View Full Version : For Sale/WTB - Engine / Drivetrain / Power
- FS [West]: Evo IX/X BOV / VIII Spark Plugs
- [FS] GT3582R Ball Bearing Garret Bolt On Turbo Evo 8/9
- WTB [SouthEast]: Wanted: used ETS T3/44mm manifold Evo 8!!!
- WTB [West]: WTB 3.5" 4 bolt design downpipe
- [FS] 2005 Evo 8 Stock turbo with 10.5 hotside
- [FS] Mishimoto lower IC pipe
- [FS] Muse upper IC pipe short route
- [FS] NGK AFX wideband
- FS [Northeast]: Quartermaster 8 leg twin disc f/s
- [FS] Zeitronix Zt-2, Gauges and Carbon parts
- FS [SouthEast]: Hks UICP with SSQV
- FS [Pacific NW]: Invida Test Pipe Evo 8/9
- [FS] Spoolin Up Evo 9 COP
- [WTB] Aem v2 standalone for Evo 8
- FS [Pacific NW]: Evo 8 Crank sensor
- [FS] ID1000 injectors
- FS [SouthEast]: Factory Parts
- [WTB] Wastegate Actuator
- FS [West]: OEM EVO IX metal dv bov diverter valve
- FS [West]: ETS 4" ETS Licp, Tatrix
- [WTB] WTB exedy purple HD pressure plate only-part #CM06H
- FS [Northeast]: Fs: Magnus v5, 6466, Spoolinup, double pumper, map
- [WTB] Precision .82AR turbine housing v-band in/out
- FS [SouthEast]: Fuel rail,omni 4 bar, coated mani, fic hi z injectors
- [FS] Toxicfab vband Hot parts kit
- FS [West]: Wtb evo 8 head
- FS [Northeast]: Blow off valve and boost controller
- WTB [Northeast]: WTB uicp
- WTB [SouthEast]: Evo 8 crank
- WTB [SouthEast]: WTB FP Red or Black Journal Bearing with Lines etc
- FS [MidWest]: FIC 2150s for sale
- [WTB] Evo 9 turbo
- [WTB] Oem water pipe and front cover/oil pump
- FS [Northeast]: Evo VIII A/C Compressor+ Condensor+ Condensor fan+ Lines *54K*
- FS [Northeast]: Evo VIII 5-Speed transmission+ Shifter cables+ shifter box *54k*
- FS [Northeast]: Torque Solution Mounts *Motor + Transmission*
- FS [Northeast]: Evo VIII ECU *54k*
- [WTB] Evo 8 ECU - stock tune
- [WTB] S2 cams evo 8
- [WTB] Stock frame Tubular manifold
- FS [SouthEast]: FL: bnib stm catch can
- [WTB] looking for a fully built 5 speed box for evo 9
- [FS] Wiseco Pistons
- FS [Northeast]: Center-member/mount with urethane roll-restrictor mount
- [WTB] Uicp
- [FS] Evo 9 Kelfords TX288 Cams
- FS [Canadian]: Fic 1000cc high impedance
- FS [Canadian]: Pte precision injector 1000cc new
- FS [Northeast]: T3 single scroll bottom mount manifold with GT3582R
- [FS] BNIB Sheepey V-Band Hot Parts Kit Stupid Cheap!!!!
- FS [Northeast]: OEM Evo 9 HEGO-housing / hot-side dump 15K miles
- FS [Northeast]: Flawless OEM Evo 9 Turbo (15K miles - no shaft play or blade issues)
- FS [Northeast]: Evo 9 OEM turbo heatshield (15K miles)
- FS [Northeast]: Evo 9 OEM motor mounts with only 15K miles
- FS [Northeast]: Excellent OEM Evo 9 Crank - 20K miles
- FS [Northeast]: OEM Evo 9 pistons / rods (20K miles - excellent condition)
- WTB [SouthEast]: Lower half of UICP
- [WTB] aftermarket ignition system
- FS [Northeast]: GTX3582 No Turbine Housing
- [FS] 100mm 4g64 OEM crank
- [FS] Brand New Fully Built 2.0
- FS [MidWest]: Evo 8/9 Partout: Tons of Aftermarket and OEM
- FS [MidWest]: Stock Evo 9 IX cams
- [FS] 4g63 block, 4g64 crank, oliver rods, wiseco 2.3L pistons
- [WTB] Evo 8 brake booster line with check valve
- [FS] English Racing Underdrive Oil Pump Gear
- [WTB] Stock Evo IX transfercase
- [WTB] OEM 10.5 hotside
- FS [SouthEast]: Fuellab 818 -8 fuel filter with 40 micron stainless element
- FS [SouthEast]: Vibrant 4" Air Filter
- FS [West]: OEM EVO 9 Exhaust Manifold
- WTB [Northeast]: Looking for OEM fuel line (short quick connect hose)
- [FS] BNIB Precision 6466 for the CHEAP!!!!
