, LM-1, Profec B II, HG, lots more
