- forge wg/omp tow hooks
- F/S HKS 264 cams
- EVO 8 PTE inj , turbo xs and more!!!
- forge bov for sale!!
- evo 8 o2 housing w/sensor
- JMF Intake with map sensor from an evo 8.
- F/S: (NY) JM Fab 02 Dump
- WTT: Brand New Red Tial Q for Black Tial Q
- New Greddy timing belt 4g63
- TIAL BOV. Silver. unpainted spring. $180 Shipped
- Throttle body w/ IAC 200 SHIPPED
- GSC S3 Cams
- AMS F1i Manifold
- ID2200 CC injectors + pigtails
- Full-Blown, Avid, AMS +++ MANY MORE---EVERYTHING 250$ OR LESSSSS!!
- Want a quiet 80mm exhaust? GReddy BNIB Cheap!!!
- ETS 3.5" exhaust Aero turbine
- ATP 35r Turbo Kit
- Fs stock fuel pump
- FS stock licp, uicp, airbox
- FS stock IX intercooler
- Fp black and 500+ hp parts
- FS: Stock Fuel Injectors, Evo 8, Only 12K Miles !!
- FS: Stock OIL COOLER, Evo 8, Only 15K Miles !!
- FS: EVO IX OEM Coils & Wires
- FS: Ignition Coils, Stock Evo 8, Only 15K Miles !!
- FS: ETS 3.5" Wide Tank FMIC
- For Sale: Slighty used FP Black
- Fs: 8 ngk bpr9es "new"
- FS: Mivec m2 cams, valve cover, clutch, ignition amp
- WI: Forge RS BOV/BV (RECIRC)
- Evo 8 Turbo and supporting access....
- FS: Brand New X02 Racing Anodized Blue Oil Catch Can
- Buschur Racing SD Setup
- FS: Coolant Bottle/lines, Fuel Pump Sending Unit, Radiator Support Bracket, Mounts
- FS: Evo 8 Stock Fuel Rail w/ Return - $25 shipped
- FS: Evo 8 Radiator Fan Controller Module - $
- used act hdss clutch
- FS: Stock Evo 8 BOV w/ recirc hose - $20 shipped from ATL, Ga.
- ETS Intake, Hallman MBC, AWD Speed Density Kit
- FS: precision 1000's
- FS: Used Front O2 Sensor
- Stock Evo 8 valve springs, retainers and seats
- FS: Greddy Type S BOV
- FS: GT4088 Twin Scroll Turbo ETS
- Evo 8/9 Parts Stock and Aftermarket
- evo8/9 Radiator Fan Cheap
- FS: Evo 8 Built Head
- FS: ATP 3071R - Complete Kit
- Manley 156mm I beam rods the ultimate long rod
- Brand New Evo 9 FP black for sale
- FS/NC: Buschur UICP tial w/blowthru setup
- FS/NC: TRE Front Dif w/RIP grip, Brand new never used
- turbotrix cdi ignition
- Shearer T4 Manifold and AMS 1000HP Fuel System and AMS VSR + Stock TB
- oem oil cooler 46k
- Evo 8 Full Race 35R turbo kit
- FS: used APS twin vent BOV from Evo 9(NH)
- Evo9 turbo (Map SST upgrade)
- Texas DFW: agency power ti, evo 8 HID heads
- T-case 30k Miles
- FS: oem exhaust manifold, O2 Housing off 2005 evo8
- OEM evo 8 oil cooler with 27k!!
- Heat Treated Lower Intercooler Piping
- Super Cheap Power Steering Pump
- Cheap Alternator
- FS NC: 272 cams, Tial V44 Wastegates
- FS: Buschur Forward Facing Precision 6262 Kit
- FS Crushed IX BOV
- Vibrant 3" Exhaust Gasket - Leak Fix
- FS: Sparktech Pro 12 CDI Ignition (Purple Anodized Plate)
- FS: 4bar Map sensor
- FS: BR Lower Intercooler piping w/J-Pipe
- FS: Ported Ebay o2 housing, Apexi electronics
- Walker Front o2 sensor (4wire) NEW
- BNIB: MAP ported and heat coated EVO 9 Exhaust manifold
- BNIB: Map ported heat coated EVO 9 hotside
- BNIB: JM fab race intercooler
- FS: Interior Fuse Panel W/ All Wiring
- TC Sale
- Stock Evo 9 bov
- FS: buschur air filter kit for stock MAF
- FS: HKS 272 for evo 9 and AMS licp
- Injectors (rc & pte) - hks vpc
- FS: BC 272 Evo 8 cams
- ID1600's
- FS: FP Black Turbo setup
- FS: Stock Radiator Fan & Hose Combo, Evo 8,,, REDUCED
- FS or FT - HKS 280s
- FS: ACT RB601 Throw Out Bearing/ Release Bearing
- FS: Buschur custom turbo set up
- FS: Exhaust galore
- FS: MI Evo IX Turbo $400
- FS JET V-Force Plus Performance Module
- ARC Intercooler. ARC Plug Cover, ARC hacked heat shield.
