View Full Version : For Sale/WTB - Engine / Drivetrain / Power
- FS [Northeast]: Curt Brown Fully Built Head
- FS [SouthEast]: HBC Manual Boost Controller
- FS [SouthEast]: Stock intake
- WTB [Northeast]: Looking for set of EVO 8 FP4R cams OR GSC S2
- FS [SouthEast]: Evo 8 Valve Cover - Stock
- WTB [SouthEast]: Stock 10.5 Turbine Housing
- [WTB] Ams test pipe
- FS [Northeast]: Complete big turbo setup $3,700 obo
- FS [Northeast]: Fuelab 42401-1 fuel pump $350
- FS [Northeast]: Evo 9 AEM V2 for sale $900 shipped
- FS [Northeast]: FIC 1120cc 400 Miles Low-Z
- [FS] Koyorad half size radiator 12-AN setup
- FS [Northeast]: AMS mustache bar delete
- FS [Northeast]: STM polished radiator bracket w/ oem inserts (NEW)
- FS [Northeast]: Evo VIII Rear Axles *68K*
- FS [Northeast]: Evo VIII REAR DIFF *68k*
- FS [MidWest]: MAP EF2 Turbo with J pipe/lines/Turbosmart Wastegate
- FS [MidWest]: Fic 1050
- [WTB] Evo IX UNDECKED Cylinder Head
- WTB [SouthEast]: Looking for: Starter metal plate shield
- WTB [SouthEast]: WTB AC condenser fan
- FS [Mid-Atlantic]: EVO rear diff and axles.
- FS [Mid-Atlantic]: 5-Speed Rebuilt Shepherd Transmission
- [WTB] Omni 4 bar
- FS [MidWest]: ETS SS intake blitz air filter
- [FS] Blitz oil cap, fan control,starter
- [FS] CBRD ultraslim rad, ARP cam bolts, Omega360 seat bases
- [FS] Crank sensor and crank pulley almost new
- [FS] Oil filter housing, thermostat housing,cam sensor
- [FS] Evo 8 shaved valve cover
- WTB [Northwest]: looking to buy AMS fuel rail
- FS [SouthEast]: Evo 8/9 Fluidampr - $300
- WTB [MidWest]: Evo 8 Crankshaft
- [FS] Stock 9 WGA
- [FS] Stock BCS and lines
- [FS] Stock exhaust manifold
- [WTB] Evo 9 Mivec Cam Gear
- FS [West]: FFTEC Manifold, O2 housing, DP
- [WTB] Valve Springs (duals, or Beehive)
- [WTB] 3" Down Pipe for my EVO IX Vendors Welcomed looking for something cheap
- FS [MidWest]: BNIB K1 RODS. oem pistons/rods. map springs Buschur fmic ki. arp headstuds
- FS [Northeast]: Evo IX Rear subframe (cross-memeber) assem.
- FS [Northeast]: Evo IX A/C LINES
- [WTB] T3 4 bolt outlet turbine housing for precision 6266
- FS [West]: New Deatschwerks DW300 pump.
- FS [Northeast]: Buschur LICP and J pipe for stock frame turbo
- FS [Northeast]: Competition Clutch stg 3 pressure plate with segmented sprung disc, OEM flywheel, TOB
- FS [Northeast]: Greddy kevlar timing belt used for 300 miles
- FS [Northeast]: Buschur Racing Evo 8/9 Cam Sensor Heatshield
- FS [Northeast]: AMS Remote Oil Pressure Sending Unit Line
- FS [Northeast]: Mishimoto water temp sensor adapter
- FS [Northeast]: NIB Fuelab 6AN filter and housing
- FS [Northeast]: English Racing underdriven oil pump gear
- FS [Northeast]: Buschur ported OEM intake manifold, S90 70mm TB, IM Phenolic spacer
- FS [Northeast]: Evo 9 MAF Sensor
- WTB [South]: WTB/WTT: OEM or other steel/chromoly flywheel. Can trade Fidanza fw.
- WTB [South]: OEM or other steel/chromoly flywheel. Can trade Fidanza fw.
- [FS] PTE 1000cc injectors
- FS [West]: FS: Few Stuff For Sale!!
- FS [Northwest]: BNIB Comp 280 cams and springs!!
