- FS: Bunch of stock evo 9 parts
- Coolingmist Check Valve
- FS WV: AEM EMS, Odyssey, Axle, Short throw
- Feeler: 6765
- Injector Dynamics 1000cc Injectors w/connecotrs and adapters
- ets 3586 complete turbo kit
- WTB walbro 255 pump
- FS: stock intake manifold $100 shipped,battery tray,coil pack,wires, pte 6765 hotside
- FIC 1850's and Easy Tune Box FS
- aftermarket parts for sale
- F/S stock MAF, fuel feed line, FORGE RS BOV, stock rubber intake pipe.
- fs cobb accessport
- fs evo 8/9 perrin fmic
- Evo8 HID Headlight L / Valve cover
- FS:: SMC Alcohol/Meth Kit/Custom trunk mount/(N.Y)
- fs AMS TBE
- BNIB: Rods and pistons
- Buschur Racing Evolution Shifter Bushings (6 speed)
- Ams fmic
- Road Race Engineering Dual Stage Manual Boost Controller
- Stock Evo 8 Turbo and Manifold ($125 Shipped)
- FS: Manley retainers for HKS Cam/Spring kit
- Stock 2003 Evo Injectors $50
- FS: Brand New Tactricx 1.3u cable/Gates Belts
- Fs: Stock camshafts, ss clutch line, ur fuel gauge adapter for easy gauge install
- fs pa nesei uicp/licp
- tial 44mm wastegate
- FEELER: 2005 EVO 8 head with supertech duel springs and retainers
- Stock VIII Parts that need to go (or my wife will castrate me)
- FS: OEM Evo 8 Valve Cover & Heat Shield
- FS: EVO 8 Turbo w/10.5hs
- FS ARP Headstuds (BNIB)
- FS: AMS front cross member
- FS: stock Evo8 injectors and rail
- Evo 8 Throttle body
- For Sale Evo 8 A/C Compressor
- FS Evo 8 Alternator
- f/s weapon r neo ti upper ic pipe
- FS: Evo 8 HKS 264 cams, Injen LICP for 8 or 9
- Stock Evo 8 Cams (Chicago Il) 35k miles
- FS/FT: Muse Short Route UICP, Gruppe-S Crank Pulley, Stock IM
- ETS 3.5 inch IC for sale
- 280 cams, 4g64 Crank, IM, Tb, and MORE!!!
- Transfer Case from 2006 EVO IX 27k miles
- Fs - arc intake box (((cheap)))
- fs:evo 8 head **cheap**
- 3" Buschur high flow cat
- Evo 8 Valve Cover Black Wrinkle Coat -10AN Fittings
- V-Band Magnaflow secondary muffler (replaces cat)
- ebay short shifter
- Buschur V-Band 3" Downpipe ($125 shipped)
- Black Oil Catch Can Baffled
- Stock evo8 intercooler $55shipped
- Wtb mac valve for aquamist hfs
- FS: OEM Flywheel & Injectors
- Stock Intake Manifold $100 shipped
- Stock Throttle Body (No Sensors) $100 shipped
- 4G63 Short Block
- FS - PTE 780cc Injectors and Walbro 255HP fuel pump
- F/S ''used'' QM twin clutch
- FS: Stock muffler and DP
- FS: Brockway R1000 OBD II Multi-Gauge w/ Shift Light
- FS: PPI 65mm Throttle Body, Phenolic Gasket, MilSpec Seals, Samco Hoses
- EVO - 9 Complete MOTOR $3000 !!!! DEAL
- BNIB Manley Turbo Tuff I Beam Rods
- AMS spark plug cover, Avid billet motor mounts
- Feeler.... Greddy Type S BOV/Recirc
- WTB:Evo 8 NON ACD Transfer Case and Evo 8 5 Speed Trans!~
- FS: Greddy Ti exhaust, ets intake, shearer 02 dump, AMS UICP, 60k timing belt kit,etc
- AMS 4" Intercooler, Lower and Upper piping kits, Mini Battery & more!
- AEM UEGO wideband, 2months old...185shipped
- BNIB Buschur Double Pumper and Wilson Rev 2.3 ported stock Intake
- JMFab "race version" intake manifold and OEM throttle body
- FS: NY: Turbo XS Catback exhaust (video inside).
- Defi racer series gauges
- FS:Quarter Master twin disc w/ hydraulic bearing.