- [FS] Brand new Exedy Twin Plate Clutch W/ Throw out bearing 1500 Shipped
- FS [SouthEast]: Omni, Taxctric, Fans, Final Drive, ARP, Oil pan
- [WTB] Looking for an hks rsi intake
- [WTB] Stock suspension/coilovers
- FS [SouthEast]: Oil catch can with breather filters $110 + shipping
- [FS] New stuff - dirt cheap!!! 6466 complete turbo set up
- [WTB] Aem EMS v2 for Evo 9
- FS [Northeast]: Bolt Ons & OEM Parts
- [FS] GSC S3 Cams, ETS Hot Parts Kit, 3586R Turbo and more..
- WTB [SouthEast]: WTB: CDI Coil on plug setup evo 9
- WTB [South]: Aftermarket exhaust in texas
- [FS] JDL FF T4 TS Hot Parts kit, ETS 4.5 fmic, Aeromotive, Evo8 VC
- [FS] Stock EVO 8 4G63 block/crank/pitons/rods/rotating assembly/squirters
- WTB [Northeast]: OEM or Aftermarket Oil Cooler Evo 8
- FS [West]: RRE Stealth High Flow Cat
- [WTB] Evo 8 stock intake manifold
- WTB [Northeast]: Titanium Downpipe
- FS [West]: EVO 8 ARC intake box
- [WTB] Evo 8/9 headlights harness
- WTB [Northeast]: Aem Ems V2 for Evo 9
- WTB [Pacific NW]: 1200cc+ injectors and dual pump
- FS [MidWest]: Two DW300 Fuel Pumps
- WTB [Northeast]: [WTB] stock frame aftermarket turbo
- [WTB] ISO Evo 9 MIVEC head
- [WTB] Parts wanted today
- [WTB] Buschur racing Exhaust manifold
- WTB [Pacific NW]: Built 5-speed (Evo 8)
- [WTB] Aftermarket rear engine mount Evo 8
- [WTB] tactrix 2.0
- FS [Northeast]: Walbro 255. $45 shipped
- FS [West]: OEM EVO 8 Cat Catalytic Converter
- WTB [West]: GSC S2 Billet Cams for Evo 8
- [WTB] Non acd t-case evo 8
- FS [MidWest]: Works Throttle Body
- [FS] 06 Evo9 ACD pump off 60k mi Cal car
- [WTB] Precision 46mm waste gate.
