- FS: (PA) Synapse Synchronic BOV
- FS: Ported HTA JB FP Black with JMF Dump (NJ)
- FS: (PA) ETS intercooler piping set POWDERCOATED!!
- EVO 8 complete AC setup, Radiator, and more
- FS: OEM EVO 8 Crankshaft
- FS: Stock Evo 8 Turbo/Intake Manifold/Exhaust manifold/02housing
- AEM Series II + MAP/IAT Sensor
- Evo VIII Cluster (Non ACD)
- Precision injectors 880
- brand new injen intake
- Old School FP red turbo - Best offer - AS IS
- FS: ARC Super Induction Box
- Speed density parts and prostreet adjustable cam gears
- FS: BNIB Competition Stage 4 Clutch & Flywheel
- FS: AEM Intake (Powdercoated Flat Black)
- FS: Greddy Competition Ti-C Catback Exhaust (Socal)
- Logic Performance SS UICP, GREDDY TYPE RS, BNIB OEM KNOCK SENS
- FS: Toxic Fab Forward Facing stock frame manifold and custom O2 Dump
- Red Tial 50mm BOV 8psi Spring
- FS BLITZ intake Evo 8 MaF
- delete
- flex fuel sensor, for use with zeitronix eca
- FS (CO): Allstar Catch Can
- Low milage FP HTA 3582 For Sale
- fs exhaust silencer
- fs stock evo 8 exhaust manifold
- fp reeeeeeeeeed
- FS: NV HKS intake, fuel pump
- F/S: Stock 02housing, stock 10.5 hotside, and Perrin High flow cat.
- FS: TurboSmart Blow off valve
- RaceLAB 6765 Forward Facing turbo kit capable of 800+ hp AEM , MAGNUS , BOOMBA
- Buschur HTA 3082 cast turbo kit
- Fs/fl hks ssqv bov.... Cheap
- FS: Greddy RS BOV SUPPPERRR CHEAP
- FS: Braille Mini Battery and evo 9 turbo!
- HKS BOV and IX BOV
- FS: EPM o2 dump, ETS LICP, Fidanza Flywhe
- Kiggly Racing HLA for EVO VIII/IX - BNIB
- Brand New OEM Timing Belt
- Rad hoses, Oem belts, stock parts
- FS: Evo 8 Short block
- FS: Brand New Greddy Head Gasket
- Autometer Phantom Oil Temp Gauge Brand New
- evo 8 oil cooler with lines, low miles 16k
- FS..acd t case and pump
- FS: VIII turbo
- OEM E8 cams
- FS: Muse SS SR UICP & Ceramic Coated Full-Race Replica T3 Manifold
- BRAND NEW! AEM EMS V2 - 30-6310 - Evo VIII and 2G DSM
- random evo leftovers
- FS: IX FMIC w/piping
- FS: Evo 8 turbo 9.8 hot side 43k miles
- FS VA: New Crower Cams and ARP headstuds cheap!
- FS: A/C compressor from Evo 9 (NH)
- FS: Hks intake pipe
- Evo VIII Buddy Club 264/272 cams and HKS cam gears
- FS: evo 8 catalytic converter
- AMS Intercooler, Sun HyperForce, Weapon R catch can, AMSoil filter
- stock intercooler piping stuff make offer
- FS: (OR) ASPEC Titanium Test Pipe - Very Low Miles!!!
- Evo 9 5speed transmission FRESH REBUILD
- Evo 8 hks 272 cams with gears
- FS:Crower 272s for Evo 8 $150 for quick sale!
- fs:used injectors, mini battery tray, misc twin disc parts, misc parts
- **UPDATE 3/1/12** New Evo FP Green turbo
- Tial 44mm wastegate
- FS: AEM wide band, VenAir 90 degree 2.5 to 2 inch coupler
- ECU for evo
- FS: Gates Timing Kit, OEM Cams, BOV, Diaqueen, O2 Housing, Filter
- [CA]Evo 8 exhaust manifold flange
- FS: (OR) Perrin Intake - low miles!
- Stock evo 8 cat and test pipe
- FS: Evo 9 Turbo, Install Kit
- FS: 6 speed tranny/lines bushings
- FS: EPM O2 dump
- FS: GSC S2 cams (BNIB!!)
- used evo9 turbo
- fp 18psi wasetgate
- evo 8 10.5 for sale
- F/S- Evo 8 + battery terminal cover (NJ/NY)
- FS: ACT clutch MB7-HDXX Evo 8-9 510-650tq!
