PDA
View Full Version : For Sale/WTB - Engine / Drivetrain / Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. FS Skunk2 Catback
  2. FS CA: Evo IX GSC S2 Cams, OEM IX Cams, Valve Springs/Retainers, ARP Rod Bolts
  3. FS: Evo 8 HKS 272 cams - $200shipped obo
  4. Apexi power fc, suit evo 7,8
  5. AC Compressor, Condenser & PS Stuff
  6. Evo 9/IX Diverter Valve (BOV)
  7. DC Sports Downpipe with Built in Cat-delete
  8. FS>Evo8 ECU, OEM intake mani, blown 8 turbo
  9. F/s-NY FP RED 84mm turbo JB
  10. 7 Buschur E85 Testers
  11. OEM Evo 8 Parts turbo, cams, injectors, valvesprings
  12. Fs:wa gt3076r
  13. az evo parts( injectors, cover, mount)
  14. FS: (NC) Apexi, Tein, Defi, OEM, etc.
  15. Buschur ported and coated o2 housing with o2 sensor. $150.00 shipped
  16. Buschur ported and coated intake manifold with sensors... $200.00 great condition
  17. Wrinkle Black Buschur evo mass air pipe and filter ... mint.... $200 shipped
  18. Cosworth m2 evo 9 -800 miles- like new $475 shipped
  19. Fs: Brand new Walbro 255 install kit (no pump)
  20. OEM Fuel pump housing w/ walbro 255
  21. Polished Injen intake w/ couplers
  22. Tactrix 2.0 cable / EvoScan GPS NAV
  23. FS: WA FIC 950cc, JMFab mini battery tray,IX cams
  24. Mini Odyssey Battery Kit
  25. HKS DLI II 120$ shipped
  26. evo 8 parts
  27. Full Race T3 Kit - No Turbo
  28. FS: AMS Delrin Shift Knob / Tactrix 2.0 / Tactrix 1.3
  29. FS: FIC 1100cc (High-Z) Fuel Injector Clinic Injector Set
  30. FS: AMS Polished FMIC, ARK TI Exhaust, Nisei LICP, ARC Intake, Zeitronix ZT2, + more
  31. ETS Intake with K&N Filter
  32. FS: AMS Mustache Bar Eliminator!!!
  33. Fs: (nc) arc fmic
  34. A/C System EVO 8
  35. GSC Evo 9 Stroker R2 Camshafts
  36. CA: FS: ARC intake box evo 8/9
  37. FS TX 3" Espilir Catback Exh & Test Pipe - Cheap
  38. FIC 2150cc - Box Spec Sheet and Resistor bypass
  39. FS Evo 8 turbo with coolantlines/wastegate/pipe
  40. Works Exhale Resonated Test Pipe and Straight Test Pipe
  41. New Borla manifold!
  42. FS: Evo 8 ECU
  43. 10.5 ported hot side, megan o2 housing
  44. Evo 8 Transmission
  45. Manley Valve Springs and Titanium Retainers
  46. FS: Stock and Aftermarket Parts
  47. FP 84mm intake, 84mm boost leak tester, OEM fuel rails
  48. PTE T3 .63 4 bolt hotside off 6262
  49. [FS] NEW built cylinder head, Kelford 280s, rocker arms, IX valve cover w/ 10AN