- [WTB] Evo Rear Diff (Need to be able to ship to APO)
- [WTB] Manley I-Beam 156mm Rods
- [FS] Manley I-Beam 150mm Rods
- FS [MidWest]: Nisei 3.5" FMIC
- [WTB] Evo 8 03-05 OEM Ecu & Complete Engine wire harness
- [WTB] AXLES Front / Damaged
- [WTB] Few Parts needed
- [WTB] TOP MOUNT V-band manifold, ADAPTRONIC ECU and more
- [FS] EVO 8/9 parts (OEM and Aftermarket)
- [WTB] 18 PSI wastegate for stock turbo
- FS [Northwest]: WTB a aftermarket stock frame turbo perferable fp turbo or ef turbo for a good price
- WTB [Pacific NW]: Licp, Valve Cover, Front lip, catch can, sd intake
- FS [West]: EVO IX OEM Cat Catalytic converter
- WTB [Northeast]: Transfer Case Cases/Housings (ACD pref)
- [FS] oem fans
- [FS] oem lifters
- FS [West]: Silicone Coolant heater hose
- FS [West]: JDM EVO 8 VIII Exhaust Manifold
- FS [West]: JDM EVO 8 VIII Intake Manifold
- FS [West]: OEM EVO 8 Ignition Coil Packs Wires
- FS [West]: LV: Act & exedy streetlite flywheels for evo 8/9
- [WTB] Carbon Fibre Drive Shaft
- FS [South]: Evo 8 9 engine and miscellaneous parts
- FS [South]: Clutch master, Exedy and Tilton Twin disk clutch
- FS [Northeast]: AMS F1i with Boomba TB
- FS [Northeast]: T4 Twinscroll GTX3582 Turbo Kit
- FS [West]: CBRD BBK Full JB AKA BPT 1.0XT
- [WTB] Bare block
- FS [Northeast]: NC: Evo 8 valve cover
- FS [Northeast]: Older style ETS Hot Parts Kit (can include turbo/wastegate)
- FS [MidWest]: FIC 850s, Hallman MBC, Invidia Test Pipe, Water Gauge
- FS [West]: Carbonetic/ATS&Across Twin Disk Carbon Clutch with Hydraulic Release Bearing
- [FS] misc parts: walbro, fuel hanger, volk, plugs, gaskets, ecu etc
- FS [Northeast]: Evo8 Turbo Back Exhaust
- [WTB] EVO 9 fusebox (in engine bay) w/ wiring
- [WTB] Wtb built Mivec head
- FS [Northeast]: BNIB STM 4" SD Intake Kit
- FS [Northeast]: STM Catch Can
- [FS] ETS Intakes SD and MAF
- WTB [Mid-Atlantic]: 3" test pipe and cbe
- [WTB] Pair of solid Lifters
- [WTB] Looking for used ETS T3 manifold
- WTB [Northeast]: Bunch of OEM parts needed with links! MAY Consider aftermarket too
- FS [MidWest]: full blown double hanger
- FS [MidWest]: bw s366 turbo NEW
- FS [MidWest]: curt brown head
- [FS] Brand New Precision v-band in/out 6466
- [FS] Id 1300
- [FS] Evo 8 Buschur powder coated coil cover
- [WTB] looking for a 5 speed tranny for my evo 9
- [WTT] tilton twin for exedy twin/triple
- [FS] 2.4l Head Gasket & Acl race bearings
- [WTB] Evo 9 wide tank intercooler
- [WTB] 2.3 pistons 85mm
- FS [Northeast]: Evo 8/9 parts. Ets,oem,stm
- FS [Northeast]: Buschur "Race Core" Intercooler Core
- [FS] Walbro 255
- [FS] Maf, Maf Adapter, K&N Cone Filter
- [WTB] Cdi ignition system!
- WTB [Mid-Atlantic]: Hafe T3 cast manifold
- FS [West]: Wtb skunk 2 intake manifold or map rev 2 evo8/9
- [FS] 272/272 hks cams evo 8
- [FS] ARP L19 headstuds
- WTB [SouthEast]: Looking for a used slim radiator Evo 4-6
- FS [MidWest]: OEM Turbo, Intake, Exhaust, FMIC and various
- [WTB] Full Blown double hanger or buschur double pumper
- [WTB] Blow Stock Frame Turbo's
- [WTB] Evo 9 Mivec Spoolin Up COP
- [FS] Hks/labonte
- [WTB] GSC S2 cams
- WTB [Northeast]: Looking for Evo 8 Valve Cover with -6 or -10an fittings
- [FS] ETS 5" intercooler with 3" in/out for Evo 8/9
- FS [Northeast]: Evo VIII Buschur Racing 2.0 longblock
- [WTB] FP Red and o2 dump
- [WTB] Built Shortblock or Longblock
- [WTB] wtb t3 manifold
- WTB [South]: WTB FP Black or Zero
- FS [Northeast]: Tactrix 1.3U cable, mounts, MAF
- FS [SouthEast]: BW EFR 7670 IWG with T4 twin scroll .92ar turbine housing.