- FS: BlueMax 1450cc injectors
- 05 Evolution full engine swap
- Fs nc aem ems v1
- Tactrix 2.0 Cable
- map and epm o2 dumps, ported exhaust manifolds, buschur uicp, throttle body, etc
- GSC S2 cams with Single Beehive Valve Springs for EVO IX (mivec)... BNIB..
- FS: (Long Island) NY Evo 8 intercooler and more
- FS:Blitz TT, STM Shift fork, Innovate LM-2, Sony deck
- CNC Race Head, Buschur stg 3 head
- FS in FL: FP Green--non-HTA
- For Sale: Turbo XS Bypass (Blow Off) Valve
- 4G63 Crank Polished, ready to run
- For Sale: Megan Racing o2 Housing
- Weapon-R power steering reservoir can $80shipped
- Forge Recirc. BOV $110 shipped
- FS: CT: injen intake adapter w K&N filter
- FS: New BR mini batt tray, NO BATTERY
- FS aps twin vent bov
- jdl forward facing t3 manifold
- For Sale: Exhaust Perrin/Magnaflow Hybrid and test pipe.
- WTS/WTT FP Black
- Tial 50mm bov CHEAP
- FS: Low Mileage Evo 9 Turbo
- fs: 45deg 3.5" stainless steel tube
- Evo 8 Stuff, pistons,cranks, ac comp, etc
- FS EVO VIII ECU, BOV, gauge pod with autometer
- Complete T4 Turbo kit / Small radiator kit
- HKS 280 EVO 8, 750cc Injectors
- EVO9 OEM Intake manifold, throttle body
- Fs: (NY) **INVIDIA EXHAUST MANIFOLD**
- FS: Ball bearing PTE 5857
- Zaklee Corp. Clear Cam Gear Cover
- GSC Chromoly Valve Spring Seats
- Cam Angle Sensor w/ housing
- Evo Thermostat Housing
- Evo Starter
- Evo Alternator
- FS: Precision 1200cc injectors
- FS: New Supertech valve set 1mm oversize Inconel
- FS: Spoolin up speed density harness and AIT sensor
- MAP/HeadGames/ETS/TiAL/Buschur/OEM/FIC/Mil.Spec
- GTSpec Turbo Outlet - $99 shipped
- evo 9 stock throttle body
- FS: Walbro 255lph/1000cc injectors
- FS: OEM Evo9 parts. turbo, intercooler, radiator, intake, DV, ect
- FS (IL): STM / Koyo Half Width Radiator & Slimfan
- Stock Flywheel from IX w/ 28k miles $60 shipped, Shep Box for shipping 5spd trans
- FS Brand new pte5557 and extras
- Evo 9 Turbo, Injectors, BPV and Hallman Pro RX MBC
- BNIB Ultimate-duty-billet-steel-156mm-long rods and 6 bolt Acl bearings
- Evo 8 272 cams
- Great stuff 4sale!!!!
- FS: OEM Evo 8 Turbo with 10.5 hotside, Stock Mani, and Megan o2
- FS or trade Brand new GT4202R ceramic coated
- Timing belt kit
- FS: ETS Stock Route UICP Couplers (Blue) *NEW*
- fs:ets uicp and more
- High End Part Out Check it Out!!!
- FS: Tial MVR 44mm Wastegate
- Exedy Twin disk
- FS:Oliver I Beam rods
- FS:4g63 crower rods NEW
- FS: Stock Exhaust Manifold
- Injectors and an FP Black
- FS: K&N Replacement Filter for AEM Intake
- Aftermarket parts sale!