  50. FS: NJ ETS intercooler piping, tial bov
  51. Ets manifold and custom down pipe for sale
  52. CA: FS: Evo 9 cosworth built head, cosworth cams
  53. TB Trunk, Lower IC Pipe, Zeal Coilovers like new
  54. Ets licp v2
  55. MAP Headstuds
  56. English Racing 4" SD Intake with 9" K&N Filter
  57. CiroDesign Racing Camberplates
  58. Synapse BOV
  59. Buschur Lightweight Battery Kit and Odessey PC680
  60. MAP 2.5" Stainless Steel External Dump o2 Housing
  61. LF Tial Q BOV and SD Intake
  62. OEM Throttle Position Sensor and Idle Air Control Valve
  63. Speed Density Kit& FFTEC EBC
  64. Greddy Turbo Timer II W/Plug and Play Harness
  65. AMS Mini Battery Kit
  66. Megan Racing Downpipe $50
  67. FS: IL - Vibrant MAF adapter
  68. Brand new Curt Brown ported stock 65mm throttle body
  69. FS: Forced Performance BBK-F
  70. LF: one exhaust hanger
  71. FS: Quatermaster 2 Piece Driveshaft
  72. FS: Whining ACD T-Case
  73. T4 DEI Titanium turbo blanket/shield
  74. Garrett GT4088R turbocharger (T4 1.06 a/r)
  75. FS: Brand new GM-Style Omni 4-Bar Map Sensor with pigtail - $75 shipped
  76. Precision T3 6766 CEA JB
  77. Evo stock intake manifold, stock ignition coils
  78. New OEM Evo 8 valve cover gasket - MD340535
  79. Buschur filter with maf / oem ignition/ wastegate and more
  80. FS: Brand New OEM Evo 9 Pistons And Rods
  81. FS: Evo 9 complete head
  82. Exedy Stage one New..Stage 4 Comp Clutch for sale. comp clutch flywheel as well
  83. rear o2 sensor
  84. EVO 9 Gunmetal BBS Rim
  85. Evo 8 cams
  86. Stock evo 9 Waste Gate Actuator
  87. Evo 8.5 Turbo (10.5 hotside) $250
  88. FS: AEM EMS evo 8 v1
  89. FS:(NJ)OEM Evo IX Cam/OEM Fuel pump Super Cheap 2 sets $89 shipped
  90. FS: ID2000 Injectors with plug and play plugs
  91. ETS 3inch IC Wide Tank
  92. GARAGE CLEANOUT>> EVERYTHING NEEDS TO BE SOLD!!! Stock and Performance Stuff
  93. fp intake for sale 75 shipped
  94. CA:FS: Tial Qr bov welded on stock uicp
  95. FS: TX - HKS Turbo timer
  96. FS: TX - Brad new black Tial Q bov
  97. FS: (PA) Custom T3/Vband 44 Ramhorn Manifold
  98. FS: Evo 8 Transfer Case *NO WHINE*
  99. Freshly Rebuilt Evo 8 turbo! ported!
  100. FS: NEW BBK Full turbo
  101. FS: (WV) RC-1000cc and ETS Short Route UICP
  102. Fs: Evo 8/9 flash connector
  103. Fs: Torque Solution EGR block off plate
  104. FS: 800 whp part out, 6466 forward facing, double pumper, 2150cc, ams, AEM, sparktech
  105. Wiseco 1400HD E85 10.5:1 .020 Pistons
  106. Feeler: MAP EF4 turbo with ported compressor housing, install kit & JDL 02/dump
  107. Exedy Flywheel Triple or Twin
  108. COBB Intake Filters - New & Used
  109. Exedy mm022sd stage 4 twin plate - sd twin disc - ***new****
  110. OEM parts for sale and an act clutch.
  111. WTT: Evo IX Weir 12-plate rear end for rearranged stock
  112. FS: BLox front motor mount
  113. FS: Euroexportinc Valve Spring Tool
  114. Greddy Easycam 264. used.
  115. 2006 Evo IX rear differential
  116. FS: HKS 272 cams cheap price!
  117. Ams licp viii/ix
  118. Evo 8/9 Parts Stock some aftermarket
  119. TurboXS, ETS, odyssey, HKS, FPred
  120. FS: 3" cat delete downpipe
  121. Evo 6 PWR radiator, fit 8/9, moves neck out of way, Anodized Black. Rare piece! HAWT!
  122. F/S Evo 8 Spoolinup COP
  123. FS: AMS 1000WHP Fuel System
  124. FS: Baffled Catch Can
  125. FS-TX Samco orange evo VIII-IX hoses
  126. FP 3794 F/S.... only 10 miles!!!!!!
  127. FS: AMS Exhaust / High Flow Cat / Resonated Test Pipe (IL)
  128. Huge Sale/Omni/Buschur/Ams/Brembo/Tyrant/Rexpeed/OEM
  129. fs eagle rods, wiseco pistons
  130. FS: Brian Crower 272 stage 2 cams, Fidanza adjustable cam gears
  131. FS: (NY) Toxicfab O2 Dump.
  132. [FS] Evo ACT HD clutch
  133. PPI ported & swaintech'd exh manifold, Aluminum UICP, 4" to oem turbo coupler
  134. Buschur Racing Parts intercooler piping catch can battery
  135. Evo 8 turbo-wga-jpipe-gaskets-o2-oil feed
  136. Tial waste gate
  137. FS/FT Grimmspeed EBC evo 8/9 mint
  138. OEM Driveshaft - 36K Miles
  139. HAFE T3 Hot Parts Kit
  140. FCS Evo Tank
  141. 894WHP Mostly Buschur parts. Engine/turbo kit/Fmic etc.
