PDA
View Full Version : For Sale/WTB - Engine / Drivetrain / Power
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. FS: Oem parts
  2. Prodrive Solenoid///Innovate LM-2///HotLap Timer
  3. Omni 3 bar map sensor
  4. BNIB Competition Clutch Stage 2 kit, EVO VIII-IX
  5. Turbo, injectors, pressure plate, flywheel and more FS
  6. FS: Downpipes/Oil Feed/return/ and Random Parts
  7. FS: Forge 004 BOV
  8. Evo 8/9 FMiC & Throttle Body
  9. FS: Evo9 OEM Parts - ECU, Cams, Intake+MAF+Adapter+Filter, O2 Housing
  10. FS: Walbro 255 Fuel Pump
  11. Exedy Oem, o2, Switzer COP, HKS
  12. WTS: (2) Stock Evo 9 BPVs
  13. IX BOV's
  14. 6262 JB, 100mm Crank
  15. Autometer Pyrometer w/ manifold
  16. Misc parts for sale **cheap**
  17. full blow double pumper with stock line kit and pumps
  18. Comp heavy twin, 200 miles brand new!
  19. extremepsi/jmfab 6266 bb turbo kit complete
  20. FS: Manley I-Beam Rods & 10:5 Stroker Pistons
  21. Tranmsission Parts MISC, Open dif, trans case, license plate holder FRONT BLITZ
  22. FS: Shearer O2 dump NEW
  23. CB Ported Magnus V5 IM + UICP, ported JB FP Black, & More!
  24. Fs: Ets licp
  25. ETS Intake kit w/ K&N filter
  26. FS: Megan Racing Resonated Test Pipe
  27. headgames evo 8 race head!
  28. Evo 8/9 Torque Solution Motor Mounts
  29. FS: Evo 9 DV, Ported stock intake, JDM 3 Bar, Air Filter and MAF adapter
  30. quartermaster street clutch new evo 8/9
  31. varex remote controlled exhaust for 8/9!
  32. squash performance double pumper!