- WTB [MidWest]: Look for Evo 9 LR Build Short Block
- FS [MidWest]: Nib ngk br8es
- WTB [Northeast]: FF stock turbo manifold/half size rad
- [FS] ATP Garret Bolt-on GT3582R Turbo Kit 03-07 Mitsubishi Evo VII/VIII/IX
- FS [Northeast]: Complete Fully Built Engine Westchester, NY
- FS [Northeast]: Samco Radiator Hose Upper & Lower
- FS [Northeast]: STM Oil Catch Can
- FS [Northeast]: Hallman Manual Boost Controller Black and Purple
- FS [Northeast]: TIAL BOV Westchester NY
- FS [Northeast]: Buschur 4" Intake Westchester NY
- FS [SouthEast]: AMA Moroso oil pan
- [WTB] SET OF GSC S3 CAMS or STM 650 CAMS
- FS [West]: Zeitronix 5 bar boost sensor
- FS [SouthEast]: Shell Rotella T6 5w-40
- FS [SouthEast]: ETS 4" Wide Tank FMIC w/ 2.5" inlet/outlet
- FS [West]: RC 1200cc Fuel Injectors.
- [WTB] Intercooler, 4g46 build items
- [WTB] Evo 8/9 RS LSD center diff.
- WTB [Northeast]: Evo 8 axle driver front
- [WTB] Evo 8/9 - (NON) ACD T-Case
- [WTB] Looking for FP Black, Radiator etc
- [WTB] EVO 8 Bare or not Head
- [WTB] Looking for tactrix for my Evo 8
- FS [Northeast]: Grimmspeed 3-port ECU Boost Controller
- WTB [Northeast]: AC Components
- [FS] EVO 7/8/9 HKS Suction intake 3.5" system, HKS Turbo Timer, Hallman MBC & Remote
- FS [Northeast]: EVO 8 9 HKS 4.111 FD, Front LSD Differential, Shifter assembly, W5 Trans, F5 trans
- FS [SouthEast]: FS Evo 8 Built 2.4LR Motor and Transfer Case
- FS [Mid-Atlantic]: 2 Evo 9 turbos
- [FS] Exedy twin disc
- FS [SouthEast]: Exedy twin parts, IX turbo, buschur bullet, oem.....
- [FS] HKS SSQ BOV and Recirculation kit
- FS [West]: APEXI - Super Catalyzer
- WTB [MidWest]: Evo 8 Shortblock
- [FS] Brand New FP Black MHI Housing For Evo IX For Sale
- WTB [Pacific NW]: uicp,licp,bov, o2 housing, downpipe, exhuast, hood ect.
- [FS] Buschur MBC
- [FS] Megan Exhaust fits with ACD
- WTB [Mid-Atlantic]: WTB Evo 8 Head
- [WTB] Oil feeder control valve
- [WTB] evo 8 intercooler and piping oem
- WTB [South]: Looking for Evo 8 ecu
- [WTB] Looking for a intercooler 4"
- [FS] 2 Walbr0n255's for sale cheap.
- FS [West]: Titek O2 Housing , OEM IX Bov
- [FS] .82 T3 Garrett exhaust housing
- WTB [MidWest]: Rear O2 sensor for Evo 9
- FS [West]: FP Zero Turbo
- FS [Northeast]: Turbo Back Exhaust (Invidia / Espelir)
- WTB [South]: Synapse - Synchronic BOV
- [WTB] Looking to buy a used FP Red
- FS [Northeast]: Manual Boost Controller
- WTB [Northeast]: FP Green or Red
- WTB [SouthEast]: EVO IX Crate Engines?
- FS [South]: Evo 8 engine (Houston)
- WTB [SouthEast]: Stock route UICP
- FS [MidWest]: (2) Tial 38mm Wastegates, BB 5862 (New), Catch-can, downpipe, LICP, dump tube
- FS [Northeast]: Innovate Motorsports MTX-L Complete complete whitebrands kit new kit
- FS [Northeast]: Used carbon fiber spark plug cover
- FS [Northeast]: Complete rear with diff/brakes / hubs
- [WTB] ams non res testpipe
- [WTB] Foward Facing kit.