  142. FS (NY) Purple Lower Samco Coolant Hose $20
  143. FS: Ets tubular, MAP EF3, FP, Gates, Sparco, Act
  144. Curt Brown ported evo 8/9 intake manifold
  145. Stock Evo 8 Radiator & AC Partout
  146. FS: lots of aftermarket parts
  147. Fic 1650cc Injectors want sold
  148. Tuning Laptop
  149. Buschur Filter, Oem Ignition,Piston and rods and more
  150. FS,IL: samco, tial, pte
  151. F/S: Evo 8 6 puck clutch kit 350 Shipped!
  152. FS NY TL-21 Boost Controller
  153. FS (NY) USED Carbon Fiber IX Timing Belt Cover $25!
  154. FS: Stealth Coated 3" Cat Back Exhaust
  155. FS: ETS 4" Intercooler
  156. evo 9 turbo with cbrd ported 10.5 hot side
  157. Ignition, Buschur intake and more
  158. FS: Stock Coils and plug wires (NM)
  159. [FS] Aeromotive A1000 fuel pump and Harwood fuel cell
  160. FS - SparkTech PRO-14 CDI COP
  161. non ACD tcase with RS lsd low miles
  162. Stock LICP, Stock 02 Housing
  163. FS: Perrin Intake MAF Adapter and Evo 8 MAF (NM)
  164. FS: Vishnu Adjustable Cam Gears (NM)
  165. FS: Evo 8 hks 262 cams, FIC 1650cc inj
  166. JDL Forward facing hot parts w/gt3582r BB Low miles
  167. FS: Quatermaster Twin, Precision 4272R, Burshur Stage 3
  168. T3 FF Man,4" Ic and 3"Ic Pipes, Intake Manifold, Mini Battery and MORE CHEAP!!!
  169. (FS/FT) Fp black with ets manifold ***1500 miles on the whole kit****
  170. Evo 9 Turbo/AMS Exhaust
  171. FS: (UT) AFI Turbo Manifold, Garrett GTX3576R, AMS F1 Intake Manifold and Carbon Roof
  172. FS (OH): FIC, Skunk 2, Full Blown, Spoolin' Up, Etc
  173. Evo 8/9 oem,gates,act
  174. Fs: Nice aftermarket parts, big power, id , aem, walbro,ams , etc...
  175. Evo 4 Engine Part Out
  176. drop in pistons built shortblock for sale evo 8 or 9
  177. Brand New AEM EMS Series 2 Standalone 03-05 Evo 8
  178. FS/ NY:Manley I Beam Rods, Wiseco Pistons
  179. EVO 8 Alternator
  180. FS: Apexi power intake
  181. FoR SaLe... EvO 8 OEM coil on plug & new wires..
  182. FS: Injector Dynamic 2200cc Injectors and Kelford 280 cams
  183. Fs: Fp intake, front motor mount, rear motor wiper
  184. Ported Cast Iron OEM Exhaust Manifold for EVO VIII & IX ready to ship!
  185. 3" Test Pipe EVO 8
  186. ACT Release Bearing BNIB EVO 8
  187. F/S: ACL tri metal race rod bearings
  188. F/S: AMS spark plug cover
  189. F/S: Buschur heat shield
  190. F/S: **CHEAP** Buschur 3inch intake
  191. FS - ETS intake - 70.00 shipped - ran it on my evo 8
  192. Aftermarket parts for sale *** Long Island **
  193. F/S: STM Clutch master cylinder to slave hard line
  194. F/S: Brand new 15w/50 AMS racing oil