- [WTB] Injector, intercooler in denver co
- [WTB] Front o2 sensor
- [WTB] Fic 1050's
- FS [Northeast]: AEM Seies 1 Evo IX
- WTB [West]: WTB GSC Zero tick lifters
- WTB [MidWest]: old school red,
- [FS] OEM crank, JE ceramic pistons, ACT monoloc
- FS [Northeast]: AMS LICP, Buschur o2 Housing, Synapse BOV
- WTB [SouthEast]: Brand New OEM Evo 9 5 Speed Trans
- [FS] Stock Evo IX intercooler, stock O2 housing
- [FS] Evo IX Turbo 38,xxx no shaft play, great condition
- [FS] Hallman Manual Boost Controller (MBC Red)
- [FS] QTP O2 Dump
- [WTB] Adjustable cam gears
- [FS] Injector Dynamics Plug and Play Adapter, Tensioner Pulley, Spark Plugs, Injectors
- FS [SouthEast]: Evo 8 transmission - $1500
- FS [SouthEast]: fs: evo 8/9 new parts...ets,supertech,hks,aem, etc
- [WTB] P/S Oil Pump Suction
- FS [MidWest]: Wiseco 2.3 Pistons on Eagle H-Beam rods
- [WTB] K1 162mm Connecting Rods
- FS [SouthEast]: T3 hotparts w/ vband exhaust - $1700
- [WTB] WTB: Evo 9 MHI 10.5 turbine housing
- FS [MidWest]: STM standard facing hot parts kit, lower Intercooler pipe and 4" intake
- FS [MidWest]: Quartermaster 8-Leg - $500
- FS [SouthEast]: Exedy Cerametallic Stage 4/5 Triple HR Clutch Kit - $1900
- FS [SouthEast]: Evo 8 Transfer Case NON ACD - $1500
- FS [SouthEast]: Evo 8 throttle position sensor (tps) - $125
- FS [SouthEast]: OEM Evo 8 Half Shafts - $50
- FS [SouthEast]: OEM Evo 8 IACV - $50
- FS [SouthEast]: ARP L19 headstuds, torqued once - $160
- [WTB] lower timing belt cover
- FS [SouthEast]: Evo 8 Alternator - $150
- [WTB] OEM Evo 8 Crank Pulley
- WTT [European]: wanted non acd transfer box & rear diff set up complete
- WTB [Australian]: CT9A Double Pumper or 400LPH PUMP, Intercooler, PPG/Billet Output Tube,
- FS [Northeast]: K & N Panel Filter for Stock Airbox
- FS [West]: FIC 1450cc injectors
- FS [West]: Evo9 gsc s2 cams
- FS [MidWest]: AMS 2.3RR Shortblock, completely refreshed and perfect
- FS [MidWest]: Evo 8 block, Manley High Comp Pistons, Manley Rods, MISC pieces
- FS [West]: WTS Quartermaster 8-LEG with HRB
- [FS] Fic 2150s
- WTB [West]: 02 dump, uicp...
- FS [Mid-Atlantic]: 5-Speed Shifter Parts
- FS [MidWest]: Fs bnib kelford 272's
- FS [Mid-Atlantic]: Exedy Triple, 200 miles!!
- FS [Northeast]: drive shaft bushings (only half set / aluminum driveshaft)
- FS [Northeast]: (2) Fuel Gas Filler necks
- FS [Northeast]: Brand new oil pump gears
- [FS] BINB Aem V2 30-6310 and Aem 3.5 Bar Map 30-2130-50 Evo 8
- [WTB] Rally armor mudlflaps
- FS [Mid-Atlantic]: RC 1000CC Injectors
- FS [SouthEast]: All new parts, Fresh 2.4LR Billet Race Motor EVO 8
- FS [Mid-Atlantic]: OEM Evo 8 cam gears - $20
- [FS] Evo X/ JDM 3 bar Map sensor
- FS [SouthEast]: 4g64 2.4 bare block forsale. $200
- [WTB] Lots of parts vendors welcomed want brand new mostly
- [WTB] 2003 Rear O2/oxygen Sensor
- [WTB] WTB evo 8 non acd engine harness
- WTB [SouthEast]: looking for an evo 8 tcase diff
- FS [MidWest]: Various evo parts
- FS [Northeast]: wtt evo 9 mivec solenoid
- FS [West]: Exedy triple less than 1k miles
- FS [SouthEast]: Evo 8 4g63 Block with stock crank CHEAP!