- F/S: new parts (ACT flywheel, 6-puck disc, and AWDMotorsports mounts)
- Brand New Never used full Thermal Exhaust Evo 9
- WTB: Evo 8 Valve Cover
- FS:Evo 9 Full Oem Turbo Kit
- Hks EIDS idle stabilizer
- A few rare parts
- stock bore evo 8 block and good crank
- Exedy twin disk, powerflex motor mount
- zeitronix zt2 with LCD & 50psi boost option
- Act hdss bnib
- Devils Own Water/Meth kit
- WTT or WTS feeler GSC S1 Cams Evo 8
- Super tech Valve Spring and retainers
- Hyper Ignition Kit 120.00 shipped
- hyper force Voltage stabalizer, grounding kit 120.00
- Perrin Aluminum crank pulley 50.00
- HKS 280/272 mivec cam setup. Both cams have 10K on them
- ultimate ratio 5 speed trans.
- bare cylinder head, crower, ferrea, ARP, etc.
- bnib aem 5 bar
- Zeintronix with LCD
- Good power upgrade
- F.S. Stock Airbox lid and Snorkle, Stock battery tray
- FS: HD EXEDY Twin disc, STM Clutch For stopper & STM Clutch line! $900
- RMR upper intercooler pipe f/s
- WTT Mint JDM Evo7 Tails for an EVo9 turbo
- FS: 6spd Shifter Base, Cables, Console
- Parts for sale evo 8
- FS: Greddy Mivec Easy Cams New-Cheap
- FS: Stock Flywheel
- FS: AEM EMS for Evolution 8
- WTB: Clutch Kit and FP Gen. 2 Turbo Install Kit for Evo 8
- Garage cleanout- turbos, WGs, Ex Mani, IM, TB....
- FS: saikoumichi dual catch can
- A few parts for sale
- Wtb Evo 8 transfer case non acd!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- FS: One set of new Kelford 272's for Evo 8
- FS: JMF External Dump O2 Housing
- FP Red: Stock Cover
- FS: 06 Rear Diff 35k miles
- FS: Tomei Procam EVO VIII 270s
- COSWORTH M3 MIVEC camshafts FS
- FS: ACT HD Pressure Plate/streetlight flywheel/TOB
- FS: Brand New Fluidampr Crank Pulley
- FS: Brand new Fluidampr
- EPM V2 O2 Dump. Great condition
- AMS spark plug cover (wrinkle black)
- FS: Misc BOV's and Wastegates
- FS: Bunch of cam gears
- Custom Upper IC Pipe
- FS: Ton of fuel pumps
- F/S;Buschur 65mm t/b and Samco rad hoses,PWR Aluminum Rad.
- FS GSC S2 IX Cams & Stg 3 Springs/Retainer Kit BNIB
- FS: Stock IC Pipes
- Hks 280
- FS:stock exhaust manifolf
- FS: Evo 9 Turbo
- fs: brand new 10.5 hot side turbine housing
- buscher racing 1000cc injectors.. $200 shipped
- BNIB: 9" K+N filter with MAF adapter
- Wtt evo 7 tails for hks evo 8 cams or aquamist meth kit
- FS: Misc GOODIES!
- BNIB JE pistons/ Full blown
- FS: FIC 1050s, Tactrix cable, Innovate Wideband, JDM 3 bar MAP, GM 3 port
- FIC 950's For sale!
- Aftermarket and OEM parts for sale! Must see.
- Evo 7 AYC rear differential
- Evo 9 Stock BOV and Ebay Intercooler!!
- FP 84MM/3.25" Intake (Green, Red, Black)
- 1250cc Blue Max FIC Injectors
- JMF 3" UICP/ Tial Flange NEW
- HKS SSQV Recirculation Kit for Sale cheep 10$
- FS: 2004 RS LSD Front Diff (low mileage)
- FS: Fortune Auto Stock Replacement Tubular Manifold (never used!)
- FS: HKS RS Intake **pics**
- FS: New Speed Density Kit (OMNI 4 Bar/ GM AIT/ BR Intake Pipe)
- FS evo 9 turbo 30k miles 400$
- fs-Perrin 3" Stainless steel exhaust
- f.s. 9.8 hot side
- Several Parts for Sale
- full race gt4088r tial msv
- Going back to stock??? FS: stock turbo back
- stock intake mani
- FS: Nisei Uicp w/ hks flange
- WTB 6 spd transmission
- FS: Stock Evo 8 turbo, exhaust manifold, o2 housing
- F/S Tial 44mm wastegate vband
- FS: aftermarket intake
- FS: new oil catch can w/ breather
- 6spd Tranny and Conversion Kit
- FS: fl Tactrix 1.3u datalogging cable
- NIB HKS 45003-AK005 EVC Boost Controller VI
- pte 1000
- Greddy Ti-Comp for sale full turbo back: $450
- new aem series 2 setup for evo 8!