- FS: MIVEC cam gear Evo IX
- FS: Fidanza RED adjustable camgear
- Genuine HKS SSQV BOV
- FS: Evo 8 Turbo w/10.5 Hotside, JDM 3 Bar MAP Sensor
- Innovate Lc-1, Megan 02 Housing, and evo 8 fp gasket kit CHEAP
- FS: (MD) 6-Spd, 6-Spd swap parts
- AEM 5 Bar Map and EBC
- Thule roof rack, injen filter, buschur MBC, walbro 255, oem coil and wires n injector
- Brand New Tactrix Openport 1.3U with 90 degree ExtensionExtension
- fs, tubular manifold, o2 housing x2, 10.5 hot side+more
- FS: Evo8 Head and Evo8 Valve Cover
- HKS SSQV 3 Sequential BOV
- 2.0 block 2.0 crank 2.4 crank
- FS: Magnus Street & Race Sheet Metal Intake Manifolds
- Need a few parts!
- fs: Buschur t3 tubular header and other hot parts
- Insanely huge part-out, over 30k invested, all custom parts, UNIQUE AND CUSTOM!
- FS: (Co) Oem Evo ix Cams
- Kelford 264 CamShafts + Jun 272s + Greddy Profec B Spec II
- FIC 2150cc injectors - BRAND NEW
- oem evo 8 map sensor, idle speed control motor, throttle position sensor
- Exedy Twin HD Combo Kit - New in Box
- Evo parts!! Nyc
- Greddy turbo timer with harness for evo
- Evo oem alternator & Power steering pump.
- 3" aluminum intake for SD setup
- Evo 9 upper timing cover, evo 8 upper+lower timing cover
- BNIB 6266 sp cover JOURNAL BEARING
- FS: OEM Evo 9 Pistons & Rods - 40K Miles
- *RNR Equal Length 37r Full Kit*
- evo 8/9 aluminum 2 row Radiator
- FS: Built EVO 8 Head
- Rebuilt Tilton Carbon/Carbon Twin Disc 6 Bolt clutch/flywheel/hyd Release Bearin
- FS-IL A bunch of random evo parts, turbo, front cover, FP filter NITROUS, LOOK!
- FS: Exedy Twin & ARP Headstuds
- FS: OEM Oil Cooler
- 2005 Evo 8 turbo, 10.5, 45k miles.
- FS: Fuel Temp Sensor
- FS: Evo 8 MAF
- FS: ACD Pump
- FS: BR IX LICP for STOCK intercooler - Buschur Racing
- FS: FP red turbo & 84mm compressor cover , Cosworth M2 exhaust cam
- NISEI mini battery kit - gloss black - Genesis battery
- Carbing, JUN, Perrin, PowerFlex, Saikou Michi, STM, Zaklee, Zeitronix
- F/S FP Black w/ 25psi wastegate SOLD.
- oem evo 8 radiator with hoses
- 6 speed conversion parts
- OMNI 4 BAR.... BRAND NEW never used
- AMS LICP....need gone A.S.A.P.
- FS: Greddy Type RS BOV with Recirculation Kit
- Oem parts for sale
- MAP O2 Dump Non contoured coated
- Synapse BOV SB001A Lightly used less than 2k miles
- BNIB Wiseco Standard Bore Size Pistons
- FS: Forge Recirculating BOV
- Brand New ID2000's- $800 shipped until 3/2
- FS: *NYC* Cosworth IX Cams,1000cc injec,Walbro,ARP,Rexpeed spoiler,Aluminum Rad,etc..
- awd motorsports turbo manifold for sale
- FS [CA] - Megan Racing Down Pipe ACD - Evolution 9
- FS: 3'' 2 bolt downpipe
- Buschur Racing IX O2 Housing
- injen intake
- helix turbo back system
- factory evo 8 intercooler piping
- left over parts, jdm rear lights
- FS: Exedy Triple Carbon Replacement Discs
- Tial 50 mm bov
- Fs: hks264 cams evo 8
- All sold
- DTM T3 manifold
- quarter master clutch
- Spearco Front Mount Intercooler
- AEM EMS Series 1
- Balance Shaft Elimination Kit-stub shaft
- aluminum EGR delete, block off plate $20 shipped
- FS: BNIB Aeromotive 340 fuel pump and Hardwire kit
- Brand new gt35r .82 vband for sale
- Evo viii random aftermarket and stock parts for sale
- Greddy type rs bov rec or vented. For sale!!
- FS: NY MISC parts laying around
- FS: New Avid Racing 8/9 4 Piece Motor Mount Kit, Cheap!
- FS: 4 inch Intake with Filter
- HKS EVC6 Special Edition BNIB $450
- Feeler: Interested in an AEM Series 2 + Sensors??