- FS [Mid-Atlantic]: Nisei LICP
- [WTB] Standalone ECU Evo 8 (NO AEM V1)
- FS [Northeast]: GSC s3 cams, manley pistons .020 over 9.0:1 and Evo 8 aem v1
- FS [MidWest]: Evo Parts How Many? ALL OF THEM!!
- WTB [West]: WTB 8-9 Oil Cooler hoses/Pipes
- FS [SouthEast]: Evo 8/9 Clutch Fork Stop - $30
- FS [SouthEast]: Mishimoto Evo 4,5,6 radiator with hoses & fan - $100
- FS [SouthEast]: Fidanza Adjustable Cam Gears - $140
- FS [SouthEast]: Stock Evo 8 intake mani - $85
- FS [SouthEast]: Low mileage 05' RS LSD - $350
- FS [SouthEast]: Walbro 255lph fuel pumps $50 ea
- FS [SouthEast]: Black short route UICP w/ Tial Q 50mm BOV - $350
- [FS] Evo 3 rear subframe, crossmembers, driveshaft, rear struts,
- FS [South]: FS: Fidanza Flywheel
- FS [SouthEast]: Shep stage II Transmission - $2000
- FS [SouthEast]: FIC 2150cc INJECTORS - $550
- FS [MidWest]: FIC 2150cc Injectors!
- FS [South]: Evo 8/9 Parts Galore!!! Offers Welcomed
- [WTB] 30r Turbo or Something Close
- FS [SouthEast]: Comp Cams 280 Evo 8
- FS [SouthEast]: Shep stage II Transmission - $2300
- FS [SouthEast]: 2.4LR stage II shortblock- $3000
- FS [SouthEast]: OMNI 4 bar map sensors ( have 2 ) - $75
- FS [SouthEast]: AEM fuel rail - $100
- FS [SouthEast]: FIC 2150's - $600
- FS [SouthEast]: T3 with 44mm v-band wastegate outlet exhaust manifold. $170 + shipping
- FS [SouthEast]: Evo 8 head - $1000
- FS [SouthEast]: Evo 8 head, complete..$1600
- FS [MidWest]: Virgin 4G63 Block, 4G64 Crank
- FS [West]: FF kit licp and new 3 inch test pipe
- [FS] 100mm forged Eagle crank 2039375900B7
- WTB [Mid-Atlantic]: WTB Springs & Retainers
- [WTB] MOTEC MDC Lancer Evo IX
- WTB [West]: WTB: ETS or JM-Fabricaton Exhaust Manifold (Stock Location).
- FS [West]: FS: Corbeau - 3in 4pt Camlock harness & NGK - Spark Plugs
- FS [Mid-Atlantic]: ETS 3.5" exhaust, Cobb downpipe, AEM EMS V2, plug covers, supertech
- WTB [Pacific NW]: Evo 9 radiator stock or aftermarket
- [FS] Precision 1000cc injectors. Never used with e85.
- [WTB] Rear door, rear bumper rear tail lights for an Evo 7-9 shipped to Miami
- [WTB] I so built 9 shortblock
- FS [SouthEast]: Bare 2.4 block, hallman boost controller w/inside controll,3" intake w/filter
- FS [Northeast]: EVO 9 Spark Plugs NJ
- [WTB] Exhaust Cam Sensor
- FS [Northwest]: AMS mini battery tray
- FS [Northeast]: ARP L9 head studs
- FS [Northeast]: Front lower motor mount
- [FS] Oem 4g64 100mm crankshaft-mint
- [FS] OEM cams for evo 8 and 9 for sale both low miles.
- FS [Northeast]: Rear window motor set up and reg --rear door locks
- [WTB] TB for BBK flange
- FS [West]: Precision T3 .82 a/r housing
- FS [Northeast]: SAMCO Intercooler hose for Evo 8 or 9
- FS [MidWest]: CBRD ultra slim radiator
- [FS] Stock injectors MR Tail lights Resistor box
- [WTB] TIAL 35r housing
- [WTB] gauge pod, ATI or the side pillar 2 gauge pod
- WTB [Northeast]: Ported intake or Throttle body
- [WTB] Evo TPS
- FS [West]: Intake Mani, Throttle Body, Power Steering & More
- WTB [MidWest]: Stock Evo 8 cylinder head
- WTB [MidWest]: Looking for Front Driver Side ABS Sensor for Evo 9
- [WTB] WTB/WTT your 2005 Evo 8 ECU for BR duel BC
- FS [Northwest]: oem front differential
- [FS] Evo 8 bare head. (Naked head)
- [WTB] Evo IX ECU - Vipec, Motec
- FS [MidWest]: Spark-Tech Sequential Ignition System, AEM EMS Version 1(Evo 9).