  33. FS: Stock Turbo 30k Miles and Misc. Parts
  34. FS: (MD) Buschur Ported Exhaust Turbo Manifold, OEM Manifold
  35. FS: (MD) Evo 9 turbo, wastegate actuator, o2 housing, outlet pipe, oem lines
  36. FS: (MD) Evo9 stock turbo 24k, 1 owner, no shaft play
  37. FS: FP inline oil filter/red
  38. GSC S1 cams. Evo8
  39. Hallman Boost Controller & Modified Wastgate
  40. BNIB - STM's 4" Intake Pipe Kit
  41. 2 Billet WGA 21psi, stock exhaust manifold
  42. HKS SSQV BOV with upper pipe 8/9
  43. oem ic spray/ windshield fluid/ lower ic
  44. Evo 9 brand new parts
  45. New Front Hub Assembly Evo 8
  46. Evo 8/9 COP Setup
  47. Garage sale, stock parts, act flywheel
  48. Evo 8 tranny
  49. Looking for a good bolt kit
  50. HIGH HP PARTOUT Built 2.0 topmount 6266 8leg much more!
  51. FS: Evo 8/9 BR DP, Megan TP, and Megan Catback
  52. Greddy BOV, UICP, LICP, ETS IC
  53. FS (OH): BC 272 Cams, ARP Studs, Stock internals/valvetrain
  54. Evil Engineering t3 4 Bolt Kit
  55. Exedy triple metallic plate clutch evo 8
  56. NEW! Walbro 400lph E85 In-tank Evo 8/9 Fuel Pump F90000267 w/ install kit
  57. NEW!! Exedy Triple Cerametallic Stage 4/5 MM023SR Clutch Kit Mitsubishi Evo 8/9
  58. Evo 8 stock and aftermarket parts, 8 turbo kit, act clutch, perrin test pipe, covers
  59. FS: 2005 EVO 8 ACT Xtreme Clutch XTSS
  60. FS: 2005 EVO 8 ACT XACT ProLite flywheel
  61. FS: 2005 EVO 8 ACD pump for transfer case
  62. FS: 2005 EVO 8 ACD transfer case
  63. SpoolinUp CoP, "new coils", 1500 miles on them, fits VIII and IX
  64. 4 NGK BPR8EIX Iridium spark plugs
  65. EvO 8-9 ETS upper i/c piping/ brand new
  66. Feeler: FS/ Trade FP Red
  67. FS: BC 272 Cams Evo 8 Cheap!!
  68. Evo VIII/IX intake mani w/ throttle body & sensors
  69. FS: JB 84mm FP Red turbo
  70. OEM Oil pan/w pickup
  71. AMS Downpipe, almost new clutch slave cylinder, flywheel, 3 Port Boost Solinoid
  72. Evo 9 turbo, MAP o2 Dump, Ported Stock Exhaust Manifold, FP Oil Lines, FP 25psi waste
  73. 2003 Evo 8 ECU
  74. FS: Manley 10.0:1 pistons, .040+, BNIB
  75. Evo 8 1050CC injectors
  76. FS: Evo 8 IM
  77. FS Tactrix 1.3m Cable
  78. FS: Evo 8 Valve Cover
  79. Hallman ES Manual Boost Controller
  80. foward facing t3 topmount new
  81. Power Steering Pump, Alternator, ect.
  82. Slowboy racing Intercooler, practically mint!!
  83. FS: NJ 8/9 intake, adapters, filter, MAF
  84. Evo 9 Cylinder head
  85. 6 Bolt 4G63t DSM Fully built
  86. Turbo XS intercooler/ Double Pumper with Fuel Sytem
  87. FS: Synapse Bov
  88. fresh built 2.2 liter engine
  89. FS: VIII Camshafts, BR Spec JE Pistons, Stock S&R's
  90. FS: ID2000cc Injectors w/ PnP Harnesses & AMS CNC Ported EVO8 Race Head
  91. FS: BBK Full ported New
  92. AEM Electronics MAP Sensor 30-2130-75 (0-75psi Tru-Boost Sensor)
  93. ETS intake - Forge BOV/UNOS/Wastegate
  94. FS: Fujita cold air intake system and DejonTool MBC (SOCAL)
  95. Exedy Twin SD W/ STM fork stop & throwout bearing
  96. FS: APS blow off, B&M short shifter, MastaMinds ss clutch line, Magnaf. high flow cat
  97. Brand new Evo VIII/IX throttle body
  98. FS: Forge RS Adjustable BOV
  99. Non ACD transfer case
  100. F/S: Cometic 86.0mm HG Evo9 (JDM) metal bypass valve Evo9 WGA Swift coilover springs