- FS: Precision SC61R BB Turbo Kit $1K
- Evo Motor Accessories
- BC 272 Cams EVO 8-- CHEAP-- pics insides
- OEM MAF, MAF Adapter, 4in Intake Pipe, UPIC
- FS (Mi): Tial 0.63 (.64) vband hotside (GT turbos)
- Ngk bpr7es
- 2006 Lancer Evolution Rear Diff, and Injen Piping kit 03-06 Evo
- Fs: AMS 35r Turbo Kit
- FS: (PA) ACR Heat shield exhaust manifold
- FMIC,HKS DLI,EVO 9 STEERING WHEEL,Vortex Generator,GAUGE CUPS,AIR BAG..
- FS: Buschur Licp
- Fs: Fp3065 bnib (dsm)
- FS: (CO) Stock Evo IX MR Clutch
- 1 rear axle, stock bat tray, side markers
- EXEDY TWIN HD - with new PP02 Steel! $$495
- FS: Electronic Cutout Test Pipe CT/NYC
- FS: Precision SC6152RE T3 Ball Bearing Turbo w/ Hafe 02 Housing
- Fs: 3.5" fmic ct/nyc
- Buschur MBC,AEM Intake, Stock Intercooler, Stock LICP, Agency Power fuel rail, ETC
- Feeler: Fully ported Skunk2 IM with TB
- FS Evo X MAP Sensor
- FS: Evo 8 head WY
- evo 8 Internal crank piston rod valve
- Fuel system pieces and motor mounts
- NY: FS Precision 66mm wastegate $420.00 Shipped
- Turbo XS intercooler, ETS I/C pipes
- oem mr gauges for sale
- Feeler RNR, 37r turbo kit
- FS: eBay O2 Housing
- Evo 8-9 ACT Street Disk Clutch
- FS:(FL) Evo VIII/IX Turbo XS 3.5" bar and plate FMIC & Nisei (Alum/short route) UICP
- Evo 9 complete Motor and 6 speed tranny parts!
- FS: Built Head and HKS 280 cams
- Precision 1000cc injectors
- Cusco Catch Can
- Ix mr bov
- HKS RACING INTAKE KIT ultra low mileage
- OEM 60k Service kit w/ Gates Belt
- Logic Performance Upper & Lower Intercooler Pipes (ALUMINUM)
- FS: Low Priced Must Go Evo 9 Parts
- FS: SD, FIC 1450cc Bluemax Injectors
- FS: Stock Exhaust Mani, Full Injen Piping w/Intake
- FS: Helix 3" DP with Testpipe, Injen LICP, Stock Fan, Complete 8 Turbo kit, etc
- FS: (CO) A/C Compressor
- FS: (Co) Evo IX OEM Head Gasket
- BNIB FP4R, BNIB BR TBE V-Band, and AEM EMS
- FS:Hallman MBC, Benen Towhook, Injen Intake, MR Gauges!!!!!
- FS: Bay Area, CA - AEM EMS 1313 Standalone ECU / Sun HyperForce System
- AMS Timing Belt Tensioner Tool
- megan ported o2 housing
- Muse licp
- Super Koted Evo 3 manifold
- FS: FP 84mm intake (cheap)
- Cometic Head gasket
- BNIB: HTA 3794 Turbo
- Works Hi_flow Drop In Air Filter and cleaner: $25
- Works Exhale Hi Flow cat $80
- Tactrix 1.3U USB cable
- Works Exhale Cat-back Exhaust $350
- NIB Tial QR BOV
- Evo 8 Rear Diff
- FS:(CO) AMS Turbo kit w/out turbo,AEM EMS(IX S1), Stock IX TB
- (NC) HKS DLI II, Blox front motor mount, SS upper clutch line, carbon pod
- Full Blown Double Pump Setup
- FS: Evolution 9 Turbo
- Random Parts 4 sale!
- precision bb 6262 ets piping tial bov jdl ff manifold
- MAP o2 eliminator dp, 3" UICP, intake manifold
- Evo IX Turbo
- Fs: Aluminum exhaust manifold cover, injen intake
- AMS Intercooler, High Flow Cat, o2 Sensor, Temp Gauge
- FS: Walbro 255s (intank and inline)
- AMS 3.5" Intercooler
- Buschur Stage III Head, ER Spec4g64 Headgasket, Felpro and More!!!
- ETS V2 Intake, MAF Adapter, K&N Filter
- Brand new OEM SE front lip
- F/S: Driven Innovations Intake Manifold (PRICED TO SELL$$)
- FS: Evo 8 Valve Cover
- Megan Racing Test Pipe
- Aem v1 1313 ems
- MAP FPR kit. Fuel Lab fuel pressure regulator kit BNIB
- Manley, Crank, Intake, Injectors,Pistons, Parts!
- FS: Evo Intake Items
- evo 8 downpipe
- FS: Buschur 2.5" UICP and 3" Intake w/Filter