- FS: buschur maf pipe / evo 8 maf
- Heat Barrier Intake Manifold Gasket
- Upper and lower SS clutch line
- EVO IX turbo, O2 housing, and manifold (everything in the picture you get) 20k miles
- FP Black/Waste Gate/TBE/Injector..much more
- FS: FIC 850cc $220 Shipped
- F/S Greddy Profec B Boost Controller
- Brand new fic 1680cc high impedance injectors
- Engine/Turbo/Parts
- FS: Evo 9 - 5 Speed Transmission - 78k Miles
- SparkTech non-CDI Evo IX application
- am looking for HKS DLI for evo 9
- evo 9 turbo
- HKS super suction, Metal MR BP (BOV), stock air box, axle, etc.
- FS: Full-race Pro stock manifold
- fic 1000 injectors 200
- tial 44mm wg (silver) roughly 3k on it
- FS: BR SS 3" DP and Megan O2 housing
- Fs: 3g revised lifters for evo
- BNIB: Tial BOV purple
- BNIB: Fluidamper
- BNIB: FP evo 9 actuator
- BNIB: FP 84mm intake with filter
- Cobb catback...Ebay 02...Evo8 turbo... ETS UICP
- BNIB: AMS moustache delete
- FS: ACT TOB and Hallman Pro
- Evo rs lsd tcase acd
- Evo8 drivetrain trans rear end more
- HKS Filter $20.00 shipped
- Evo 8 Bare head + Stock Springs and retainers
- FS: Perrin Air Filter/AEM 3.5 Bar Map Sensor/Hawk Front & Rear Set
- FS: Evo 9 Turbo, Supertech Valves
- FS: Stock Evo 8 Manifold + Heatshield
- fp5r evo 8
- FS: Stock IX DV
- FOR SALE - Evoscan GPS Display & Tactrix Cable
- FS: OEM VIII MR turbo
- FS: BBK-Full, GSC S2's, FIC 1050's, install kit and FP oil line
- evolution 8/9 Manifolds (CUSTOM Forward facing, and oem megan oem replacement)
- Turbo xs bov 50 shipped
- Evo 9 cyl head, Act clutch, Cossie cams,inj
- Evo 8 10.5 16G turbo, OBX SMIM, 750cc injectors
- EVO IX Block, Pistons and Crank FS
- FS: HKS 264/264 evo 8
- Evo 8 ECU and HKS ssqv bov fs
- Innovate LM-2 wideband kit
- Manley Performance Connecting Rods 156mm
- AEM shorty intake $100+ shipping
- FS: NV HKS Exhaust, Forge WGA, Test Pipe, CAI
- FS: Brand new Grimmspeed 3 port, Stock Coilpacks, and Mac valve 3 port
- BRAND NEW BR Double Pumper Ready for Install!
- FS UNorthodox Racing light weight pulley
- FS: MAP o2 dump
- FS: stainless clutch line, ARP head studs
- Stock 9 RS cams, springs/retainers, coils, head bolts
- (CT)Stock MAF, buschur LICP, starter, fial bov
- bnib spec twin disk aquamist turbo manifold
- WANTED Buschur UICP w/ Tial BOV
- ams uicp. b/r licp. stock 8 turbo. & more
- BALLER PARTS-1000hp PART OUT!!! AMS-ETS-PRECISION-GSC++++MMMOOORRREEE!!!!!
- Buschur Racing PTE 5857 Tubo Kit For Sale
- FS: Buschur slip fit downpipe
- FS: GSC S1 Cams Evo 8 Brand New
- Ported Intake Mani, Sun Auto
- Fs: Brand New 84mm Fpred
- Perrin Oil Catch Can/Coolant bottle
- DNP Manifold
- mini oil catch can, intercooler piping wrap, ams clutch line, coil packs
- FS: Megan Racing Catback Exhaust
- FS: FIC 750cc injectors NEW
- Injen UICP
- FS: FP 18psi Wastegate Actuator
- FS: Helix Adjustable Cam Gears
- FS: Clutch Fork Stop
- FS: Used Exedy Twin HD
- Omni 4 bar map sensor for sale brand new
- FS: Injen IC Piping
- fs unorthodox cam gears
- F/S Evo 8 HKS 272 CAMS
- SNOW CAMO SAMCO RADIATOR HOSES! Brand New!
- synapse dv, hyper voltage system, k&n intake pipe,
- Swaintech Coating o2 Housing BNIB!
- FS ACT HD Clutch and 6 Puck sprung
- Act tob bnib
- For Trade/Sale Precision 6262 turbo
- FS STOCK PARTS and some Aftermarket WI