  101. (FS) NY - Evo 8 Turbo with manifold - Complete
  102. Fs: DW300 fuel pump and Cusco catch can
  103. ACT street sprung disc BNIB
  104. Perrin catback exhaust "NY"
  105. Brand new AP Motor Mount
  106. FS: MAP, OEM and MORE!!
  107. OEM evo 8 balance shaft crank sprockets
  108. Works Blue Drop Filter, 8 Turbo complete, 9 BOV crushed/ Perrin Fuel
  109. Crankshaft sprocket and crank angle disc
  110. Mitsubishi Evo 8 VIII OEM Parts Turbo
  111. Evo 8 Cylinder Head
  112. Used Evo 8 AEM Cam Gears
  113. Evo 8 Autronic PNP Ecu
  114. FS: Precision 1000cc injectors
  115. ARC titanium manifold heat shield and intake box
  116. FS: Cobb AccessPort Evo VIII/IX
  117. Brand new turbo tuff I beam rods 2.0L
  118. Magnus v2 smi used weisco hd pistons arp head studs
  119. FS: ACD pump, ACD tcase, ported ix turbo, and FP 18psi actuator
  120. FS: WA FP Black,Tial, MAP o2 elim dump, OEM metal DV
  121. FS: Aem 320 fuel pump
  122. Agency Power 100% or 50/50 BOV
  123. Spoolin up COP Ignition
  124. OEM Exhaust Manfiold, cheap, AFPR, shifter bushings
  125. Short Throw Shifter Kit for 6 Speed MRs !!!
  126. FIC 1150cc & 1000cc
  127. FS: Custom stock frame 25G/T67 turbo (OH)
  128. WI: FS: 3" powder coated test pipe
  129. FS: MAP EF3 like new 3k miles plug and play SoCal
  130. FS: Buschur racing double pumper new in box
  131. PPI Vertical fmic, aluminum radiator setup
  132. Stock Evo 8 intercooler + all piping
  133. bc272's cheap
  134. Exedy triple metallic clutch evo8 2003-2005
  135. FS: (IL) EVO 9 Stock Turbo with Forge Wastegate
  136. For sale FP Red or trade
  137. Buschur 1/2 radiator
  138. MAPerformance single piece downpipe, dump, & turbosmart waste gate
  139. FS: Evo 8 parts and misc. items
  140. FS: Lots of parts from my IX - Florida
  141. Fp 25lb wga
  142. blox front motor mount 50 shipped
  143. Evo 8 head!!!!
  144. Dynatek Arc-2 w/ 2 Montero Coils COP
  145. Spoolin up COP
  146. Magnaflow 3" Muffler
  147. Thermal Wrapped Megan Downpipe
  148. FS:SD GSC S2, Kelford 272, 2 sets of ST Duals, AMS IM, Boomba 75 TB, PTE 1200's
  149. FS: Aftermarket Parts & Stock IX Turbo (PA)
  150. Buschur Racing Downpipe
  151. MAPerformance Stainless Steel External Dump O2 Housing (Evo 8/9)
  152. Carbontics twin, Carbonetics blade clutches
  153. ETS Evo 9 Wide Tank Intercooler FMIC
  154. FS: Evo 9 MR 6 Speed Trans 30K miles
  155. FS: FP 3586HTA and TiAL V44 WG
  156. TiAL 44mm Wastegate Fs
  157. FS: 1000CC Injectors ( 2 Sets)
  158. FS: 100mm Manley Billet Crank - 5k Miles
  159. FS: Evo 8/9 Stock ported O2 housing
  160. aem 1313
  161. FS: BR small battery kit BNIB
  162. FS: BR moustache bar BNIB
  163. FS: Precision 6262BB
  164. Evolution VII GTA Transmisions
  165. FS: Evo 8 Performance Parts..Kelford, HKS, BC, Fidanza, MAP
  166. evo 9 turbo or tomei arms 7960 turbo for sale
  167. FS: MD - Injen Upper Intercooler Piping
  168. ETS FF Turbo kit w/ PTE 6466
  169. MAP O2 Housing
  170. FP Green turbo sale
  171. FS: (MD) JunBL 3" Stainless catback exhaust, Vband w/ 2 bolt adapterstraight through
  172. Evo parts --part out
  173. FS: (MD) Forge RS bov blow off valve, diverter, bypass
  174. FS: (MD) Torque Solution Billet Aluminum Front Engine Mount Evo VII-IX
  175. AEM Intake. Carb Legal. HKS Filter.