- [FS] Curt Brown intake Manifold & 70mm Full blown TB
- FS [Northeast]: (MI) Grimmspeed EBCS, DW300 Fuel pump
- FS [Mid-Atlantic]: Like New Mitsubishi Evolution 8 & 9 Buschur Spec GRP Aluminum Rods
- [WTB] Evo 8/9 Short block/Long block Motor
- [WTB] WTB 4g63 torque hone plate
- [WTB] 3" downpipe and 02 housing
- FS [MidWest]: WTT: Sheepey FF hot parts for standard placement kit
- FS [Pacific NW]: OEM AC system components
- [FS] maperformance EF3 turbo
- FS [SouthEast]: 6262 standard placement turbo kit $2500
- [WTB] Rear LSD for passive differential
- WTT [Northeast]: buschur bullet brand new
- [FS] custom gsc cams evo 4-8
- FS [Pacific NW]: MAP O2 eliminator w/ dump and v-band
- [WTB] EVO 9 stock valve cover
- [FS] brand new Walbro 255Lph + install kit
- FS [SouthEast]: Custom catchcan with 3, -8AN fittings and lines - $250
- FS [SouthEast]: Grimmspeed MBC, new - $75
- FS [SouthEast]: ETS SD 4" intake - $120
- FS [SouthEast]: Small battery kit w/ new battery - $175
- FS [SouthEast]: Kelford 272 cams, Evo 8
- FS [SouthEast]: Spoolin Up COP *fits under cover* - $275
- FS [SouthEast]: Mishimoto Evo 4,5,6 radiator with hoses & fan - $200
- FS [SouthEast]: Evo 8 valve cover - $300
- FS [SouthEast]: 6262 turbo kit $2850
- [WTB] alternator mounting bracket #1801A020
- FS [MidWest]: HKS 274/278 BNIB, Exedy Twin HD (needs rebuild), XS Engineering LICP
- FS [Northeast]: FS:Manley Pistons with 95 miles on them!!!
- [FS] (MI) Torque Solutions, ETS, AEM, and stock parts
- FS [MidWest]: Project Sale - STM 6266 turbo kit, FIC 1650, Tial WG, etc......
- WTB [Northeast]: Bunch of aftermarket parts evo 8/9
- FS [West]: FS Exedy, Koyo, Mishimoto, Forced Performance
- FS [SouthEast]: Garage clearing sale (Evo9 turbo, HKS 280, standalone, etc...)
- FS [West]: brand new evo 9 turbo
- FS [Canadian]: Wideband Zeitronix Zt-3 kit
- FS [MidWest]: Buschur Race FMIC 3.8" core, 2.5" inlet, 3" outlet
- [WTB] Evo 8 Exhaust Cam trigger wheel and bolt
- [FS] NEW HKS GTII 7460R TURBO for EVO 8/9
- [WTB] Evo 8 Exhaust Cam Sensor Housing and bolt
- FS [Mid-Atlantic]: COP, never been used
- FS [West]: Quartermaster 8 leg cluch kit 8/9
- [FS] Evo 8 turbo 32k miles
- WTB [West]: TPS, Throttle Position Sensor for evo 8/9
- FS [Northeast]: Hallman manual boost controller
- [WTB] injectors
- WTB [West]: WTB Evo 9 turbo
- [WTB] Looking for a set of +1mm valves
- FS [Northeast]: AMS, FP, MAP, Defi, Forge, Buschur
- FS [Pacific NW]: ***Megan Racing DP & Invidia TP for sale***
- [WTB] rear axels
- [WTB] 65mm evo TB
- [FS] Autronic SM4 ECU with full CDI500R Coil on plug, Reulctor interface, and short loom
- [FS] EVOIV to IX - Vband Tubular Manifold
- FS [West]: Quarter Master 8leg street version
- FS [South]: WTS/WTT Transmission and clutch
- FS [SouthEast]: AMS Moroso Wet Sump Oil Pan, Windage Tray, Crank Scraper and Improved Pickup
- FS [SouthEast]: Spoolin Up COP kit (!read!)
- [WTB] Exedy IM02