- Last of my Evo Parts
- FS:New BR Ported Intake Manifold
- Feeler: BlaqOps double pumper
- Fs fidanza 3.2 clutch kit 3oo miles
- Ported o2 housing, Zeitronix display, & Apexi grounding kit
- FS: NY: Radiator Shroud / Cover
- TACTRIX 1.3 Cable (3 wire connector)
- FS: Zeitronix ZT-2 & ZR-1 Wideband Gauge Package
- FS: Autronic Plugin
- MoTeC ANTILAG kicker
- FS: MoTeC EVO9 plug in
- FS: Brand New Aquamist HFS-6 complete kit with 5 qt. reservoir tank.
- ECUs
- FS: TURBO XS Turbo back exhaust (tbe with race pipe)
- hta green
- FS: 10.5 hotside - turbine housing
- FS: ACD Transfercase and Rear Diff
- FS (NC): 3" Megan Down pipe, Tial V44 wastegate,
- Perrin Radiator Hoses BNIB
- Supertech Dual Valve Springs and Ti Retainers: $275 15-20k on them
- FS: Precision Turbo 5857 Billet LIKE NEW !!!
- GA: Used HKS Intake Kit
- NY: Full Labonte meth kit. Great price!
- arc box
- FS: Cusco Catch Can (NJ)
- Cusco Stainless Heat Shield
- FS: Buschur Ported/Coated Exh. Mani
- Megan 02 housing BNIB $90 shipped: Decided to go big and get a O2 dump
- FS (Co) Tial 44mm WG Blue BNIB
- FS (Co) Tial 50mm BOV Blue BNIB
- Bosch 044 inline for sale. BNIB. $150.00
- AMS half width radiator.
- FS: RC 1000cc Injectors
- 04 Intake manifold. Complete with stock injectors.
- FS:Walbro,Stock Inj.,and VIII ECU
- Megan o2 and new oem gasket
- FS: HKS Hi power exhaust
- FS: (NC) Buschur Racing Forward Facing Turbo Kit
- Fs: Exedy twin disc hd 450 shipped!!!
- FS: Mitsu OEM filters, Diaqueen tranny
- FS Tial BOV w/flange
- Evo 8 Valve Cover 145 shipped!
- HKS DLI-II Ignition for sale!
- FS:ACD Shep Stage 3 Tcase w/ Quaife Diff
- FS: Transfer case ring & pinion
- FS: PTE 880cc injectors
- F/S 8 turbo with mani, forge actuator, aftermarket j pipe.
- F/S Crank angle sensor for EVO 8/9...$50
- FS: FIC 1050cc Injectors
- FS: Evo 9 Stock IC and pipes / plug cover / oem cat back exhaust
- FS: Deka ETX14 Mini Battery (NJ)
- OE TBE 2,200 miles... kept inside (feeler)
- FS: gsc evo 8 s2's new in the box!
- F/S Evo 9 Denso iridium spark plugs "IKH24"
- F/S High performance lower motor mount
- AC compressor and lines
- FS: (AZ) JDM 3 bar MAP sensor, PTE 1000cc Inj
- *******MAP SST Turbo*****
- Agency Power Exhaust, Synapse BOV
- FS: AEM Meth Injection Kit
- Brand new FP HTA 3582/ used hotside
- FS: Muse Short Route UICP W/Tial Flange
- FS: AMS Manual Boost Controller - Chicagoland
- FS: Saikou Michi Dual Catch Can - Chicagoland
- Solid ACT 6 puck
- 9.8 hot side
- FS: Precision 880cc Injectors
- FS: 10.5 Hotside
- FS: AMS Turboback w/ High Flow Cat , Blitz BOV
- GT30r, HKS 272, Evo IX BOV, RC 1000cc 18PSI WGA
- FS:EVO ACD computer.
- FS: Zeitronix Black LCD Setup w/ Sensors
- MIL.SPEC t/b and Buschur ported stock intake manifold
- 6262 custom turbo kit w/ everything ready to bolt on
- Saikou Michi DC3 Dual Catch Can
- STOCK parts take a look!
- Acd ecu
- FS: Stock Evo 8 Cams