  176. pro efi 128 ecu for sale open to trades on ignitions
  177. Aem digital wideband and boost gauge
  178. Full blown double pumper, aeromotive fpr, fuel rail
  179. 2004 Evo 8 Motor Longblock
  180. Exady clutch, stock springs, gauge
  181. FS: Grimmspeed Electronic Boost Controller
  182. Evo 8 stock intake manifold
  183. HKS 272/272's & BUSCHUR DUAL SPRINGS/RET
  184. FS: Evo 9 turbo rebuilt
  185. FS: 6 speed transmission, prosport, stock parts
  186. F/S NY: stm radiator brackets CANDY PURPLE
  187. HKS 272s and RC1200 Injectors
  188. Borla catback Evo IX
  189. FS: Stock Evo 9 FMIC w/ Stock LICP, RRE Rally Cat Test Pipe (NorCal: SF)
  190. Testing waters, HTA86 Turbo f/s
  191. EVO 8 stock cams - $75 + shipping
  192. FS: Tomei 280's (evo 8) Helix (adj) gears
  193. CA FS: Crushed Evo IX DV / BOV
  194. [FS] Fidanza flywheel
  195. ETS Radiator Hose
  196. FS: Injen uicp
  197. ef3 3 weeks old!
  198. FS: Lower Intercooler Pipe
  199. FS: Injen intake
  200. FS (FL): Blue Tial MVR 44mm v-band waste gate
  201. AMS EVO 8 CNC Head Complete Low Miles
  202. FS: RS front diff
  203. HKS, Ingalls, SSQV, APS, Exhaust parts
  204. Buschur 3" Slip Fit Test Pipe
  205. FS: BNIB Manley/K1/Mahle Rotating Assembly
  206. FS: IAC, ARP Headstuds, Holset etc.
  207. FS: BNIB Exedy Twin Wasabi
  208. Evo 8 Longblock, 6 Spd -- Miami, FL
  209. FS: AEM Tru-Boost
  210. FS - Evo 9 Cosworth M2Cams, Front Sway Bar
  211. AMS Mini Battery Tray and Omni 4 Bar
  212. F.S. EVO 8 AMS Downpipe
  213. FS GSC 272 first grind Techna-fit SS brake lines
  214. New SOLD feature!!!
  215. F/S NJ: Invidia O2 Housing & Turbo xs RFL
  216. FS: *Used* BC valve/ti rtainer kit
  217. Tomei procam 270 evo 8 solid type + solid pivot kit
  218. Evo 9 turbo
  219. Looking for 94mm crank
  220. Buschur 65mm Throttle Body
  221. WTS: MAP open dump o2 sensor housing, NEW
  222. ETS Buschur MAP TIAL grimmspeed halman
  223. Knock sensor & Clutch master cyl
  224. Oem 9 cams batt tray acd pump bracket
  225. Cobb AccessPort Evo 8/9
  226. FS: Evo 8 Valve Cover, Built Head, 272 HKS Cams
  227. Evo 9 turbo SoCal
  228. Parts for sale! AMS UICP, Stock FMIC, stock j-pipe
  229. FS: HKS 272 EVo 8 $300
  230. IL-Evo8 turbo/SD Intake/AMS testpipe
  231. Ams vband pte6466 turbo kit
  232. AMS VSR Sheet Metal Intake Manifold $500 Shipped
  233. FS 6262, STM intake, Head gasket, more
  234. holset hx40 1500miles!!
  235. ACT stage 2 clutch with street lite flywheel, Walbro 255, and ARP head studs
  236. Spun Bearing Evo 8 Shortblock
  237. FS MI: Brand new Manley 2.1L +10 pistons
  238. F.S. Precision 1000cc injectors/FIC 1450cc injectors FREE SHIPPING!
  239. scat rods for sale. 250
  240. Cams (stock) & TSA Turbo Outlet
  241. HKS 272's Evo8
  242. FS: GSC S2 cams Evo 9
  243. Buschur Racing 3" Slip-fit Hollowed Catalytic Converter - Free Shipping!
  244. Fuel Injector Clinic 850cc Injectors- Free Shipping!
  245. 3" High flow catalytic converter less than 1000 miles on it
  246. 6-speed MR tranny
  247. some stock parts, cams, maf, turbo, bov, o2 housing, boost solenoid.
  248. FS: RNR Turbo kit! DBB GT3788R, Tial wastegate, GSC S2's, Beehive springs
  249. FS: Big intercooler plus custom piping.
  250. Fp 71hta