  195. F/S: **CHEAP PRICE** T3 .82a/r HTA3586R
  196. 14' of -10AN Russell Proclassic fuel/oil hose
  197. Evo 9 Cams, Muffler, Down Pipe, Power Steering colling Line, A/C Lines
  198. AEM EMS, HKS DLI, C.O.P., Exedy plates
  199. Stage 2 clutch, flywheel, IX BOV, spacers, IACV Cheap Prices!!!
  200. Genuine JDM Evo 9 MR taillight passenger side
  201. Exedy Twin SD - Rebuilt with brand new components - 900$ Shipped to lower 48
  202. FS: Ams 1000hp Fuel setup, acd pump, and a bunch more
  203. FS: FP Red JB
  204. megan o2 housing
  205. FS: BR Built 2.4 Manley Rods & JE Pistons - $2000 Firm
  206. FS: (VT) Torque Solution Billet aluminum 3 piece Engine Mount kit
  207. FS: New in Box: ARP Head studs, HKS Ignition System, Buschur Alky/Meth kit & More
  208. Full Race T3 Kit w/ PTE CEA 6766
  209. Evo 9 BC Cams ($100), Supertech Dual Springs ($125) & More
  210. For Sale-----Evo IX Starter motor
  211. [FS] Evo 9 engine harness w/ fuse box
  212. [FS] Evo 9 ACD transfer case, rear diff, axles
  213. Map 02 dump fs// nj
  214. Tactrix 1.3 cable and Ingersoll-Rand BCS
  215. Evo 9 turbo 10.5 and stock parts
  216. PTE 1200's BNIB
  217. FS: built evo 8 short block
  218. Evo ix parts
  219. FS: (NY) USED JMF Small Battery Tray
  220. FS: (NY) USED FUELAB FPR Kit
  221. Muse o2 dump for sale
  222. FS: (NY) USED STM Fuel Rail
  223. FS: Brand new Toxicfab manifold, o2 dump, Map EF4
  224. RC 1000 injectors
  225. FS: (NY) USED Buschur Upper Intercooler Pipes
  226. FS: (NY) USED AMS Lower Intercooler Pipe
  227. build 2.0 for sale $2800
  228. FS: (NY) Used Zaklee Cover. Evo IX.
  229. FS: (NY) USED JMF Intake Manifold
  230. CBRE ported 10.5 hot side
  231. Sparktech ignition system (pro14 cdi)
  232. Used Exedy Triple Cheap
  233. FS: MD - DBB FP Black, Full-Race Manifold, STM Intake, MAP O2 Eliminator, Kelford 272
  234. Saikou Michi Dual catch can
  235. Tial 44mm Wastegate Flanges
  236. 3" Speed Density K&N Intake (4" silicon turbo adapter)
  237. Evo 8 OEM Head Gasket
  238. Precision Injectors, 780 and 1200's
  239. Bare 63 block, k1 billet crank, k1 rods wiesco pistons
  240. FS ACT Streetlite Flywheel Ingall dampner
  241. FS:WA Magnus V5,GSC S3's,FIC,ETS,GSC springs
  242. Dejon Tool 3" Stock Replacement Intake Pipe
  243. ETS upper rad pipe
  244. cams, springs, retainers, megan
  245. cams, springs, megan
  246. FS: EVO 8/9 samco intake
  247. Brand New '04 RS Transfer Case
  248. FS: Evo IX Series 1 AEM EMS with AEM 5 bar map sensor and serial to USB cable
  249. brand new 02 sensor
  250. FS: OEM Valve Springs + Retainers
